Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1191Likes
post #61 of 3061 Old 01-16-2018, 10:49 AM
halfelite's Avatar
Quoted: 654 Post(s)
Liked: 341
Originally Posted by javanpohl View Post
I'm still trying to wrap my brain around this one. I'll update the OP when assimilation is complete
Not much has changed you just have to grab the Hash Keys file from https://www.makemkv.com/forum2/viewt...p?f=12&t=16959. Then if you have a disc that is not supported make the dump and send it to mike and he will make a hash for it.
halfelite is offline
post #62 of 3061 Old 01-17-2018, 06:25 PM
KMFDMvsEnya's Avatar
Quoted: 317 Post(s)
Liked: 644
Originally Posted by Jon S View Post
I have had no luck ripping Blade Runner... What drive do you have? i have a new LG 16NS40 manufactured date 09/2017... I get a physical disc error but it plays fine on my UHD player.
Mine is the WH16NS40 from Amazon and received it an OEM box:
Manufactured: Sept 2017 /// 2017 09 26
ROM Version: 1.02
SVC Code: NS50
I have done a new rip of The Martian EE with the most current version of MM, 1.10.9, although I may try one more time after removing the previously leaked keys from the Key.cfg and just use the hashed_keys. The log shows a ton of AV sync errors. Allegedly this due to how the multi-branching is authored and I would not be surprised if the title obfuscation is also a cause of the audio dropouts. Need to also try a supposed method of bypassing AV Sync Correction and see how that goes. Or just rip the audio separately.
Also ripped ST-ID today but have not really watched it yet. What little I have watched it plays better than Blade Runner on my PC, which always slows down and misses a ton of frames.
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
post #63 of 3061 Old 01-18-2018, 08:53 PM
audioguy's Avatar
Quoted: 5724 Post(s)
Liked: 4838
I'm getting ready to download MakeMKV. Anyone using this with success on a Mac? I will be ripping both BR and 4K/HDR discs. Also need to purchase some NAS drives. Recommendations? Best 4K/HDR optical drives?
audioguy is offline
post #64 of 3061 Old 01-19-2018, 08:54 AM
djb61230's Avatar
Quoted: 37 Post(s)
Liked: 73
Yes it works fine on the Mac. I have the ASUS BW-16D1HT drive and a Vantec NST-536S3-BK external case purchased from Amazon a couple of weeks ago. Best to read the UHD section on the makemkv forum to make sure you know what you are doing.
djb61230 is offline
post #65 of 3061 Old 01-19-2018, 09:15 AM
blackssr's Avatar
Quoted: 1229 Post(s)
Liked: 671
Is this a sustainable solution going forward? Can the studios find a way to prevent this way of UHD ripping (for lack of better way to ask my question)?
I've paid for my sins. We're even!
blackssr is offline
post #66 of 3061 Old 01-19-2018, 09:30 AM
Ph8te's Avatar
Quoted: 6993 Post(s)
Liked: 7060
People always adjust to what the studios do. Many asked this whenever a new encryption is used. Of course changing keys all the time OR requiring online authentication would prevent this, but they’d abandon those without internet access.
Ph8te is online now
post #67 of 3061 Old 01-19-2018, 08:04 PM
halfelite's Avatar
Quoted: 654 Post(s)
Liked: 341
Its sustainable the only weak link is Mike. As he is the one making the Hash's. DEUHD can make keys but seems they are a bit slower then Mike at it but I think that has to do with not as many people wanted to spend 200$ plus on software. So Makemkv has a bigger audience sharing the dumps. Konats on doom9 seems to know as well but by the key releases I assume he is just giving out the discs that pass's through his hands.
post #68 of 3061 Old 01-19-2018, 08:15 PM
blackssr's Avatar
Liked: 671
Progress is being made at a brisk pace.
https://club.myce.com/t/newly-releas...s-topic/400070
blackssr is offline
post #69 of 3061 Old 01-20-2018, 08:57 AM
psuKinger's Avatar
Quoted: 1704 Post(s)
Liked: 783
I just updated MakeMKV to the latest and greatest version (1.10.10) in preparation for my first 4K UHD ripping attempt. I have one of the external drives that "supposedly" supports it (LG BE16NU50)?
