Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 937Likes
post #1801 of 2711 Old 11-04-2018, 12:01 PM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Originally Posted by wl1 View Post
Thanks for your reply - I got Gravity to work, along with "3D versions with Atmos" for Blade Runner 2049, Pacific Rim Uprising, Wonder Woman, Spiderman Homecoming and Ready Player One.
My success here led me to add Live Die Repeat (non Atmos) to my server - but the 3D effect has "bad depth" or "ghosting" - not sure of the correct term. Very strange....perhaps i should just re-rip and try again.
Check to make sure the 3D doesnt default to Right eye sync instead of Left Eye (majority of titles). I had that happen with Kong Skull Island when I remixed with Atmos and the image looked like it was ghosting super hard and the depth was weird, I had to remux with right eye sync checked.
wl1 likes this.
grendelrt is offline
post #1802 of 2711 Old 11-04-2018, 02:06 PM
dbone1026's Avatar
Quoted: 409 Post(s)
Liked: 205
Not sure if it has been mentioned here, but got an email from DVDFab :
World's Easiest UHD Drive Firmware Downgrading Tool
Backing up the legally purchased 4K Ultra HD Blu-ray discs for home use is what every 4K Blu-ray lover will do. To do that, a 4K UHD drive compatible with popular UHD backup tools is a must. However, if a 4K UHD drive is natively manufactured or personally flashed with the latest firmware, then it may not be able to work with that sort of software tools.
Panic Not! DVDFab has a solution on the way — we're working on an extremely easy-to-use Firmware Downgrading Tool to help you dump the current firmware on your 4K UHD drive, so that you can make legal backups of your expensive and precious 4K Blu-ray discs.
This upcoming handy utility will be surprisingly friendly to non-tech savvies, even green hands. You don't need a profound knowledge to perform the downgrading process. And we already have the first batch of 4K UHD drives that will make it to the supported list:
• LG WH14NS40 (internal, SVC code: NS50) Firmware: 1.03
• LG WH16NS40 (internal, SVC code: NS50) Firmware: 1.03
• LG BH16NS40 (internal, SVC code: NS50) Firmware: 1.03
• LG UH12NS40 (internal) Firmware: 1.01
• LG BH16NS55 (internal) Firmware: 1.03
• LG BH14NS58 (internal) Firmware: 1.01
• LG BH16NS58 (internal) Firmware: 1.01
• LG WH16NS58 (internal) Firmware: 1.V1, 1.V2, 1.V5
• ASUS BC-12B1ST b (internal, manufactured 2015+) Firmware: 3.01
• ASUS BW-16D1HT a (internal, manufactured 2015+) Firmware: 3.02, 3.03
• LG WH16NS60 (internal, recommended) Firmware: 1.01
Tips: It's better to grab one of the above-mentioned drives in advance, just in case they run out of stock.
Cheers
dbone1026 is offline
post #1803 of 2711 Old 11-04-2018, 07:48 PM
Audio/Video Enthusiast
alexcoluzzi32's Avatar
Quoted: 269 Post(s)
Liked: 200
Hey folks I'm back! Gotta catch up on what i've missed
Living Room: Xfinity XG1v4-A cable box + Apple TV 4K > Sony HT-ST5000 Atmos/DTS:X Soundbar > Sony XBR-65X900F Television
Office: Oppo UDP-203 + Apple TV 4K > Sony HT-Z9F Atmos/DTS:X Soundbar (with rears) > Sony XBR-55A1E Television
alexcoluzzi32 is offline
post #1804 of 2711 Old 11-04-2018, 07:58 PM
Quoted: 269 Post(s)
Liked: 200
Don't be afraid to crossflash those LGs to the ASUS 3.01 firmware and enjoy the higher ripping speed the ASUS firmware offers.
Originally Posted by rmilewsk View Post
Finally Success!!.
Thanks Everyone for your help.
The ripping speed seems much slower than blu ray rips.
