New Zidoo Z9S and Z10 (RTD1296 SoC) - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 517Likes
post #1561 of 1761 Old 07-25-2019, 08:27 AM
coolgeek's Avatar
Quoted: 1736 Post(s)
Liked: 955
Originally Posted by Whirlpool0548 View Post
Dune Pro 4K, none of the issues that the Z9s with glitchy menu playback from BDMV folders, handles seamless branching and forced subs.
The Z9s plays MKVs OK. Seamless branching handling has taken a step backwards with the latest firmware.
What is seamless branching?
I noticed that when I was watching some movies from the hard disk, it sometimes just stopped, loses the connection to the hard disk.. is this what you're talking about?
coolgeek is offline
post #1562 of 1761 Old 07-25-2019, 01:18 PM
MOberhardt's Avatar
Quoted: 956 Post(s)
Liked: 665
Originally Posted by coolgeek View Post
Last week my Zidoo pop up a message to install the latest firmware.. i am not sure if this was it.. i then clicked ok.. it then hanged halfway with the robot picture.. i left it there for something like 40 hours.. it's still hanging with the same robot image... then i just power off and power on.. it seems to be able to work.. i am not sure if something is wrong with the update now...
Should I re-install the firmware?
Yeah it is idiotic. I had to power cycle mine a couple of times after this. That message does nothing. When it restarted it then straight installed.
I'd never try network upgrade again. I'll USB it...
MOberhardt is online now
post #1563 of 1761 Old 07-25-2019, 04:10 PM
Quoted: 661 Post(s)
Liked: 161
Some movies comprise a varying number of m2ts files. The movie’s playlist dictates the order in which the files are played. Currently the Z9s pauses at each m2ts file transition. The Z9s has always had a problem handling these transitions, but the latest firmware has taken a step backwards earlier versions of the firmware handled the transition with a glitch but carried on playing. The Dune Pro 4K handles seamless branching with no issues.
If you want to stick with the Z9s your only option is to create an mkv file of the movie, which in the process merges the transitions.
Whirlpool0548 is offline
post #1564 of 1761 Old 07-25-2019, 05:49 PM
MOberhardt's Avatar
Quoted: 956 Post(s)
Liked: 665
Anyone know the best way then to convert a 3d Blu Ray iso to a 3d mkv then? Most of my library is 3d Blu Rays I've remuxed Atmos into. I have been using ISO.
post #1565 of 1761 Old 07-26-2019, 06:40 AM
coolgeek's Avatar
Liked: 955
I have lots of 3D in ISO and have never noticed the branching problem so far...
The only thing that happens a lot is every now and then any movie i play will just stop, and it loses the connection to the hard disk.. it's like the hard disk stopped or got disconnected.. then i have to replay it after the hard disk re-appear...
MOberhardt likes this.
coolgeek is offline
post #1566 of 1761 Old 07-26-2019, 07:20 AM
deano86's Avatar
Quoted: 647 Post(s)
Liked: 319
Why wouldn't you just open the file with MakeMKV and convert it then? Does it not work? And why convert? I have no problem with the ISOs (albeit, relatively few) I have....
deano86 is offline
post #1567 of 1761 Old 07-26-2019, 08:15 AM
rondi's Avatar
Quoted: 69 Post(s)
Liked: 59
TRY connecting to the USB2 instead of USB3--sometimes USB3 is known to have problems--if it is powered from the USB3 vs it's own separate power.
JVC RS600, 110"d StudioTek 130, Panny 820 4k Player, Denon AVR-X6500H, 5.2.4 DIY Sound Group speakers, Crown XLS 2502 Sub amp,
rondi is offline
post #1568 of 1761 Old 07-26-2019, 08:57 AM
coolgeek's Avatar
Liked: 955
Hmm... i haven't tried that. I always thought USB 3 is better than USB 2....
But now that I think about it, after connecting to the SATA cables directly I am not sure if this occurred... i'll have to monitor it now...
Another question. After the latest firmware update, some of my 4K HDR demo that I downloaded (those that they use to demo 4K tvs), causes the player to hang now... it seems less stable after the update...
coolgeek is offline
post #1569 of 1761 Old 07-26-2019, 09:27 AM
Quoted: 14 Post(s)
Liked: 2
would the dune 4k be recommended over the z9s, i am currently using a dune smart d1 for 1080, I would like to gain 3d iso.
a little late to the party, but trying to do my research between the 2, love the D1, has always just worked
(i also have a ps3 i can stream 3d iso with, and a ps4 also. )
thanks much for the time.
