Apple TV 4K lacks support for 24.000 video - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 186Likes
post #361 of 459 Old 03-24-2020, 02:17 PM
So final version of tvOS 13.4 is out. As it has the same build number as public beta 6, nothing has changed. Issue not fixed.
There will be no 13.5 right?
So next major update will be tvOS 14?
There are rumors there will be a new kids mode.
I’m so excited.
KingNothing81 is offline
post #362 of 459 Old 03-24-2020, 11:26 PM
djnice77's Avatar
Quoted: 117 Post(s)
Liked: 34
Originally Posted by Otto Pylot View Post
Understood. I looked at the Nvidia Shield and for what we do, it doesn't offer anything more than the ATV4k, aside from the 24p issue, which we don't see. We're not gamers and don't bother with voice control or integration with other devices (don't trust Google or any mfr for that matter). Nvidia is definitely a good streamer, and I will look into it when the time comes, but we're very happy so far with our Apple products and how well they work together (Airplay, etc).
Not only 24p, but proper handling HDR metadata....
djnice77 is offline
post #363 of 459 Old 03-25-2020, 09:31 AM
Otto Pylot's Avatar
Quoted: 3870 Post(s)
Liked: 2765
To be honest, I wouldn't know what "proper handling HDR metadata" means. Everything HDR we've streamed via the ATV4k (DV or HDR10) has look absolutely gorgeous. For me, if I don't see a difference or perceive any issues, then it's fine. No streamer of tv is perfect so I don't go looking for issues. I just enjoy it.
I never trust an atom, they make up everything.
Otto Pylot is online now
post #364 of 459 Old 03-25-2020, 09:34 AM
HD-Master's Avatar
Quoted: 660 Post(s)
Liked: 754
Fixing the 24p issue
Proper HDR metadata handling
Basic audio bitstreaming
These are all things I have given up on them ever addressing.
My 2019 TCL 6-Series QLED R625 Calibrated Settings
HD-Master is offline
post #365 of 459 Old 03-25-2020, 12:18 PM
Manni01's Avatar
Quoted: 5798 Post(s)
Liked: 6251
It's not only the 24p, it's also the 30p [typo corrected] and 60p.
I tried to watch The Irishman on Netflix (24.00 forced to 23.976 by the ATV), and almost every single frame drop was visible. It was unwatchable and very distracting, especially on a big screen.
This is the main reason why I've sent the ATV 4K back at the end of its return window, when I saw that the 24p issue was still not solved in 13.4 beta 6.
I don't like the remote, but I use iRule and the universal remote from my X8500H, so not a dealbreaker for me.
It would be nice to get bitstreaming, but that doesn't really matter for streaming, which is my only use for this box (I use an Oppo 203 and my HTPC for all my disc content).
I'm not sure what the HDR metadata issue is. Please could you elaborate?
Apparently Apple said that the 24p issue was on their to do list and might be solved in TVOS 14, so I'll give the ATV another try in September/October, when the new model will likely launch (according to the latest leaks).
It's a real shame because it's the best streamer out there purely for streaming content if you want Atmos/Dolby Vision and don't need HDR10+.
I tried the Amazon Cube and it only has match frame rate for Amazon Prime, all other content (including Netflix) is forced to 60p. So it went back too...
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
JVC Macro feature on Vertex/Vertex2/Integral2/Maestro
Manni01 is online now
post #366 of 459 Old 03-25-2020, 03:59 PM
meli's Avatar
Quoted: 377 Post(s)
Liked: 131
Originally Posted by Manni01 View Post
....Apparently Apple said that the 24p issue was on their to do list and might be solved in TVOS 14, so I'll give the ATV another try in September/October, when the new model will likely launch (according to the latest leaks)....
I'm new to this topic. Is it believed that this issue could be fixed with a software update? Or does it need a hardware revision?
meli is offline
post #367 of 459 Old 03-25-2020, 04:05 PM
Manni01's Avatar
Liked: 6251
We don't know, it could be a hardware limitation, hence why they said TVOS 14 and not earlier. It is weird that they can't do 24.00 or 30.00 [typo corrected] or 60.00. Whether it's incompetence, carelessness or a hardware issue, I don't know.
We should find out in September/October...
meli likes this.
post #368 of 459 Old 03-25-2020, 04:07 PM
Otto Pylot's Avatar
Liked: 2765
And that is what is confusing to me. I watched The Irishman (in 2 sittings) on my 65C8 and didn't notice any stuttering or frame dropping at all. I guess I'm just not sensitive to it.
post #369 of 459 Old 03-25-2020, 04:19 PM
Manni01's Avatar
Liked: 6251
Have you set auto frame rate to on on the ATV? Are you sure you are displaying 24p and your display isn't converting to 60p?
For example, does your 65C8 have motion flow or similar enabled? If you interpolate the dropped/repeated frame, it might attenuate the effect, but then you have SOE (which you might like).
Is it from Netflix?
On my 88" 16/9 (JVC RS2000) almost every single drop/repeat was visible, due to the number of slow pans / steadicam shots.
