Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 936Likes
post #2011 of 2709 Old 12-22-2018, 05:44 PM
jhughy2010's Avatar
Quoted: 906 Post(s)
Liked: 288
This is certainly going to be interesting.... Just when I was getting used to the UHD ripping workflow - they have to throw a wrench in it. Well, at least storage is cheap. I'll continue to backup BDMV. Just to understand this better; backing up HDR10+ to BDMV doesn't seem to loose the metadata correct?
jhughy2010 is offline
post #2012 of 2709 Old 12-22-2018, 07:24 PM
rdgrimes's Avatar
Quoted: 3850 Post(s)
Liked: 3086
Correct. The special sauce is lurking somewhere in those folders.
jhughy2010 likes this.
rdgrimes is offline
post #2013 of 2709 Old 12-24-2018, 11:52 AM
Quoted: 27 Post(s)
Liked: 5
Originally Posted by SeeMoreDigital View Post
As a side-note...
With regard to maintaining Dolby Vision meta-data, jdobbs, the author of BD Rebuilder posted the following yesterday: https://forum.doom9.org/showthread.p...47#post1860747
Cheers
What's this mean exactly? That we can have m2ts rips that will properly play in Dolby Vision?
thebabyparrot is offline
post #2014 of 2709 Old 12-24-2018, 02:32 PM
JRock3x8's Avatar
Quoted: 1858 Post(s)
Liked: 623
received more 4k BR's for Xmas - Alex's drive rips them like a champ.
aaronwt likes this.
JRock3x8 is offline
post #2015 of 2709 Old 12-24-2018, 03:41 PM
Audio/Video Enthusiast
alexcoluzzi32's Avatar
Quoted: 269 Post(s)
Liked: 200
Your drive! Remember, straight flush always beats 4OAK. I walked away from that table with nothing but my um, hmm, oh yeah HAT in my hands.
Living Room: Xfinity XG1v4-A cable box + Apple TV 4K > Sony HT-ST5000 Atmos/DTS:X Soundbar > Sony XBR-65X900F Television
Office: Oppo UDP-203 + Apple TV 4K > Sony HT-Z9F Atmos/DTS:X Soundbar (with rears) > Sony XBR-55A1E Television
alexcoluzzi32 is offline
post #2016 of 2709 Old 12-26-2018, 08:14 AM
UHD Addict
aaronwt's Avatar
Quoted: 9312 Post(s)
Liked: 6000
Originally Posted by rdgrimes View Post
Well we need some testing from people using HDR10+ displays. But at present I cannot get any kind of HDR from any kind of ripped file. Only works from a full disc rip. So yes, it seems to be even more crippled than DV as far as ripping is concerned.
Is this specific to MakeMKV? Because last night I tried ripping an HDR10+ title to an MKV with RedFox CloneBD. And it played in HDR10 using Plex. It worked just like the DV titles I've ripped.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #2017 of 2709 Old 12-26-2018, 08:41 AM
jrolmstd's Avatar
Quoted: 49 Post(s)
Liked: 26
We could have multiple failure points between the file and the end of the video chain (TV). For me, it is Kodi, Nvidia Shield, and a receiver before it even gets to the TV. Is there something in the MKV file that can used to determine if the HDR10+ was captured or not? Seems like that needs to be done to determine where the root cause of the problem is determined.
Sony XBR-65Z9D | Marantz AV7702MK II | Monoprice Monolith 7 channel Amp | SVS: Prime Tower(2), Ultra Center, Prime Elevation(4), PB-2000 Sub | OPPO UDP-203 Ultra HD | Nvidia Shield
jrolmstd is offline
post #2018 of 2709 Old 12-26-2018, 02:49 PM
Quoted: 27 Post(s)
Liked: 5
Has anyone seen the news that Dolby Vision MP4's can be created from backup ISO's and played via USB on Lg / vizio televisions? Their are hard limitations: Audio can only be in AC3, and we are limited to mp4. The procedure to do is legnthy, but I figured I'd post it here:
The steps are:
1. Make ISO of movie. I have only tested this with Black Panther since that's the only one I own. I will be buying Gladiator this weekend to test out though.
