New Zidoo Z9S and Z10 (RTD1296 SoC) - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
post #1591 of 1713 Old 09-16-2019, 12:32 AM
silver-eye's Avatar
Quoted: 179 Post(s)
Liked: 118
Originally Posted by Guz911 View Post
You can consider the oppo 203 clone. It plays bluray menus like the original.
Out of curiosity, what's the name of the oppo 203 clone?
silver-eye is offline
post #1592 of 1713 Old 09-16-2019, 05:47 AM
Guz911's Avatar
Quoted: 18 Post(s)
Google m9702.
silver-eye and dr4go like this.
S/W: LightSpace HTL, CalMAN Home for LG
P/G: DVDO AVLab TPG, VideoForge Pro
Meters: i1PRO2, SpectraCAL C6 HDR2000
TV: LG Oled 65 c8, chinoppo udp-203, himedia q10 pro
AVR: Denon x-4500 5.1.4, SVS Prime Satellite 5.1, RSL C34E
Guz911 is online now
post #1593 of 1713 Old 09-16-2019, 06:01 AM
silver-eye's Avatar
Quoted: 179 Post(s)
Liked: 118
thanks!
post #1594 of 1713 Old 09-16-2019, 09:34 AM
karipu's Avatar
Liked: 0
The problem:
Zidoo does not approve my iMacs SMB shared folder username and password.
However I'm sure the username and password are correct.
Is this known bug in media players/android boxes?
Is there a solution?
karipu is offline
post #1595 of 1713 Old 09-16-2019, 10:57 AM
coolgeek's Avatar
Quoted: 1734 Post(s)
Liked: 953
Google m9702.
Does it play 3D ISO?
coolgeek is online now
post #1596 of 1713 Old 09-16-2019, 12:05 PM
Guz911's Avatar
Quoted: 18 Post(s)
Yes it plays everything exactly like the original oppo. It comes with the latest firmware.
post #1597 of 1713 Old 09-16-2019, 03:16 PM
indieke2's Avatar
Quoted: 81 Post(s)
Since I installed the V2.2.82 firmware, the player is unstable. Tired of it. It freezes a lot. It works after rebooting the advice, but the crashes are more and more frequent. Does anybody has same problems and what can I do about it?
I like my HT, wine and pretty girls. But...am I the only one
indieke2 is offline
post #1598 of 1713 Old 09-17-2019, 01:14 AM
Quoted: 657 Post(s)
Liked: 159
http://forum.zidoo.tv/index.php?thre...-proved.49461/
You could try checking out the above link.
Looks like this version has issues, there are suggestions for reverting to a good version 2.2.61
It looks like 2.2.82 went backwards, missing out an earlier fix for seamless branching.
It looks like the developers have poor version control and apply firmware updates on top of earlier versions of the firmware. Maybe there’s more than one set of developers, not coordinating their activities.
I think the Z9s is in the doldrums.
MOberhardt likes this.
Whirlpool0548 is online now
post #1599 of 1713 Old 09-17-2019, 10:57 PM
MOberhardt's Avatar
Quoted: 906 Post(s)
Liked: 562
Yes, I haven't tried the latest firmware, but I did make the mistake of loading the one before it. Before that I didn't have any problems with single movie iso's I'd created (playlist with multi m2ts files) but after the prior update, I'd get jerks. I really prefer iso for 3D as I can always burn to a disc properly. I should figure out the prior firmware version and see if I could downgrade it.
MOberhardt is offline
post #1600 of 1713 Old 09-18-2019, 01:11 AM
Quoted: 657 Post(s)
Liked: 159
There may be a firmware version that minimises multi m2ts playback issues, it depends what you are prepared to live with, but there hasn’t yet been a Z9s firmware version that plays every title containing multi m2ts files flawlessly.
So, it looks like 2.2.82 still hasn’t fixed the multi m2ts file playback issues - Wow
A real disappointment, it has to be said.
post #1601 of 1713 Old 09-20-2019, 04:00 AM
Liked: 6
About HDR to SDR BT2020, I'm going to do some tests during this weekend.
