Dune HD Pro 4K (Ultra) Thread - Page 212 - AVS Forum | Home Theater Discussions And Reviews
 1819Likes
post #6331 of 6433 Old 01-10-2020, 07:21 AM
xiulet's Avatar
Originally Posted by markswift2003 View Post
It's not a problem, it's just a case of picking the right picture mode. The Zidoo behaves exactly the same in relation to this but neither box will introduce banding if the mode is set correctly.
It must be noted however that the Dune will not play back at the correct frame rate in these modes in 4K so you may see microstutters.
The attached pdf should help.
ok,
I thought that this problem did not exist or could be avoided with 1296 since I read that it has improvements at the level of hdr and in hdr-sdr, thanks
and have dune worst processor for dvd content that this zidoo?
xiulet is offline
post #6332 of 6433 Old 01-10-2020, 08:22 AM
markswift2003's Avatar
Quoted: 857 Post(s)
Liked: 579
Originally Posted by xiulet View Post
ok,
As far as chroma banding goes, that has nothing to do with HDR, it's purely down to handling material at the wrong bit depth, so regardless of the SOC, if you process a file with 10-bit colour at 8-bit with no dithering, you're always going to get banding.
If you throw a 10-bit file at either box and process at 10-bits (or higher) you won't get any banding.
No idea about DVD - I rarely use SD content.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #6333 of 6433 Old 01-10-2020, 10:20 AM
Liked: 1
Banding
Is the Dune Pro 4K and the Dune Pro 4K Plus the same on this list? Good list by the way, thanks.
Kilroy
Kilroy_1962 is offline
post #6334 of 6433 Old 01-10-2020, 11:27 AM
Quoted: 857 Post(s)
Liked: 579
Kilroy
I can't categorically say yes because I haven't got one to test but I would fully expect so.
All the newer Dunes are still based on the old 1295, so basically the same as the Pro just with extra bits strapped on - drive bays, power supplies, DACs etc and the firmware is ostensibly exactly the same.
Although we know it can be done (Zidoo did it for the X9S in Jan 19) they have never managed to nail the 4K frame rate down and the internal 8-bit processing at 12-bit 422 seems inherent in the SOC as every other box using the same family has the exact same issue.
post #6335 of 6433 Old 01-10-2020, 12:42 PM
Liked: 1
Thanks markswiftt2003.
markswift2003 likes this.
post #6336 of 6433 Old 01-10-2020, 06:05 PM
Liked: 1
I had a problem with my DUNEHD pro player that just started happening recently... when ever I would choose a movie that was 4k the screen would go blank with no audio. I read a few responses, and tried what they said to do, but nothing worked...except where someone commented about which audio player you were using. I went and switched the audio player to kodi...same problem, but when I switched it back to what I thought it had been on it worked. The working setup uses internal player.
Living room HT
Front channels...3 Klipsch RP160Ms, 4 RP150Ms surrounds,Yamaha CXA5100, 2 Dune HD PRO, 2 Yamaha p2500s, 2 Nobsound 50wpc, UnRaid, APC HT power center, Pioneer bluray player, PS3, XBOX ONE,
Xilica xp4080 crossover
NBPk402 is offline
post #6337 of 6433 Old 01-11-2020, 12:37 AM
Liked: 2
Originally Posted by robena View Post
I tried to play one of the first 59.94 UHD rips (Gemini) on the Dune Pro. I stream the output to an Oppo 203 to do the decoding since my processor does not support TrueHD
Whatever the video mode, I get audio drops and lip sync problems.
Playing directly with the Oppo is perfect, so the Dune Pro has a serious problem with 60fps UHD movies.
I tried the the movie today with my Dune HD Max 4K and had no Problems at all. No lip sync Problems, no Audio Dropouts.
It plays perfectly at 59.94 fps.
hellhero is offline
post #6338 of 6433 Old 01-11-2020, 01:27 AM
robena's Avatar
Quoted: 228 Post(s)
Liked: 101
Some people have problems, and some not. Dune will have to resolve that ASAP.
Robert
robena is offline
post #6339 of 6433 Old 01-13-2020, 04:43 AM
Pretorian's Avatar
Quoted: 32 Post(s)
Is there different hardware between the Pro and the Max?