I am very sensitive to it, but I can't imagine that anyone would miss such an artifact every 40 secs or so.
I have an HD Fury Maestro, so I know exactly what comes out of the source and gets to the display. The ATV definitely sends 24.00p content at 23.976p. That can't go well.
Here is a screenshot I took from the developer mode in the Amazon Cube that shows the content is mastered in 24.00p (it's not The Irishman but Bird Box, one of the many titles listed here as being 24.00p). I had exactly the same problem with Bird Box on the ATV, 24.00 forced to 23.976=dropped/repeated frames. The Cube wasn't better as ALL content is forced to 60p on the cube (apart from Amazon prime content).
Name:	Cube Netflix native 24.00p content (Bird Box).jpg
post #370 of 459 Old 03-25-2020, 04:28 PM
Otto Pylot's Avatar
Liked: 2765
Is it from Netflix?
On the ATV4k, both Match Dynamic and Frame Rate are enabled. TruMotion (motion interpolation) on the C8 is disabled and Real Cinema is enabled. Streaming service is Netflix Premium.
post #371 of 459 Old 03-25-2020, 04:39 PM
Manni01's Avatar
Liked: 6251
I have no idea then. Maybe you are lucky and are unable to spot these? If that's the case, I envy you
post #372 of 459 Old 03-25-2020, 05:46 PM
mrtickleuk's Avatar
Quoted: 5712 Post(s)
Liked: 8256
I watched The Irishman (in 2 sittings).
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #373 of 459 Old 03-25-2020, 06:08 PM
Otto Pylot's Avatar
Liked: 2765
Originally Posted by mrtickleuk View Post
Yeah, somebody had posted some reasonable stopping points that didn't affect the flow of the story so I opted for the "2 viewing" break instead of the "3 viewing" break I'm too old to sit that long in one spot
post #374 of 459 Old 03-25-2020, 06:10 PM
Otto Pylot's Avatar
Liked: 2765
Maybe it's a combination of my LG OLED and my lack of visual sensitivity to the frame skipping. Whatever the reason, I'm happy. I'm sure it does exist but not for us, my wife hasn't noticed it either .
post #375 of 459 Old 03-25-2020, 11:27 PM
djnice77's Avatar
Quoted: 117 Post(s)
Liked: 34
The correct metadata (MaxCLL/MaxFALL) is important for tone mapping, especially on LG OLEDs and Projectors. The ATV always send 4000/1000 for these values (except iTunes).
The best streamer is the NVidia Shield TV Pro 2019.
djnice77 is offline
post #376 of 459 Old 03-25-2020, 11:52 PM
Andy o's Avatar
Quoted: 43 Post(s)
We don't know, it could be a hardware limitation, hence why they said TVOS 14 and not earlier. It is weird that they can't do 24.00 or 50.00 or 60.00. Whether it's incompetence, carelessness or a hardware issue, I don't know.
Isn't 50p OK? There is no other "50" or "25" like there is 23.976/24.000 or 59.94/60.000. It's always 25.000 and 50.000.
Craig Mecak and JJC1138 like this.
Andy o is offline
post #377 of 459 Old 03-26-2020, 12:27 AM
markus767's Avatar
Quoted: 6019 Post(s)
Liked: 3034
Sold my Shield a while back because NVidia never implemented auto frame rate matching and auto dynamic range matching. Is it now supported? Do apps like Netflix, Prime, Disney+, HBO NOW support it without any user interaction?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #378 of 459 Old 03-26-2020, 12:36 AM
Manni01's Avatar
Liked: 6251
If it's not a problem for you, you should go on enjoying it!
Thanks, I'm familiar with the importance of metadata for tonemapping when you rely on the metadata (which is often incorrect, even when the source sends it properly). I just didn't notice this metadata issue on the ATV because I have an Envy Extreme that does dynamic frame by frame tonemapping with HDR10 content and doesn't need metadata to do so, so I didn't even look at the metadata reported by the Envy or the Maestro while I was evaluating the ATV. At least you know that there is a solution for that issue if Apple doesn't fix it.
I wish I had spotted this HDR metadata issue even if it doesn't apply to me, I would have reported it too. The Dune HD 4K Pro has a similar issue, and that's one of the reasons why I have one in the family room but I use other sources in the cinema room for my disc content (Oppo 203 clone and HTPC with madVR).
I tried to look at the nVidia Shield TV Pro but my understanding is there is no automatic frame rate match, that nVidia has stopped developping it that beta feature and that you have to use an unsupported menu that could go at any time to manually specify the frame rate you think applies (your guess)? If that's the case, it's not acceptable to me.
Also I only need another box for streaming services with Atmos and Dolby Vision (the latter only to run some tests, I don't need DV with an Envy). There are many UK streaming services beyond Netflix and Amazon Prime that I need and I don't think they are all present in the Shield TV Pro (Apple TV+, NowTV, Britbox, Mubi, Disney+, BT Sport). Finally there is no integration that I can see in iRule (IP) or the universal remote of my Denon X8500H (IR. The ATV is supported in both. Lastly, there is no stock for it in the UK, so I can't get a unit to evaluate it. If you don't game and don't need Plex or Kodi, I'm not sure that the Shield Pro is a better option than the ATV, but I'm happy to revise this if any of the above is incorrect.
