New Nvidia Shield TV Pro announced! Faster SOC, Dolby Vision, new remote! - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 1475Likes
post #2521 of 2630 Old 02-12-2020, 03:45 PM
galonzo's Avatar
Quoted: 1452 Post(s)
Liked: 1981
Originally Posted by 3DSammy View Post
Nothing projector specific but I'd would suggest applying for the Hot fix after you've confirmed that the hardware works. Make sure to install Disney+ app as once applied the Hot fix would prevent it's installation. The warning about not being able to back out of Hotfixes once applied, is specific up until the next general release. After that your back in the standard update release schedule.
The details:
2019 SHIELD Experience Upgrade 8.1.0+ HotFix Image
Application form
If you already have D+ installed, will you be able to update it after installing the current hotfix? (i.e. what if D+ adds Atmos support in an update before the next Shield general release?)
Main: UN78HU9000/SEK-3500 | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630)
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Knives Out (2019) and other UHD Digital codes (and some HD codes)
galonzo is online now
post #2522 of 2630 Old 02-12-2020, 03:54 PM
whiteboy714's Avatar
Quoted: 1620 Post(s)
Liked: 708
Originally Posted by veggav View Post
Yeah but I believe with Kodi is different because if you let Kodi do it's thing, it will upscale the video stream by itself.
If you tell Kodi to output at 1080p or 720p than thats what the Shield will output and the TV will be doing the upscaling.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #2523 of 2630 Old 02-12-2020, 05:22 PM
Liked: 0
Originally Posted by whiteboy714 View Post
I was referring to the webui not the app. The app does work yes. Just doesn't have all the info that the webui had.
Ahh, my mistake
amnigo is offline
post #2524 of 2630 Old 02-12-2020, 05:29 PM
taz291819's Avatar
Quoted: 420 Post(s)
Liked: 303
That's correct, you need resolution switching turned on in Kodi, and whitelist what you want.
Vizio P65-C1 (2016)
Onkyo Tx-NR656 (5.1.2 setup)
JBL Studio S-Center, JBL Studio S26ii (FL/FR), JBL N24 (LS/RS), JBL N24 (Overhead Atmos), JBL Studio SUB250
Nvidia Shield TV 2019 Pro / Fire Stick 4K
taz291819 is online now
post #2525 of 2630 Old 02-13-2020, 03:41 AM
Quoted: 47 Post(s)
I'm not sure if Disney+ updates work but you may be able to side load an updated APK if your willing. I've cancelled Disney+ so an update never was available after I applied the Hotfix to my shield.
galonzo likes this.
3DSammy is offline
post #2526 of 2630 Old 02-13-2020, 05:00 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
This Hotfix I see people talking about. Is this firmware for the shield? I googled it and it appears to be beta firmware. I asking because I plan on buying a shield tube soon.
Man cave-Marantz 8012, Oppo 203, 4K ATV, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM. B&W PX for travel
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #2527 of 2630 Old 02-13-2020, 05:18 AM
sprins's Avatar
Quoted: 143 Post(s)
Liked: 100
Correct, you enter the beta program. It’s worthwhile since there are some important fixes and it’s unknown when they will be released as an official firmware.
HT:7.2.4 - Marantz AV7705 - InterM amps - Bose Controlspace ESP88 16x16
LCR: Bose 802-III - Surround/Atmos: Bose 502A - LFE: Bose AWCS
Living:3.1 - Marantz AV7702mk2 - InterM reference amps - Bose Controlspace ESP880 8x8
LR: Bose 901mk3 - C: Bose DS100SE - LFE: Bose MB12
sprins is offline
post #2528 of 2630 Old 02-13-2020, 10:20 AM
SamuriHL's Avatar
Quoted: 272 Post(s)
Liked: 333
It should be "soon" since the shield pro hasn't had an official update since release.
LG C8 OLED | Pioneer VSX-LX303 | HTPC (9900k, RTX 2070) | nVidia SHIELD 2019 | Panasonic UB820
SamuriHL is online now
post #2529 of 2630 Old 02-13-2020, 11:52 AM
UHD Addict
aaronwt's Avatar
Quoted: 9756 Post(s)
Liked: 6422
Scratch all that.
My receiver is capable of showing the color space and it doesn't switch to plain YCbCr.
It looks ok because the shield must be expanding the color space to bt.2020 with match color space turned off.
Still this sucks big time:
The Witcher plays at BT.2020 YCbCr 10bits.