I struck out on both of my first two attempts (Interstellar and Sing). MakeMKV was able to "load" both discs, and reported that they were 4K UHD and AACS v.61, etc, but when I tried to open them both failed.
"The volume key is unknown for this disc - video can't be decrypted
Failed to open disc"
I have a few more discs I can try (Despicable Me 3, Logan, Planet Earth II, etc). I'll report back if I have any luck with any of the others...
Living Room: Sony x940E; Denon x4400h w/ Marantz MM7055; Ascend Sierra RAAL Tower L/R's and 2EX center, Polk Monitor 35B Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 & LN-T4065F (x2); Onkyo TX-NR809; Kplisch RP-600m L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA, Pi running Ropieee.
psuKinger is offline
post #70 of 3061 Old 01-20-2018, 10:54 AM
Keenan's Avatar
Quoted: 4492 Post(s)
Liked: 4135
Did you add the hashed key file to the MakeMKV data directory?
http://makemkv.com/forum2/viewtopic.php?f=12&t=16959
Keenan is online now
post #71 of 3061 Old 01-20-2018, 11:35 AM
Ph8te's Avatar
Liked: 7060
They have instructions on what to do when that happens. You need to email the dump file so that it can be added in a future hash release. Discs can have multiple keys so the more dumps they have, the better.
That external drive DOES work when they key matches.
Ph8te is online now
post #72 of 3061 Old 01-20-2018, 12:01 PM
Keenan's Avatar
Liked: 4135
I looked at the list and there are several Logan releases(currently 8), maybe yours is a different release and as Ph8te notes, you need to email it to Mike at MakeMKV.
post #73 of 3061 Old 01-21-2018, 04:57 AM
barhoram's Avatar
Quoted: 274 Post(s)
Liked: 47
do I just put the keys_hashed.txt file in the MKV directory?? Is that all that needs to be done?
I previously had a KeyDB.cfg file downloaded from doom....so now I'm confused which is needed??
I don't really like talking about my flair
barhoram is offline
post #74 of 3061 Old 01-21-2018, 06:28 AM
Willie's Avatar
Quoted: 249 Post(s)
Liked: 336
Yes.
Willie is online now
post #75 of 3061 Old 01-21-2018, 06:41 AM
Brajesh's Avatar
Quoted: 599 Post(s)
Liked: 310
I renamed mine to KEYDB.cfg ... in screenshots:
I'm using ASUS BW-16D1HT, which works very well.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #76 of 3061 Old 01-21-2018, 06:48 AM
Sparty1020's Avatar
Quoted: 259 Post(s)
Liked: 51
Are any of the supported drives external? I saw the lgbe16nu50 which is 140.00. Any cheaper ones? This thread is very informative. Thanks guys!
Sparty1020 is offline
post #77 of 3061 Old 01-21-2018, 08:53 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
Not sure why, but since 1.10.9 my ripping scripts weren't working. They use the command line interface of Makemkv (makemkvcon) and Makemkv would stop working shortly after starting. Had to change "makemkvcon" to "makemkvcon64" in my scripts.
javanpohl is offline
post #78 of 3061 Old 01-21-2018, 09:21 AM
sutton8's Avatar
Quoted: 410 Post(s)
Liked: 169
As willie says just put the text file in the appropriate directory. No need to rename it. I deleted the CFG file I was previously unsuccessfully using.
7.1 Yamaha RX-A3080, Monitor Audio (Apex & Silver), Seismic 110, XBone, ATV 4K, Node 2i, Panasonic TX65GZ950B
5.1 Denon X7200WA, Focal Dome/Seismic 110, Firestick 4K, Panasonic TX55GZ950B
In both Setups Virgin Tivo V6, Zappiti 4K HDR, Harmony Elite, Dune HD RealBox 4K, Cambridge Audio CXUHD, Anti Mode 8033
sutton8 is offline
post #79 of 3061 Old 01-21-2018, 09:44 AM
Ph8te's Avatar
Liked: 7060
Just get an internal and put it into an enclosure?
