Official 2018 (new) FireTV Stick 4K--Dolby Vision, HDR10+, Dolby Atmos - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 298Likes
post #151 of 1086 Old 11-01-2018, 04:33 AM
DaveFi's Avatar
Quoted: 716 Post(s)
Liked: 224
Originally Posted by JonnyVee View Post
Originally Posted by user1085 View Post
Here are my notes from testing Harry Potter & Prisoner of Azkaban 4K UHD rip that has a DTS:X 7.1 audio track with the stick connected directly to Denon X1300. The receiver was connected to 2017 Vizio M65. Here's what I observed with audio passthrough enabled
Nvidia Shield TV
  • Kodi - DTS audio signal on receiver and receiver app
  • Plex - DTS-HD MR
Fire Stick 4K
  • Kodi - DTS
  • Plex - DTS
Have you tried MrMC? Curious if that will pass Atmos or DTS:X.
So far, it reads as if the stick will give me no extra functionality over WebOS on my 2017 LG OLED. Netflix and Amazon prime all do Dolby Vision. While Xplay will play UHD rips, but with regular DD or DTS audio.
I would test but it doesn't work with my receiver. I have an Onkyo 676.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is online now
post #152 of 1086 Old 11-01-2018, 04:42 AM
Paul Arnette's Avatar
Quoted: 66 Post(s)
I have my new Amazon Fire TV Stick 4K connected directly to my Marantz SR7010 receiver, which is passing audio and video to my LG OLED65E6P. I watched an episode of The Haunting of Hill House on Netflix last night and got Dolby Vision fine, but I had three audio dropouts, which I've never had with Netflix until last night. So I am going to try a couple ethernet adapters and see if that helps. Does anyone have any other suggestions for this issue?
I also had a couple settings questions. Is there a set of recommended settings for this device? Perhaps it is it too early to tell? Or are they the same as the previous ones? If it is the latter, where can I find those?
I set my Color Depth to "Up to 10 Bits" for my display, which again is an LG OLED65E6P, is that correct?
Finally, and this is just a personal preference at this point, it seems like Fire TV Stick 4K defaults to force everything out into HDR whether the material was intended to be in HDR or not. Maybe it was just the menus. I turned that setting to automatic or the equivalent for now.
Paul Arnette is offline
post #153 of 1086 Old 11-01-2018, 05:37 AM
RickD1225's Avatar
Quoted: 228 Post(s)
Liked: 201
So after seeing that all content I tried last evening was in HDR DV I went to settings and it set to force everything to DV. Changed the setting to Adaptive. Not that the content looked bad, it actually looked great.
Sony XBR-75X900F, Marantz SR6012, Rotel RMB-1095, Monster HTS3600MKII, Klipsch RF-5, RC-7, RS-7, RP140SA, Dual SI-18 DIY Subs, Behringer EPX 4000, Crown XLi 1500, Fire Stick 4 K.
RickD1225 is offline
post #154 of 1086 Old 11-01-2018, 06:04 AM
mr b's Avatar
Quoted: 178 Post(s)
Liked: 79
Originally Posted by RickD1225 View Post
I received my 4K stick today and I have found it to be excellent. I streamed some NBC shows on Hulu and they are in Dolby Vision, outstanding. I have not had any negative issues. I have it plugged directly into the TV. The new remote can power on my Sony 75” 900F which also turnes on my Marantz SR6012. It can adjust the volume and mute. Everything works great. Wi-Fi speed as measured using the Netflix speed test is +150 Mbps. Streaming is smooth as silk.
I'm pretty sure that the default setting for the fire stick is to show everything in DV. I noticed that as well, but when i set to Adaptive, I only get DV via Prime.
For some reason, Netflix kicks in HDR, but I'm only getting 1080p. Probably something I got set wrong.
As is stands now though, I think this is the 1st time with my setup that I've been able to stream anything in both DV & Atmos. I've got a 4k player that I think does this also but I haven't been buying many UHD BD's lately so I don't use it much anymore.