You are right, I meant 24p, 30p and 60p. I think 25p and 50p are OK. I only tested 24.00p anyway.
post #379 of 459 Old 03-26-2020, 12:50 AM
djnice77's Avatar
Quoted: 117 Post(s)
Liked: 34
Yes, auto dynamic range is on the system level and auto frame rate is fine with the third party Refresh Rate App.
djnice77 is offline
post #380 of 459 Old 03-26-2020, 12:56 AM
markus767's Avatar
Liked: 3034
Is it working reliably? Sounds more like a hack reading the description: https://www.nvidia.com/en-us/geforce...esh-rate-tool/
Markus
post #381 of 459 Old 03-26-2020, 12:56 AM
Manni01's Avatar
Liked: 6251
As per my post above, does the 3rd party refresh app apply the correct frame rate automatically according to content with all the streaming app, or does the user have to select what they think is the correct rate it in a menu?
post #382 of 459 Old 03-26-2020, 01:25 AM
djnice77's Avatar
Quoted: 117 Post(s)
Liked: 34
Automatically, I use it every day.
Manni01 likes this.
djnice77 is offline
post #383 of 459 Old 03-26-2020, 01:26 AM
djnice77's Avatar
Quoted: 117 Post(s)
Liked: 34
"Hack", but works fine.
Keenan likes this.
djnice77 is offline
post #384 of 459 Old 03-26-2020, 01:52 AM
Manni01's Avatar
Liked: 6251
Thanks, but based on the number of issues in the comments, and the fact that if the dev stops supporting the app the feature can disappear with any OS upgrade, it's not very reassuring.
Shame that nVidia dropped the ball on that one.
I might give it a try if I see it in stock in the UK at any point, when I get a confrmation of which streaming services it supports in the UK, as I can't find that list.
Anyway, back to the ATV topic
post #385 of 459 Old 03-26-2020, 02:18 PM
Maybe just a typo but of course ATV can do 50.00Hz ... it can’t do 24./30./60.00Hz.
Yeah ... we all just don’t know. And this makes me crazy.
I know someone called Apple and was told that it’s on their radar and it might get fixed with tvOS14. But I’m sure that’s what the tell many people about a lot of issues: we are aware of it, just wait for the next update. Just the usual support talk.
As I’m in Europe and 24.000fps is way more common here even before Netflix decided to release all of their future original content this way (as it seems), this is a major issue for me for quite some time now. And I know that Apple knew about this even before tvOS13 was out. I told them and others told them. So I had high hopes this would be fixed with tvOS13. But didn’t happen. So I’m pretty sure it won’t happen with tvOS14. At least not on the current model. Because if it’s possible and they do care they would have done it already.
It’s such a shame. For me no other device is so close at being the perfect streamer.
post #386 of 459 Old 03-26-2020, 02:33 PM
Manni01's Avatar
Liked: 6251
Yes, as I've already indicated, it was a typo. I have corrected it to prevent an endless stream of comments
KingNothing81 likes this.
post #387 of 459 Old 03-26-2020, 03:14 PM
Yes, sorry. I forgot to refresh the page before posting so I missed that.
Manni01 likes this.
post #388 of 459 Old 03-26-2020, 04:39 PM
Bacon_67's Avatar
Quoted: 193 Post(s)
Liked: 80
No, and Prime Video, Vudu, Disney+ etc just crash back to the main screen and won’t actually make the switch.
Manni01 likes this.
Bacon_67 is offline
post #389 of 459 Old 03-27-2020, 03:36 AM
Manni01's Avatar
Liked: 6251
Thanks for this confirmation, this is what the many comments in the hack thread seem to suggest as well. A lot of issues and instability, along with no guarantee that the hack will keep working after any OS update.
So no point in testing the Shield Pro, which is great I'm sure if you're a gamer or want to Plex your rips with audio passthrough, but I'm looking for a pure streaming solution with all the channels I need as I use better sources for my disc content and have no interest in the Shield gaming abilities as my HTPC is a better gaming platform.
In the list of channels for the Shield Pro, I can't see NowTV, Britbox, Apple TV+, Mubi and BT Sport which are channels that I want to see supported (especially NowTV and ATV+). And in case anyone wonders, no, I don't want to use another stick just for these.
So back to waiting for a fix for this frame rate match issue in TVOS14 and/or the next ATV model, as it's the only box that fits all my requirements.
In the meantime, back to slumming it in 4K60 with my good old UB900 (no Atmos sadly)...
post #390 of 459 Old 03-27-2020, 03:54 AM
DaveFi's Avatar
Quoted: 967 Post(s)
Liked: 351
You can set the third party refresh tool on the Shield to change resolution/refresh modes on a single remote key press. I do it on my 2017 Shield, works fine. I don’t even use my ATV4k anymore, I’m going to sell it.
mrtickleuk likes this.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