I still don't understand why there is a 103 version in the Clean_NS50_compatible_firmwares file if it isn't supposed to be used. THat seems completely backwards to me.
post #1805 of 2711 Old 11-05-2018, 12:16 AM
wl1
wl1's Avatar
Quoted: 441 Post(s)
Liked: 396
You are definitely on to to something.
I ticked the "Use base video stream for right eye" on the BluRay Tab of tsMuxeR and tried again - but it seemed the same. BUT - I flipped my 3D glasses around (left eye with right lens....) - and voila - 3D image was correct.
Can you clarify if I ticked the correct box in the correct software?
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #1806 of 2711 Old 11-05-2018, 07:01 AM
Quoted: 269 Post(s)
Liked: 200
What they fail to mention is this will not be free. Still not sure what there is to get excited about. Those with the technical chops to do flash will flash, those on the fence or simply want a pre-configured solution will continue to go that direction.
post #1807 of 2711 Old 11-05-2018, 07:17 AM
dbone1026's Avatar
Quoted: 409 Post(s)
Liked: 205
I actually think it is clear that this is part of their paid services and not something free. Also, I think it is being targeted at the less tech savvy, so I could see for those who don't want to go the DIY route posted here why this would be appealing.
captainbrent likes this.
Cheers
post #1808 of 2711 Old 11-05-2018, 07:45 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Yeah that's the right box I believe, I remember having to try multiple times to get it to work. I got it working on a mkv file, and I just took that file and tried m2ts and it was wrong again, so I am still working on m2ts for oppo playback on that file.
Sent from my SM-G920V using Tapatalk
wl1 likes this.
post #1809 of 2711 Old 11-05-2018, 12:53 PM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
If you want to confirm it so you are working towards the right issue, you can use MediaInfo on the file, go to text view, then check this area, example from Kong.
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Stereo [email protected] / [email protected]
MultiView_Count : 2
MultiView_Layout : Both Eyes laced in one block (right eye first)
I am rebuilding my MKV to M2TS now, I will update if I get it working this time.
post #1810 of 2711 Old 11-05-2018, 02:16 PM
wl1
wl1's Avatar
Quoted: 441 Post(s)
Liked: 396
Video
Format : AVC
MultiView_Count : 2
The MKV file shows the same description you have in Bold. But the M2TS files don’t - and I have tried ticking the box a few times, with no joy so far.
I wish you luck - please post back if you resolve.
wl1 is offline
post #1811 of 2711 Old 11-07-2018, 06:48 AM
deano86's Avatar
Quoted: 644 Post(s)
Liked: 319
IME... and I only work with MKV files....ticking the box does nothing to change the actual MVC coding of the video file. It may now "say" left eye first after remuxing or redoing the video file and then checking it with Mediainfo... but when playing the file, you still have to manually swap the eyeview. Certain titles are just this way.... But, I haven't experimented with changing it to ISO or other file formats... the number of titles that need the eyeview to be swapped is quite small in my collection.
wl1 likes this.
deano86 is offline
post #1812 of 2711 Old 11-08-2018, 11:58 AM
Quoted: 269 Post(s)
Liked: 200
does anyone own or know someone who owns an LG slim BU30N drive?
Looking for an image of it's firmware. I am very passionate about finding this. Thank you.
post #1813 of 2711 Old 11-08-2018, 01:17 PM
Ph8te's Avatar
Quoted: 6529 Post(s)
Liked: 6254
Clean firmware should be in the zip posted earlier in the thread (with the rest of the “clean firmwares”. I think they had almost every good model in there.
Ph8te is offline
post #1814 of 2711 Old 11-08-2018, 01:25 PM
Quoted: 269 Post(s)
Liked: 200
I guess I'm not seeing it. Pretty sure I have all of them but I'd love to be proved wrong thank you!
post #1815 of 2711 Old 11-14-2018, 10:39 PM
Quoted: 269 Post(s)
Liked: 200
Yeah there’s no dump of a
BU30N I’m not even sure the drive exists but I have a couple originals on their way from China. Bet their counterfeit. Lol.