My Gear:
Spoiler!
mr b is online now
post #155 of 1086 Old 11-01-2018, 06:10 AM
Mark_Venture's Avatar
Quoted: 120 Post(s)
Liked: 37
Originally Posted by DaveFi View Post
Ok, I plugged it directly into my TV- no more flashing. I suppose this is a decent workaround- with ARC I get DD+, no lossless on this thing so it doesn't matter.
Interestingly enough the Vizio TV's system menu says "Dolby Atmos" for Jack Ryan so apparently the TV pass it no problem.
Anyone have the Vudu apk off a Sony TV w/DV? The apk on APKMirror only plays back the movies you own in HDX (no 4k), you can't rent through it.
Mark- I see you said you got Vudu working with 4k/DV on the stick? I sideloaded the latest Android TV APK off APKMirror- should work, but it's kind of crippled for me.
Hmm, no 4k on Netflix either, just 1080p w/DV. Odd. This is with it plugged directly into my Vizio P65-E1. Amazon plays UHD content just fine.
Ahhh. YouTube 4k/60Hz HDR. Sweet!
Nevermind- got it all working. Had to reset the stick, TV, etc.
Pretty snappy. Very quick- wifi works better now that it's not jammed up behind my receiver. Not great, but ok.
Vudu no go- Encountered Problems During Playback- please try again.
For Vudu... I'm using 4.1.23.60526 which also worked on my 2nd Gen Fire TV Box.... It DOES do DV/ATMOS/UHD when the 4K Stick is connected to my Sony XRB65X900F in the family room (that TV supports DV), and the Vudu app shows HDR when attached to my Sony XBR43X800D in the bedroom that doesn't support DV. With the 4K Stick it also seems I need to be using an ethernet adapter or I get errors when trying to start playing a movie.
When trying 4.2.53.116291 (the newest version), or 4.2.52.110309 (one back, which works great on my cube for HDR/ATMOS/UHD) on the new 4K Stick, it immediately errors trying to play SD/HDX/UHD movies wireless or wired.
Did resetting the stick get rid of the flashing, etc. when plugged into receiver? or are you still direct in TV.
Mark_Venture is offline
post #156 of 1086 Old 11-01-2018, 06:14 AM
Quoted: 120 Post(s)
Liked: 37
Nvidia Shield TV
  • Plex - DTS-HD MR
Fire Stick 4K
  • Kodi - DTS
  • Plex - DTS
which version of Kodi are you using on the Fire TV? Do you have older Fire TV models and does it work ok on them (particularly interested in 1st and 2nd gen Fire TV boxes)
And side question if you don't mind answering... are you using MakeMKV to rip your UHD's or something else?
post #157 of 1086 Old 11-01-2018, 06:24 AM
Quoted: 120 Post(s)
Liked: 37
Originally Posted by VisionxOrb View Post
Speaking of lan, if one needs to break the 100m barrier you can try a OTG/Gigabit combo https://www.amazon.com/ethernet-adap...+fire+tv+stick
Do we think this will also work if we put a USB3.0 hub inline so I can also add a FLIRC adapter?
In other words, I want fast wired ethernet, but also need an additional USB port to hook up the FLIRC device to use my IR Harmony.
post #158 of 1086 Old 11-01-2018, 06:32 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Quoted: 8834 Post(s)
Liked: 5627
Nvidia Shield TV
  • Plex - DTS-HD MR
Fire Stick 4K
  • Kodi - DTS
  • Plex - DTS
What settings do you have for audio? When I tried my Harry Potter UHD mKV rips I got DD+ from the stick. So then I tried a couple of legacy DTS test files, and I still only got DD+. I couldn't get it to output DTS.
Sent from my Nexus 7(16GB) using Tapatalk
53TB unRAID2--45TB unRAID3--35TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #159 of 1086 Old 11-01-2018, 06:34 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
Originally Posted by redlikemethodz View Post
How are you switching between HDR formats?