Pretorian is online now
post #6340 of 6433 Old 01-13-2020, 05:14 AM
robena's Avatar
Quoted: 228 Post(s)
Liked: 101
The pro Uses:
Realtek RTD1295 SoC
The Max:
Sigma Designs 8642
But the Max is limited to 1080p, it's an old model:
https://dune-hd.com/eng/products/ful...dia_players/11
video output flexibility: output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
I don't understand how you can play UHD with it.
Robert
robena is offline
post #6341 of 6433 Old 01-13-2020, 07:09 AM
xiaNaix's Avatar
Quoted: 50 Post(s)
Liked: 42
The pro Uses:
Realtek RTD1295 SoC
The Max:
Sigma Designs 8642
That's the old Max. He's talking about the new(er) Max 4k, which also uses Realtek.
https://www.dune-hd.com/products/dune-hd-max-4k
Sony BDP-S6700 (Region Free) | Dune Solo 4K | Zidoo X9S
Epson Home Cinema 3100 | Silver Ticket STR-169110 110" Screen
Yamaha RX-A770 | Chane A2.4 L-C-R | Fluance XLBP Wide Dispersion Bipolar Rears | Hsu VTF-2 MK5 Sub
xiaNaix is offline
post #6342 of 6433 Old 01-13-2020, 08:45 AM
robena's Avatar
Quoted: 228 Post(s)
Liked: 101
Yes, same SOC.
Specs do say that 4K60 HDR is supported on both, it should work. It looks like a firmware bug.
Robert
robena is offline
post #6343 of 6433 Old 01-13-2020, 01:43 PM
a5ian300zx's Avatar
Quoted: 637 Post(s)
Liked: 217
there is a bypass setting on the oppo 203 hdmi in. test it with that in case it is an issue with the hdmi.
Just I suggestion I remember I had to do something similar with my setup at the time.
Sent from my Samsung Note 9 using Tapatalk
TV: Sony 65" A1E OLED Surround: Sennheiser AMBEO + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Iscan Mini + Darbee 5000S Players: Oppo 203 (Coris) / Nvidia Shield TV Pro 2019 / VU+ Ultimo 4K NAS: Qnap TVS-871 Pro i7 10GBE
a5ian300zx is offline
post #6344 of 6433 Old 01-13-2020, 04:37 PM
robena's Avatar
Quoted: 228 Post(s)
Liked: 101
I will, but I also have the issue direct to the TV without the Oppo. And with the AC3 track already!
Robert
robena is offline
post #6345 of 6433 Old 01-16-2020, 09:24 AM
Quoted: 21 Post(s)
Liked: 1
Good afternoon, I live in Brazil, I'm looking for an average center that plays blu ray ISO or BDMV, but I can navigate perfectly in the menus like a physical blu ray, I'm in doubt on some models, you can suggest me what are the more efficient for what I'm looking for? For example between ZAPPITI, ZIDOO, DUNE, EGREAT and CHINOOPO which is the best or the models I can buy without fear that will suit me in what I need, I will probably put sata internal hd 5t and play everything on the internal hd. a hug
Cbizotto is offline
post #6346 of 6433 Old 01-16-2020, 09:39 AM
Tsunamijhoe's Avatar
Quoted: 248 Post(s)
Liked: 69
The Dune 4k Pro has been perfect for me, it has played every bluray i have tried flawlessly be it either ISO or BDMV.. Just know, time search and FF/REW does not work in full bluray menu mode,you are likely to blow your speakers if trying to FF/REW playing anything,but time search works fine on single m2ts file play for example.. Chapters work fine though,as does all menu navigation and pop-up menus.
I have no knowledge about the other devices you mention
Marantz 7704, Emotiva XPA-5,Emotiva XPA-2,Densen B-340+,B&W 683,B&W HTM61,B&W DS3,2XSVS PB-2000,4XMonitor Audio BX1 (Atmos),Sony VPL-HW65ES,Stewart 123" CIMA Neve Motorized, Dune HD Pro 4K, Mede8er x600 3D,Panasonic BD60,PS4
Tsunamijhoe is offline
post #6347 of 6433 Old 01-17-2020, 05:11 PM
Amidujusu89's Avatar
Quoted: 51 Post(s)
Hi guys!
