Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1191Likes
post #31 of 3061 Old 01-04-2018, 12:57 PM
KMFDMvsEnya's Avatar
Quoted: 317 Post(s)
Liked: 644
What is the average rate of ripping?
Is it typical for it to start real slow then get a bit faster later on? 1x -> ~4x
The fastest I got for The Martian Extended was 4x, maybe as high up as 6x, with my new WH16NS40.
Conventional BR seems rip as fast as before with my original WH16 drive, maybe.
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
post #32 of 3061 Old 01-04-2018, 01:05 PM
robnix's Avatar
Quoted: 1021 Post(s)
Liked: 767
Don't know the exact rate, it takes me 60-90 minutes per UHD vs 20 minutes for a BR.
KMFDMvsEnya likes this.
Looky here!
robnix is offline
post #33 of 3061 Old 01-04-2018, 01:47 PM
Quoted: 317 Post(s)
Liked: 644
Took me about 48 minutes to rip Blade Runner Final Cut, about 45gbs.
Selected only the main audio track, commentaries, and English subtitles. The average probably was 4x, with a short peak of 5.5x.
post #34 of 3061 Old 01-04-2018, 03:24 PM
Willie's Avatar
Quoted: 249 Post(s)
Liked: 336
Originally Posted by Brajesh View Post
Re: firmware, Windows 10 doesn't automatically update it for an optical drive right?
No. However, IMO, best to not do Windows updates automatically anyway. Certainly Microsoft possesses enough chutzpah (and hubris) to attempt it.
Willie is online now
post #35 of 3061 Old 01-05-2018, 02:46 PM
alextheg's Avatar
Hi. I already have a UHD .iso in bdmv structure but want to convert with makemkv. How do I go about this ? Thanks in advance
alextheg is offline
post #36 of 3061 Old 01-05-2018, 06:34 PM
robnix's Avatar
Liked: 767
Same as any other ISO. Open the file in MakeMKV, rip the main film.
Looky here!
robnix is offline
post #37 of 3061 Old 01-07-2018, 07:40 AM
Quoted: 317 Post(s)
Liked: 644
I have ripped The Martian Extended Edition twice and each time I have audio drop outs in the same place. The only other title I have ripped is Blade Runner Final Cut and what I have listened to so far seems to be fine.
The disc for The Martian plays fine.
I have successfully converted the Atmos track for Blade Runner to flac for analysis but eac3to fails everytime with TM Atmos track.
SuperFist likes this.
post #38 of 3061 Old 01-07-2018, 04:13 PM
jasonkennethrose's Avatar
Quoted: 218 Post(s)
Liked: 94
Was your source from the original disc? Others have commented about issues with eac3to.exe and Atmos tracks from UHD. I am trying to get a few sources to help provide feedback to madshi.
jasonkennethrose is offline
post #39 of 3061 Old 01-07-2018, 06:33 PM
Quoted: 317 Post(s)
Liked: 644
Yes, I own all the discs I am ripping.
Purchased The Martian from Amazon a few months ago.
The disc does not exhibit the audio drop out during one example that occurred on two separate rips. At 1:13 and between 8-11 seconds.
My second rip of the disc was saved directly to an SSD and the same issue. Previously had played the first rip from my PC and off an external HDD connected to my Oppo 203. There were several other instances of audio drop outs later all in the original file.
My eac3to is an older standalone installation from a few years ago and I was only using it to convert the audio track to flac to analyze the waveforms in Audition.
Currently using the most recent version of MakeMKV with a Sept build WH16NS40.
post #40 of 3061 Old 01-08-2018, 06:56 AM
Quoted: 39 Post(s)
Liked: 83
I have been trying to use eac3to to convert the Atmos track on The Martian Extended Edition to THD+AC3 in order to build an ISO for The Martian 3D with Atmos (as I have previously done with Fantastic Beasts and Wonder Woman), and it also fails every time. In my Internet research it appears the problem stems from the seamless branching used to put both the theatrical and extended versions on one disc. There are about 6-7 bytes of corrupt data on the entire 5GB+ file, but eac3to is unable to overlook those.
brbeck is offline
post #41 of 3061 Old 01-08-2018, 07:50 AM
Herve's Avatar
Quoted: 442 Post(s)
Liked: 85
Originally Posted by javanpohl View Post
3)
To manually add volume keys to makemkv, you open Makemkv, go to view->preferences, then, ->general and establish a folder for the "makemkv data directory". In that newly established data directory folder, create a (plain) text file and paste those codes and all their info into the text file. Mine is named keys.txt and I made it with notepad. (If that does not work for you, try renaming it to be a .cfg file)
I'm not sure just exactly what to copy and paste from that rather long line of numbers and characters for each movie. Would you be kind enough to give a verbatim, complete example of the copied line, or portion of the line, of characters and numbers that you would then paste into the txt or cfg file? (If you prefer, you can make up a fictional line of numbers and characters with say "How to Save the World" as the title of the movie.)
Herve is offline
post #42 of 3061 Old 01-08-2018, 08:30 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
This is what each line of the text in my file looks like (I had originally copied it over verbatim but changed my mind on doing that)
0x7A3C818B3722DCA0B7C16A4527C475BFE79BFB5B = FAKE MOVIE NAME | V | 0xB360FA78B205BA030E53A0D6DC14F7B0 ; AACS 2.0 MKB v60
javanpohl is offline
post #43 of 3061 Old 01-08-2018, 09:08 AM
Herve's Avatar
Quoted: 442 Post(s)
Liked: 85
That's exactly what I needed to know. Thank you very much!
Herve is offline
post #44 of 3061 Old 01-08-2018, 08:47 PM
captainbrent's Avatar
Quoted: 449 Post(s)
Liked: 510
Just curious as to why you felt the need to make the change?