I have JVC X5500: have I to choose everything in "auto" on Zidoo Z9s except HDR mode, right?
And about JVC, what kind of signal I'll get? It will switch to HDR mode or it has to remain in SDR?
And have I to select manually BT2020 gamma?
If you have settings to share, it will be really appreciated.
Thanks a lot.
Marsell
Gengis Marsell is offline
post #1602 of 1713 Old 09-20-2019, 06:46 AM
markswift2003's Avatar
Quoted: 744 Post(s)
Liked: 504
Thanks a lot.
Marsell
I'd recommend discrete video settings rather than auto.
Nothing wrong with auto per se, but I always think it best to take the guesswork out of it, particularly with a projector.
If you want to try that, set the following:
Display
HDMI mode: 3840x2160p 23Hz
Color settings/Deep Color Mode: Priority 10bit
Color settings/Color Space Mode: Priority YCbCr 444
Color settings/HDMI Range Mode: 16:235
HDR to SDR/Gamma: Bright (personal preference here)
HDR: SDR Rec.2020
Then create a custom picture mode on the PJ with Standard Gamma and BT.2020 colour and you're good to go.
When the Zidoo recognises an HDR presentation, it will switch from standard Rec.709 to SDR.2020.
The projector will not auto switch into HDR since it's an SDR signal, so you'll manually have to switch to your new custom picture mode.
If you're feeling adventurous, an HDFury Vertex can be used to automate the process...
dr4go likes this.
Zidoo Z9S | Dune Pro 4K | HDFury Vertex | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #1603 of 1713 Old 09-20-2019, 08:49 AM
Liked: 6
Talking
Thank you so much Mark.
I suppose you intended to say "it will switch from standard Rec.2020 to SDR.2020."
So, now I have the answer that the short test I did on Monday was not good because I got HDR signal to projector also if It was on SDR.2020 the Zidoo (but I have a lot of other settings not in auto mode so I'll try to figure out which one cause the mess).
Moreover I needed to add +40 on contrast and -30 on brightness to get a good image (but with a little white crash on the clouds of a sky) so I don't think I'm in the right way
I'll keep the community updated...can be useful for all users with Zidoo+prj
post #1604 of 1713 Old 09-20-2019, 11:21 AM
Guz911's Avatar
Quoted: 18 Post(s)
If you change contrast or brightness it makes the zidoo display wrong colors. I checked its output and it was bit perfect for colorchecker only with default values in picture settings.
post #1605 of 1713 Old 09-20-2019, 11:39 AM
Quoted: 744 Post(s)
Liked: 504
No - when the Zidoo is set to "SDR Rec.2020", the menus etc are still presented in Rec.709. When an HDR video is played, the Zidoo switches from standard gamma Rec.709 to standard gamma BT.2020 (commonly, but technically incorrectly, referred to as SDR.2020).
Also, if a Rec.709 SDR video is played the Zidoo will remain in Rec.709, standard gamma.
So basically, when applied to HDR video, "SDR Rec.2020" converts the PQ gamma to a power gamma but retains the BT.2020 colour space.
Once you have it nailed, you shouldn't have to touch brightness or contrast, doing so only messes up black level (brightness) and white level (contrast).
post #1606 of 1713 Old 09-20-2019, 11:41 AM
Quoted: 744 Post(s)
Liked: 504
Contrast and brightness have nothing to do with colour - contrast adjusts luminance white level and brightness adjusts luminance black level.
post #1607 of 1713 Old 09-20-2019, 11:49 AM
Guz911's Avatar
Quoted: 18 Post(s)
That’s what I also thought when I fiddled with those settings believing as you correctly say and which applies to how the contrast and brightness controls work for a TV. However I used the colorchecker function of a DVDO Avlab TPG to check the digital color output of the zidoo and in order to get correct color output I had to reset both contrast and brightness.
Those controls definetly messes up the greyscale not sure if they affect the colors.
post #1608 of 1713 Old 09-20-2019, 12:22 PM
Quoted: 744 Post(s)
Liked: 504
Those controls definetly messes up the greyscale not sure if they affect the colors...
