New Nvidia Shield TV Pro announced! Faster SOC, Dolby Vision, new remote! - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 2353Likes
post #3901 of 4599 Old 06-01-2020, 10:35 AM
Frank Derks's Avatar
Quoted: 612 Post(s)
Liked: 460
Originally Posted by elee532 View Post
I'm just setting up Plex on my 2019 Shield. I'm new to Plex. This is both server and client. I cant figure out why my FLAC 5.1 music files are playing as stereo. Anyone have suggestions for fixing this?
Having issues with this as well. Although I had playing 5.1 channels flac files using plex. However when the player finishes playing the file the hdmi connection is lost until I press the "back" button on the remote to get video back.
After this the same file plays with 2 channels only.
Stopping plex and emptying cache sometimes gets me mc back. Restarting Shield did work too.
Files play without issues but the plex interface is very unstable after an hdmi handshake.
I suspect framerate changes causing hdmi handshakes.
It's all an hdmi Sh1tsh0w
Stereo is simply Multichannel light.
Frank Derks is online now
post #3902 of 4599 Old 06-01-2020, 10:42 AM
Quoted: 612 Post(s)
Liked: 460
Originally Posted by whiteboy714 View Post
I'm no audiophile either. Maybe a little bit OCD as I know it's messing with things a little bit. But I mostly have been using Spotify lately and I'm plenty happy with the quality.
That said the $80ish Odroid N2 with coreelec installed can play multi channel pcm flawlessly. So there really shouldn't be a reason Android can't figure it out.
Kodi playes all my mc flac files without issue.
Don't like the interface for browsing my library....
post #3903 of 4599 Old 06-01-2020, 11:00 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
rest assured, 44.1 to 48 doesn't hurt anything. It just adds more headroom which is filled with nothing. Can't create audio that isn't there.
Shadow Theater Build: https://www.avsforum.com/forum/19-dedicated-theater-design-construction/3141596-shadow-theater-build.html
b_scott is offline
post #3904 of 4599 Old 06-01-2020, 12:33 PM
Quoted: 28 Post(s)
Liked: 7
Nyquest
Sampling rate has to do with the frequency response, not headroom. 2 times the highest frequency, hence 44.1 khz = 22.05 khz, more commonly referred as 20 khz. The bit depth has everything to do with headroom. 6 db per bit. 16 bit = 96 db s/n ratio. 24 bit = 144 s/n ratio. For you individuals that think putting a standard definition (cd quality or less) recordings into HiRez (96/24 0r better) files yields better sound, it doesn't. That is a large bit bucket "filled with nothing".
mutelight and b_scott like this.
riknik is offline
post #3905 of 4599 Old 06-01-2020, 12:40 PM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
Yeah, I didn't want to get into all that. But 48hz is usually 24 bit, at least my recordings are.
b_scott is offline
post #3906 of 4599 Old 06-01-2020, 01:05 PM
dabl's Avatar
Quoted: 87 Post(s)
Liked: 39
Tidal Atmos
Originally Posted by Nikolaos Tsarmpopoulos View Post
...Tidal hasn't clarified publicly which devices are compatible.
Actually they have.
You can stream music in Dolby on your Dolby Atmos compatible soundbars, TVs, and AVRs, in addition to your Dolby Atmos compatible Android mobile devices.
Compatible TV-connected devices include:
Apple TV 4K (running tvOS 13 or later)
Fire TV (Fire TV Stick 4K, Fire TV Stick 2016, Fire TV Gen 3 2017, Fire TV Cube 1st Gen or 2nd Gen)
Nvidia Shield TV and Shield TV Pro (2019 and newer models)
The updated TIDAL app is also available on Dolby Atmos enabled Android TVs from Sony and Philips.
Please ask Tidal support when the client update for the Shield TV will be pushed. The current version is 2.25.1
For what it's worth the client version on the Amazon Firestick 4k that works is 2.26.1
dabl is offline
post #3907 of 4599 Old 06-01-2020, 04:15 PM
ntsarb's Avatar
Quoted: 57 Post(s)
Liked: 8
Originally Posted by dabl View Post
Actually they have.
Very useful to know, thank you.
ntsarb is offline
post #3908 of 4599 Old 06-01-2020, 05:36 PM
taz291819's Avatar
Quoted: 459 Post(s)
Liked: 355
Yeah, I'm looking forward to Tidal releasing the updated app for the Shield as well. Not a current subscriber, but will give it a shot once Atmos is supported.
elee532 likes this.