Marantz AV8802A | Wyred 4 Sound (500W X 3, 250W X 2) | Marantz MM7025 (140W X 2) | Oppo UDP-203 | Roon ROCK Music Server | ATV4K | Vero 4K+ | LG OLED 65E6P | MiniDSP DDRC-88A | Oppo PM1's | APC H-15 power conditioners (x2) | GoldenEar Triton 1's (FL & FR) | SuperCenter XL (C) | Aon 2's (SL & SR) | SuperSat 3's (FHL & FHR) | SVS PB13-Ultra | Unraid NAS 40TB
captainbrent is offline
post #45 of 3061 Old 01-09-2018, 02:21 AM
latreche34's Avatar
Quoted: 151 Post(s)
Liked: 66
I see some of those drives are not triple layer capable, How can they read a UHD blu-ray?
I have the pawtec ultra slim BDXL up to 100GB drive that uses the Mat****a BD-MLT UJ265 internally, Any chances that it will work?
latreche34 is offline
post #46 of 3061 Old 01-09-2018, 03:25 AM
Quoted: 449 Post(s)
Liked: 510
If you have the drive, just give it a try and report your findings!
post #47 of 3061 Old 01-09-2018, 01:34 PM
hobbs47's Avatar
Quoted: 473 Post(s)
Liked: 504
Can anyone recommend an external drive that works with makemkv/BDXL?
Benq HT3550/LG OLED65B6P /Panny UB820 4k Bluray/Apple TV 4k
Nvidia Shield/HDFury AVRkey/Samsung HW-K950 Soundbar
hobbs47 is online now
post #48 of 3061 Old 01-09-2018, 01:54 PM
robnix's Avatar
Liked: 767
The buffalo drive mentioned in this thread works. I have it.
hobbs47 likes this.
Looky here!
robnix is offline
post #49 of 3061 Old 01-10-2018, 05:48 AM
Quoted: 39 Post(s)
Liked: 83
The LG BE16NU50 I have has been great so far.
hobbs47 likes this.
brbeck is offline
post #50 of 3061 Old 01-13-2018, 05:06 PM
Jon S's Avatar
Quoted: 1149 Post(s)
Liked: 421
I have had no luck ripping Blade Runner... What drive do you have? i have a new LG 16NS40 manufactured date 09/2017... I get a physical disc error but it plays fine on my UHD player.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #51 of 3061 Old 01-13-2018, 07:58 PM
Jon S's Avatar
Liked: 421
tried another disc, The Martian (Extended Edition). While I was able to rip it, there was a lot of noise in the resulting file. Also, the image was dark with no color saturation.. see attached... MakeMKV takes about an hour to do a disc. if the end files are like this, it is of no use for me...
ID:	2345208   Click image for larger version
ID:	2345210   Click image for larger version
Jon S is offline
post #52 of 3061 Old 01-14-2018, 06:36 AM
Quoted: 1707 Post(s)
Liked: 951
Makemkv doesn't change the source video.
Something in your playback chain isn't configured properly.
dwaleke is offline
post #53 of 3061 Old 01-14-2018, 09:26 AM
Quoted: 519 Post(s)
Liked: 295
It looks like an HDR film that you're viewing on an SDR screen. Poor contrast is expected, it needs appropriate processing.
BattleAxeVR is offline
post #54 of 3061 Old 01-14-2018, 11:17 AM
robnix's Avatar
Liked: 767
Colorspace is incorrect on whatever you're using to playback the file.
Looky here!
robnix is offline
post #55 of 3061 Old 01-14-2018, 05:44 PM
Nitemage's Avatar
Quoted: 69 Post(s)
Liked: 41
Noise could be caused by not having enough bandwidth, assuming you are streaming over a network. Make sure all of your switches are Gigabit. Most older 100 MB switches aren't able to stream full UHD discs. I discovered that the hard way.
Nitemage is offline
post #56 of 3061 Old 01-14-2018, 07:51 PM
blackssr's Avatar
Quoted: 1229 Post(s)
Liked: 671
Good news?
https://www.myce.com/news/makemkvs-n...y-discs-83455/
This should shake things up a bit.
I've paid for my sins. We're even!
blackssr is offline
post #57 of 3061 Old 01-15-2018, 01:06 AM
Quoted: 449 Post(s)
Liked: 510
Another member posted this in a couple other threads but this is great news...so happy that I paid up for MakeMKV, a couple of years ago. Great programs and well worth the cost of admission!
Oops, sorry, edited to delete the same link as above!
post #58 of 3061 Old 01-15-2018, 07:42 AM
lockdown571's Avatar
Quoted: 493 Post(s)
Liked: 367
You have used BRUHD-PU3 buffalo drive successfully with MakeMKV? I thought only UHD "friendly" and not "official" drives worked with makemkv. I have the Buffalo drive and have not been able to rip any discs with MakeMKV. DeUHD worked though.
lockdown571 is online now
post #59 of 3061 Old 01-16-2018, 10:01 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
Incorrect color spacing or HDR-conversion could be part of the problem, but it's not all of the problem. The distortion you're seeing on the Fox logo is something that tends to happen with Fox discs (usually the newest releases), at least until Makemkv issues a firmware update to correct it. I don't know what it is--my guess is some additional layer of encryption that Fox puts on their discs. Or maybe it's just an error. I usually can't successfully rip a Fox movie until it's been out for a month or so, which is about how long it takes for Makemkv to issue the next firmware update.
I realize the Martian has been out longer for a month, but the UHD ripping side of Makemkv is still in its infancy.
post #60 of 3061 Old 01-16-2018, 10:08 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
Originally Posted by blackssr View Post
I'm still trying to wrap my brain around this one. I'll update the OP when assimilation is complete