JS racer is offline
post #1570 of 1761 Old 07-26-2019, 01:59 PM
MOberhardt's Avatar
Quoted: 956 Post(s)
Liked: 665
I'm not sure. I've tried it and aside from it not selecting the two video tracks, the output looks odd, when I open the mkv in media info or remuxed. Like the stream flags are wrong.
post #1571 of 1761 Old 07-26-2019, 02:12 PM
deano86's Avatar
Quoted: 647 Post(s)
Liked: 319
MakeMKV should open up your ISO, just like opening up any other disc.... and, when MakeMKV opens any 3D title, you always have to manually select the MVC stream in addition to the regular video stream for it to create a 3D MKV... what does Mediainfo say about your created mkv 3d file? If it shows that the base stream is "right eye first" then that title would be one of the rare swapped eye view titles and the only thing I could think of that would explain the output looking odd....
But, to be honest, I have always used MKV for my 3D titles, so I will have to test it on a 3D ISO and see for myself I guess....
deano86 is offline
post #1572 of 1761 Old 07-27-2019, 08:14 AM
rondi's Avatar
Quoted: 69 Post(s)
Liked: 59
But now that I think about it, after connecting to the SATA cables directly I am not sure if this occurred... i'll have to monitor it now.....
more info regarding USB3 problems:
http://forum.zidoo.tv/index.php?thre...3-issue.49348/
btw, mirror is the "official" zidoo person on that forum.
rondi is offline
post #1573 of 1761 Old 07-27-2019, 06:52 PM
Kerberos's Avatar
Quoted: 16 Post(s)
specs wise yes but for uhd contents, usb 2 will provide enough bandwidth anyway
Kerberos is offline
post #1574 of 1761 Old 07-28-2019, 12:05 AM
Liked: 1
Hi How do you do this? "also have a ps3 i can stream 3d iso with"
Ray Mondo is offline
post #1575 of 1761 Old 07-28-2019, 04:48 AM
MOberhardt's Avatar
Quoted: 956 Post(s)
Liked: 665
Yeah, that has me interested also.
post #1576 of 1761 Old 07-28-2019, 03:06 PM
Quoted: 14 Post(s)
Liked: 2
I have a different firmware on my ps3, and run an app on my pc,
JS racer is offline
post #1577 of 1761 Old 07-28-2019, 11:03 PM
Quoted: 24 Post(s)
Liked: 1
My Z9S is working great these days. Did the update online, had no issues. Originally I had 3 USB-3 external drives connected via a USB splitter (3.0), but found the movies would sometimes stop partway through which was annoying. I switched out the splitter and that fixed the issue with the movies cutting out. I have since replaced all three drives with a 5 bay RAID-5, which has much faster output than the standalone drives had, and it has been working fantastic. All glitches gone.
drakorice is offline
post #1578 of 1761 Old 07-29-2019, 01:42 AM
coolgeek's Avatar
Liked: 955
Happened again, this time on USB 2. Though prob not as frequently.
coolgeek is offline
post #1579 of 1761 Old 07-29-2019, 05:37 AM
Liked: 1
Hi can you pm me how please Thx.
post #1580 of 1761 Old 07-30-2019, 03:06 AM
indieke2's Avatar
Quoted: 81 Post(s)
Can somebody tell me how to use the Z 9 as a audio player too? I have a lot of issues with it. it scanned all my music files, the audioplayer 5, but sometimes only 1 song per album is showed.
I can use the app and filebrowser, to select so ok. But how do I play my SACD and 192-96 hz files? If I put usb on, will not play (maybe change in setting?)
I also tried the Hiby player, I installed from APK, latest version. But Hiby always crashes, is very annoying. I open it it say something about remote and then same image stays on.
So if somebody knows a configuration to play all audio files well. I never use Kodi, because not like it.
I like my HT, wine and pretty girls. But...am I the only one
indieke2 is offline
post #1581 of 1761 Old 08-09-2019, 08:27 PM
CalJake's Avatar
Quoted: 57 Post(s)
Liked: 30
I'd actually like to know this too.
CalJake is offline
post #1582 of 1761 Old 09-02-2019, 08:07 AM
BillZ's Avatar
Quoted: 33 Post(s)
Liked: 24
Bought it...Now what?
