New Zidoo Z9S and Z10 (RTD1296 SoC) - Page 77 - AVS Forum | Home Theater Discussions And Reviews
 736Likes
post #2281 of 2405 Old 05-10-2020, 02:47 PM
vidwiz's Avatar
Quoted: 40 Post(s)
Liked: 32
Thank you for the reply, the specs you quoted appear to be for 60hz. I've tried 422 10 bit at 23,24, 25 and 30 hz but no bueno. Zidoo info shows 8 bit and I think there was an earlier post that says 422 is broken. There is no option for 420.
karipu likes this.
vidwiz is offline
post #2282 of 2405 Old 05-11-2020, 08:31 AM
johng's Avatar
Quoted: 315 Post(s)
Liked: 151
Originally Posted by vidwiz View Post
My new receiver is downgrading the 4k 23hz YCbCr 4:4:4 10 bit output to 8 bit. Works fine when i bypass the AVR. Am I interpreting the specs correctly that it should support 10 bit?
Supported resolutions
HDMI IN1 to IN4:
• Copyright protection technology: HDCP1.4/HDCP2.2
• Color space (Color Depth):
– 720×480i 60 Hz, 720×576i 50 Hz, 720×480p 60 Hz, 720×576p 50 Hz,
1920×1080i 50/60 Hz, 1280×720p 24/25/30/50/60 Hz, 1680×720p
24/25/30/50/60 Hz, 1920×1080p 24/25/30/50/60 Hz, 2560×1080p
24/25/30/50/60 Hz, 4K (3840×2160p) 24/25/30 Hz, 4K SMPTE
(4096×2160p) 24/25/30 Hz : RGB/YCbCr4:4:4 (8/10/12 bit), YCbCr4:2:2
(12 bit)
– 4K (3840×2160p) 50/60 Hz, 4K SMPTE (4096×2160p) 50/60 Hz : RGB/
YCbCr4:4:4 (8 bit), YCbCr4:2:2 (12 bit), YCbCr4:2:0 (8/10/12 bit)
Amp has zero setup parameters for deep color or anything similar. Cables test ok, hdr and resolution are ok, Oled has deep color enabled, the 8bit banding is the only problem.
When you write "works fine when i bypass the AVR" do you mean physically removing the AVR from the chain? Many AVR's have a "bypass" or "direct" mode for the video portion of the HDMI signal. That is usually the preferred method of using an AVR because it eliminates (or at least greatly reduces) the possibility of something in the AVR from distorting the video signal.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Panasonic DP-UB420, Zappiti Mini4K HDR, Zidoo Z9s, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #2283 of 2405 Old 05-11-2020, 08:43 AM
deano86's Avatar
Quoted: 724 Post(s)
Liked: 390
HDMI IN1 to IN4:
(12 bit)
I am a bit confused as to why you are posting in the Zidoo thread for what sounds like you have already determined that the issue is with your receiver/prepro? Have you made certain of your power on sequence in case of an HDMI handshake discrepancy? Display first, then receiver, and then the Zidoo last...
deano86 is online now
post #2284 of 2405 Old 05-11-2020, 10:41 AM
vidwiz's Avatar
Quoted: 40 Post(s)
Liked: 32
Yes, I removed it from the chain.
vidwiz is offline
post #2285 of 2405 Old 05-11-2020, 10:55 AM
vidwiz's Avatar
Quoted: 40 Post(s)
Liked: 32
That is a valid point thank you. Was posting here because there has been a lot of talk about the banding issue at 8 bit so I thought someone might have experience with this. I will try the power on sequence. We can let this post be the last on this issue.
In parting I will say though, that no matter what I set the Zidoo video settings to, it only ever seems to output, according to the info button, 23hz 4:4:4. My oled should accept most formats so I'm not blaming the display.
It has also come to light that just because my cables work with the display, doesn't mean they will work with the AVR as it processes things differently. According to others. Cabling is confusing what with description/specs of Active, certified, high speed, ultra high speed, with ethernet, fiber ... Hard to determine which one to try next. Currently considering the Monoprice Dynamic View, says it has the latest chipset... https://www.monoprice.com/product?p_id=14131
vidwiz is offline
post #2286 of 2405 Old 05-12-2020, 03:42 AM
Quoted: 39 Post(s)
Liked: 4
Dear friends ,
I want your opinions regarding the latest fw 2.3.10 for Z10 .
Is it better than the 2.2.96 .
Main concern is the stutter ..
Dimitris Asimakopoulos is offline
post #2287 of 2405 Old 05-12-2020, 04:47 AM
Quoted: 737 Post(s)
Liked: 174
Originally Posted by Dimitris Asimakopoulos View Post
Dear friends ,
If you are using NFS, the stutter isn’t improved by 2.3.10.
