New Zidoo Z9S and Z10 (RTD1296 SoC) - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
post #1081 of 1713 Old 04-08-2019, 06:52 AM
leonkoum's Avatar
Quoted: 30 Post(s)
"Update: HT2 2.1.9 solved the auto update function."
HT2 2.1.9:
http://apidl.zidoo.tv/app/zidoo_poster_v2.1.9.apk
gymnos and dr4go like this.
Klipsch & Denon always!!!
leonkoum is offline
post #1082 of 1713 Old 04-08-2019, 07:05 AM
Quoted: 32 Post(s)
Liked: 1
HT2 2.1.9:
Thanks a lot for sharing! Strangely I couldn't find this upgrade in the Zidoo Forum.
mrdh68 is offline
post #1083 of 1713 Old 04-08-2019, 10:32 AM
blenky's Avatar
Quoted: 968 Post(s)
Liked: 877
http://forum.zidoo.tv/index.php?thre...16/#post-88319
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #1084 of 1713 Old 04-08-2019, 05:18 PM
rondi's Avatar
Quoted: 69 Post(s)
Liked: 59
Thanks for the reply Whirpool,
Did you mean X9s OK with MKV, but no forced subs---vs Z9s in your first line?
Originally Posted by Whirlpool0548 View Post
Z9s OK with MKV, but no forced subs.
Z9s glitchy HD/UHD blu-Ray menu playback no forced subs, seamless branching still not working, doesn’t handle obfuscated playlists.
JVC RS600, 110"d StudioTek 130, Panny 820 4k Player, Denon AVR-X6500H, 5.2.4 DIY Sound Group speakers, Crown XLS 2502 Sub amp,
rondi is offline
post #1085 of 1713 Old 04-09-2019, 12:32 AM
Quoted: 657 Post(s)
Liked: 159
No, can’t speak at all for the X9S, all my comments relate to the Z9s.
Hopefully another user can comment on Forced Subs on MKV with the X9S, but I suspect it also does not support Forced Subs.
Hope you get some feedback on the X9S, I don’t rate the Z9s because of the issues I mentioned previously.
But some users put up with compromised functionality, because frame rate stutter with 23.976 has been resolved.
Whirlpool0548 is offline
post #1086 of 1713 Old 04-09-2019, 06:47 AM
b curry's Avatar
Quoted: 1032 Post(s)
Liked: 650
Any media players with the RTD 1295/1296 SoC have a problem with forced sub's with MKV rips's. For what ever reason, they do not read the flag. To mitigate this issue, I rip an ISO if the movie has forced sub's and they playback without a problem.
I have the X9S and have held off buying the Z9S because quite frankly, I cannot see any really difference on paper between between the RTD 1295/1296 chip-sets other than the additional I/O's and memory. I prefer to wait for a newer SoC than the RTD 1296 to see if it solves or better address 4K UHD playback.
The X9S with the v2.1.22 firmware is quite stable and plays back correct framerates which many of the other RTD 1295/1296 SoC players have a problem with including Dune HD Pro 4K. As far as I can tell the X9S is equal with the Z9S with regards to UHD 4k playback with an edge to the X9S menu support.
The only title that I had a problem with seamless branching on the X9S was "Incredibles 2". Interestingly, rewinding/resetting to the last chapter and hitting play again resulted in correcting the problem. That was on firmware v2.0.34 for me.
I've had no problems with Bluray HD menus with the X9S. I've also not had a problem with UHD menu's but I only have 2 rips.
I have a Dune HD D1 and a Dune HD Solo. The X9S plays back Bluray HD equally well compared to the Dune's. I would maybe give the Dune's a very slight edge to the Dune's for DVD. I prefer Zidoo's movie scraper over Dune's.
I had a Dune HD Pro 4K and became frustrated with it compared to the X9S as the X9S simply offered better performance. I sold the Dune HD Pro 4K some time ago.
I think the X9S is better from a firmware stand point at this time compared to the Z9S. I do think the Z9S will quickly catch up as Zidoo seems to be very aggressive and responsive to their users. I do believe that there are some problems with the RTD 1295/1296 SoC and or the SDK supplied by RealTek that will simply never be addressed or fixed.
The Z9S is the new and most popular box from Zidoo. That means that you can buy the X9S for less money and in my mind, that makes it something of a bargain. So far, the X9S continues to have good support from Zidoo albeit second place to the Z9S at this point in time.
There is an X9S thread here:
https://www.avsforum.com/forum/39-ne...zidoo-x9s.html
xiaNaix and gymnos like this.
b curry is online now
post #1087 of 1713 Old 04-09-2019, 07:02 AM
goosecat's Avatar
Quoted: 28 Post(s)
Liked: 44
My Z9S running 2.1.40 plays forced subs fine with The Revenant 4k mkv.