Friends plays at BT.2020 YCbCr 10bits.
So you can see the problem.
Friends should be played at YCbCr without bt.2020 flag and 4:2:0.
Some TVs have an issue with that. Fortunately my TCL and Sony UHD TVs have no problem with SDR being sent with BT2020. So I leave the colorspace switching off.
ggw2000 likes this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #2530 of 2630 Old 02-13-2020, 01:40 PM
Quoted: 275 Post(s)
Liked: 55
Originally Posted by Fjodor2000 View Post
Thanks everyone that commented on this.
I checked the nVidia Shield support forum, and the topic is apparently being discussed there with the nVidia support, see:
https://www.nvidia.com/en-us/geforce...-remote-for-m/
https://www.nvidia.com/en-us/geforce...change-via-re/
https://www.nvidia.com/en-us/geforce...for-m/2354890/
Let's hope they fix this, because currently the volume buttons on the nVidia Shield remote control are completely useless to many users, since they change the volume too slowly.
I'm just glad the menu button can be programmed to be a mute button on the new remote. That makes the slow vol buttons less of a pain.
Tfid is offline
post #2531 of 2630 Old 02-13-2020, 02:39 PM
Quoted: 275 Post(s)
Liked: 55
I received the hot fix yesterday and it fixed the color space change )
I'm really really happy with my Shield now!
So help me understand, so I can enjoy the A.I. upscaling with Kodi, I need to whitelist 1080p and 720p resolutions so kodi changes resolutions and this way the shield will perform the upscaling, is that correct?
No, You need to prevent Kodi from switching resolution output to 1080p. If Kodi matches resolution output to the source of a 1080p input, the TV will do the upscaling to 4K, and the Shield's AI won't be in effect.
The source has to be 1080p or 720p and 30fps or less, and the Shield's output must be set to 4K so it forces the Shield (Kodi) to upscale from less than 4K to 4K.
This is done by whitelisting only 4k resolutions in Kodi.
galonzo and beerhunt like this.
Tfid is offline
post #2532 of 2630 Old 02-13-2020, 04:52 PM
HD-Master's Avatar
Quoted: 622 Post(s)
Liked: 723
New hotfix (5th) is now available.
galonzo likes this.
LG OLED65C7P - Professionally Calibrated l Apple TV 4K l Microsoft Xbox One S l Sony STR-ZA1100ES l Polk Audio CS2 Series II Center Channel l Polk Audio Monitor 60 Series II Floorstanding L/R l Polk Audio Monitor 45B Rear Surround l Dual BIC V1220 Subwoofers
HD-Master is offline
post #2533 of 2630 Old 02-13-2020, 07:12 PM
avernar's Avatar
Quoted: 557 Post(s)
Liked: 512
I bought a the Shield tube to replace my older one. Unfortunately I ran into an issue with Plex. Playback stutters on some movies and sometimes freezes then aborts playback. Some are high bitrate while some are not. The old Shield handles them perfectly.
Anyone have any ideas? Do I just have a defective unit?
avernar is online now
post #2534 of 2630 Old 02-13-2020, 07:19 PM
SamuriHL's Avatar
Quoted: 272 Post(s)
Liked: 333
Any idea what it fixes?
post #2535 of 2630 Old 02-13-2020, 07:21 PM
HD-Master's Avatar
Quoted: 622 Post(s)
Liked: 723
https://www.nvidia.com/en-us/geforce...image/2386154/
- Fixes an issue of stutters & cracking sound with few headphones when dolby processing is enabled - Improves volume control for 2015 remote and controller - Fixes and issue where Google home commands would cause the volume to lower but not be raised after the command is completed - Fixes an issue of System hang while enable/disable "Match content color space" on DV playback in Netflix - Includes incremental Dolby vision fixes - Fixes an issue where interlaced video playback exhibits stutters after 13minutes of playback This HotFix image has not been certified by Google so no Disney+ installs or updates from the playstore while on this image but it’ll continue to work as is if you have it installed.