Switch to SMB
Whirlpool0548 is offline
post #2288 of 2405 Old 05-12-2020, 06:00 AM
Quoted: 39 Post(s)
Liked: 4
Switch to SMB
I'm using only SMB . So what's the outcome ? Do you think it worth the update?
post #2289 of 2405 Old 05-12-2020, 06:14 AM
Quoted: 737 Post(s)
Liked: 174
OK, Stick with 2.2.96, not worth the update, but how frequently are you seeing stutter with SMB ?
post #2290 of 2405 Old 05-13-2020, 02:24 AM
Quoted: 39 Post(s)
Liked: 4
Sometimes. But I read that both 2.3.10 and the beta 2.3.17 is not good at all and every one is waiting for the new stable which is still coming....
Whirlpool0548 likes this.
post #2291 of 2405 Old 05-15-2020, 03:27 AM
Liked: 0
Hi Guys
One year after the purchase of Zidoo Z10 I can say that its performance are goods on my Sony Af9, it plays any kind of file, iso 4k, untouched et...
Unfortunately I've noticed some issues playing some iso 4k like this :MPEG-H HEVC Video 79253 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 / 90Gb
or untouched 4k like this HEVC Video 77823 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / HDR10 / BT.2020 / 70Gb
The issues are random and are diffucult to describe
They can occur 3/4 times during the movie (but not in every movies) and last about 1 or 2 second in which movements and pan are jerky and nearly slow mo.
If i rewind the scene, the issue doesn't recur. So the issues are totally random. I don't think it's related to the Sony AF9.
Maybe it could be some parameter to set of the ziddo control panel? Or it's a real bug or issue of this player?
I don't use NAS. I play my movies directly fron the hdd inside the zidoo
Is there any 4k player with image quality, versatility and compatibility with any kind of file (iso 4k hdr10, unouched 4k high bitrate etc) better then the zidoo z10?
Marcus Lame is offline
post #2292 of 2405 Old 05-15-2020, 04:02 AM
mike0zero's Avatar
Quoted: 24 Post(s)
Liked: 7
Originally Posted by Marcus Lame View Post
Hi Guys
They can occur 3/4 times during the movie (but not in every movies) and last about 1 or 2 second in which movements and pan are a little jerky and nearly slow mo.
Is there any 4k player with image quality, versatility and compatibility with the any kind of file (iso 4k hdr10, unouched 4k high bitrate etc) better then the zidoo z10?
I have had virtually all the media boxes - Nvidia Sheild TV / Zidoo X9/ Z9 / Zappatti HDR 4k / Dune 4K / Apple TV and all have some sort of issue, for me anyway, the only box that plays all files perfect without stutter is Vero 4K, the issue you have with Zidoo I also had, although seemed to be for me a frame skip very so often, still annoying.
mike0zero is offline
post #2293 of 2405 Old 05-15-2020, 05:02 AM
Liked: 0
Doesn't sound like frame skip, becouse this issue lasts about 1/2 seconds during which the image is stutter and almost slowed down
And what does it depends of? Chipset? Ram?
Considered how much I spent fot this TV I wanted to have a top mediaplayer with no issues...
post #2294 of 2405 Old 05-15-2020, 05:16 AM
mike0zero's Avatar
Quoted: 24 Post(s)
Liked: 7
to be honest mine might not have been a skipped frame come to think of it, I recall remembering a slight pause, like there was a delayed frame, anyway since using the Vero 4K no such issues.
post #2295 of 2405 Old 05-15-2020, 05:27 AM
Quoted: 737 Post(s)
Liked: 174
Hi Guys
I have had an Oppo203 For over a year, it has been the only player with absolutely no issues. Unfortunately scarce and expensive now. (Supports BDMV but not ISO).
Has played everything flawlessly over NFS.
(I also have a Z9s, poor seamless branching support, a Dune Pro 4K good seamless branching support, but has micro stutter, although that hasn’t been an issue for me)
post #2296 of 2405 Old 05-16-2020, 12:38 PM
Liked: 0
I don't use the optical drive....It would be interesting an Oppo mediaplayer , less expensive, without optical driver , more essential....
So these issues are "normal" and zappiti one 4k,(or pro 4k ) dune hd pro 4k plus/II (max or ultra), egreat A10 (A11) can't offer better performance about image quality and reproduction without issues. Is it correct?
post #2297 of 2405 Old 05-21-2020, 04:17 AM
Liked: 0
Hi...why my Zidoo online update stuck at firmware (12/7/2019. Z9S 2.2.82), and said firmware up to date. Please whats the problem
Ihsan Maulana is offline
post #2298 of 2405 Old 05-21-2020, 08:56 AM
Quoted: 737 Post(s)
Liked: 174
If you try updating OTA, it always says the firmware is up to date.
