Apple tv 4k vs amazon fire cube vs roku ultra - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Christcorp
  • 1 Post By speavler
  • 1 Post By REDdawn6
post #1 of 13 Old 04-14-2019, 04:43 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 0
I am looking for a streaming device for my home theater, I would like to be able to stream 4k and prefer to have a ethernet plug to hard wire the internet. Any recommendations on best device?
SDoutdoorsman is offline
post #2 of 13 Old 04-14-2019, 08:41 PM
Christcorp's Avatar
Quoted: 441 Post(s)
Liked: 234
First, let me say, going with ethernet is definitely the right choice. WIFI is never better; especially for streaming Live TV. The ONLY reason WIFI is even available, is for convenience, NOT for performance. It's the only reason it was even designed. Ethernet is always better. So for that; excellent choice and vision.
Next; narrow it down to the apple 4k tv and the roku ultra. It seems like "most" of the issues I've seen with ALL of the streaming services, Amazon Fire, of any type, seems to have more issues than any other streaming device. Having said that, both the apple tv 4k and roku ultra have their pros and cons. The two biggest advantages of the apple 4k tv is 1) if you are into apple/iphone/itunes at all, the apple tv 4k is perfect for bringing together all of your movies and music. It even coexists with movies anywhere perfectly. It has plenty of apps for just about anything you want. It is the most stable of the streamers in my opinion. 2) For those who are SERIOUS about movies/video, apple tv 4k does Dolby Vision. While HDR is great, Dolby Vision is BETTER. It's the next step up. Now, if someday, Roku comes out with a streamer that does Dolby Vision, I might reconsider. But, because I'm big into itunes and such, it will always be my first choice.
Roku on the other hand, is the industry leader. Just about every app made, is made for Roku. Roku also allows basically open source, to allow anyone to write an app for it. There are LITERALLY MORE THAN 8,000 apps for Roku. Anything you can think of, is written for Roku. The ultra is powerful, fast, and stable.
CONS:
Apple tv 4K; Price: $175 for the apple 4k tv. That is a bit higher than all others. Another con; but not a deal breaker, is it doesn't have the 8,000+ apps. But it definitely has a BOAT LOAD. So for most people, it's not an issue. Only for those really wanting to find obscure private channels; then the Roku is better.
Roku Ultra: While it has a fast processor, the ethernet port is only 10/100. The Apple tv 4k is a TRUE 1GB port. Also, Roku developers, when coordinating apps, doesn't spend a lot of time on convenience. For instance; if you have Hulu TV, when you go to the guide, which could have 100+ channels, you have to press the up or down button on and off to go up or down the channels one at a time. With the apple, you can hold the up or down button and the guide will fast forward and scroll super fast. Also; Apple updates their firmware on a much more regular basis. And their firmware is much more stable. Basically, the apple tv, iphones, ipad, etc. use the same firmware base. Roku has very specific firmware and it's simply not as good.
Conclusion: If you're not into Itunes; and don't already do Iphone or Ipads, and you are content with HDR and aren't too interested in Dolby Vision; then by all means skip the apple tv 4k and go with the Roku Ultra. On sale, it runs around $89. That's about $90 LESS than the apple. But, if you want the highest end video, such as Dolby Vision; if you're into itunes or other apple products at all; if you want the fastest ethernet port and fastest processor; then definitely go with the Apple tv 4k.
FWIW: I own BOTH. And also 2 other Roku's. i have 4 tv's so I use them all over. BUT, for my MAIN Home Theater TV, where I watch SERIOUS MOVIES on netflix, prime, hbo, dvd/itunes, etc. The apple tv 4k is the best. Especially with Dolby Vision. The Roku's, I mainly use on tv's to "WATCH TV"; such as Hulu Live tv, Philo, and similar.
Philip To likes this.
Michael
LG OLED65B7P, Yamaha 7810, 5.1.2 ATMOS
Philips 7302 BR/DV, ATV4K, Roku Ultra, Roku Premiere, Roku Stick+
Christcorp is offline
post #3 of 13 Old 04-15-2019, 11:38 AM
Dave Morton's Avatar
For another perspective, I was in the same boat this past weekend. I had a 2nd generation firetv and couldn't watch anything on the new criterion channel app because of DRM/HDCP issues. I've never had an issue with my firetv to date. After considering cost and needs, I went with the FireTV cube. I'm happy to have kept the ethernet connection and was super happy with the Alexa integration. It detected my old rotel rsp-985 pre-amp, my old panasonic plasma tv and can control them. I was able to tell Alexa to set a timer to remind me of GOT at 8pm and it turned it on for me. So I'm happy with the FireTV cube. Since I do most stuff via amazon, it was an easy choice and it was $79 this weekend everywhere.