Indeed, that's exactly what they do - adjust the top and bottom end of the greyscale.
They could affect colours with a poorly balanced implementation across the primaries, and hey, this is a cheap Android box, so who knows!
Generally though, you should only adjust at the display and leave any source settings well alone...
post #1609 of 1713 Old 09-20-2019, 12:29 PM
Guz911's Avatar
Quoted: 18 Post(s)
What I meant with incorrect greyscale is that the correct ycbcr triplet for white is (235,128,128) and zidoo’s output was producing something different. So if the color white is wrong to begin with then the whole greyscale will be affected also.
I’m not sure if these controls affect other colors but resetting BR and CR gave correct output for white and greys.
post #1610 of 1713 Old 09-21-2019, 09:22 AM
leonkoum's Avatar
Quoted: 30 Post(s)
Changelog
Model: ZIDOO_Z9S
Version number: v2.2.96
Upgrade: OTA
System:
1.Fix the occasional green screen problem of HDMI IN
2.Optimize optical RAW output.
3. Optimize the stability of system.
4. Add German and Polish language support.
5. Fix the occasional noise problem when playing video.
6. Fix the problem that some online video applications couldn‘t be played.
7. Color depth output 10bit by default.
8. Optimize application stability.
9. Optimize online playback.
10. Fix the problem that the front panel USB icon was not displayed.
11. Optimize seamless branching issue.
12. Fix occasional prompts "the format is not supported"œ when playing dts music via HIFI MUSIC APP.
Music Player
1. Solve occasional error message of playing the music through the file manager.
2. Lyrics closing function is added.
3. Add German and Polish language support.
4. Optimize stability of application.
5. Optimize the function of obtaining music information.
6. Optimize the problem of automatically switching the next track.
7. Fix the stuck problem of 64bit music players.
8. Optimize the music basic information interface.
9. Add album folder recognition function.
10. Solve the abnormal songs display problem in flac album folder.
11. Optimize the image recognition and profile text recognition of album folders.(need to clean the old data and rescan)
12. Fix the problem that some CUE songs are not successfully matched.
13. Optimize recognition error caused by suffix identifier of the folder.
14. Add scroll bar for list.
Control center
1. Add the function of uploading screen shots from mobile phone.
2. Optimize stability of connection .
3. QR code for downloading IOS and Android app.
Poster wall
1. Solve crash issue during the matching process.
2. Solve the problem of recognizing ISO music as ISO video.
3. Improve the recognition rate of files with parentheses in file names.
4. Compatible with title of file name with "."œ
5. Optimize local image recognition.
6. Fix inaccurate automatic update due to the incorrect judgment of the video file.
7. Solve the problem that the restore function of mobile phone control app does not work.
8. Add function to view folder directly in device list.
9. Add device synchronization function.
10. Solve jitter issue caused by long device name when scanning device.
11. Solve abnormal folder size display on folder viewing interface.
12. Solve losing focus problem after stop scanning in the device list interface.
13. Fix the issue that BD cannot be deleted.
14. Solve the problem that non-Chinese and non-English titles could not be matched.
15. Fix the problem that the poster modification from web page cannot select image on the computer.
16. Category browsing by movies/TV series.
17. Optimize accented characters incorrect sort issue.
18. Optimize the initialization speed of the sorting tool.
19. Solve the occasional crash problem on category browsing.
20. Turn on PIP by default.
Local player
1. Add Blu-ray forced subtitle.
2. Press the delete button on remote control to delete plug-in subtitle.
3. Add more information interface for app control.
4. Optimize the progress bar.
5. Optimize play button no response problem after popping up menus.
6. When switching to 3D mode, associated frame rate will pause time.
7. Fix the problem that bit rate 1b/s show up coincidentally.
8. Optimize some shortcut keys.
9. Fix the problem that the download subtitle from mobile phone is different form media player.
10. Add Playlist on Mobile phone App.
11. Add more information of video display on Mobile phone app.
Weather
1. Resolve some wrong data display issue.
Quick settings
1. Add function that forced subtitles follow the language of audio track.
2. Fix the problem of incomplete German display.
One-click cleaning
1. Add Polish language support.
2. Fix the abnormal focus problem in the APK file management user interface.
Only i hope it is working properly
Klipsch & Denon always!!!
leonkoum is offline
post #1611 of 1713 Old 09-21-2019, 10:13 AM
Quoted: 657 Post(s)
Liked: 159
MOberhardt 2.2.96 may fix your multi m2ts files issue, according to the changelog ?
