New Nvidia Shield TV Pro announced! Faster SOC, Dolby Vision, new remote! - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 2337Likes
post #1861 of 4538 Old 12-26-2019, 08:01 PM
thomasphoenix's Avatar
Quoted: 256 Post(s)
Liked: 153
Originally Posted by Huang wei View Post
it seems it not works for me, still happened every 5 mintues
Witcher is @ 24hz that's why there is a problem with 23.976hz. Many new Netflix programs are 24hz. Older are 23.976.
Keenan, rjmcinnis and a5ian300zx like this.
TV-Sony Bravia KD-65"A1, Pioneer SC-LX901 7.2.4 ATMOS/DTS-X, Polk DSW 660*2, Polk RTi A7*2, Pol Csi A6, Polk RtiA5*2, Polk Tsi300*2, Polk TSX 220B *2, Polk OWM 3*2, ZidooZ9s, Nvidia Shield Pro-19, Zappiti-4kHDROne, Oppo UDP-203, XboxOneX, PS4, Oppo BDP-83, Darbee DVP-5000s, ZidooX10, Sony Bravia HX925 55"
thomasphoenix is online now
post #1862 of 4538 Old 12-27-2019, 01:56 AM
a5ian300zx's Avatar
Quoted: 644 Post(s)
Liked: 221
What was that app that does manual switching for you?
I tried the beta version of nvidia app but it does nothing when I select it.
Sent from my Samsung Note 9 using Tapatalk
TV: Sony 65" A1E OLED Surround: Sennheiser AMBEO + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Iscan Mini + Darbee 5000S Players: Oppo 203 (Coris) / Nvidia Shield TV Pro 2019 / VU+ Ultimo 4K NAS: Qnap TVS-871 Pro i7 10GBE
a5ian300zx is offline
post #1863 of 4538 Old 12-27-2019, 04:21 AM
Quoted: 256 Post(s)
Liked: 153
The is an app called 'refresh rate' in Google play store. you can set it up to auto change refresh rate as per source, so 23.976hz movies & 24hz movies play back in native.
Remember it's only need reed or Netflix not for Plex & Kodi as those apps do native refresh rate within as long as you have enabled it in the app settings.
galonzo and a5ian300zx like this.
post #1864 of 4538 Old 12-27-2019, 06:10 AM
ggw2000's Avatar
Quoted: 1024 Post(s)
Liked: 504
A while back I looked into "refresh rate" and from what I saw it appears to be a real pain to setup and get going? Is it that bad to get it setup?
Gerry
Sony XBR 77A9G - Sony STR-DH790 ATMOS - Sony UBP-X700 UHD BD Player - 2019 Shield TV Pro - 2019 Roku Ultra
ggw2000 is offline
post #1865 of 4538 Old 12-27-2019, 06:23 AM
JohnnytheSkin's Avatar
Quoted: 131 Post(s)
Liked: 78
So one other suggestion that worked for me, is on my Sony TV I had the Cinemotion setting at High. Turning it to Low fixed the stutter, leaving the Shield at it's normal 59.xxx display setting.
The other option, as mentioned, is to manually set the Shield to 24Hz output but I don't want to keep toggling.
Sent from my Pixel 3 XL using Tapatalk
JohnnytheSkin is offline
post #1866 of 4538 Old 12-27-2019, 06:38 AM
Quoted: 173 Post(s)
Liked: 45
Gerry
It's quite easy.
galonzo likes this.
65" Sony A9G | 49" Sony X900E | Sony HT-ST5000 SB | 2019 Nvidia Shield TV Pro | Xbox One X
jbalsor is offline
post #1867 of 4538 Old 12-27-2019, 06:40 AM
Quoted: 256 Post(s)
Liked: 153
Gerry
Hi Gerry, Its fairly well explained, https://www.nvidia.com/en-us/geforce...l-google-play/
One another note,there is currently a problem with the Netflix app on Sheild 2019, where the video tends to go 'slow motion' or skip bits. This is an issue whether the refresh rate app is used or not, this needs to get fixed by Netflix. The sheild devs have responded that this problem has been registered.
