Streaming with Standard BD player question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-18-2020, 10:19 AM - Thread Starter
Liked: 0
If I want to watch Amazon shows that are native 4K do I have to have a newer device or does Amazon have these shows in HD too so that a standard BD player will play them? My tv is 4K but I don’t want to use it as streaming device. Waiting to get Apple 4K tv unit. Just wasn’t sure if shows shot in 4K had HD versions too. Thank you.
whgarrett1394 is offline
post #2 of 4 Old 05-18-2020, 11:10 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 585
Amazon will have the same show listed twice, one for HD, one for UHD. And you can play either on a normal HD device without issues. But watch out that Amazon will automatically detect that you are playing a UHD show on a HD device and replace it with the HD version instead in the suggested list.
Since the two playlists are independent to each other, it will be a pain to track your progress on a TV series when switch back and forth between HD device and 4K device.
Remember, 4K playlist has the UHD listed in the show title. If you are playing a show without UHD name in the title, that is a normal HD playlist.
Foxbat121 is offline
post #3 of 4 Old 05-18-2020, 12:21 PM - Thread Starter
Liked: 0
Thank you for the quick reply.
post #4 of 4 Old 05-18-2020, 03:34 PM - Thread Starter
Liked: 0
Also if anyone knows. My player has only hdmi 1.4. It claims it can upscale to 4K. Will the limit on frame rate pose a problem when upscaling for my 4K tv? Like I said. I’m only going to be using it for a bit until I get an Apple 4K tv. Thanks again.
