Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #2371 of 2481 Old 04-09-2019, 10:23 AM
whiteboy714's Avatar
Quoted: 619 Post(s)
Liked: 162
Originally Posted by lujan View Post
Thanks, I guess I'll have to look more at PLEX but so far I haven't found something like that.
Looks like you have at least a couple options.
1. Backup the default folder where plex stores all the metadata with the mkv's you have saved.
https://support.plex.tv/articles/202...ctory-located/
2. Store any custom images you downloaded in the media folders themselves and plex will use them. These should be backed up along side your library.
https://www.plex.tv/blog/making-your...great-in-plex/
whiteboy714 is offline
post #2372 of 2481 Old 04-09-2019, 10:46 AM
lujan's Avatar
Quoted: 4160 Post(s)
Liked: 2354
Great, I've already backed up the images but now I can backup the metadata as well!
aaronwt and whiteboy714 like this.
lujan
490 Ultra HD
725 HD
4 SD
lujan is offline
post #2373 of 2481 Old 04-14-2019, 10:56 PM
Audio/Video Enthusiast
alexcoluzzi32's Avatar
Quoted: 241 Post(s)
Liked: 183
Originally Posted by Taxcheat View Post
They work fine. Just get rid of those nasty m2ts files in the stream folder (overwrite them with a blank mt2s file -- look in the folder for one with a tiny file size and use that).
Rhapsody: 3, 619, 650-1, 653, 675
Aquaman: 0, 4, 7-10, 16
There. FBI warning and related annoyances removed for all eternity.
Hey thanks for this. Yeah I over reacted as usual. Folders are working. I’m still keeping this precious box off the network
Sent from my iPhone using Tapatalk Pro
Living Room: Xfinity XG1v4-A cable box + Apple TV 4K > Sony HT-ST5000 Atmos/DTS:X Soundbar > Sony XBR-65X900F Television
Office: Oppo UDP-203 + Apple TV 4K > Sony HT-Z9F Atmos/DTS:X Soundbar (with rears) > Sony XBR-55A1E Television
alexcoluzzi32 is online now
post #2374 of 2481 Old 04-14-2019, 10:59 PM
RapalloAV's Avatar
Quoted: 2188 Post(s)
Liked: 762
My new LG BH16NS55 with UHD Friendly firmware drive has been working perfectly for 4K rips with makemkv but today no luck.
Ive tried and tried to rip the 4K disc I just bought of The Patriot with no luck over and over, it just won’t load. I have cleaned the disc over and over and still no luck, what does one do now? Do you know if there are any issues with this Universal title?
I have also tried DVDfab with same results.
This is the message I get on makemkv.
MakeMKV v1.14.3 win(x64-release) started
Using direct disc access mode
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\Murray/.MakeMKV/MKB21_v61_Patriot,_The_(2000)_6721.tgz
The volume key is unknown for this disc - video can't be decrypted
Failed to open disc
Drive Information
OS device name: E:
Current profile: BD-ROM
Manufacturer: HL-DT-ST
Product: BD-RE BH16NS55
Revision: 1.02
Serial number: KLKIBTD5243
Firmware date: 2115-12-11 14:40
Bus encryption flags: 17
Highest AACS version: 66
LibreDrive Information
Status: Enabled
Drive platform: MT1959
Firmware type: Original (unpatched)
Firmware version: 1.02
DVD all regions: Yes
BD raw data read: Yes
BD raw metadata read: Yes
Unrestricted read speed: Possible, not yet enabled
Disc Information
Label: THE_PATRIOT_2000
Timestamp: 2018-03-16 13:46:46
Data capacity: 91.43 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is online now
post #2375 of 2481 Old 04-14-2019, 11:04 PM
Quoted: 241 Post(s)
Liked: 183
Originally Posted by ipca204 View Post
uninstalled makemkv and then reinstalled it cured my issue. NO idea why that happened...
Lotta weird stuff happening with the program lately. Spending far
too much time doing tech support for someone else’s code.
Lots of certificate revoking which I understand very little about. Lots of missing keys for titles that have been in there forever.
Far too many custom flashers and firmware discussions.
I’m not complaining though. Poor newbies visit forum, spend an hour getting a massive headache, give up, and end up emailing me or Billy and problem solved
SuperFist likes this.
post #2376 of 2481 Old 04-14-2019, 11:08 PM
Quoted: 241 Post(s)
Liked: 183
Failed to open disc
Drive Information
OS device name: E:
Revision: 1.02
Status: Enabled
Disc Information
Number of layers: 3
Sir, both The Patriot and Fury use a form of encryption that has not
yet been “cracked” and are not able to be backed up using MakeMKV right now. What you are experiencing is by design.
You are OK!
SuperFist and Madmax67 like this.
post #2377 of 2481 Old 04-14-2019, 11:13 PM
RapalloAV's Avatar
Liked: 762
You are OK!
