Official 2018 (new) FireTV Stick 4K--Dolby Vision, HDR10+, Dolby Atmos - Page 35 - AVS Forum | Home Theater Discussions And Reviews
 298Likes
post #1021 of 1096 Old 03-20-2019, 07:43 AM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
Originally Posted by mmmccall View Post
New owner of fire stick 4K here, I’ve read other places that you can access the system x-ray (similar to developer hud on Apple TV) by holding DOWN + SELECT FOR 5 seconds and then pressing menu. I can’t get this to work for the life of me, anyone have any idea of the info is bad or if maybe I’m just doing something wrong?
On the directional pad, press and hold the center and down together (simultaneously) for 5 seconds; then release the buttons and press the remote's menu button. Many times I have to do it a few times before I get it to work.
Details can be found on Amazons site here -
https://developer.amazon.com/docs/fi...per-tools.html
aaronwt likes this.
Mark
mjwagner is online now
post #1022 of 1096 Old 03-20-2019, 01:07 PM
mmmccall's Avatar
Quoted: 20 Post(s)
Thanks for the response. Yes I have seen that and tried but for whatever reason it’s not working for me. Curious if anyone has a suggestion or has had the same problem.
mmmccall is offline
post #1023 of 1096 Old 03-20-2019, 01:32 PM
Keenan's Avatar
Quoted: 3713 Post(s)
Liked: 3411
You can always just use the Developer Tools Menu Shortcut app instead of a button pressing sequence.
giomania likes this.
Keenan is online now
post #1024 of 1096 Old 03-20-2019, 02:55 PM
mmmccall's Avatar
Quoted: 20 Post(s)
Awesome, thanks so much!
mmmccall is offline
post #1025 of 1096 Old 03-20-2019, 05:00 PM
Taxcheat's Avatar
Quoted: 454 Post(s)
Liked: 337
Also, if you're using Netflix, you can connect a bluetooth keyboard and hit F8 to get the bitrate. Would have been nice if Amazon mapped that key to the info button on the remote.
XBR-75Z9D fed by Oppo 203. Decrapifying the X1 Extreme
Taxcheat is offline
post #1026 of 1096 Old 03-21-2019, 10:00 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5757
Anyone using the current pay version of MRMC? I got it yesterday to try, and I like the menu's and scraper, but a few 1080p/24 tv shows I player were herky jerky at 1080p and 2160p.
Kodi Leia has been great, the scraper is just sometimes quirky. One thing I miss from the ATV4K is Infuse Pro.
XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-500SA / FV15HP(2)
gadgtfreek is offline
post #1027 of 1096 Old 03-23-2019, 01:09 AM
tigermad's Avatar
Quoted: 29 Post(s)
I’m using a fire stick 4K and bbc iplayer and Netflix are a juddery mess. This is on my Sony 9005f. I have all the setting as recommended on here. It’s like the frame rate is all wrong. I have had to switch back to using the Sony’s inbuilt app. Any ideas?
tigermad is offline
post #1028 of 1096 Old 03-23-2019, 08:46 AM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
Are you using the little HDMI extension that came with the stick? If so try it without. Their have been reports of the extension causing judder. If that doesn’t help, have you experimented with the settings within Settings, Display & Sounds, Display? Have you tried it with Match Original Frame Rate both on and off? If that doesn’t help have you tried experimenting with the settings for Color Depth and Color Format (they shouldn’t cause judder but who knows)? Try various combinations to see if you get any improvement. I have seen no issues but I don’t have any Sony displays.
Mark
post #1029 of 1096 Old 03-24-2019, 07:59 AM
Chuck666's Avatar
Quoted: 263 Post(s)
Liked: 65
My sound issues went away after I did a reset????????????
Samsung UN82MU8000 4K UHD TV | Onkyo TX NR787 9.2 AVR with Klipsch R-15M L&R and R-34C front stage speakers | Klipsch G-12 surrounds | 2 Atrium 5 Front Tops | 2 Klipsch R-14SA Rear heights | Dual BIC RtR EV-1200 Subs | 5.1.4 Atmos system | Samsung UBD M9500 BD Player | FireTV 4K | Logitech Harmony 750 | TIVO BOLT OTA 849000
Chuck666 is offline
post #1030 of 1096 Old 03-25-2019, 07:41 PM
rdgrimes's Avatar
Quoted: 3734 Post(s)
Liked: 2921
Anybody else having issues today with home screen, watchlist or recently viewed? My watchlist is scrambled and lots of stuff missing, can't add anything to it, some titles just open a blank screen. My account works fine from PC or Roku, every thing is there as it should be and plays fine.
Already been through all the "delete app data, reboot, etc" to no avail. If I need to call a CSR I'll have to break out the 18 yr old scotch first.
mjwagner likes this.
rdgrimes is offline
post #1031 of 1096 Old 03-25-2019, 08:07 PM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
Haven’t any issues with running anything on my stick today.
I’m with you on needing a scotch or two before calling pretty much any customer support...LOL!
Mark
post #1032 of 1096 Old 03-26-2019, 07:43 AM
rdgrimes's Avatar
Liked: 2921
I even tried a full reset to factory defaults which didn't help.Today the main issue is the watchlist ordering is random. If I add a title to watchlist it vanishes to some random spot in the order. Which makes it pretty useless. Odd thing is that my watchlist is perfectly normal if I access it from PC or Roku.
rdgrimes is offline
post #1033 of 1096 Old 03-26-2019, 07:46 AM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
What watch list are you talking about? Within what app? Sounds like an app issue rather than a FireTV Stick issue.