Thomas
ggw2000, rjmcinnis and jbalsor like this.
post #1868 of 4538 Old 12-27-2019, 08:29 AM
UHD Addict
aaronwt's Avatar
Quoted: 9985 Post(s)
Liked: 6655
Gerry
It only takes a few minutes to setup. And then you can select what apps you want to use with it.
Sent from my Galaxy S10
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1869 of 4538 Old 12-27-2019, 08:31 AM
UHD Addict
aaronwt's Avatar
Liked: 6655
Thomas
I have not run across this with Netflix. And I've watched around fifteen hours of Netflix with the Shield Pro using the refresh rate app. But I did run across this with the Amazon app. But once i turned off the refresh rate app with Amazon, the issue hasn't turned up.
galonzo likes this.
aaronwt is offline
post #1870 of 4538 Old 12-27-2019, 08:43 AM
Quoted: 256 Post(s)
Liked: 153
I read several posts on the nvidia sheild forum, then watched the entire season of Witcher, it happened 3-4 times for me.
The refresh rate app is wonderful though.
post #1871 of 4538 Old 12-27-2019, 10:54 AM
Fargus777's Avatar
Quoted: 41 Post(s)
Liked: 25
I'm assuming i know the answer, but just wanting to throw this out there. Whenever I put the Shield on Dolby Vision 59.940 hz i get green pixelation all over the screen, but when i drop it down to dolby vision 23.976 the pixelation goes away. Is this possibly due to the HDMI cable not being able to support 4K HDR @ 60hz? I know the cable going from the shield to the receiver is a monoprice certified premium one that advertises it, but im not sure about the one that runs through the wall from the TV to the receiver. Might need to rerun that one. I wasn't sure if there was any other setting to look for to get rid of the green pixelation when using the 59.xxx hz setting.
side note, there is no pixelation when i do the HDR10 59.xxx setting
Gamertag: Fargus
Playstation ID: Fargus79
Fargus777 is offline
post #1872 of 4538 Old 12-27-2019, 11:25 AM
Quoted: 256 Post(s)
Liked: 153
While it may me the cables, to rule out other factors could you share your TV model? Some televisions dont support DV at more than 23.976.
Fargus777 and galonzo like this.
post #1873 of 4538 Old 12-27-2019, 11:40 AM
Fargus777's Avatar
Quoted: 41 Post(s)
Liked: 25
Sony 75" Z9D
Gamertag: Fargus
post #1874 of 4538 Old 12-27-2019, 12:13 PM
Quoted: 1279 Post(s)
Liked: 840
I find that app causes constant HDCP errors when I use it with NetFlix or Amazon Video. Nice software, but not without issues. nVidia needs to implement automatic rate changes into the OS like they did with color space matching.
rjmcinnis likes this.
LG 77 C9 (Also LG 65 C7 and Sony XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #1875 of 4538 Old 12-27-2019, 02:12 PM
Keenan's Avatar
Quoted: 4564 Post(s)
Liked: 4221
I thought Nvidia via a post at their forum has already stated that auto-refresh rate is not going to happen?
Keenan is online now
post #1876 of 4538 Old 12-27-2019, 02:20 PM
HD-Master's Avatar
Quoted: 789 Post(s)
Liked: 902
Correct
HD-Master is online now
post #1877 of 4538 Old 12-27-2019, 03:39 PM
Liked: 840
True, but we can keep leaning on them to try and get them to change their mind.
galonzo likes this.
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #1878 of 4538 Old 12-27-2019, 05:21 PM
mpatnode's Avatar
Quoted: 120 Post(s)
Liked: 84
Originally Posted by mpatnode View Post
FLIRC + Harmony works fine, but it just maps everything to the keyboard equivalent, AFAICT. The Kodi mapping works just as well as the NVidia specific one. What I'd really like is the ability to map specific Shield functions to specific keyboard keys. IE: Auto-sync, AI, etc. Anyone know how to do that?