Ph8te is online now
post #80 of 3061 Old 01-21-2018, 09:54 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
Ripping movies with only one drive is AAAAWWWWFFUUUUULLL. Don't know how anyone does it
If I can get these 10Gbe cards I got (and this NAS I got came with one) to work I'm debating busting out my storm trooper pc case (with 8 external drive bays), rebuilding my ripping pc, and just adding UHD friendly drives instead of replacing drives in my current 4-bay ripping unit. Ripping on 4 bays maxes out a 1 Gbe connection (once the rips get going at max speed) so I've never had a reason to go any higher, but it's starting to look like 10Gbe is breaking into the "affordable" realm.
post #81 of 3061 Old 01-21-2018, 09:57 AM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
To elaborate on what @Keenan said, make sure you replace the old volume keys files we've been using with the hashed keys files (I added a reference for that at the beginning of the OP) that Makemkv now needs (the old volume keys now do not work).
post #82 of 3061 Old 01-21-2018, 10:00 AM
Deja-vue's Avatar
Quoted: 64 Post(s)
Liked: 36
Ok, quick question:
Once ripped, which Device are you Guys using to actually play the Movie? I got the Dune 4K, will this work?
Deja-vue is offline
post #83 of 3061 Old 01-21-2018, 10:56 AM
Ph8te's Avatar
Liked: 7060
Originally Posted by Deja-vue View Post
Ok, quick question:
Infuse on my ATV4K works (but HDR is broken currently). I also have an A5 by Egreat that plays it back.
Deja-vue likes this.
Ph8te is online now
post #84 of 3061 Old 01-21-2018, 11:01 AM
Deja-vue's Avatar
Quoted: 64 Post(s)
Liked: 36
Thanks !
I will see if my Dune plays it back, I am ripping Independence Day as we speak.
Deja-vue is offline
post #85 of 3061 Old 01-21-2018, 11:03 AM
Sparty1020's Avatar
Quoted: 259 Post(s)
Liked: 51
Solid idea. Thank you
post #86 of 3061 Old 01-21-2018, 04:15 PM
halfelite's Avatar
Quoted: 654 Post(s)
Liked: 341
Affordable yes but otherwise its still a pita. I run Mellanox 10GB spf+ from my NAS units to my mikrotik switch it works well enough but cable length was an issue. If you are thinking about going 10GBASE-T Watch out for the heat and the power usage. I tested out some 10Gbe over twisted pair and ended up with a melted intel NIC from the heat the case did not have proper cooling around the NIC.
post #87 of 3061 Old 01-23-2018, 07:59 AM
psuKinger's Avatar
Liked: 783
Yep. Apologies guys this is definitely where I went wrong. Stupid mistake, thanks for your patience.
The solution isn't/wasn't immediately obvious to me either... I'm at work right now and can't trouble shoot, but will revisit this when I get home and see if I can't figure out what this all means...
post #88 of 3061 Old 01-23-2018, 08:10 AM
Natrix1973's Avatar
Quoted: 84 Post(s)
Liked: 59
Helpful FAQ at the makemkv forum, https://www.makemkv.com/forum2/viewt...p?f=12&t=16883
Natrix1973 is online now
post #89 of 3061 Old 01-24-2018, 10:56 AM
Quoted: 132 Post(s)
Liked: 36
I've tried for the first time with a couple of discs I bought recently and it works flawlessly. Amazing!!!
Thank you all for the step-by-step instructions.
What media player actually play these MKV with HDR support?
stefanop is offline
post #90 of 3061 Old 01-24-2018, 02:02 PM - Thread Starter
javanpohl's Avatar
Quoted: 875 Post(s)
Liked: 559
I have a Zidoo X9 that I play my 4k HDR files on (my 4K tv is in my bedroom). I also have a Zappiti 4K HDR player downstairs on my main rig (which is only 1080p), but I haven't tried that one on my 4K tv yet.
The Zidoo definitely plays the files in HDR but I haven't yet done an A/B comparison with the disc in a UHD player to see if there's a noticeable difference in quality.