Vizio P65-C1 (2016)
Onkyo Tx-NR656 (5.1.2 setup)
JBL Studio S-Center, JBL Studio S26ii (FL/FR), JBL N24 (LS/RS), JBL N24 (Overhead Atmos), JBL Studio SUB250
Nvidia Shield TV 2019 Pro / Fire Stick 4K
taz291819 is offline
post #3909 of 4599 Old 06-01-2020, 09:57 PM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
my Shield TV tube just came. For a $149 device I was surprised it didn't come with an HDMI cable.
b_scott is offline
post #3910 of 4599 Old 06-01-2020, 10:32 PM
Tygeezy's Avatar
Quoted: 309 Post(s)
Liked: 179
Yeah, the pro doesn't either.
Tygeezy is online now
post #3911 of 4599 Old 06-02-2020, 06:47 AM
dabl's Avatar
Quoted: 87 Post(s)
Liked: 39
Tidal Atmos
Got the 2.26.1 Tidal app update this morning for my Shield TV 2017 and am getting Atmos in Tidal. Woo hoo!
asabrag likes this.
dabl is offline
post #3912 of 4599 Old 06-02-2020, 06:51 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
I played media that was supposedly Dolby Vision in Netflix on my shield and I didn't get the Dolby Vision flag pop down on my LG OLED.
b_scott is offline
post #3913 of 4599 Old 06-02-2020, 07:08 AM
HD-Master's Avatar
Quoted: 802 Post(s)
Liked: 904
Do you have it enabled on the Shield?
My 2019 TCL 6-Series QLED R625 Calibrated Settings
b_scott and asabrag like this.
HD-Master is online now
post #3914 of 4599 Old 06-02-2020, 07:11 AM
rec head's Avatar
Quoted: 394 Post(s)
Liked: 394
Do you pay for the 4K NF plan? Does the TV go into Dolby Vision mode when you use the TV's app?
galonzo and b_scott like this.
rec head is online now
post #3915 of 4599 Old 06-02-2020, 07:16 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
Thanks! That setting was not there when I initially plugged in the Shield TV. It must have gotten added during one of the updates?
b_scott is offline
post #3916 of 4599 Old 06-02-2020, 08:01 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 641
That option is only available when it detects a DV capable TV is connected.
Foxbat121 is online now
post #3917 of 4599 Old 06-02-2020, 08:21 AM
Quoted: 2299 Post(s)
Liked: 1583
Probably because they don’t know if it’s connecting to a 4K display or not or if you’ll be watching HDR/DV content.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #3918 of 4599 Old 06-02-2020, 08:22 AM
rcraigiii's Avatar
Hi Everyone ...
I'm unable to get ATMOS out of Vudu with Shield Pro. Instead, my Yamaha AVR shows DD+. I can get ATMOS (when avail) on Netflix, Disney+, and Amazon. I have a Samsung Q90 65" and a Yamaha RXA780 Receiver. I have a ticket opened with Vudu, but it's slow moving.
Thanks in advance for any guidance!
Rob
Yamaha RXA780, Samsung QN65Q90RAFXZA, B&W 685 Bookshelf Fronts, B&W Center, Polk Audio Rear & Sub, Klipsch RP-140SA Dolby Atmos Front Presence, Directv Genie 2 with C61k-700 Client, Nvidia Shield Pro.
rcraigiii is online now
post #3919 of 4599 Old 06-02-2020, 08:26 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
Not sure why that matters. Just include a short 18gbps capable cable.
b_scott is offline
post #3920 of 4599 Old 06-02-2020, 08:36 AM
Liked: 1583
Only 1/3 of the households have 4K so that's overkill for most. A lot of us want Premium Certified so I guess it's best to do as many other manufactures do including Apple, let the users decide what they want.
aaronwt likes this.
Mike
post #3921 of 4599 Old 06-02-2020, 08:40 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
Uh, Apple includes connection cables with their phones.
HDMI is HDMI. Most "premium" stuff is just bullsh*t. It's ones and zeros, this isn't waves like in the past. You should at least get something to connect with. Cables are pennies for them.
b_scott is offline
post #3922 of 4599 Old 06-02-2020, 09:41 AM
UHD Addict
aaronwt's Avatar
Quoted: 9992 Post(s)
Liked: 6656
I would never use the HDMI cable if it did. Just like I never use the AA and AAA batteries that come with devices.
