New Zidoo Z9S and Z10 (RTD1296 SoC) - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 612Likes
post #1201 of 2038 Old 05-20-2019, 02:21 AM
markswift2003's Avatar
Quoted: 900 Post(s)
Liked: 623
Originally Posted by mike_carton View Post
....Now if they support external scraper files without needing to rename files...
How do you mean?
Zidoo Z9S | Dune Pro 4K | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #1202 of 2038 Old 05-20-2019, 06:38 AM
b curry's Avatar
Quoted: 1141 Post(s)
Liked: 737
Originally Posted by Whirlpool0548 View Post
Try Incredibles2 Blu-Ray, which comprises many m2ts files and is problematic from the start.
Thor Ragnarok Blu-Ray, e.g where the dragon is chasing and about to catch Thor near the start of the movie. There are other seamless branch points in that movie.
Can’t see it why it would be any better on the Z1000, Zidoo Just haven’t got a handle on this issue.
Originally Posted by jwort93 View Post
I have seamless branching issues with Incredibles 2 when playing back via the full disc menu, but if I tell the Zidoo just to playback the main title, it plays without issue. Is that what you notice as well?
From my view point, Incredibles 2 is simply a problematic title, period. I've had problems with it even on a Dune HD Solo, Bluray full ISO and MKV. The only unit that has worked with out problems for me with that title has been an MKV on an Oppo.
However, after re-starting it as a full ISO several times on a Zidoo X9S it seems to work fine now.
b curry is offline
post #1203 of 2038 Old 05-20-2019, 07:25 AM
mike_carton's Avatar
Liked: 42
Originally Posted by markswift2003 View Post
How do you mean?
regarding my comment earlier: "....Now if they support external scraper files without needing to rename files..."
Can it use files created by YADIS or ThumbGen for the movie wall (Mede8er and Dune support this) or does one need to use built-in scraper?
mike_carton is offline
post #1204 of 2038 Old 05-20-2019, 07:59 AM
Quoted: 900 Post(s)
Liked: 623
I've always been very dubious of internal scrapers - I like to do it all myself externally if possible. To the extent that I decompiled yaDis and added options for HEVC, Atmos, DTX-X, HDR, UHD-BD etc on the drop-down list boxes to bring it all up to date, but I have to say that the scraper on the Zidoo is the best I've seen and if it gets things wrong or you don't like the cover etc, it's very easy to amend.
That said, you can use Kodi nfo files for the metadata and artwork I you like (unfortunately not yaDis or Thumbgen) - so you can use a program such as Tiny Media Manager (https://www.tinymediamanager.org/download/) to create the nfo, poster and fanart and have the Zidoo use that rather than its own scrapes.
But as I say, I haven't felt the need; And I'm a fussy bugger!
post #1205 of 2038 Old 05-20-2019, 08:19 AM
Liked: 42
Thank you. I'm similar. I got source code for ThumbGen and have been updating it. It can generate different kinds of files. One profile can create Mede8er files, another Dune files etc.
On a different note: Does the built-in scraper get details like MKV, 3D, 4K by itself (or using mediainfo behind the scenes) or do those features need to be indicated by explicitly naming the MKV file?
post #1206 of 2038 Old 05-20-2019, 09:08 AM
indieke2's Avatar
Quoted: 81 Post(s)
I have a stupid question. I have a concert in classic dvd structure. It will not play with menu or I do something wrong. it not shows on the video wall, as it is a concert. If I use th Vts files I have to do them one by one. But probably thee is a way around.
I like my HT, wine and pretty girls. But...am I the only one
indieke2 is offline
post #1207 of 2038 Old 05-20-2019, 09:38 AM
Quoted: 900 Post(s)
Liked: 623
Bizarrely, although the box uses mediaInfo, it is not employed during the scrape for some reason. Once a file has been played however, those details populate.
This can also be invoked by naming as well - there are a few posts detaining this back in the thread, but I must admit I don't bother.
I've never used Thumbgen, but as you have the source, it might be a nice project to get it to export a Kodi nfo file, poster and fanart for the box...