SamuriHL likes this.
post #2536 of 2630 Old 02-13-2020, 07:27 PM
SamuriHL's Avatar
Quoted: 272 Post(s)
Liked: 333
Thanks. Looks like they're getting closer to a final release.
post #2537 of 2630 Old 02-13-2020, 07:29 PM
Quoted: 49 Post(s)
Liked: 43
I believe a fix was released last week:
https://forums.plex.tv/t/new-old-pla...-dv/489790/123
https://forums.plex.tv/t/release-ann...eta/154124/277
k2dak is online now
post #2538 of 2630 Old 02-14-2020, 12:42 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
Thanks for confirming that for me.
post #2539 of 2630 Old 02-14-2020, 03:28 AM
Epedemic's Avatar
Quoted: 25 Post(s)
Talking
Yay! The new hotfix fixed the slow volume buttons when using both IR or CEC to a Onkyo RZ820 I can now hold the buttons and have the volume keep changing
Epedemic is offline
post #2540 of 2630 Old 02-16-2020, 05:36 PM
mzs22's Avatar
Quoted: 260 Post(s)
Liked: 95
I have been having problems getting my xbox controller to connect to my shield. I got it to pair once but didn't work once it was paired. The next time I went to pair it I couldn't get it too. Is there something I am missing ?
mzs22 is offline
post #2541 of 2630 Old 02-17-2020, 05:01 AM
Steelman99's Avatar
Quoted: 257 Post(s)
Liked: 90
From what i have read only the authentic Shield game controller will work properly. A new PS4 controller i tried had input lag. Most other controllers have issues.I am not a big game person,so it was not a big concern for me , although a shield controller will be delivers today, we will see how it preforms.
Samsung QN55Q8FN / Pioneer Elite SC-81 AV Receiver/ ELAC Uni-Fi B5 Book Shelves/ SVS PB-1000 Subwoofer/ Nvidea Shield Pro / iFi SPDIF iPurifier/ MiniDSP 2x4 HD
Steelman99 is offline
post #2542 of 2630 Old 02-17-2020, 08:58 AM
movd's Avatar
Quoted: 155 Post(s)
Liked: 85
I use an Xbox one controller via bluetooth on my 2015 Shield and really don't have any problems. I know this doesn't help you much, but I just want to mention my experience.
Vizio P55-C1 | Sony 49X900F
Nvidia Shield | Zidoo X9S | Popcorn Hour VTEN | Firestick 4K | AppleTV 4K
movd is online now
post #2543 of 2630 Old 02-17-2020, 09:41 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
Harmony Remote
Anyone here using the Tube with a Harmony Remote (One)? If so do you have any issues? I plan on purchasing this coming weekend.
Last edited by pappaduke; 02-17-2020 at 09:41 AM. Reason: Add additional information
post #2544 of 2630 Old 02-17-2020, 11:36 AM
JPHCCFC's Avatar
Quoted: 71 Post(s)
I'm using two harmony remotes with two shield units, one 2017 and the other 2019 pro and having no problems whatsoever.
JPHCCFC is offline
post #2545 of 2630 Old 02-17-2020, 11:48 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
Thanks for the reply. I'm going to pick one up this weekend.
post #2546 of 2630 Old 02-17-2020, 11:51 AM
Quoted: 304 Post(s)
Liked: 155
and as an added bonus you can sell off the remote for around $70 to $80 on ebay! I bought two tube versions and a pro and sold all remotes on ebay for $75 EACH. Considering I only paid $100 for the tube versions I am a pretty happy camper..
aaronwt likes this.
ipca204 is online now
post #2547 of 2630 Old 02-17-2020, 11:59 AM
pappaduke's Avatar
Quoted: 477 Post(s)
Liked: 466
I see the remotes sell for $29.99 from Nvidia, but I also see they are out of stock. I guess it's a sellers market.
aaronwt and galonzo like this.
post #2548 of 2630 Old 02-17-2020, 12:11 PM
UHD Addict
aaronwt's Avatar
Liked: 6422
Wow!! those are amazing prices.
I'm still amazed at some of the things there is a big market for on ebay.
Like the BD slip covers I always throw away. I'm still amazed there is a big market for selling those things.
aaronwt is offline
post #2549 of 2630 Old 02-17-2020, 12:12 PM
djnice77's Avatar
Quoted: 90 Post(s)
Liked: 27
Dolby Vision Profile 5 files works fine with MrMC after latest hotfix (no more crash).
SamuriHL and JGrana like this.
djnice77 is offline
post #2550 of 2630 Old 02-17-2020, 02:11 PM
Steelman99's Avatar
Quoted: 257 Post(s)
Liked: 90
I use the "One" with a FLIRC IR usb dongle someone here recommended.It works pretty darn good. Just remember u have to use the FLIRC device setup in the Harmony software. it is not plug and play.