You need to download a later version e.g. 2.2.96 is recommended.
Then update from USB.
Firmware download: http://apidl.zidoo.tv/Z9S/v2.2.96/ZI...ta-package.zip
Ihsan Maulana likes this.
post #2299 of 2405 Old 05-21-2020, 01:42 PM
Liked: 0
ok, so it is normal for my Zidoo which always said the software up to date when updating OTA. Thank you very much.
post #2300 of 2405 Old 05-22-2020, 02:29 AM
blenky's Avatar
Quoted: 1038 Post(s)
Liked: 962
Their OTA does not seem to be very reliable. To check on the latest official release - which you can d/l and install go here
https://www.zidoo.tv/Support/downloa...McQ%3D%3D.html
However note that some people have reported issues with v2.3.10 - so you may be better to stick to the one before - v2.2.96.
I'm on v2.3.10 and have no issues
Samsung UE55KS8000 | Pioneer SC-LX701 | Zidoo Z9S | Apple TV 4K | Nvidia Shield TV (2019) | Fire TV Stick 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #2301 of 2405 Old 05-22-2020, 08:10 AM
leonkoum's Avatar
Quoted: 43 Post(s)
Liked: 53
New fw v2.3.30 ΒΕΤΑ and for the first time in public we see the new Poster Wall 3.0 (v3.0.35)
Model: ZIDOO_Z9S
Version number: v2.3.30
MD5: A02DCB11549AC03EA88C2565952E84B5
Upgrade method: OTA
Changelog
(From here, translation via Google Translate.)
(original text below)
System
1. Fixed the issue that the local video played occasionally stuck
2. Optimize the smoothness of online video playback
Music
1. Fix the problem of no channel number display
2. Fix the problem of getting sampling rate error
3. Optimize folder scanning function
4. Optimize album logic
5. Optimize the front panel information display
6. CD playback adds song information
7. Optimization can not match online
Player
1. Fix the issue that the movie name is displayed wrongly
2. Add shortcut keys for subtitle download
3. Optimize the subtitle deletion function
4. Optimize the custom font function
5. After the location of the external SRT subtitle is set, the location of the built-in text subtitle will also change
6. Fix Swedish subtitles recognized as Swahili, Romanian is marked as Russian
File Manager
1. Increase SMB3.0 support
2. Add file filter switch
3. Fix the problem that the SACD files collected will be played in video mode
Poster Wall
1. Update to the new interface of Poster Wall 3.0
2. Optimize the title recognition, compatible with the "season x. Episode xx" video
3. When adding to the collection, the focus control of the collection list
4. Solve the problem of possible crash when scanning occasionally
5. Automatically categorized collection movies, adding "Remove Collection" function
6. Optimized movie added to the collection function
7. TV series category added to the left column of the home page
8. The movie details interface adds a trailer function (can be turned off in the settings)
9. Optimize the display of the new collection of personalized pictures
10. Solve the problem that the pictures of Douban matching movies are not clear
11. Optimize the function of getting local pictures automatically if the movie has no poster when the priority local picture switch is turned off
12. Rematch and add poster preview function
13. Solve the problem that the details of the video resolved through NFO will occasionally crash.
14. When the child lock password protection is closed, the main interface will no longer display the lock icon
15. Solve the problem that movies with the same title in different years will be matched into the same movie
16. Added CLEARLOGO function in the detail interface
17. Increase the function of Pop-up button of remote control
18. Solve the problem of "scanning" when adding devices
19. Solve the problem that the change of poster language does not take effect
20. Optimized sorting function
21. Priority search for TMDb during smart search
22. Optimize the child lock function
23. Search interface adds full keyboard input function
24. Add category browsing mode
25. Add custom widget function
26. Add custom classification function
27. Increase the viewing history of recently added forced time reverse display
28. Fix the problem that the widget external device does not display occasionally
29. The main interface widget adds region selection
30. Add custom function to the main interface type
31. Fix the problem that the main interface type is displayed in English individually
32. The main interface device adds a browsing mode (file and poster browsing)
33. It is recommended to add a display switch on the main interface
34. Recently added to increase the default sorting settings (add time and file time)
35. Add local trailer feature (movie name. Trailer.mp4)
36. Add alphabet navigation function on the poster list interface (effective when the poster names are sorted)
37. Optimize the trailer playback logic
38. Modify the default layout size of the poster list interface
39. Add the function of clearing application data
40. Optimize application stability
HDMI IN
1. Add PIP adjustable position and size function
DLNA
1. Fixed the issue that the playback ratio of individual videos is incorrect
Control Center
1. Add whether authorization confirmation switch is needed
2. Add mobile phone sleep interface
Hot Key
1. Add shortcut keys for subtitle download
Application Installer
1. Optimize web installation function
2. Support mobile phone installation
Mobile Phone Control
Android
1. Optimize connected device management
2. Add the function of installing local applications
ios
1. Add screenshot save phone function
2. Add the function of sharing APP files to the machine
Klipsch & Denon always!!!