Just a memory from the dim and distant past - doesn't Thumbgen export XBMC files? Maybe it already does it??
post #1208 of 2038 Old 05-20-2019, 10:28 AM
Quoted: 900 Post(s)
Liked: 623
Stretching my memory a bit here, but try playing <VIDEO_TS.IFO>
post #1209 of 2038 Old 05-20-2019, 10:55 AM
indieke2's Avatar
Quoted: 81 Post(s)
Yes on computer, but it not work on the player.....
indieke2 is offline
post #1210 of 2038 Old 05-20-2019, 11:24 AM
Quoted: 900 Post(s)
Liked: 623
Might sound odd, but navigate to where the containing directory is - ie the one that has VIDEO_TS & AUDIO_TS inside it.
Highlight the containing folder, press menu and select <Open With> then <View Poster>. This should trigger a scrape and might or might not find the correct metadata, but whatever it finds, it should allow you then to play it by pressing <enter> as you would from HT2.
I've never tried playing a DVD though, so no idea whether it actually works!
post #1211 of 2038 Old 05-20-2019, 11:51 AM
Quoted: 900 Post(s)
Liked: 623
No mention of any UHD menu changes, but according to the changelog for v2.2.65 we will be able to use the Z9S as a kitchen appliance now...
(from the Russian forums)
Version number: v2.2.65
System
1. Optimize the seamless playback of the meat sauce dish
2. Fixed more than 32 subtitles not displayed.
3. Increase the plug-in subtitle support
4. Fix the problem that the indicator light does not light after hibernation
5. Add a one-click root function
5. Optimize system stability
Poster wall
1. Optimize the source to choose "Douban" can not get data problems
2. Optimize the matching degree
3. Optimize stability
RS232
1. Fix the problem that the "pause play" command does not take effect
2. Fix the problem that the "play mode" command does not take effect.
3. Add the "Play" command (#PLU)
HDMI IN
1. Fix the problem that the reservation recording interface is open abnormally.
File manager
1. Fix some hard disk does not display the volume label problem
2. Add local m3u8 as a video file
Player
1. When the automatic frame rate is turned on, 1080P29 switches to 1080P30.
2. Automatically load manually added subtitles
3. Optimize playback stability
dr4go likes this.
post #1212 of 2038 Old 05-20-2019, 12:04 PM
Quoted: 692 Post(s)
Liked: 167
That's all OK then, if at first it doesn't work, try it again. Oh also try that for Venom 4k that seems to get a few false starts too, sometimes you get the trailer, sometimes it starts at chapter 2 of the movie, sometimes (if you are lucky) it plays OK. (on the Z9S).
The Pro 4k plays both with no issues - Blu-ray menu, BDMV folders. (Oh both also play fine on the Oppo 203).
Incredibles2 is not a problematic title.
The Z9s is a problematic player when it comes to handling seamless branching and Incredibles2 is an excellent test.
Whirlpool0548 is offline
post #1213 of 2038 Old 05-20-2019, 12:12 PM
blenky's Avatar
Quoted: 1006 Post(s)
Liked: 931
System
Poster wall
RS232
HDMI IN
File manager
Player
I take it " 1. Optimize the seamless playback of the meat sauce dish" is a translation issue!
dr4go likes this.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is online now
post #1214 of 2038 Old 05-20-2019, 12:15 PM
blenky's Avatar
Liked: 931
I agree and have used quite a few over the year. The one BIG frustration for me is that you can't separate videos by type - that is Movie or TV. I keep asking them but to date its fallen on deaf ears.
post #1215 of 2038 Old 05-20-2019, 12:17 PM
Quoted: 900 Post(s)
Liked: 623
I think it sounds rather nice!
post #1216 of 2038 Old 05-20-2019, 12:19 PM
Quoted: 900 Post(s)
Liked: 623
The one thing you learn with these devices is it's horses for courses - I use the Dune for 2K, the Zidoo for 4K and a Mede8er for TV (with TVRename as a scraper).
