AnyDVD/CloneBD vs DVDFAb (4K Ripping image quality)) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-03-2020, 08:02 AM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
Why won't Windows 10 recognize my KS9000 as HDR capable
I have changed the title of this thread because for the moment the source of my trouble has changed. Please see posts 10 and 11 below for the current core question and if interested below this line for how the original troubleshooting started:
I have been using AnyDVD/CloneBD for a long time now and AnyDVD/Handbrake before that. Recently I was in need of some software that DVDFab had to offer, and the "bundle" pricing just seemed to make sense so I now have licenses for both.
I recently did some comparisons between videos ripped with each software (for reasons I'll cover in another thread). I found that there is a substantial difference in the image on 4K videos between the two programs, while BluRay didn't seem to have the same visible variance.
The DVDFab rip seems to have a sharper image with more detail, but the color is muted / washed out. 1st screen image
The CloneBD rip is deeper colors but is saturated and looses some of the detail you should pick up in 4K. 2nd screen image
Has anyone noticed this? I have not been able to find any settings that would adjust this during ripping.
2K Blu Ray was not noticeably different between the results.
Thanks for any thoughts or help on how this might be adjusted. I'm really not happy with either results.
There is also a separate question about video studder, but I'll do that in a separate thread.
Name:	Bad Times (DVDFAB).JPG
ID:	2720346   Click image for larger version
Name:	Bad Times (CloneBD).JPG
Marantz - AV7702mkii | Adcom - GFA 7500 (2 Ea)
5.1.2 Definitive Technology Speakers | Mains: BP-20 (bi-amped) | Center: CLR (bi-amp custom crossover) | Rears: BP-6 | Front Height: BP-1
Media Player: HTPC | BR Player: Pioneer BPD-80D
UnRaid / Plex Server
TODDAVS is offline
post #2 of 13 Old 05-03-2020, 08:15 AM
Quoted: 163 Post(s)
Liked: 124
The DVDFab output looks like it was a 4K rip that had it's HDR stripped without proper tone mapping. What was the output video profile you used in DVDFab?
jwort93 is online now
post #3 of 13 Old 05-03-2020, 08:35 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
I'm using MKV.4K.H265.10bit
I've tried 12bit, but it doesn't seem to use hardware acceleration and would take an eternity to process.
I have an image attached with my profile settings
Also, I tried ripping two different movies with those settings, both have the same issue.
Sorry for not replying more quickly today and thanks for your help.
Name:	Profile Settings.JPG
ID:	2720694   Click image for larger version
Name:	Profile Settings1.JPG
TODDAVS is offline
post #4 of 13 Old 05-03-2020, 08:45 PM
eric.exe's Avatar
Quoted: 118 Post(s)
Liked: 45
DVDFab did not properly tonemap the HDR to SDR. Do you want SDR video? It could still be HDR but your playback software on PC isn't tonemapping to SDR either. If you play the DVDFab version on a HDR TV it might show in HDR if DVDFab preserved the HDR metadata. If not you can play with madVR's tonemapping to convert to SDR properly. CloneBD probably did a sloppy SDR tonemap.
eric.exe is offline
post #5 of 13 Old 05-03-2020, 10:25 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
Is the loss of HDR because I'm using 10 Bit instead of 12 bit? I'd rather have full HDR.
TODDAVS is offline
post #6 of 13 Old 05-04-2020, 05:29 AM
Quoted: 163 Post(s)
Liked: 124
No, HDR10/HDR10+ is only 10 bit. Have you tried playing the file on a tv with HDR support rather than your computer?
post #7 of 13 Old 05-04-2020, 08:51 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
I just copied it into Plex (direct play, no transcodning). The color was worse and resolution even grainy. I did learn this:
DVDFAb ripped movie is noted "4K (HEVC Main 10 HDR)" This is the washed color version.
ConeBD ripped movie is noted as "4K (HEVC Main)" This has much better color but missing the finer detail and doesn't appear to be the sharper image.
So does this mean the CloneBD movies are actually coming out SDR and the DVDFab movies are HDR, but also not correctly tone mapping?
How should I be able to rip a correctly formatted HDR 4K movie?
TODDAVS is offline
post #8 of 13 Old 05-04-2020, 09:00 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
OK I think I figured out my setting issue with CloneBD causing it to be SDR. Doing a test rip, and hoping the tone mapping isn't an issue.
I still have no idea what is going on with DVDFab
TODDAVS is offline
post #9 of 13 Old 05-04-2020, 09:55 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
The CloneBD 10 bit file is the exact same as the DVDFab 10 bit file. color washed out.
TODDAVS is offline
post #10 of 13 Old 05-04-2020, 10:56 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
So continuing to trouble shoot. Windows 10 is not recognizing that my display is HDR compliant.
My Plex player is an HTPC with a GTX 1060 video card. The card is HDR compliant
The HTPC plugs into my Marantz processor, AV-7702mkii... it is HDR10 compliant
When I look in the windows settings it shows my display, as the Marantz processor, not my TV.
The TV is a Samsung KS9000 and is also HDR compliant.
TODDAVS is offline
post #11 of 13 Old 05-06-2020, 09:48 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
Any help with this?
I think the current question is why will Windows not recognize my KS9000 as HDR capable.
TODDAVS is offline
post #12 of 13 Old 05-08-2020, 06:42 PM - Thread Starter
TODDAVS's Avatar
Quoted: 74 Post(s)
still looking for some help with this.
TODDAVS is offline
post #13 of 13 Old 05-23-2020, 12:49 AM
Stevetd's Avatar
Quoted: 461 Post(s)
Liked: 211
Will your tv play an mkv file from a usb device? Maybe try that to see if it plays correctly that way. If it does then you know it’s either your htpc or your AVR. Maybe plug your htpc directly to your tv first.
Stevetd is offline
