Ripping UHD 4k discs with Makemkv: Instructions How-to - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 1244Likes
post #2551 of 3126 Old 07-27-2019, 10:46 AM
Stereodude's Avatar
Quoted: 4373 Post(s)
Liked: 3107
Originally Posted by SeeMoreDigital View Post
But given all UHD disc players offer USB ports that can play .mkv contained media files off a USB connected pen-drive or HDD, there's very little reason to create UHD compliant authored discs!
Except they all have some sort of limits. Like the Sonys that won't play TrueHD in a .mkv container. TrueHD requires a m2ts container. At least TSmuxer is now open source so hopefully some enterprising folks will get it all fixed up for UHD-BD compliant output shortly.
I have a 203, 205, Dune 4K, Zidoo Z9s + 2 of those players, they get used almost exclusively vs. the other equipment. Is the server windows based? you can use https://www.hanewin.net/nfs-e.htm it works well and have used it in the past before switching to a synology. send me a pm if you have any q's.
Yes, it's a Windows 10 Pro system. I'll take a look at that software should I try to give it another shot in the future.
Stereodude is offline
post #2552 of 3126 Old 07-27-2019, 10:51 AM
SeeMoreDigital's Avatar
Quoted: 1189 Post(s)
Liked: 1036
Yes, with any luck it will become "fully" open source anytime now. But any new development tweaks will take time to implement.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #2553 of 3126 Old 07-27-2019, 01:02 PM
rdgrimes's Avatar
Quoted: 4096 Post(s)
Liked: 3408
Originally Posted by Sam S View Post
Well that is true. But part of me still wants to see if I can make a disc
I'm going to try TSMUXER, then TSM2UHD, then ISO, then burn. I have some 50GB-REs, so nothing wasted except time.
You won't get 46GB on a BD-RE disc. Maybe you will with a BD-R 50.
rdgrimes is offline
post #2554 of 3126 Old 07-27-2019, 05:41 PM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 139
Sadly, TSmuxer GUI (along with any application that uses TSmuxer to perform muxing) is unable to create fully compliant 4K UHD HEVC muxes that can be played in a hardware player, as it's development ceased many years before HEVC video came into being! [click here for the latest news]. So don't waste your time....
And note what is said here: https://www.videohelp.com/software/TSM2UHD
Cheers
Good info! Actually, I got it work. Sort of. I was able to mux (after some failed attempts), then ran TSM2UHD. The resulting disc had stutters, and wasn't really watchable because of them. But at least it was recognized as a UHD BD w/HEVC by my OPPO. So it was a decent experiment.
Ah good to know. I de-selected a several foreign language tracks and it got down to ~30GB.
Sam S is offline
post #2555 of 3126 Old 07-30-2019, 06:46 AM
thehun's Avatar
Quoted: 1360 Post(s)
Liked: 1489
since the first post hasn't been updated awhile I wonder which drives currently available that is good for ripping, especially external ones... thanks.
De sagittis Hungarorum libera nos, Domine!
You want true diversity? Champion the diversity of thoughts!
The Hun
thehun is offline
post #2556 of 3126 Old 07-30-2019, 06:51 AM
whiteboy714's Avatar
Quoted: 1895 Post(s)
Liked: 813
Any drive can be external with an enclosure or adapter.
aaronwt likes this.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
post #2557 of 3126 Old 07-30-2019, 10:34 AM
UHD Addict
aaronwt's Avatar
Quoted: 9980 Post(s)
Liked: 6645
Yes. My three drives I use for ripping UHD BDs are just internal drives I installed in USB 3.0 enclosures. Whether the drives are connected to a SATA port on the PC or connected over the USB external enclosure, ripping speeds have been the same.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #2558 of 3126 Old 07-30-2019, 01:22 PM
thehun's Avatar
Liked: 1489
okay , but my question is which currently available that is suitable for the task at hand, I did a search randomly from the ones on the first page and people mention that some came with an update already installed that made them useless and it's hard to according them to revert from such update... so is there a specific drive I should look into right now as plug and play? Thanks.
The Hun
thehun is offline
post #2559 of 3126 Old 07-30-2019, 01:35 PM
Liked: 813
I think all of the drives currently being made need to be flashed to do what you want (to be UHD friendly) but it is honestly very painless.
I bought this drive BW-16D1HT a few months ago and it was easy to flash. The makemkv forum is where you want to go for current info on this topic.
Ph8te likes this.
post #2560 of 3126 Old 07-30-2019, 01:40 PM
Ph8te's Avatar
Quoted: 7011 Post(s)
Liked: 7100
If you don’t want to flash the drive then you’ll need to head over The the makemkv forums and buy from a third party that sells unflashed or preflashed drives. Any drive bought now (as stated) will need to be flashed as we are long past the period of “good” drives unless you get one of the available “real” UHD drives that is compatible now.
Ph8te is online now
post #2561 of 3126 Old 07-30-2019, 01:51 PM
Liked: 1036
I'd quite like to try one of LG's BU40N slim-line drives....
post #2562 of 3126 Old 07-30-2019, 03:26 PM
Ph8te's Avatar
Liked: 7100
I think that’s the one I have, it works well from what I have tested (especially since makemkv now has ability to rip from them).
Ph8te is online now
post #2563 of 3126 Old 07-30-2019, 04:59 PM
thehun's Avatar
Liked: 1489
thanks guys I found Alex over at MMKV forum.....