I have followed this thread but didn't get a definite answer.... Does the Dune support forced subs in Bluray ISO? I trying to decided between the DUNE and ZIDOO UHD 2000 but I can't a definite answer as to which media player supports forced subs in ISOs currently.
Thanks in advance!
Sampinto
Amidujusu89 is offline
post #6348 of 6433 Old 01-17-2020, 07:11 PM
Quoted: 82 Post(s)
Liked: 9
Get the Dune 4k Pro Plus. It is almost the same as the Dune 4k Pro but you can put a 3.5" HDD into it.
Abraços
Caesar
-Caesar- is offline
post #6349 of 6433 Old 01-17-2020, 07:36 PM
Quoted: 21 Post(s)
Liked: 1
Abraços
Caesar
I was offered a dune hd duo 4k here in Brazil at an excellent price, it can also be right, Caesesar?
Cbizotto is offline
post #6350 of 6433 Old 01-18-2020, 02:29 AM
Quoted: 82 Post(s)
Liked: 9
Get the Dune HD Pro 4K Plus amigo.
There is a reason why they want to sell you the Duo...
-Caesar- is offline
post #6351 of 6433 Old 01-18-2020, 07:52 AM
Quoted: 21 Post(s)
Liked: 1
hmm, what is the reason, any problem?
Cbizotto is offline
post #6352 of 6433 Old 01-18-2020, 08:07 AM
tbass2k's Avatar
Quoted: 336 Post(s)
Liked: 352
It's the older model....no HDR capability.
Sent from my SM-N975U using Tapatalk
-Caesar- likes this.
tbass2k is offline
post #6353 of 6433 Old 01-18-2020, 10:09 AM
Quoted: 21 Post(s)
Liked: 1
tank you
Cbizotto is offline
post #6354 of 6433 Old 01-18-2020, 10:43 AM
Quoted: 21 Post(s)
Liked: 1
friends, I heard that the old model from DUNE, the DUNE SMART B1, came with a built-in blu ray player, there are newer models from this brand and others that do the same work with blu ray iso and bdmv and that also accompanies physical blu ray player? brands like DUNE, ZIDOO, ZAPPITI, EGREAT among others?
Cbizotto is offline
post #6355 of 6433 Old 01-18-2020, 11:01 AM
007james's Avatar
Quoted: 53 Post(s)
Liked: 46
If you don't care about 4K, I'd look for a Dune D1
mrlittlejeans likes this.
007james is offline
post #6356 of 6433 Old 01-18-2020, 11:10 AM
Quoted: 21 Post(s)
Liked: 1
yes, not 4k, but 1080p blu rays iso and bdmv, this model B1 disponible the built-in blu ray player
Cbizotto is offline
post #6357 of 6433 Old 01-18-2020, 02:48 PM
a5ian300zx's Avatar
Quoted: 637 Post(s)
Liked: 217
For 1080p only get the dune solo 4k. Its more 1080p player and can do hdr to sdr it also has the vxp video processing.
They even pushed out a new firmware to the unit last year.
xiaNaix likes this.
post #6358 of 6433 Old 01-18-2020, 02:57 PM
Quoted: 21 Post(s)
Liked: 1
Tank You,really the dune solo is more current, is there any other media center like B1? that has in addition to reading bd iso and bdmv with menus, also the physical blu ray player and that is more current? not only from the Dune brand but also from other brands
Cbizotto is offline
post #6359 of 6433 Old 01-19-2020, 11:07 PM
Scurly's Avatar
Quoted: 56 Post(s)
Absolutely love this player. A few questions.
1. Is the Dune HD Pro 4K HDCP 2.2 compliant
2. How on earth can you save the aspect ratio setting to fit screen or 16:9? Always having to change.
2. How can you save the audio language to English as default when playing a downloaded video? Always having to change.
Thx for your help
Scurly is offline
post #6360 of 6433 Old 01-20-2020, 01:15 AM
Pretorian's Avatar
Quoted: 32 Post(s)
I have been asked by Dune support to give them info on the HFR file I am trying to play.
As you can read a few posts back some of us have problems playing Gemini Man in 4k High Frame Rate.
IMAGE: Epson 6050/9400
SCREEN: 104" Grey High Contrast ReAct Fixed Screen
SOURCE: Dune HD Pro 4K
RECEIVER: Denon AVR-2311
SPEAKERS: Bowers & Wilkins CDM SE 5.1