Dave
Dave Morton is offline
post #4 of 13 Old 04-15-2019, 02:41 PM
speavler's Avatar
Quoted: 30 Post(s)
Liked: 43
iTunes 4K streaming has my Blu-ray player collecting dust. ATV 4K all the way.
Tweeter2002 likes this.
speavler is offline
post #5 of 13 Old 04-15-2019, 08:19 PM
adam355's Avatar
Quoted: 189 Post(s)
Liked: 163
Nvidia Shield TV
adam355 is offline
post #6 of 13 Old 04-15-2019, 09:05 PM
Liked: 2
I agree with adam, the nvidia shield is superior to pretty much anything. It is on the android platform. The only negative is it does not support spectrum cable, aside from that it is the fastest processor easy to use, great remote. Amazon prime, KODI, Sremio and you tube are flawless.
Stephen Dohring is offline
post #7 of 13 Old 04-16-2019, 08:01 AM
ggw2000's Avatar
Quoted: 735 Post(s)
Liked: 352
Shield PQ is "soft" compared to ATV4K....
Sony XBR 75X940E - Sony Z9F 3.1 Soundbar - Sony UBP-X700 UHD BD Player - ATV 4K
ggw2000 is offline
post #8 of 13 Old 04-16-2019, 12:06 PM
Christcorp's Avatar
Quoted: 441 Post(s)
Liked: 234
Have to agree. I've looked at Shield on 2 of my friend's systems. I even downloaded some of the apps I use, and brought over my apple tv 4k. I'll stick with the apple tv 4k any day of the week. Especially when I'm sitting their with an OLED tv that is top of the line for picture quality, dolby vision, hdr, and other 4k signals.
The only reason I'd even recommend or consider a Shield, is if I was really into Plex or Kodi. Other than that, the Apple tv is much better in my opinion. PLUS..... I HATE ANDROID. Thus, why I also decided against Youtube TV. Not a google fan. I have a $55,000 PER MONTH cellular bill. (Yes, that's NOT a typo). The company I work for, I manage ALL of their cellular devices. More than half are Android. Only about 5-10% are IOS. The rest are true mobile platforms like Airlink/Cradlepoint. I've written a lot of APK/Apps for android. It is ok. It's fine and even great in some regards. But for the world of streaming video, especially for personal use, I'll take the Apple tv 4k IOS any day over the others. Again; unless you're really into plex/kodi. Then shield is set up more for that.
Michael
post #9 of 13 Old 04-17-2019, 07:46 AM
Quoted: 549 Post(s)
Liked: 185
I've heard some good things about ATV4K, never own one so can't comment.
However, just want to point out so OP to know, ATV4K or any of those on your list is NOT capable of passing lossless audio through.
tinhvo is online now
post #10 of 13 Old 04-17-2019, 10:04 AM
lockdown571's Avatar
Quoted: 350 Post(s)
Liked: 266
I've said this a million times, but IMO the most important question is, do you have 'height' speaker channels and do you plan on playing blu-ray rips? If these answer to that is yes, then get a Shield (or maybe something like a Vero 4K+ if you only plan on playing local media and don't need streaming services like Netflix). If the answer is no, then Apple TV 4K (and then use the Infuse app or MrMC for rips).
Although, keep in mind the Shield does not support Atmos in Netflix or Dolby Vision.
lockdown571 is online now
post #11 of 13 Old 04-17-2019, 11:38 AM
REDdawn6's Avatar
Liked: 24
I am not a fanboy. But after reading ,IIRC , Apple 4k was the only hardware to support 4k w HDR, ATMOS and all the other goodies of 4k , ON THE 4 BIG services like Vudu, Amazon Movies, Netflix and one more I cant remember.
I just upgraded my receiver to a New Denon , I am still using my 1080p tv. Only on ATV (MY roku wont) can i stream 1080p video and ATMOS sound.
REDdawn6 is offline
post #12 of 13 Old 04-17-2019, 03:25 PM
Quoted: 549 Post(s)
Liked: 185
The Atmos sound you mentioned is a re-encoded or upmixing audio signal plus if it isn't, that Atmos is carried on top of a lossy signal such DD+.
Not the true lossless audio signal from source.
Just so you know.
post #13 of 13 Old 04-17-2019, 06:17 PM
m0j0's Avatar
Quoted: 308 Post(s)
Liked: 238
I use Nvidia Shield to stream 4K mkv’s with bitstream audio and it works great. Don’t think it’s soft at all from my experience, though I don’t have atv4k to compare it to. I do have a Panasonic 820 though and it fairs pretty well in comparison, minus the tone mapping.
m0j0 is online now