What a nightmare then, I have no way of playing it now as I dont own a 4K BD player.
I had the BD 1080p version I bought many years ago and just bought the 4K version yesterday to compare it, to my BD version, Ive just wasted my money
Is there a place we can go to of the discs that wont rip, at lease then I dont throw money down the drain?
Murray Thompson
X Owner RapalloAV
post #2378 of 2481 Old 04-14-2019, 11:19 PM
Quoted: 241 Post(s)
Liked: 183
I think the DeUHD stuff can “rip” these but you’d have to check with those folks.
Also I’d post something in the thread regarding that issue on the MakeMKV forums so he can see that yet another user has run into this issue.
post #2379 of 2481 Old 04-14-2019, 11:43 PM
RapalloAV's Avatar
Liked: 762
Can you give me a link to that forum please?
Murray Thompson
X Owner RapalloAV
post #2380 of 2481 Old 04-15-2019, 02:29 AM
SuperFist's Avatar
Quoted: 1236 Post(s)
Liked: 4648
I see you've already posted on the official Makemkv forum and they told you that AACS 2.1/Category C, i.e., Fury 4K UHD and The Patriot 4K UHD, are NOT supported.
What you can do is purchase DeUHD, which is the software that was able to decrypt this copy protection, and make copies of these films.
Subwoofers: PSA S3000i x 2 | L+R Front: Onkyo SKF-200F | Center: Onkyo SKC-200C | L+R Surround: Onkyo SKM-200S | Atmos: Pioneer SP-T22A-LR | AVR: Yamaha RX-A660BL | HTPC: Lenovo Q190
SuperFist is offline
post #2381 of 2481 Old 04-15-2019, 05:58 AM
UHD Addict
aaronwt's Avatar
Quoted: 8843 Post(s)
Liked: 5631
It would make more sense to buy a UHD BD player with that money.
Sent from my Nexus 7(16GB)
Keenan, Ph8te and RapalloAV like this.
53TB unRAID2--45TB unRAID3--35TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #2382 of 2481 Old 04-15-2019, 12:56 PM
RapalloAV's Avatar
Liked: 762
Yes I wonder why DeUHD is so expensive $200 someone said. I tried to use its free evaluation software to see if it would rip Patriot, but I couldnt even get that to work. I had to email them asking why it wouldnt work for me but I very much doubt I would pay $200 to get one disc ripped. I paid for makemkv and DVDfab, I dont see the point in adding another....
Murray Thompson
X Owner RapalloAV
post #2383 of 2481 Old 04-15-2019, 01:31 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 519 Post(s)
Liked: 376
I wonder if the red fox program Clone BD can rip those discs? It must be paired with any DVD HD but I have that anyway.
I never have to choose playlist either at exit automatically. I love it!
Mark
giomania is offline
post #2384 of 2481 Old 04-15-2019, 01:41 PM
Wryker's Avatar
Quoted: 187 Post(s)
Liked: 67
Mark
I use the AnyDVDHD rip to ISO for UHD and so far it's worked flawless. I then convert just the movie to MKV. Plays without issue on my Zappiti 4K player from a USB connected drive.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #2385 of 2481 Old 04-15-2019, 02:10 PM
UHD Addict
aaronwt's Avatar
Liked: 5631
Mark
No it cannot. Unless something has changed recently, it cannot rip The Patriot or Fury UHD BDs.
giomania and SuperFist like this.
aaronwt is offline
post #2386 of 2481 Old 04-15-2019, 02:24 PM
rdgrimes's Avatar
Quoted: 3732 Post(s)
Liked: 2911
Mark
I think it can rip them as a protected ISO if you want to save that for the future. But you won't be able to do anything with it till a fix comes out.
rdgrimes is offline
post #2387 of 2481 Old 04-15-2019, 02:33 PM
UHD Addict
aaronwt's Avatar
Liked: 5631
That would make sense. Since a protected ISO is like playing the actual disc. But I have not tried that since I have no way to play an encrypted UHD BD from a PC.
I have used the protected ISO option for titles that are not available in Any DVD HD yet. And then I will run MakeMKV on the protected ISO and it will still create an MKV from it. Assuming that title is in it's database. Which is usually is since MakeMKV typically has the titles in their database much sooner than Redfox has them.
aaronwt is offline
post #2388 of 2481 Old 04-17-2019, 06:09 PM
Onkyoman's Avatar
Quoted: 861 Post(s)
Liked: 534
Has anyone here noticed that links to the MakeMKV forums are now being blocked by AVS Forum?
I posted several links to MakeMKV in a 4K PC build guide in the HTPC forum and they have suddenly become blocked. The links in the first post of this thread also do not work. Any link to the MakeMKV forums posted here is being redirected. The same links tested at the Kodi forums still correctly direct to MakeMKV. And links to other ripping software still work.
I smell a conspiracy...