2. Use TS Muxer to open the ISO. Find the correct M2TS file and demux the following files:
A. HEVC1 in 4K (Base layer)
B. HEVC 2 in 1080p (this is the dolby vision enhancement layer)
C. Audio track which you will have to convert to AC3. This is a hard line limitation- you need to use AC3!!!
3. Once you have HEVC1, HEVC2, and the Audio track. Run Dolby Vision MP4Muxer (https://github.com/DolbyLaboratories/dlb_mp4base)
DolbyVision MP4 Muxer only works in Command Prompt so you have to navigate to the corresponding folders where the files are and type
mp4muxer --dv-profile 7 --input-file (baselayername.hevc1) --input-file (dvlayername.hevc2) --input-file (audio.ac3) --media-lang eng --output-file (nameofmovie).mp4
post #2019 of 2709 Old 12-26-2018, 03:32 PM
tbass2k's Avatar
Quoted: 321 Post(s)
Liked: 307
The steps are:
Thank goodness for Oppo. Full Dolby Atmos and Vision glory.
Sent from my SM-N960U using Tapatalk
tbass2k is online now
post #2020 of 2709 Old 12-26-2018, 03:40 PM
Quoted: 27 Post(s)
Liked: 5
Some of us unfortunately don't have 2 thousand to spend on a UHD bluray player.
aaronwt likes this.
post #2021 of 2709 Old 12-26-2018, 10:00 PM
tbass2k's Avatar
Quoted: 321 Post(s)
Liked: 307
I feel you. I got one before they stopped making them and paid regular price. It's the best media player I've owned next to the Dunes, but it isn't worth $2000.
post #2022 of 2709 Old 12-27-2018, 11:54 AM
jrolmstd's Avatar
Quoted: 49 Post(s)
Liked: 26
Not sure what model you are referring to but the OPPO UDP-203 I picked up was closer to $500 than 2k... Even the UDP-205 is listed at 13 hundred on the OPPO site.
jrolmstd is offline
post #2023 of 2709 Old 12-27-2018, 12:00 PM
jrolmstd's Avatar
Quoted: 49 Post(s)
Liked: 26
Mike has updated the status of the support for official UHD drives on his "MakeMKV" web site.
giomania and Ph8te like this.
jrolmstd is offline
post #2024 of 2709 Old 12-27-2018, 12:18 PM
poppagene's Avatar
Quoted: 860 Post(s)
Liked: 758
That was the price when oppo was in business. Good luck finding one for that price anywhere.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #2025 of 2709 Old 12-27-2018, 01:50 PM
jrolmstd's Avatar
Quoted: 49 Post(s)
Liked: 26
lol, checking amazon and I see what you mean. They (203 & 205) are selling for 3x the MSRP. Makes me think I should put mine on E-Bay but I don't know what I would replace it with...
jrolmstd is offline
post #2026 of 2709 Old 12-27-2018, 02:02 PM
rdgrimes's Avatar
Liked: 3086
Oppo is still very much "in business", just not making players. Anyway the 203 is selling close to $900 on FleaBay. Arguably still a decent value given the cost of the 2 or 3 other devices you'd have to buy to get all the same functionality.
rdgrimes is offline
post #2027 of 2709 Old 12-29-2018, 10:32 AM
Quoted: 269 Post(s)
Liked: 200
A little while ago there was talk of creating 3D discs in this discussion. Does makemkv rip 3D discs as it should? I seem to recall making a full disc backup of one awhile back, tried recently and it failed making me think this feature may have been broken. Now i'm thinking I should check again.
I've a friend asking about ripping 3D blu raysand wanted to recommend makeMKV and an ASUS but wanted to be sure about the 3D disc part. He also wanted to burn the contents back onto a blu ray disc and I think something called imgburn will do that?
Thanks for any advice.
post #2028 of 2709 Old 12-29-2018, 10:44 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4644 Post(s)
Liked: 4493
Yes, it will create MKV files with the MVC encoded 3D image which is found on Blu-ray discs.
However, make sure your playback method supports that format. More devices support the side-by-side and top-bottom variants, which are not used in Blu-ray. MakeMKV will not create those other types. Years ago I think DVDFab would, but I have not used it recently.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #2029 of 2709 Old 12-29-2018, 11:22 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
It does, if you are planning on using the Oppo 203 I saw in your sig you would need to convert them to m2ts format and reorder the H264 and MVS streams, I think its in this thread or the Oppo thread.
grendelrt is online now
post #2030 of 2709 Old 12-29-2018, 11:31 AM
Quoted: 269 Post(s)
Liked: 200
Thanks all!
post #2031 of 2709 Old 12-29-2018, 07:13 PM
lujan's Avatar
Quoted: 4604 Post(s)
Liked: 2675
Has anyone tried ripping "Stranger Things" season 2 UHD with makemkv yet? I started to watch the rips tonight but the chapters (possibly the episodes as well) are not in order. If someone has run into this and has a solution, I would appreciate it. I did a Google search and also a search on the makemkv forums but didn't find any results pertaining to this issue.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #2032 of 2709 Old 12-29-2018, 07:41 PM
Ph8te's Avatar
Quoted: 6526 Post(s)
Liked: 6240
Did you rip the ISO or individual episode MKVs ? You need to verify if the episodes match the title after ripping if doing individual MKVs. Sometimes TV episodes are not a 1:1 when ripping to MKV so it must be manually checked before you rename them (this happens with BRs as well). I’m guessing due to obfuscation titles are not always in order, but that rarely matters when playing the actual disc.