Although, ‘optimize’ Isn’t quite ‘fix’.
(Wow - and forced subtitles !!)
post #1612 of 1713 Old 09-21-2019, 11:00 AM
leonkoum's Avatar
Quoted: 30 Post(s)
They are workink on it...but..
In Apocalypse Now (redux) ISO in chapter 10 (1:17:23) i have 'stuck'...
leonkoum is offline
post #1613 of 1713 Old 09-21-2019, 11:39 AM
Quoted: 657 Post(s)
Liked: 159
Thanks for the status update, so not fixed yet.
At this point there may be little chance to expect this to be fully fixed.
post #1614 of 1713 Old 09-24-2019, 10:08 AM
Liked: 6
Running perfectly with the settings below but I prefer to use my projector with HDR
Probably depends that I have a small high contrast screen (100") and still a lot of nits (about 100 with low power on lamp) but I honestly prefer HDR also if the black is much better on SDR.2020
Display
HDR: SDR Rec.2020
post #1615 of 1713 Old 09-24-2019, 10:33 AM
Quoted: 744 Post(s)
Liked: 504
It's all about personal preference - if it looks right to you then it is right.
I don't use SDR.2020 either - I use my own custom curves for HDR and a Vertex so I can use the dynamic iris.
Yours is a 2016/17 projector right? I think they improved the HDR curve on those models over mine (2015/16).
On mine, Gamma D engages on an HDR signal which was way too dark and the dynamic iris is disabled.
post #1616 of 1713 Old 09-24-2019, 12:50 PM
Quoted: 44 Post(s)
Changelog
Model: ZIDOO_Z9S
Upgrade: OTA
Thank you for the info. Do you have a link for this update? My Z9S says no update needed (version 2.2.82) and the website doesn't have a download for 2.2.96.
Interested in updating because the player for some reason is becoming non-responsive to the remote (won't turn on from standby), it occasionally freezes (non-responsive to remote commands), and the front display will sometimes not light up. Yes, the remote batteries are good ;-) Thank-you!
savage01 is offline
post #1617 of 1713 Old 09-24-2019, 02:37 PM
Quoted: 657 Post(s)
Liked: 159
You may need to enable beta updates on the player then update OTA.
post #1618 of 1713 Old 09-24-2019, 07:07 PM
Seryl's Avatar
Quoted: 160 Post(s)
Liked: 105
From the Zidoo forum: http://apidl.zidoo.tv/Z9S/v2.2.96/ZI...ta-package.zip
Seryl is offline
post #1619 of 1713 Old 09-24-2019, 07:29 PM
coolgeek's Avatar
Liked: 953
Originally Posted by Seryl View Post
Last time i upgraded via their wifi... after that update, my zidoo becomes ever more 'crash prone'... playing anything halfway it'll just hang... and this was even more frequent than when i got my player... someone says it's the HDMI 3.0, but it happens the same with HDMI 2.0 slots so i don't think that's the case. It's the software that's hanging..
So, does this version solve the stability issue? And if so, how do i install it via thumb? Any instructions?
post #1620 of 1713 Old 09-24-2019, 08:23 PM
Seryl's Avatar
Quoted: 160 Post(s)
Liked: 105
Here is a link to the Zidoo form, there is a change log for this release: http://forum.zidoo.tv/index.php?thre...release.51434/
I haven't installed it yet, I am still on the last beta so no comment on this release's stability. To install: https://www.zidoo.tv/Support/guide/g...z%2Bdw%3D.html
Seryl is offline
