New Nvidia Shield TV Pro announced! Faster SOC, Dolby Vision, new remote! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 939Likes
post #31 of 1606 Old 10-24-2019, 05:26 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6065
Originally Posted by whiteboy714 View Post
Dynamic range is working on the old Shield, frame rate matching I believe is still not an option. Usually if your device doesn't support DV it will just come up as standard HDR.
Thanks, so if you are watching Netflix will it just output 60hz, or can you adjust for 60 or 24hz? My Sony will do DV, but they dont do it as well as HDR10 IMO, so I just turn DV off if there is a toggle for it. Some devices force it though...
XBR65A9G / XBR65A8F / 55R615
ATV4K / Uverse / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #32 of 1606 Old 10-24-2019, 05:29 PM
whiteboy714's Avatar
Quoted: 1517 Post(s)
Liked: 638
No there is no setting for framerate, its just 60. Thats why a lot of people use the Netflix Kodi add on. You get framerate/resolution matching. My tv is 60 hz as most are. So its getting converted to 60 somewhere, so not a huge deal.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #33 of 1606 Old 10-24-2019, 05:34 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6065
Interesting on the Kodi add on, I would need Kodi anyways, I watch a lot of 1080p/24 files off a NAS.
post #34 of 1606 Old 10-24-2019, 05:36 PM
Highjinx's Avatar
Quoted: 1323 Post(s)
Liked: 538
Does the Nvidia Shield support JBOD devices such as this: Thanks!
https://www.amazon.com/Mediasonic-Pr...60715328&psc=1
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
post #35 of 1606 Old 10-24-2019, 05:40 PM
Quoted: 1905 Post(s)
Liked: 1205
Sounds like you gave up on the ATV4K/Infuse combo.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #36 of 1606 Old 10-24-2019, 05:51 PM
Liked: 638
https://forum.kodi.tv/showthread.php?tid=329767
Here is the thread for it. I don't use it because it is limited, depends on device. Some folks can get it working at 4k on the Shield, HDR is a no go I believe.
It has plenty of hiccups along the way. One thing that is cool is you can add things from netflix to your normal library. So it looks like you own them and don't have to
dig into the netflix add-on.
post #37 of 1606 Old 10-24-2019, 07:29 PM
JohnnytheSkin's Avatar
Quoted: 103 Post(s)
Liked: 74
Be curious to know if the new version has a was to disable DV and just use HDR10? Also, did Nvidia ever work out framerate and dynamic range matching like Roku and ATV4K? When I had the shield a couple of years ago, you kinda had to pick dynamic range at times depending on what you were watching.
Bought one this morning...you can toggle DV on or off. Can also choose a custom display mode that is only HDR10.
Sent from my Pixel 3 XL using Tapatalk
aaronwt, galonzo, beerhunt and 1 others like this.
JohnnytheSkin is offline
post #38 of 1606 Old 10-24-2019, 11:41 PM
DaveFi's Avatar
Quoted: 868 Post(s)
Liked: 281
I had one of these many years ago (I upgraded to the 8 drive bay). As I recall the Shield wouldn't mount more than 1 drive. It's been a while so I could be mistaken.
It would be easier to set up a small SMB server with this, maybe on Coreelec running on a S922x or S912 based box. I do that with my 8 drive bay and it works fine for just streaming media.
Highjinx likes this.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #39 of 1606 Old 10-24-2019, 11:52 PM
Highjinx's Avatar
Liked: 538
Thanks Dave!
Highjinx is offline
post #40 of 1606 Old 10-25-2019, 04:57 AM
Liked: 1205
I attached a 7 port USB hub to one of my Shield ports and all my 10TB drives (currently 4) mount fine.
Mike
post #41 of 1606 Old 10-25-2019, 07:24 AM
ggw2000's Avatar
Quoted: 943 Post(s)
Liked: 467
Could an owner tell me if the 2019 Shield TV Pro comes with the stand in the box? If not, is the 2019 the same dimensions as the 2017 Shield (2017 stand will work)?
Thanks, Gerry
Sony XBR 75X940E - Sony STR-DH790 ATMOS - Sony UBP-X700 UHD BD Player - ATV 4K - 2019 Shield TV Pro
ggw2000 is offline
post #42 of 1606 Old 10-25-2019, 07:37 AM
Liked: 638
Thanks, Gerry
Didn't see a stand. But as far as I can tell it's the exact same device as far as externals.
For anyone interested I tried the smart YouTube app to see if HDR might work. No go. Forcing the vp9 codec causes the video to fail to load.
aaronwt, ggw2000 and galonzo like this.
post #43 of 1606 Old 10-25-2019, 08:00 AM
Liked: 638
Well jeez. Played a 4K video in Mrmc and the shield remote was useless. Wouldn’t do anything. Had to reboot and now all I get is snow through my receiver. Thought the shield was dead but got a picture straight to tv.
Went back to the receiver and still happening. Receiver works on other inputs. Also I can see the nvidia splash screen but then flashing static.
post #44 of 1606 Old 10-25-2019, 08:16 AM
mjwagner's Avatar
Quoted: 1038 Post(s)
Liked: 867
Anyone with the new Shield, can you post the version number of the NetFlix app? If we could get our hands on the updated app I wonder if it would be possible to sideload it onto a 2017 Shield and get ATMOS support?
For reference the version of the NetFlix app on the 2017 Shield is 7.0.0 build 3011.
nc88keyz likes this.