Ph8te is offline
post #2033 of 2709 Old 12-30-2018, 12:25 AM
lujan's Avatar
Liked: 2675
Individual MKVs. I'll check each one, thanks!
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #2034 of 2709 Old 12-30-2018, 11:28 AM
clarkss12's Avatar
Quoted: 157 Post(s)
Liked: 65
I have the LG WH16NS40 that I purchased Oct. 2, 2015 and have been trying to get it to **see** my 4k video without success. At this time, I only have one 4k disk to test (Man of Steel), and not having any luck. I even updated the firmware to version 1.01, then after more testing, updated it to version 1.02.
I read somewhere that there is a model of that burner that does not work.
When I insert the 4k movie into my drive, Windows 10 does not even recognize that a disk has been installed into it, should it???
For testing using MakeMKV, I downloaded the keys_hashed.txt file and put it into the MKV data folder and changed the name to KEYDB.cfg. That did not work. There are 4 options for that movie, so I took the hashtag from that text file, and pasted it into a new text file and named it KEYDB.cfg, this is the string that I pasted into the text file, is it correct?? " 9RuZtj!lZ4minryPOIB3cdKG0+pofp1QhKv0sWKW ". Is there something else I need to add to that text file???
Thanks for any help.
clarkss12 is online now
post #2035 of 2709 Old 12-30-2018, 11:46 AM
Quoted: 269 Post(s)
Liked: 200
The one and only test you really needed to do was to check the sticker on that drive and verify the svc code to be NS50. Having handled and played with literally hundreds of those drives that date sounds right on the edge of when the 4K "loophole" came into being. I'll bet you when that drive was purchased it came with rom ver. 1.00 as you mentioned updating firmware to 1.01 and then 1.02. If that's the case and it still doesn't work it most likely won't. With the current version of makeMKV there is no user interaction needed with the hashed keys file, it is automatically downloaded and updated. You are wasting time messing with the keys file, especially changing it's name like that. The drive may be OK for 2K blu rays but that'll be about it. My advice is to acquire another drive, something much newer.
post #2036 of 2709 Old 12-30-2018, 12:24 PM
clarkss12's Avatar
Quoted: 157 Post(s)
Liked: 65
Thank, you Alex, that is exactly the information I was looking for. I have spent several hours trying to get it to work.
post #2037 of 2709 Old 01-03-2019, 09:25 AM
Quoted: 130 Post(s)
Is the Asus bw-16d1ht still the best drive to get for these purposes?
RichardPryor is offline
post #2038 of 2709 Old 01-03-2019, 05:26 PM
UHD Addict
aaronwt's Avatar
Liked: 6000
I'm still seeing no problem with HDR10+ discs. I've tried two now and they both show up in HDR10 when playing back in PLex. I used CloneBD for the first one to create an MKV. And I used MakeMKV for the second one.
It shows up as HDR10 from multiple devices. With all of them going through an HDMI switch before going to an Onkyo receiver in one setup(with a TCL UHD TV) and a Vizio speaker bar in another setup(with a Sony UHD TV)
captainbrent likes this.
post #2039 of 2709 Old 01-03-2019, 07:09 PM
Seryl's Avatar
Quoted: 160 Post(s)
Liked: 105
That's what I use and it works very well. I have a dozen or so successful UHD 4K rips so far with no failures. This includes MKV, ISO and folder rips. Now I've had mine for quite some time and don't know if they've mucked anything up with firmware changes you might get on a more recently manufactured drive.
Seryl is offline
post #2040 of 2709 Old 01-11-2019, 01:52 PM
hobbs47's Avatar
Quoted: 458 Post(s)
Liked: 491
Has this thread died? Not even Alex posting here lately. Hmm...............
Benq HT3550/LG OLED65B6P /Panny UB820 4k Bluray/Apple TV 4k
Nvidia Shield/HDFury AVRkey/Samsung HW-K950 Soundbar
hobbs47 is offline
