Spotify Connect - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-01-2018, 01:53 AM - Thread Starter
Liked: 0
Spotify Connect
Hi.
I haver a Denon AVR x1400h receiver with 2 Klipsch RP-280f. I can stream Spotify direct to receiver using Heos or through PS4 Pro.
When I stream from PS4 sounds a lot better! You can really ear the difference!
Is this normal? I've done a google search and most of the people are having poor sound when stream from PS4 after an update.
My sounds great but I wish the same quality from Sportify Connect.
Can anyone help?
Rui Abreu is offline
post #2 of 4 Old 03-01-2018, 08:35 AM
Audioplus93's Avatar
Quoted: 107 Post(s)
Liked: 41
You have the upgraded Spotify Connect account? https://community.spotify.com/t5/Des...l/td-p/1124871
Audioplus93 is offline
post #3 of 4 Old 03-01-2018, 09:06 AM - Thread Starter
Liked: 0
My problem isn't the connection. I don't have any trouble on both devices. Ps4 Pro and Denon AVR Sportify Connect works great.
The only problem is sound quality. Very good from PS4 Pro and not so good direct to AVR.
post #4 of 4 Old 03-01-2018, 09:51 AM
andygiddings's Avatar
Quoted: 118 Post(s)
Liked: 79
Seems like you are not alone https://community.spotify.com/t5/for...d/25355/page/1 - although there are some that state it sounds great and others that recommend Airplay over connect
Room 1 system: Paradigm Reference Active 7.2 system, Anthem AVM50, Oppo BDP-103. Pioneer Elite 610HD. Room 2: Samsung 65HU8550 with SEK3500, Paradigm Monitor 5.1 system, Denon AVR-X2400H, Oppo BDP-203, Nvidia Shield, Apple TV 4k
andygiddings is offline