Hey guys serious question: what is the recommended way to play back bdmv folders? Specifically the type created by MakeMKVs “full disc backup” process.
I put mine on a portable hard drive and plug it into the Oppo which does a wonderful job of handling the files. It’s exactly as if you’d put the disc in the tray. In fact if you stop file playback and put in the disc it will ask you if you’d like to continue from where you left off!!
Suggesting folks pick up an Oppo solely for file playback is not a realistic solution these days so I was wondering what the next choice would be.
Sent from my iPhone using Tapatalk Pro
post #1816 of 2711 Old 11-14-2018, 10:48 PM
Quoted: 269 Post(s)
Liked: 200
Originally Posted by lujan View Post
Sorry, the last time I tried to do something similar with merging Atmos and a 3D title (Gravity), I could never get it to work so I gave up. I'm just now waiting for Gravity to be released in 4k.
Sorry I’m a little slow, so 3D Blu Rays are not released with Atmos audio tracks so you’re re-releasing them with that oversight corrected?
post #1817 of 2711 Old 11-15-2018, 04:31 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 644 Post(s)
Liked: 401
See this thread and the document linked, which is another of my compilation projects.
https://www.avsforum.com/forum/39-net...yer-list.html#
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #1818 of 2711 Old 11-15-2018, 05:04 AM
Tedd's Avatar
Quoted: 2155 Post(s)
Liked: 902
I wouldn't rule that out, as there's a large pre-owned market out there.
Tedd is offline
post #1819 of 2711 Old 11-15-2018, 12:05 PM
Quoted: 269 Post(s)
Liked: 200
I'm hoping I can get one of them to build a simple little box or make that code open source and post it somewhere. I know both of those ideas make me sound like I've been on the legalized weed out here but I assure you I'm straight.
post #1820 of 2711 Old 11-16-2018, 09:26 AM
Quoted: 269 Post(s)
Liked: 200
https://www.avsforum.com/forum/39-ne...yer-list.html#
Seriously, you do nice work. The spreadsheet makes it official, stick with Oppo and buy nothing else.
giomania likes this.
post #1821 of 2711 Old 11-18-2018, 01:25 PM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Ok, after having bought a drive a year ago or so, I thought I would finally start ripping some of my UHD discs. I haven't even used my drive before, but after plugging it in, it doesn't even have a DVD Region code assigned to it. I'm in the US, but for everything to work the way it should, does it matter what I set the Region code to or is it necessary for me to set it at all? I'm assuming I would set it for the US since all my discs are US discs. I just don't want to do anything that might prevent my drive from working.
JVC RS4500K, Paladin DCR, Lumagen Radiance Pro, LG OLED W7, OLED E7, OLED C6, Sony A1E, Samsung QLED Q9F, QLED Q7F, Vizio P75c1, Marantz AV8805, Emotiva XPA-7 Gen 3, Integra DRC-R1, Anthem MRX 720, Oppo 203, Sunfire TGA-7401, Outlaw 5000, Triad Silver 7.1.4 Atmos setup, SVS PB16 Ultra, PSA 3601,SVS PB-13 Ultra, 31 Sonance VP88R, 6x6 Control4 4K HDR AV matrix, Control4 8 Zone AMP, Control4 EA-5, Control4 EA-1, QNAP TVS-882 & TS-451+
rolldog is offline
post #1822 of 2711 Old 11-18-2018, 01:38 PM
Quoted: 269 Post(s)
Liked: 200
No region settings necessary with UHD 4K Blu Rays. You're clear for takeoff sir!
rolldog likes this.
post #1823 of 2711 Old 11-19-2018, 01:39 AM
SeeMoreDigital's Avatar
Quoted: 1007 Post(s)
Liked: 770
I can't remember... Does the firmware 'tweak' reset the DVD region code counter?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #1824 of 2711 Old 11-19-2018, 03:39 PM
UHD Addict
aaronwt's Avatar
Quoted: 9324 Post(s)
Liked: 6005
I never set the region code for any of my drives. Whether UHD drives or 2k BD drives. It has never caused me any issues ripping 2k BDs or UHD BDs.