post #1217 of 2038 Old 05-20-2019, 12:22 PM
blenky's Avatar
Liked: 931
True - I was hoping after all this time to have a one box solution. But similar I use Zidoo for most things but use the Dune if I need forced subs or have issues on Zidoo. Use the ATV for Netflix\Amazon\iPlayer.
post #1218 of 2038 Old 05-20-2019, 12:28 PM
Quoted: 900 Post(s)
Liked: 623
To be honest with all the streaming services these days, ripping TV stuff is becoming less of an issue and more transient so I've started to just navigate to directories with either the Dune or the Zidoo to play TV shows and not worry about the niceties of metadata, posters etc.
And yes, I forgot - I use an Amazon Fire TV for Netflix, Amazon et al.
post #1219 of 2038 Old 05-20-2019, 01:14 PM
Quoted: 692 Post(s)
Liked: 167
The other thing you learn about these devices is that if you put up with second best then you end up with a hotch potch of devices, because you made some poor choices.
post #1220 of 2038 Old 05-20-2019, 01:16 PM
Liked: 42
Why not Mede8er for 2K?
post #1221 of 2038 Old 05-20-2019, 01:21 PM
b curry's Avatar
Liked: 737
It maybe an excellent test... But the Bluray ISO doesn't work on my Dune Solo.
I don't use BDMV.
As I said, it works on Oppo's.
b curry is offline
post #1222 of 2038 Old 05-20-2019, 01:30 PM
Quoted: 900 Post(s)
Liked: 623
I love the Dune Shell - their skin implementation is extremely powerful which lets me change the look and feel to my liking - one thing I dislike is the "My First Media Player" look a lot of these players seem to have.
The Med was and still is a great product, and I created a half decent skin for that, but the Dune Shell is much more adaptive and on a completely different level for customisation.
I knew I knew your name from somewhere - I used to spend a lot of time on the Med forums
post #1223 of 2038 Old 05-20-2019, 01:48 PM
johng's Avatar
Quoted: 258 Post(s)
Liked: 120
There was a known issue on the previous version, v2.2.56 which was:
"Known issue : HT2 unable to scan local devices, please install the below version."
So it only affected local scans and was addressed with a separate upgrade to HT2.
However, this issue was fixed in later firmware and v2.2.61 includes the fix, so you're good to go.
Thank you, Mark.
markswift2003 likes this.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #1224 of 2038 Old 05-20-2019, 05:37 PM
blenky's Avatar
Liked: 931
What customisation? I must be missing something.
post #1225 of 2038 Old 05-21-2019, 12:24 AM
Quoted: 900 Post(s)
Liked: 623
Skin customisation - you can pretty much change anything you like using a combination of graphics, .properties files which define positioning, size etc and an xml file.
The same goes for yaDis so you can tailor the two together so it all works together seamlessly.
This page hasn't been updated since the days or yore, but it gives a very basic overview:
https://dune-hd.com/firmware/skins/
post #1226 of 2038 Old 05-21-2019, 12:25 AM
Quoted: 900 Post(s)
Liked: 623
Just realised we're on the Zidoo forum
Oops.
post #1227 of 2038 Old 05-21-2019, 01:52 AM
Quoted: 692 Post(s)
Liked: 167
Oops.
And strangely enough the Z9s still has issues with seamless branching, forced subs and glitchy blu-Ray menu playback.
post #1228 of 2038 Old 05-21-2019, 02:55 AM
blenky's Avatar
Liked: 931
Oops. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Blimey I missed that as well!
And you will never let us forget &#x1f609;
post #1229 of 2038 Old 05-21-2019, 06:28 AM
b curry's Avatar
Liked: 737
And even stranger is your continuous repetition of this mantra.
It seems to have become a kind of Gregorian Chant for you triggered by the word "Zidoo" at which point you seamlessly branch to your mantra ...
mikela and jherring69 like this.
b curry is offline
post #1230 of 2038 Old 05-21-2019, 06:38 AM
Quoted: 692 Post(s)
Liked: 167
Matching markswift and his moaning on about stutter.