leonkoum is offline
post #2302 of 2405 Old 05-22-2020, 11:28 AM
markswift2003's Avatar
Quoted: 1108 Post(s)
Liked: 823
I'll post here what I posted on the Zidoo forum - just in the interests of passing information:
Please be aware that although v2.3.30 is today's internal beta, "ZIDOO News" is an unofficial Russian source - it is not Zidoo and this is Android.
Not that I have any reason to believe that there's anything dodgy with these files, but better you know the script than not.
mikela likes this.
Zidoo Z9S | Nvidia Shield Pro | HDFury Vertex² | 32TB mirrored storage
Denon AVC-X8500H | JVC DLA X7000 | Screen Research 9ft multi aspect ClearPix 2 ISF screen
3 x PMC IB2S fronts | 4 x PMC Wafer 2 rears | 4 x PMC Wafer 1 ceiling | 2 x M&K SS550 THX height | Rel Stentor III
A pair of slippers, a comfy sofa and a glass of 16 year old single malt
markswift2003 is offline
post #2303 of 2405 Old 05-23-2020, 03:23 AM
Liked: 0
zidoo z10 server mutlimedia
hello I have a zidoo z10 and I am very satisfied, I would like to use it as a server, my goal is to be able to access all of my zidoo library from another android tv box (mi box s) how to proceed ?
pere noel is offline
post #2304 of 2405 Old 05-23-2020, 05:31 AM
Quoted: 737 Post(s)
Liked: 174
The objective is to enable SMB in your Z10 using openWRT and share the Respective attached HDDs
To enable either Samba or FTP servers on Zidoo box using OpenWRT.
(In the following steps, you should be able to use the web browser from the Z10 to manage the openWRT config on that Z10)
1. Find the IP address of your Z9S/Z10/X20/X20 Pro on your local network. Home screen - About. (e.g. 192.168.0.33)
2. Access that IP address from the Z10’s web browser. The default password is a blank space (highly recommended to change it on first use!).
3. Go to NAS Services in the OpenWRT menu, then the Samba or FTP options. Check the 'enable' box to turn on.
4. For Samba, select which directories you want to share by selecting 'Add' at the bottom. If you want to share everything enter / in the path box. All attached storage is at path /mnt
5. Selected folders should now be visible to the network as Samba shares (or FTP folder if FTP chosen).
post #2305 of 2405 Old 05-23-2020, 09:15 AM
Liked: 0
I am actually in the smb configuration of openwrt but I don't know the path of my disks, only mnt / sbc. . . are present and I don't know which one selected or how to manually add a particular disc
post #2306 of 2405 Old 05-23-2020, 11:02 AM
Quoted: 737 Post(s)
Liked: 174
If the HDD is attached to the Z10, add /mnt.
Then see if you can browse network shares from your Android device.
post #2307 of 2405 Old 05-23-2020, 11:20 AM
Liked: 0
this is my external usb hdd that i want to use in smb patage and not the main hdd of the zidoo, and i don't know which path it corresponds to
post #2308 of 2405 Old 05-23-2020, 04:08 PM
Quoted: 737 Post(s)
Liked: 174
Find the mounted devices listed in openwrt under ‘system’
vidwiz likes this.
post #2309 of 2405 Old 05-24-2020, 02:10 AM
Liked: 0
Model: ZIDOO_Z9S
Upgrade method: OTA
Changelog
System
Music
Player
File Manager
Poster Wall
HDMI IN
DLNA
Control Center
Hot Key
Android
ios
Anyone review after upgrading?
post #2310 of 2405 Old 05-25-2020, 07:56 AM
johng's Avatar
Quoted: 315 Post(s)
Liked: 151
Very glad they have updated the Poster Wall. Hopefully it will be more accurate than 2.0. The poor implementation of the poster wall, and proper identification of titles is the largest reason I've relied upon the Zappiti rather than the newer chip in the Zidoo Z9S.
johng is offline