Just FYI. Turns out the Refresh Rate app also provides some extra remote key mapping. Was able to map the refresh rate switching to a numeric key.
galonzo and rjmcinnis like this.
mp
mpatnode is offline
post #1879 of 4538 Old 12-27-2019, 05:23 PM
HD-Master's Avatar
Quoted: 789 Post(s)
Liked: 902
No. There was a specific reason they listed for why it will never be automatic at the system level, due to a requirement of Google. I haven’t been able to find their comment now though. They have also said that the ability to set 3rd party launchers as the default has been permanently disable due to a Google requirement as well.
post #1880 of 4538 Old 12-27-2019, 05:42 PM
Keenan's Avatar
Liked: 4221
Third-party launchers being able to have the machine startup in the Kodi interface, for example, is that what that means?
And what was the Google requirement WRT auto-refresh rate?
post #1881 of 4538 Old 12-27-2019, 06:04 PM
HD-Master's Avatar
Quoted: 789 Post(s)
Liked: 902
No, third party launchers for the Shield itself. You can still use them, but you can no longer set them to be used instead of the default system one. It’s a limitation of official Google certification. Google is no longer allowing it going forward. It is not an NVIDIA or Shield issue.
groove93 likes this.
post #1882 of 4538 Old 12-27-2019, 06:49 PM
Quoted: 256 Post(s)
Liked: 153
Sony 75" Z9D
I believe the processor is the same as my A1E. So you're good there. Make sure you are using ports 2 or 3 and have 4k enhanced turned on for inputs.
post #1883 of 4538 Old 12-27-2019, 09:39 PM
whiteboy714's Avatar
Quoted: 1901 Post(s)
Liked: 821
Pretty sure their reason for not allowing auto refresh rate was Netflix and the issues that it brings with the previews. At least the quote that was posted here from them said as much.
Keenan and rjmcinnis like this.
TCL 65R625 -- Denon X3500h -- Klipsch RP600m -- RP450C -- Ascend HTM 200 SE -- Dual Klipsch RW-10
whiteboy714 is offline
post #1884 of 4538 Old 12-27-2019, 10:34 PM
Quoted: 256 Post(s)
Liked: 153
Netflix Preview videos come in a variety of refresh rates, Auto Refresh changes would mean multiple hdmi re-syncs while browsing, I truly don't know how Apple TV handles this aspect. I believe they may be having their own custom launcher for Netflix.
post #1885 of 4538 Old 12-27-2019, 11:36 PM
Keenan's Avatar
Liked: 4221
Right, I know what you mean now, I installed a custom launcher on one of those cheap Amlogic boxes awhile back.
post #1886 of 4538 Old 12-27-2019, 11:39 PM
Keenan's Avatar
Liked: 4221
The Netflix app on the Apple TV does not have that screen blanking/auto-refresh problem while scrolling through titles, it only changes the framerate once the title is selected and starts to play.
post #1887 of 4538 Old 12-28-2019, 12:38 AM
Quoted: 256 Post(s)
Liked: 153
Oh ok! Xbox1X has the same problem as Shield it's 59.940 hz refresh rate. Does the Apple TV UI & UX look and work the same way as Shield?
post #1888 of 4538 Old 12-28-2019, 04:35 AM
Liked: 840
Well then seems like leaning on Google, while fruitless, might be helpful. Dumb question, will a HTPC be just as problematic, or are there Media Center apps that will handle all this for you to give you a Shield or ATV4K like interface with more accuracy around frame rate and resolution matching?
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #1889 of 4538 Old 12-28-2019, 01:06 PM
Keenan's Avatar
Liked: 4221
The Netflix UI? Yes, they are very similar with the only major difference being that the Apple Netflix app stays at 60 Hz while scrolling titles/previews and the Shield Netflix app changes to the native frame rate on every title/preview.
post #1890 of 4538 Old 12-29-2019, 04:43 AM
Quoted: 256 Post(s)
Liked: 153
Sheild Tv-pro 2018 Having trouble with a bunch of Hong Kong blu ray backups with HD audio. 'Ip man 3' showing up as dts hd 5.1 instead of DTS-X,
'Big brother' Tru-HD skipping and stuttering on Plex , MrMC also skips and stutters on the file. Both play flawlessly on Zappiti-one and Zidoo Z9s.