Mark
mjwagner is online now
post #45 of 1606 Old 10-25-2019, 08:28 AM
Quoted: 34 Post(s)
Apparently the Match Frame Rate beta can be "enabled" via Settings - Device Preferences - System - Customise Quick Settings, then accessed from the main menu - anyone tried this on the new Shield (couldn't see the setting in my 2015 or 2017 Shield)?
mtthwgrms likes this.
k2dak is offline
post #46 of 1606 Old 10-25-2019, 08:29 AM
Liked: 638
Right now my Shield is a no go through a Denon x1400, multiple cables, multiple inputs on the receiver. Factory Reset of the Shield, works through my tv but not the receiver.
Not sure how it could possibly be the receiver as it was working just fine and still does otherwise. Sounds like I will have to do a return whenever they get more stock.
Not sure what else to do.
post #47 of 1606 Old 10-25-2019, 08:32 AM
groove93's Avatar
Quoted: 1172 Post(s)
Liked: 652
Do you have Passthrough enabled on your Denon?
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is online now
post #48 of 1606 Old 10-25-2019, 08:33 AM
archer75's Avatar
Quoted: 791 Post(s)
Liked: 413
Hmmmm, might have to pick one up. If I can sell my current shield. Though it seems like everything they added to the new one is just software? I know there's a slightly faster CPU but really any of the rest could be added to the existing shield? I know current shield is on 8.0 and new one is 8.1 so maybe....
I never have gotten the shield remote to control TV on/off or receiver volume whereas my ATV4k remote controlled it all out of the box. Perhaps I should explore this more and see if I can resolve it.
Streaming Devices: Nvidia Shield, 2x Roku 3's, 1st/2nd gen chromecast, ATV4k, Apple TV 4, xbox 360/one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
archer75 is online now
post #49 of 1606 Old 10-25-2019, 08:33 AM
Liked: 638
Not for that input, I could try that but it worked before?
post #50 of 1606 Old 10-25-2019, 08:35 AM
nc88keyz's Avatar
Quoted: 429 Post(s)
Liked: 266
may do a microprocessor reset on the denon or pull plug for 180 seconds. I've seen it before. Also pull the shield power brick from wall for 3 min. You may just need to flush the handshake.
Sent from my SM-G965U using Tapatalk
nc88keyz is online now
post #51 of 1606 Old 10-25-2019, 08:36 AM
groove93's Avatar
Liked: 652
Considering Marantz and Denon AVR interfaces are almost identical, I figured passthrough would be one of the settings to use.
Also,considering Dolby Vision is a new feature for the Shield, is your AVR capable of passing through DV signals?
Sony XBR55X900E
XBox One X
post #52 of 1606 Old 10-25-2019, 08:40 AM
Liked: 638
I will do both although I pretty much already did.
Yeah DV was working, but I also turned it off to be safe. Passthrough doesn't even work, no picture. What a mess.
post #53 of 1606 Old 10-25-2019, 08:43 AM
groove93's Avatar
Liked: 652
Do you recall making any specific adjustment to your HDMI port on the TV which could affect the AVR or the Shield? An "enhanced" mode of some type on the TV?
Sony XBR55X900E
XBox One X
post #54 of 1606 Old 10-25-2019, 08:45 AM
Liked: 638
No I didn't touch the TV, I was messing with settings in the Shield, but I would assume a factory reset would fix that. I can also set to default through the TV which previously worked.
It's really strange, I did find the "match frame rate setting", but it didn't seem to do anything. I diabled it before the reset to see if it would help, didn't seem to.
I had been looking in the denon settings, but just at color space was trying to get the Shield do switch properly. Don't think there is anything I could have messed with.
post #55 of 1606 Old 10-25-2019, 08:51 AM
Liked: 638
Reset didn't do anything, double checked all the settings on the denon. Really strange. I guess I am stuck for now, need to go to work anyways.
post #56 of 1606 Old 10-25-2019, 08:53 AM
groove93's Avatar
Liked: 652
Just as long as the Denon is set to "Passthrough", you wouldn't need to touch the AVR, as the Shield's settings go straight to the display.
This reminds me of when I first got my Sony 4K display. Messing around with the HDMI Ports, Colorspace settings, resolution settings on the Shield, before I knew it, I had a mess on my hands because I didn't understand the tech. Colorspace, HDR/HLG, Full and Limited, this stuff was all alien to me.
I hope you get the Shield back up and running on your setup.
Sony XBR55X900E
XBox One X
post #57 of 1606 Old 10-25-2019, 08:57 AM
Liked: 638
When I set it to passthrough I get no picture through the AVR. But I get one straight to TV. As far as HDMI modes its the same old settings from the first shield. Nothing really new and different so don't see how it could be that.
Remember it locked up during a movie, pushing power button resulted in this, so I didn't change a setting and get static. Seems if it was just a setting a factory reset would get it back to where it was before and working.
post #58 of 1606 Old 10-25-2019, 09:04 AM
groove93's Avatar
Liked: 652
I can only go by what I recall seeing on my Marantz AVR, but in the same section for Passthrough, CEC and ARC are two additional features that I have disabled. If CEC is turned on, my AVR automatically changes my TV's input to HDMI3 where my Xbox One is connected. This screws up my Harmony Remote Commands.
Sony XBR55X900E
XBox One X
post #59 of 1606 Old 10-25-2019, 09:07 AM
nc88keyz's Avatar
Quoted: 429 Post(s)
Liked: 266
I blame Denon. 99.9999% of the time it is just that. Sorry but it's the truth. If you did a microprocessor reset on the denon it wipes it all out. audessy input labels assignments ..everything. hdmi ids. back to wizard with denon easy setup!
dwaleke and rjmcinnis like this.
post #60 of 1606 Old 10-25-2019, 09:07 AM
Liked: 638
Oh I understand that, but this is much more than that. I even set the Shield to 1080p, won't play nice with the receiver.