I have a box with dozens of HDMi cables and batteries that came with devices over the years. I will throw one in with a device I sell. But that is all I use them for.
Theetjuh and jazzrock like this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #3923 of 4599 Old 06-02-2020, 09:42 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
ok, good for you. that doesn't change the fact that it should've come with one, regardless of cable snobs.
b_scott is offline
post #3924 of 4599 Old 06-02-2020, 09:47 AM
rec head's Avatar
Quoted: 394 Post(s)
Liked: 394
I uninstalled and reinstalled Tidal and now have Atmos music. My brief experience so far: The levels are much quieter than stereo tracks. I had to increase the volume 10 to 12 db. In my limited trial the pop songs sounded flat and lame like they squeezed the life out of them. I have regular stereo tracks that sound more spacious. The James Brown track has the vocals in the rear which is weird but maybe there is a reason for that. The Art Blakey track I listened to seemed like the only mix that felt right but I was multitasking at the time. I have not done strict A/B testing using Tidal to test between the Atmos and stereo versions of the same track.
asabrag likes this.
post #3925 of 4599 Old 06-02-2020, 09:49 AM
Liked: 1583
Stop with the “uh” snarky stuff okay? What I’m saying is other devices don’t come with them either. Premium Certified cables like Monoprice are inexpensive but certified by HDMI.org. Many of us use them. Apple includes a “Lightning” charging cable for their phones which are specific for their phones. They don’t include HDMI cables for their streaming devices.
NotShorty, chi_guy50 and jazzrock like this.
Mike
post #3926 of 4599 Old 06-02-2020, 09:52 AM
Quoted: 315 Post(s)
Liked: 132
Actually they have.
Thanks!, I just checked, updated and listening Cold Play in Atmos....great add on from Tidal
asabrag is online now
post #3927 of 4599 Old 06-02-2020, 09:58 AM
b_scott's Avatar
Quoted: 742 Post(s)
Liked: 290
I said Uh because the post i originally quoted said "uh". Looks like it's been edited. It's not snarky, it was mirroring. If i'm going crazy and it didn't, then I apologize.
I don't even consider Apple TV's, and I didn't know they didn't come with a cable. They should too, so my opinion stands. Again, HDMI is HDMI as long as it is to spec, and no one in my decades here has been able to prove to me otherwise on my tons and tons of devices. Ones and zeros.
b_scott is offline
post #3928 of 4599 Old 06-02-2020, 09:59 AM
groove93's Avatar
Quoted: 1403 Post(s)
Liked: 803
Considering I don't have a 2019 Shield, for the Tidal/Atmos music, are all of the songs available in Atmos, or are selected titles only in this format?
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is online now
post #3929 of 4599 Old 06-02-2020, 10:18 AM
Philnick's Avatar
Quoted: 850 Post(s)
Liked: 443
The value of Atmos music mixes would be that the mixing engineer places instruments (and ambiance) in space intentionally. Anything given to Tidal in stereo should be distributed in stereo, not Atmos, so clearly only things mixed in Atmos would be available in that format.
If you want to put stereo material through an upscaler on your own, nothing will stop you - other than a result that doesn't sound pleasing to you. Personally, I prefer to play stereo material in "car stereo" mode - I use my AVR's mode that sends each channel to all the speakers on that side of the room. (On Yamahas, it's called "x channel stereo" - x being the number of power amps your unit has.) That avoids artificial-sounding results.
groove93 likes this.
Phil
True 4K/HDR10/3D JVC DLA-RS1000 (N5/NX5) projector, 7.2.4 Paradigm/Boston Acoustics/Onkyo speakers. Yamaha RX-A3070 (w/ Denon 2307CI to power 4 overheads). Oppo UDP-203, 4K Nvidia Shield, 4K Roku Ultra, 4K Amazon FireStick, Comcast 4K cable box, Win 10 PC.
My water-themed landscape photography website - only 24 pix up so far.
Philnick is offline
post #3930 of 4599 Old 06-02-2020, 10:27 AM
groove93's Avatar
Liked: 803
That is what I thought. Thank you. Yea I can simply add DSU or Neural X using my AVR, but I'm more into 2-Channel music to begin with, along side a few Multi-Channel DSD files in my Music Library. I cancelled Tidal a few months ago and now I have a 30-day Trial of Qobuz, and that service doesn't even have an Android TV app available.
Sony XBR55X900E
XBox One X