I have not tested forced subs with any other mkv's.
goosecat is online now
post #1088 of 1713 Old 04-09-2019, 02:10 PM
mike_carton's Avatar
Liked: 42
How about forced subs in 1080p MKV?
mike_carton is offline
post #1089 of 1713 Old 04-09-2019, 10:46 PM
schumy's Avatar
Quoted: 87 Post(s)
Q re video noise reduction setting (for grainy videos)
I have one Q about picture parameter setting and wonder if you can share your experience -
some movie/video play back looks a bit grainy , is there any setting on the z9s which can provide some noise reduction/smoothing effect?
Many TV and Blu-ray disc players come with such function/setting, but I can't seem to find it on the Zidoo.
Many thanks
schumy is offline
post #1090 of 1713 Old 04-10-2019, 06:44 AM
Nitemage's Avatar
Quoted: 63 Post(s)
Liked: 40
The Z9S has supported forced subtitles in both 1080p and 4k mkvs since January's update. Not sure if forced subtitles are supported in iso's or folders since I only use mkvs.
Nitemage is offline
post #1091 of 1713 Old 04-10-2019, 11:52 AM
deano86's Avatar
Quoted: 644 Post(s)
Liked: 319
Is that with the Zidoo player in addition to the ZDMC(Kodi) player?
deano86 is offline
post #1092 of 1713 Old 04-10-2019, 12:41 PM
Nitemage's Avatar
Quoted: 63 Post(s)
Liked: 40
Yes, it works with their internal Zidoo player. So it works within their HT2 app and since it is the default player in ZDMC, it also works there.
Nitemage is offline
post #1093 of 1713 Old 04-10-2019, 01:55 PM
farsider3000's Avatar
Quoted: 1564 Post(s)
Liked: 946
Some “forced subs” are actually burned into the image like any other computer graphic effect so this may be why Revenant seems to okay ok. I have not had success with any of my 4K rips playing forced subs correctly on the Zidoo X9s.
Sent from my iPhone using Tapatalk Pro
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator subs: One S2, Two RS2, One S1, 2 Seaton Submersive (FOR SALE)
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #1094 of 1713 Old 04-10-2019, 02:00 PM
rondi's Avatar
Quoted: 69 Post(s)
Liked: 59
Why is it so many guys say they don't work with mkv files? @b curry & Whirlpool0548 mentioned it a few days ago in a reply to my post asking about X9s vs Z9s. Others have mentioned it in the past month--do a forum search for "forced subs".
But maybe--you guys who have success have a different way of ripping your BD/UHD discs to mkv--if so please share .
Do you use mkvtoolnix to change some of the parameters?
rondi is offline
post #1095 of 1713 Old 04-10-2019, 02:05 PM
Liked: 946
I have not tried the latest firmwares released over the last few months. I will try it this week and see what I find.
post #1096 of 1713 Old 04-10-2019, 03:09 PM
goosecat's Avatar
Quoted: 28 Post(s)
Liked: 44
makemkv here. With The Revenant, I had to select both english forced subs as I think it didn't work when I only selected one of them. Did not use mkvtoolnix.
post #1097 of 1713 Old 04-10-2019, 03:28 PM
Nitemage's Avatar
Quoted: 63 Post(s)
Liked: 40
I use MakeMkv to rip. Before ripping I remove all subtitles but the English and English[forced] tracks.
Once the MKV is created I then check it with MkvToolNix.
Select the forced subtitle track and check its properties they should be:
Track name: Forced (If it isn't for some reason.)
"Default track" flag: Yes *
"Forced track" flag: Yes *
* I notice that sometimes MakeMkv only sets one of these flags.
If you change any settings then use MKVToolNix to remux the MKV.
Haven't had any rips that don't work. I will check my copy the "Relevant" since it was mentioned.
MOberhardt likes this.
Nitemage is offline
post #1098 of 1713 Old 04-10-2019, 03:32 PM
MOberhardt's Avatar
Quoted: 908 Post(s)
Liked: 567
I use MakeMkv to rip. Before ripping I remove all subtitles but English and English[forced].
BDEdit. Ah nice, I was wondering how to fix an existing one. I do have some that I think with tsmuxer it isn't set properly.
It is a pain - I have some remuxes I've done and I'm actually no longer sure for some which should be the forced sub track - or even if I extracted it or have to go back to the disk and pull it and remux
MOberhardt is online now
post #1099 of 1713 Old 04-10-2019, 04:33 PM
Liked: 42
Obviously, the definition of “working” for forced subs involves the subs appearing without any user action even when all subs are generally off for the movie. So, you’re saying forced subs functionality didn’t work for you.
post #1100 of 1713 Old 04-10-2019, 04:46 PM
Liked: 42
In addition, you’d have to set (in the player) the subtitles to always display; the above by itself would not be sufficient.