The Hun
thehun is offline
post #2564 of 3126 Old 07-31-2019, 04:03 PM
lujan's Avatar
Quoted: 5205 Post(s)
Liked: 3217
Sorry if this is a bit off topic. I was wondering if anyone knows of some music converting software that I could use to convert .m4p files to .mp3? I only have about 10 files to convert but most of those I've tried want to charge $30 to $40 for the software. I hardly ever convert music files but need to do it for these few songs for a class reunion that will be coming up soon.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2565 of 3126 Old 07-31-2019, 04:15 PM
MaDMaX**'s Avatar
Quoted: 16 Post(s)
I could be wrong about this, but .m4p is the apple audio file is it not, if so you can use itunes to make a mp3 copy, that will end up in your itunes folder in Music, in windows i believe,
Ive done it myself previously, so know its possible,
MaDMaX** is offline
post #2566 of 3126 Old 07-31-2019, 04:19 PM
Liked: 813
https://www.dbpoweramp.com/
21 day trial.
post #2567 of 3126 Old 07-31-2019, 04:19 PM
lujan's Avatar
Liked: 3217
Yes it is but these .m4p files were sent to me so that I didn't have them in my iTunes library, hence the problem. It won't even add the .m4p files to my library.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2568 of 3126 Old 07-31-2019, 04:21 PM
lujan's Avatar
Liked: 3217
Thanks, it doesn't mention .m4p but I'll try it anyway.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2569 of 3126 Old 08-01-2019, 01:07 AM
Liked: 1036
Apple created the .m4p file extension (not to be confused with .mp4) to highlight the fact that such audio files are copyright protected with Apples 'Fairplay' DRM.
Regular 'unprotected' audio files with an .mp4 or .m4a file extension can be converted from one format to another quite easily!
aaronwt and MaDMaX** like this.
post #2570 of 3126 Old 08-01-2019, 08:10 AM
lujan's Avatar
Liked: 3217
As I suspected, it doesn't even recognize the .m4p files so it won't convert them.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2571 of 3126 Old 08-01-2019, 08:21 AM
Lost Dog's Avatar
Quoted: 72 Post(s)
Liked: 42
Have you tried something like this?
https://www.onlinevideoconverter.com/convert-mp4-to-mp3
Edit: D'oh! you've got m4p. Nevermind...
Lost Dog is offline
post #2572 of 3126 Old 08-01-2019, 08:22 AM
Liked: 813
As mentioned above those files have DRM. So pretty sure you won't be able to convert them until that is stripped. Although when I searched m4p converter plenty of stuff came up.
SeeMoreDigital likes this.
post #2573 of 3126 Old 08-01-2019, 08:49 AM
lujan's Avatar
Liked: 3217
Yes, I also did a search and have installed a ton of programs but they all had limitations as far as file size and time restrictions unless you buy them.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2574 of 3126 Old 08-01-2019, 08:51 AM
Liked: 813
How important is this project to you, not worth spending a few bucks?
post #2575 of 3126 Old 08-01-2019, 08:52 AM
lujan's Avatar
Liked: 3217
No, $30.00 or $40.00 for 10 files and never again. Not worth it to me or the project.
lujan
694 Ultra HD
737 HD
4 SD
lujan is online now
post #2576 of 3126 Old 08-01-2019, 09:06 AM
Liked: 1036
Does this mean you can't find these particular tracks on YouTube then?
If not... What are they?
post #2577 of 3126 Old 08-01-2019, 10:26 AM - Thread Starter
javanpohl's Avatar
Quoted: 876 Post(s)
Liked: 563
Ok, so back to the media player topic for a second. I recommended the Zapiti all out earlier, but I do use a Zidoo X8 in my bedroom ... and it just got a major update. I had never even bothered with their "home theater" app before (I'd like to think I check it out and it seemed too clunky to bother using), but with the update I saw that it was now "home theater 2.0" and WOW. It's in the running for best movie interface yet. It does the grouping like Zapiti does, adding drives is a piece of cake, it autoupdates the folders, AND!!!... you can set default subtitles to "external" (which is extremely useful for getting forced subtitles). Not to mention, it's very snazy looking. Solid system if you're looking for a less expensive media player.
javanpohl is offline
post #2578 of 3126 Old 08-01-2019, 11:32 PM
Audio/Video Enthusiast
alexcoluzzi32's Avatar
Quoted: 282 Post(s)
Liked: 223
Hi!
Google "buy UHD friendly drive" or "drives"
Whoops, Googles got some weird caching going on
OK if this gets pulled I'm sorry
https://www.makemkv.com/forum/viewtopic.php?t=17829
Living Room: Xfinity XG1v4-A cable box + Apple TV 4K > Sony HT-ST5000 Atmos/DTS:X Soundbar > Sony XBR-65X900F Television
Office: Oppo UDP-203 + Apple TV 4K > Sony HT-Z9F Atmos/DTS:X Soundbar (with rears) > Sony XBR-55A1E Television
alexcoluzzi32 is offline
post #2579 of 3126 Old 08-01-2019, 11:41 PM
thehun's Avatar
Liked: 1489
Originally Posted by alexcoluzzi32 View Post
Hi!
Yes, you and I had exchanged some email messages already I'm actually waiting some follow up from you. I'm the guy lives up in the No. Bay.... I didn't realize you post here too.
The Hun
thehun is offline
post #2580 of 3126 Old 08-01-2019, 11:45 PM
Quoted: 282 Post(s)
Liked: 223
Hello!
mikela likes this.