SuperFist likes this.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1825 of 2711 Old 11-20-2018, 03:10 PM
JRock3x8's Avatar
Quoted: 1858 Post(s)
Liked: 623
just had to stop in with a quick plug for Alex - just got off the phone with him - just a really great professional, extremely well informed guy.
Thanks for your time man. Enjoyed our chat.
aaronwt and SuperFist like this.
JRock3x8 is offline
post #1826 of 2711 Old 11-21-2018, 12:17 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4887
I read the first few pages of the thread and then skipped to the last two, but there's too much in between for me to wade through.
I've bee using my LG BE14NU40 external R/W drive to rip blurays with makemkv for a few years now, but just ordered my first UHD Blurays for my new LG UBK90 player and want to take advantage of Black Friday specials to upgrade to a new external drive for ripping UHD Blurays.
I've seen the list from the first post from a year ago:
LG BE16NU50
LG WH16NS40
LG BH16NS40
ASUS BW-12B1ST
ASUS BC-12D2HT
ASUS BW-16D1HT
LG BH16NS55
LG WH16NS58
ASUS BW-16D1H-U A201
LG BU30N
Have there been any additions to the list since then? Seems as though most of the drives are internal with the exception of the LG BE16NU50 - is that the recommended external drive or is there another one to consider?
Any advice on the best external UHD-capable external drive to pick up over the next couple weeks appreciated...
[edit: seems as though the LG BE16NU50 is out of stock everywhere, and the DVDFab link now lists the LG BP60NB10 and the Buffalo BRUHD-PU3 as the only 'UHD Official' external drives (with the Buffalo being recommended).
Anyone have any experience with these two drives? Is the Buffalo the better one to get?]
fafrd is offline
post #1827 of 2711 Old 11-21-2018, 01:28 PM
Ph8te's Avatar
Liked: 6254
LG BE16NU50
LG WH16NS40
LG BH16NS40
ASUS BW-12B1ST
ASUS BC-12D2HT
ASUS BW-16D1HT
LG BH16NS55
LG WH16NS58
LG BU30N
Just buy an internal and put it into an external enclosure (voila “external” drive) that’s what many of us have done.
Ph8te is offline
post #1828 of 2711 Old 11-21-2018, 02:27 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4887
Sounds like some screwing around but if it's easy and it's cheaper (or more available), why not?
Is there an internal drive that is most-used / recommended on the board?
Any recommendations on a decent budget 'enclosure' appreciated as well...
fafrd is offline
post #1829 of 2711 Old 11-21-2018, 02:41 PM
UHD Addict
aaronwt's Avatar
Liked: 6005
I got three of the Vantec NST-536S3-BK enclosures for my three drives I rip UHD BDs with.
I got mine from ebay. With the current 15% off at ebay, the enclosure would be around $39. And maybe Newegg has it on sale.
EDIT: I see Amazon has it for $36 when you apply their $5 off coupon that shows up on the page.
https://www.amazon.com/Vantec-NST-53...c+nst-536s3-bk
fafrd, Ph8te and JRock3x8 like this.
aaronwt is offline
post #1830 of 2711 Old 11-21-2018, 02:57 PM
Ph8te's Avatar
Liked: 6254
I think the LGs are popular, haven’t been keeping up with things. I also know there are people who sell “ready” drives for close to the retail price if you’re uncomfortable with the flashing process (go to makemkv forums). I picked up an LG and flashed it to an ASUS via an old laptop I have. As far as price goes it works out to the same or cheaper than an external and these days it’s extremely hard to find a compatible drive so flashing is usually a “must”.
Ph8te is offline