OK, so I purchased the Z10 a few months ago and I am finally getting around to playing with it. Silly me, I thought I was just plugging this in and all would be there. So how do I get this item up and running? (ie. Automatic Poster Wall). Am I just installing Kodi? What else? Any Z10 for Idiots guide out there?
Or maybe I am just missing something. Seems the older I get, the more I miss...
My nephew has HDADD. High Definition Attention Deficit Disorder. He can barely pay attention, but when he does, it's unbelievably clear!
Steven Wright
BillZ is offline
post #1583 of 1761 Old 09-03-2019, 11:15 PM
Scott KL's Avatar
Quoted: 40 Post(s)
I don't have the Z10 but the Z9S but I'm sure are very similar. Have you tried the user manual and help forums?
http://apidl.zidoo.tv/instruction/Z1...anual_v1.4.pdf
http://forum.zidoo.tv/index.php?forums/zidoo-z10.53/
There is a a browser function where you can open files from attached HDD or NAS or for the poster art, the home theater app on the home page. Open this and add source and if you are already connected to the internet (set up wi-fi first) the poster art will automatically be added. I don't use Kodi but there are links in the forum to set this up. Zidoo have their own Kodi fork called ZDMC. https://www.zidoo.tv/Support/release_apk.html
Hope this helps.
BillZ likes this.
JVC DLA-N7 | Screen Research ClearPix 4K 130" 2.40 | Pioneer VSX-LX503 | Crown DCi 8|300N | 7.2.4 JBL 708i(3)+705i(4); JBL Control 328C (Atmos); Subwoofer Syzygy SLF-870 x 2 | Ferco seating
Scott KL is offline
post #1584 of 1761 Old 09-04-2019, 05:54 PM
BillZ's Avatar
Quoted: 33 Post(s)
Liked: 24
Hope this helps.
Yes, I had found that manual but it is really useless as far as getting started though. I will be spending some time in the forums for sure. Thanks for the info!
Steven Wright
BillZ is offline
post #1585 of 1761 Old 09-13-2019, 04:35 PM
b curry's Avatar
Quoted: 1046 Post(s)
Liked: 657
New firmware up v2.2.91
Link: ZIDOO_Z9S_N_v2.2.91_201909101723_OTA
http://forum.zidoo.tv/index.php?thre...release.50709/
b curry is online now
post #1586 of 1761 Old 09-14-2019, 05:36 AM
blenky's Avatar
Quoted: 982 Post(s)
Liked: 887
Don't bother unless there is something specific on the change log you want. Otherwise this is once again a release with a long list of 'things' but does not address any of the main concerns with this device.
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Samsung UBD-K8500 UHD Player
blenky is offline
post #1587 of 1761 Old 09-14-2019, 06:20 AM
Quoted: 661 Post(s)
Liked: 161
Maybe it’s time to give up on the Z9S, unless you only play MKVs.
The changelog fails to mention any of the remaining significant issues with this player.
post #1588 of 1761 Old 09-15-2019, 12:45 PM
leonkoum's Avatar
Quoted: 30 Post(s)
To 'give up' to buy 'What'?
Klipsch & Denon always!!!
leonkoum is offline
post #1589 of 1761 Old 09-15-2019, 04:10 PM
Quoted: 661 Post(s)
Liked: 161
The Dune Pro 4K plays BDMV folders flawlessly, handles forced subs, seamless branching and obfuscated playlists, but has the framerate stutter issue(if that’s a problem for you).
The Z9S struggles with BDMV folder playback, but is an OK MKV player.
Dune are actively working to resolve the framerate issue.
If they solve it, the Pro 4K will offer the better solution for BDMV folder playback.
post #1590 of 1761 Old 09-15-2019, 08:00 PM
Guz911's Avatar
Quoted: 18 Post(s)
You can consider the oppo 203 clone. It plays bluray menus like the original.
S/W: LightSpace HTL, CalMAN Home for LG
P/G: DVDO AVLab TPG, VideoForge Pro
Meters: i1PRO2, SpectraCAL C6 HDR2000
TV: LG Oled 65 c8, chinoppo udp-203, himedia q10 pro
AVR: Denon x-4500 5.1.4, SVS Prime Satellite 5.1, RSL C34E
Guz911 is online now