There is an HDR setting on the Stick. Once set it will switch automatically between SDR, HDR0, and Dolby Vision.
post #160 of 1086 Old 11-01-2018, 06:34 AM
RickD1225's Avatar
Quoted: 228 Post(s)
Liked: 201
It does seem Odd that the stick would come with DV enabled for all content as the default.
post #161 of 1086 Old 11-01-2018, 06:36 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
The default is HDR. On my DV capable TV it output everything in DV. On my HDR10 only TV, it output everything in HDR10. Until I changed it in the setting so it would output SDR, HDR10, and DV for the proper content.
giomania likes this.
post #162 of 1086 Old 11-01-2018, 06:40 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
I can already break the 100mbos barrier using wireless. It is Rock solid on both of my Sticks and allows play back of UHD BD rips to play flawlessly. Or even 100mbps+ bitrate videos as well. Although since the stick can't bitstream Dolby True HD or DTS-HD MA, it really not a device I would use to play back my UHD BD MKV rips.
post #163 of 1086 Old 11-01-2018, 06:41 AM
mr b's Avatar
Quoted: 178 Post(s)
Liked: 79
Yeah, that's what I was trying to say, I just worded it wrong. Should have said it shows everything in HDR or DV.
The point I was making was that when set to default, the stick sends everything out in HDR or DV, regardless of what the source is, making it seem like the source is HDR/DV.
@aaronwt , are you getting 4K from Netflix when set to adaptive? Not sure why I'm only getting 1080p, even though the DV kicks in properly. I've been using Sabrina for testing.
My Gear:
Spoiler!
mr b is online now
post #164 of 1086 Old 11-01-2018, 07:14 AM
Quoted: 120 Post(s)
Liked: 37
What router are you using?
post #165 of 1086 Old 11-01-2018, 08:09 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
Yes. I am getting 4K from Netflix. Dolby Vision shows up as well. The issue I had was with Plex. If I set Plex to framerate match then the Stick would down convert it to 1080P for output. But if I set Plex to just output 60P, then the stick would output at 2160P from Plex.
post #166 of 1086 Old 11-01-2018, 08:19 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
I am using an old 2011 Asus RT-N56U router(running the custom Padavan firmware) since it has zero issues maxing out a GigE connection on the WAN and LAN. And then I use two Asus RT-N65U routers in AP mode. And then I also use two Asus RT-ACRH13 routers in AP mode. All my wireless UHD devices connect to one of the RT-ACRH13 APs. Since they have wireless AC capability.
So including the Asus I use as an actual router, i use five Wireless Access Points. So every device has maximum signal strength and no congestion. So every device can get a rock solid signal and excellent speeds over wireless.
But I also have around seventy wireless devices. So without having multiple Access Points, things would grind to a halt over wireless.
post #167 of 1086 Old 11-01-2018, 08:53 AM
DaveFi's Avatar
Quoted: 716 Post(s)
Liked: 224
Still no Vudu playback.
Unfortunately no- I even did a factory reset on the stick 2x and it did nothing- still blanks out- flickering black screen. Seems like an HDCP issue. Once again, none of my other Dolby Vision devices have this and they're both using cables, not connected directly to the device like the stick, so either Amazon needs to fix this, Onkyo, or both.
Sure it's nice to have it connected directly to the receiver, but unless someone ever figures a way to get lossless audio out of the 4k stick it really doesn't matter- my Vizio can pass DD/DD+/DTS over ARC just fine.
One thing I can't get it to do is pair with my Harmony Hub. It just doesn't happen regardless of how close I put the Hub to the stick.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #168 of 1086 Old 11-01-2018, 09:46 AM
VisionxOrb's Avatar
Quoted: 334 Post(s)
Liked: 222
probably not inline like a chain. what you would do is use the hub with the OTG adaptor and then plug the ethernet adapter into the hub. that should work.
2000 watts of power and climbing
-Fred
VisionxOrb is offline
post #169 of 1086 Old 11-01-2018, 09:58 AM
Taxcheat's Avatar
Quoted: 453 Post(s)
Liked: 335
Is that the app sideloaded, or the weird browser weblink? I haven't tried the link yet.
XBR-75Z9D fed by Oppo 203. Decrapifying the X1 Extreme
Taxcheat is offline
post #170 of 1086 Old 11-01-2018, 09:59 AM
Quoted: 73 Post(s)
Use Smart YouTube tv app. You can pick hdr quality
Taxcheat likes this.
