Synology DS416+ & LG C8PUA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-11-2020, 10:04 AM - Thread Starter
Liked: 0
Hi all,
Been tearing my hair out trying to figure out how to get this TV to reliably connect to my Synology NAS and was hoping someone could help. I can occasionally see it pop up in my list of sources and if I start a movie I can watch it through. However, if I let it sit idle for a couple of minutes it will disappear and it's very difficult to get it connected again. Current setup:
-Synology DS416+ using DNLA via the Media Server application. Connected via ethernet to switch, switch to router
-Netgear XR500 with uPNP enabled
-LG OLED C8PUA, connecting both via wireless or ethernet
When I AM able to get it to work it usually involves waking up the Synology via some other device in the house, then changing the network setup on the TV. This can be plugging/unplugging the ethernet cable or switching between the 2.4ghz and 5ghz wireless networks. It isn't reliable and often doesn't work, but there is a reliable correlation that it does work SOMETIMES. I've played with the broadcast interval and it's currently at 2 minutes.
Can anyone make any suggestions for what to try? Any help is appreciated!
FrostSabre is offline
post #2 of 5 Old 02-11-2020, 02:20 PM
Charles R's Avatar
Liked: 860
Since your NAS supports WOL (Wake on LAN) it's probably worth checking. Try turning it off (24/7) and see if it works... if it does you know it's WOL related. If it is you might be able to spin down the drives and leave it up... that's what I do with my ODROID (NAS storage) since it only draws a couple of watts idling. Luckily everything (so far) waits for the drives to spin up outside of the Amazon Echo where at times I have to repeat the request... as it quickly times out.
125" Projection | 5.2.4 Audio | Shield TV | LibreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" LG OLED TV | TiVo | Shield TV |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #3 of 5 Old 02-11-2020, 04:22 PM - Thread Starter
Liked: 0
Interesting, I will give that a shot. Thanks!
post #4 of 5 Old 02-11-2020, 07:07 PM - Thread Starter
Liked: 0
Unfortunately it looks like I already had WOL off and disk hibernation after 20 minutes. This is much longer than it takes to disappear from the TV if detected initially.
post #5 of 5 Old 02-12-2020, 08:59 AM - Thread Starter
Liked: 0
Figured this out! Apparently the issue was that I needed to uncheck "Disable IGMP Proxying" on my router. Apparently IGMP snooping can also be an issue on managed switches, but that wasn't the case for me.
c8pua , dnla , lg oled , nas , Synology
