Quoted: 164 Post(s)
Liked: 68
MakeMKV keep getting "Fatal error occurred, program will now exit.......... I uninstalled it and re-installed it, but no luck........
It rips the video, but I get that message after it scrapes the information,, and shows all the files. I get the error, even when I don't have a disk in the drive, and I select preferences.........
Any suggestions??
Edit: Problem solved. Not really sure how I solved this issue, but I kept uninstalling, re-installing several times. I uninstalled using the "uninstall" function from the Windows Control panel, several times, but still did not help. I even ran CCleaner after each uninstall, but that did not help either. Finally, I just deleted the MakeMKV folder from the "C" drive, which is the last drive I installed on. I also deleted the ".MakeMKV" under C > users.
It finally started to work. no idea what I did to get it to work.......... Been awhile since I had used the MakeMKV app, so not sure what caused it to stop working.......