Denon X1300W | Klipsch RF 82 II, RC 62 II, R-12SW | Fire TV 3 Pendant, Nvidia Shield TV, Roku Premiere+
user1085 is offline
post #171 of 1086 Old 11-01-2018, 10:03 AM
Quoted: 120 Post(s)
Liked: 37
That is what I'm hoping for... for that "package"... move the ethernet dongle and FLIRC device into the hub, and plug the hub into the "pigtail" part which is of course connected to the Stick and power.
post #172 of 1086 Old 11-01-2018, 10:07 AM
DaveFi's Avatar
Quoted: 716 Post(s)
Liked: 224
I have an ethernet adapter with 3 USB ports on it. I'll try out my Flirc in it later.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #173 of 1086 Old 11-01-2018, 10:24 AM
Quoted: 120 Post(s)
Liked: 37
Are you using wired or wireless for network? For me, I must use wired. I got errors when wireless.
As for the flickering and flashing, not sure if you saw, I added a HDMI repeater (by Monoprice) on the TV end of my HDMI cable and that fixed it. My Cube doesn't need it, but the stick does. My Sony UBP-X800 player also needed it due to cable length through the wall (but even with repeater, the Sony can't be fed through the receiver, the 4K Stick can).
post #174 of 1086 Old 11-01-2018, 10:27 AM
Quoted: 120 Post(s)
Liked: 37
No worries. I have a amazon basics hub with FLIRC, Logi Keyboard, USB stick and ethernet being used on my cube, and a hub with FLIRC and Logi keyboard on my FireTV 2 (box), so I'm just hoping to replicate on 4K Stick
post #175 of 1086 Old 11-01-2018, 10:27 AM
Quoted: 73 Post(s)
Nvidia Shield TV
  • Plex - DTS-HD MR
Fire Stick 4K
  • Kodi - DTS
  • Plex - DTS
Haven't yet but will try it out today
  • Using Kodi 17.5, will update to 17.6 today
  • Don't have those older Fire TVs
  • Yep, using MakeMKV to rip UHDs
Here are the Kodi audio settings
Mark_Venture likes this.
user1085 is offline
post #176 of 1086 Old 11-01-2018, 10:28 AM
DaveFi's Avatar
Quoted: 716 Post(s)
Liked: 224
With or without ethernet adapter it flickers. Plugged directly into the receiver with no dongle it still flickers.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #177 of 1086 Old 11-01-2018, 11:17 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
That sounds defective.
post #178 of 1086 Old 11-01-2018, 11:36 AM
DaveFi's Avatar
Quoted: 716 Post(s)
Liked: 224
Works fine directly with the TV so probably not.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
post #179 of 1086 Old 11-01-2018, 11:53 AM
Quoted: 120 Post(s)
Liked: 37
my bad.. I mean Vudu... when trying Vudu, are you wired or wireless? For me, I installed Vudu, got the error, decided to try wired... unplugged power from the stick, connected network adapter, powered back on and tried and it was working... but only with that older version.
At this point.. I'm spinning my wheels... All apps I have/use are working. The screen flicker when running through my receiver can be solved by adding a HDMI repeater ($25), but then I need to add usb OTG cable that also can do power(need to buy), usb hub (i have a left over amazon basics usb2.0 i can use), wired ethernet(need to buy) and FLIRC(I have) for it. At least all this can be hid behind the audio equipment then. If I left the Cube in the family room (with the 900F TV that supports DV&HDR), and put the stick in the bed room (on the 800D TV that doesn't support DV), I don't need the repeater, but would need to deal with the rest, and the HDMI ports are on the side of the TV so the stick would stick out beyond the end of the TV and be visible and also impacts my keeping the TV in the cabinet (due to width). OR I can just stick with my 2nd Gen FTV Box (and no HDR) in the one room for "free"
post #180 of 1086 Old 11-01-2018, 11:58 AM - Thread Starter
UHD Addict
aaronwt's Avatar
Liked: 5627
Have you tried changing from the default RGB colorspace output to YCbCr?
I have mine set for YCbCr at 12bit so it will output 422 for non Dolby Vision content. Of course DV content is still output as RGB.
Sent from my Galaxy S8 using Tapatalk