But all that does not amount to forced subs working. “Forced subs working” means they display when all the following conditions are met
- the forced flag is on (on a subtitle track)
- the default flag (on the same subtitle track) does not matter
- the player’s “display subtitles” flag is no (or is set to “only forced subtitles” if the player offers that option)
dr4go likes this.
post #1101 of 1713 Old 04-10-2019, 06:03 PM
goosecat's Avatar
Quoted: 28 Post(s)
Liked: 44
I meant that I select both "english forced only" checkboxes on makemkv. This creates a single subtitle track on the mkv.
When I play the mkv on Zidoo, I do need to make sure the subtitle track is selected when I start up the movie. Then the forced subs work as they should - subs off for the whole movie except for non-english forced subs. For me, I define this as "working".
On makemkv, even if I select both English subtitles with both forced only, it still gives me a forced sub only track. I end up with 3 subtitle tracks with the last one being the forced sub only.
The Revenant is the only UHD bluray>mkv that I have tried forced subs with. Maybe it works with other discs, maybe not, I don't know.
post #1102 of 1713 Old 04-10-2019, 06:07 PM
deano86's Avatar
Quoted: 644 Post(s)
Liked: 319
Exactly!... For me and on my X9s....with those parameters, this only works on the Kodi internal player with ZDMC....But that player is obviously very inferior to the Zidoo player which does not recognize the forced flag on my MKV files and automatically play it. That is why I was interested if the Z9s was capable of it.... and it appears it is not...
deano86 is offline
post #1103 of 1713 Old 04-11-2019, 12:21 AM
Quoted: 657 Post(s)
Liked: 159
I agree, there is also still a Forced Subs issue with the Z9s.
The best way is to be sure is to verify if the movie actually does have forced subs.
A good test is the UHD version of ‘The Shape of Water’. (Forced Subs for Russian dialogue)
This definitely has forced subs. Last time I tried it didn’t work on the Z9s.
A good Forced Subs HD blu-Ray test is Jack Ryan Shadow Recruit at 19:33, speaks Russian. It also wasn’t fixed last time I tried it.
Any latest feedback welcome, It could be fixed but I doubt it.
(Should have mentioned, playback from BDMV folders).
post #1104 of 1713 Old 04-11-2019, 04:32 AM
Liked: 946
Or is it only an issue with Russian forced subs? The conspiracy theory takes shape
post #1105 of 1713 Old 04-13-2019, 02:11 PM
Quoted: 44 Post(s)
Solution To Windows 10 Seeing NAS On Z9S
Originally Posted by savage01 View Post
Greetings all. Two questions with the Z9S: (1) In win 10 I can see the Z9S in the network but receive a message 'windows is unable to connect' when I click on the network Z9S (or try to expand it) so I can't map the usb HDD shares. I am able to see the network shares (and map the shares) in win 7. Is there something which needs to be set up in win 10?
Hi folks. I finally found a solution to map/connect the connected NAS usb shares on the Z9S from windows 10 explorer. Below is a link to another forum. Scroll down and watch the first portion of the video regarding Samba. Hope this helps!
http://forum.zidoo.tv/index.php?thre...on.3603/page-3
gymnos likes this.
savage01 is offline
post #1106 of 1713 Old 04-17-2019, 11:56 PM
markswift2003's Avatar
Quoted: 746 Post(s)
Liked: 507
Zidoo Z1000
Here's interesting...
https://www.zidoo.tv/Product/index/model/Z1000/target/WHvkmmOxFORKKmVViAFMcQ%3D%3D.html
Briguy65, gymnos and dr4go like this.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #1107 of 1713 Old 04-18-2019, 12:15 AM
Liked: 0
[link to z1000, below 5 posts]
Thanks, interesting but still the 1296, which I might entirely skip (currently on X9S).
dr4go is online now
post #1108 of 1713 Old 04-18-2019, 12:53 AM
Quoted: 657 Post(s)
Liked: 159
Also, might be worth them fixing the missing/broken functionality on the Z9s first.
dr4go likes this.
post #1109 of 1713 Old 04-18-2019, 02:05 AM
Briguy65's Avatar
Quoted: 103 Post(s)
Liked: 67
I like how it looks -- it reminds me a lot of my Egreat A10, which while decent, seems to have stopped development and stuck on Android 5.11. This could be a nice replacement, we'll just have to see
dr4go likes this.
Briguy65 is offline
post #1110 of 1713 Old 04-18-2019, 04:29 AM
b curry's Avatar
Liked: 650
Sure is pretty...
Looks like Zidoo is staying busy. If they can achieve all of the advertised operations aka firmware/software features, they will sell a lot of the Z1000's.
gymnos likes this.