Onkyoman is offline
post #2389 of 2481 Old 04-17-2019, 11:36 PM
Keenan's Avatar
Quoted: 3711 Post(s)
Liked: 3407
I just tried the MakeMKV link in the first post and it works fine.
Keenan is online now
post #2390 of 2481 Old 04-18-2019, 01:08 AM
SeeMoreDigital's Avatar
Quoted: 943 Post(s)
Liked: 672
Just tried too... The links are working okay for me.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #2391 of 2481 Old 04-18-2019, 05:28 AM
Onkyoman's Avatar
Quoted: 861 Post(s)
Liked: 534
Thanks for testing. They are still blocked on the browsers I tried. One other person was having this issue. I guess I can't blame this forum.
Onkyoman is offline
post #2392 of 2481 Old 04-18-2019, 09:34 AM
tjenkins95's Avatar
Quoted: 487 Post(s)
Liked: 442
I purchased deUHD lifetime support for $99 several months ago.
I had no problems ripping The Patriot and Fury.
I also own AnyDVD HD, CloneBD and DVDFab.
deUHD rips faster than DVDFab.
Ray
www.raysdvds.org
Denon AVR-X6200W; JVC RS500; Panasonic DMP-UB900; Oppo UDP-203;
Klipsch Speakers: RF-82, RC-62, RS-52, RB-61, RT-10d sub, Klipsch CDT-3650-C (4) ceiling.
Pioneer Dolby Atmos enabled Elite Concentric Speakers: SP-EFS73, SP-EBS73, and SP-EC73 in the guest room.
tjenkins95 is offline
post #2393 of 2481 Old 04-22-2019, 10:43 PM
RapalloAV's Avatar
Liked: 762
Im a bit new to ripping 4K discs but have used makemkv and DVDfab for years!
I just hate trying to rip my 4K discs I buy, often I have issues, sometimes they load many times they dont. Often when i get them to load they get 3/4 the way through then they die and with errors. I have one of the LG friendly drives I bought from the place in Australia.
I try to clean the discs just with a clean cloth, that never helps. is there some trick to making them work or more reliable?
I have over 1500 BDs I have ripped over the years and hardly ever have I had an issue ripping them.
These 4K discs really drive me nuts
The latest frustration today is with Coco, Ive attempted this film like four times today, just a real pain......
I have DVDfab for BDs but my trail version for 4K ran out as they only allow you three attempts.... Is it worth me buying the 4K version from DVDfab, or is it a bit like, if it doesnt work on makemkv, dvdfab wont be any better senario???
Murray Thompson
X Owner RapalloAV
post #2394 of 2481 Old 04-23-2019, 11:37 AM
UHD Addict
aaronwt's Avatar
Liked: 5631
Maybe it's the drive you are using?
I use three Asus drives for ripping my UHD BDs. It's extremely rare for me to have any issues ripping the discs.
aaronwt is offline
post #2395 of 2481 Old 04-23-2019, 12:47 PM
Quoted: 619 Post(s)
Liked: 162
Reading the makemkv forums it seems pretty common to have discs that won't rip, they will play in a player but have rip issues, needing to be returned.
I just got into 4k ripping myself and out of the 6? discs I have bought one needed to be returned as it wouldn't rip. Luckily it was new from amazon so no big deal. But seeing how common it is has made me leery of the second hand market.
post #2396 of 2481 Old 04-23-2019, 01:05 PM
RapalloAV's Avatar
Liked: 762
I bought the drive from a person in Australia who sells UHD friendly drives with the firmware flashed, it was recommended to me.
Murray Thompson
X Owner RapalloAV
post #2397 of 2481 Old 04-23-2019, 01:07 PM
RapalloAV's Avatar
Liked: 762
I dont buy and second hand discs for that very problem. I got Coco to rip after about 6 attempts of re cleaning and re cleaning and re cleaning it!
Murray Thompson
X Owner RapalloAV
post #2398 of 2481 Old 04-23-2019, 01:13 PM
Quoted: 619 Post(s)
Liked: 162
Oh so you finally got it, nice. I forgot what mine was but I finally gave up. The second disc I got through the return worked first shot. I have read about bad batches, so sometimes even a return has the same issue. I guess doing a rip is more sensitive than just watching the movie in a BD player.
post #2399 of 2481 Old 04-23-2019, 01:55 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 519 Post(s)
Liked: 376
Ray
Looks like it is either still on sale or on sale again for €99. Hmmm...
giomania is offline
post #2400 of 2481 Old 04-23-2019, 02:11 PM
rdgrimes's Avatar
Liked: 2911
When I ripped my entire collection of maybe 150 discs, roughly 15% failed. Of those that failed, roughly 1/2 were "rescued" by cleaning and polishing.
I put all this down to the fact that the PC drives, while "friendly" to BDXL discs, are not optimized in hardware or software for UHD discs. Hence, more likely to fail reading. STB players have hardware and firmware optimized for UHD, and more importantly they spin the disc at 1X during the movie.
rdgrimes is offline