Mark
post #1034 of 1096 Old 03-26-2019, 07:49 AM
rdgrimes's Avatar
Liked: 2921
My amazon video watchlist. It supposed to be ordered by date added, until yesterday the order is random.
rdgrimes is offline
post #1035 of 1096 Old 03-26-2019, 08:01 AM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
Sorry, you said Home screen, which is the screen you are on when you have “Home” highlighted on the top, which doesn’t have a watchlist. That had me confused. The Watchlist on the “Your Videos” screen is not something I ever use. I just took a look at mine and I can tell you it is definitely not in the order of most recently viewed for me. I can’t confirm that that is a change in behavior since, as I said, I have never even looked at that Watchlist before.
Or, are you talking about the “Your Watchlist” inside the Prime Video app? If so then that is more of an app issue. Again, not something I use so don’t really know, sorry.
Mark
post #1036 of 1096 Old 03-26-2019, 07:18 PM
LeRoyK's Avatar
Quoted: 66 Post(s)
Liked: 94
new Firmware available
Firmware M43.R.0277 for UBP-X700
Benefits and improvements from the latest update
Removes the Gracenote® function
I checked, no Auto mode for Dolby Vision with this update. It still applies Dolby Vision tags to media not intended for Dolby Vision playback.
LeRoy
LG OLED65C8PUA, Onkyo TX-RZ920, Sony UBP-X700, Apple TV 4K, Amazon Fire TV Stick 4K, AT&T Gigabit Internet & U-verse
LeRoyK is offline
post #1037 of 1096 Old 03-26-2019, 09:02 PM
spongebob's Avatar
Quoted: 417 Post(s)
Liked: 38
Originally Posted by VisionxOrb View Post
Ill still complain of no lossless passthrough for my local library.
I had to by a Shield to get that. Too bad, cuz I love the little 4K stick.
bob
spongebob is offline
post #1038 of 1096 Old 03-27-2019, 08:45 AM
rdgrimes's Avatar
Liked: 2921
Today, as if by magic, title sorting is back to normal again.
rdgrimes is offline
post #1039 of 1096 Old 04-17-2019, 09:33 AM
Mr.G's Avatar
Quoted: 1224 Post(s)
Liked: 1128
Amazon restores the ability to move and rearrange Fire TV apps.
http://www.aftvnews.com/amazon-resto...-fire-tv-apps/
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #1040 of 1096 Old 04-17-2019, 09:36 AM
rdgrimes's Avatar
Liked: 2921
I noticed that a week or so ago. Apparently this update does not register and is rolling out in stages.
rdgrimes is offline
post #1041 of 1096 Old 04-18-2019, 07:23 AM
Mike4HDTV's Avatar
Quoted: 123 Post(s)
Liked: 152
YouTube and YouTube TV are coming to the Fire TV.
https://www.theverge.com/2019/4/18/1...n-announcement
aaronwt, giomania, brotony and 3 others like this.
Mike4HDTV is online now
post #1042 of 1096 Old 04-22-2019, 06:20 AM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
Now if only Amazon and Walmart would kiss and makeup maybe we could get the native VUDU app...
Mark
post #1043 of 1096 Old 04-22-2019, 06:25 AM
Quoted: 1608 Post(s)
Liked: 952
Yes to this, freaking yes to this!
Sent from my Pixel using Tapatalk
Hetfieldjames is online now
post #1044 of 1096 Old 04-22-2019, 02:05 PM
DaveFi's Avatar
Quoted: 718 Post(s)
Liked: 229
I'll keep using Smart Youtube TV. Native refresh rate and no commercials.
Taxcheat likes this.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #1045 of 1096 Old 04-23-2019, 05:25 AM
djnice77's Avatar
Quoted: 60 Post(s)
Does not switch the output frequency on FTV 4K.
djnice77 is offline
post #1046 of 1096 Old 04-23-2019, 07:20 AM
Chuck666's Avatar
Quoted: 263 Post(s)
Liked: 65
Does anyone get Dolby Atmos audio when viewing Netflix's "Our Planet"?
Chuck666 is offline
post #1047 of 1096 Old 04-23-2019, 04:48 PM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
It does video frame rate switching on mine, if that’s what you are talking about. Do you have “Match Original Frame Rate” set to “on” on your FireTV Stick 4k? Do you have “Autoframerate” selected in the SmartYouTubeTV app?
Mark
post #1048 of 1096 Old 04-23-2019, 05:10 PM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
See my post #996 .
Mark
post #1049 of 1096 Old 04-23-2019, 05:29 PM
Chuck666's Avatar
Quoted: 263 Post(s)
Liked: 65
See my post #996 .
Dont see anything relevant. That one is about speakers???????? my error, found it........
Chuck666 is offline
post #1050 of 1096 Old 04-23-2019, 06:24 PM
mjwagner's Avatar
Quoted: 745 Post(s)
Liked: 552
No worries. Just wish NetFlix would get it fixed already. You would think they would pay more attention to one of the most popular steaming devices...🤔
Mark
