Questions on DLink DSM-520 - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 1954 Old 07-10-2007, 05:59 AM
aldamon's Avatar
Originally Posted by knsdye View Post
Now that my device thinks it is 1.05...if and when DLINK comes out with a new update, I'll have to do this routine and "trick" it again?
No it doesn't. We've already established that auto-updates will work fine after a manual downgrade.
aldamon is offline
post #662 of 1954 Old 07-10-2007, 09:04 AM
outatime80's Avatar
Hello all
Thanks for the details for downgrading, I have got 90% of the way there but am getting a message when I try and upgrade to check my network connection.
I have done the connect to internet text and that works fine, I am using bullet proof server as per msg 655 and have it all connected and working fine using port 22 to connect and changed the URL for medialounge to my local IP it see's the new firmware but when I click it gives me the network error.
This is the log from the FTP:
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > connected to ip : 192.168.2.12
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > sending welcome message.
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > 220 BulletProof FTP Server ready ...
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > USER anonymous
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > 331 Password required for anonymous.
(000006) 7/10/2007 11:38:30 AM - (not logged in) (192.168.2.68) > PASS ********
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > logged in anonymously with login/pass : anonymous/[email protected]
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 230 User test logged in.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > CDUP
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > asked to change directory : 'C:\\ftp\\ -> C:\\ftp\\' --> Access allowed.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 250 CWD command successful. "/" is current directory.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > TYPE I
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 200 Type set to I.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > SIZE /DSM520-VerInfo.txt
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 213 57
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > PASV
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 227 Entering Passive Mode (192,168,2,12,46,135)
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > RETR /DSM520-VerInfo.txt
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > asked to download 'C:\\ftp\\DSM520-VerInfo.txt' --> Access allowed.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 150 Data connection accepted from 192.168.2.68:1080; transfer starting for DSM520-VerInfo.txt (57 bytes).
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > started downloading 'C:\\ftp\\DSM520-VerInfo.txt'.
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > finished downloading 'C:\\ftp\\DSM520-VerInfo.txt' - (00:00:01 - 0.056 KB - 0.056 KBytes/s)
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 226 Transfer ok
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > QUIT
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > 221 Bye bye ...
(000006) 7/10/2007 11:38:30 AM - anonymous [test] (192.168.2.68) > disconnected. (00:00:00)
As you can see it connects just fine but thats all it does, doesnt try to download the 2nd file with the firmware in because of the check network error
Can anyone please help me?
Thank you
Stu
outatime80 is offline
post #663 of 1954 Old 07-11-2007, 12:55 AM
sebw7561's Avatar
Did you remember to edit the "DSM520-VerInfo.txt"?
The first line needs to show a version number greater than that currently in the DSM-520, and the second line should be the firmware which you wish to load.
HTH
sebw7561 is offline
post #664 of 1954 Old 07-11-2007, 04:03 PM
outatime80's Avatar
Thanks for the reply, get the txt file was edited, this is what I have in it:
VERSION='1.05'
LOCATION='DSM520_2006.06.12-2043__1.02'
I am using the 1.02 file as mentioned, just don't understand what the problem is!
Thank you
Stuart
post #665 of 1954 Old 07-11-2007, 07:21 PM
Kevin Gorski's Avatar
VERSION='1.05'
Thank you
Stuart
It looks correct. Is the txt file and the firmware in the same directory? Try making the version something higher if this is not working, like 1.61 or something like that. After it applies the firmware, it will correct the version number as it is built into the firmware release.
Kevin Gorski is offline
post #666 of 1954 Old 07-12-2007, 06:12 AM
outatime80's Avatar
Hmmmm ok thanks for the info, tried the version number change like you suggested not still the same.
After I kept getting the network error I took a look at my network and then I eliminatied the router to try fix it and now when I try upgrade (still using local ip oif 192.168.2.12:22) I get a different message, says I already have newest firmware...I don't know whats going on! I have 1.04 on the dlink right now and am trying to downgrade to 1.02 (1.05) ! Crazy!
Anyone please help, what could I be doing wrong?
Thank you
Stuart
post #667 of 1954 Old 07-12-2007, 07:45 AM
aldamon's Avatar
So you connected the 520 directly to your cable/DSL modem?
aldamon is offline
post #668 of 1954 Old 07-12-2007, 08:06 AM
outatime80's Avatar
Hello, no I normally use two routers in my home, I limited to one router and it appears to be connecting now....but it says I have the newest firmware!
post #669 of 1954 Old 07-12-2007, 08:13 AM
aldamon's Avatar
Mine appeared to connect to the right place too (I used the old FTP server method from a while back) when I got this message but it really wasn't connecting. I believe the default response when it can't actually find a new firmware is to tell you that you already have the newest one. Technically, this message is correct, but not very informative
aldamon is offline
post #670 of 1954 Old 07-12-2007, 09:09 AM
outatime80's Avatar
Hmmm thats a tough one then, this is my setup right now, I have wireless antenna on my D-Link, connecting to a belkin router, and then I have a BP FTP setup on the PC connected directly to that router, no firewall or anything to block it, connects fine from any pc on the LAN to the FTP using ftp://192.168.2.12:22
Is there another way I should be trying to connect it, how are your setups connected from the Dlink?
Stuart
post #671 of 1954 Old 07-12-2007, 09:43 PM
freddiefenster's Avatar
outatime80,
I'm having the same problem as you, it says there is a new version available, do you want to upgrade. I then get the message unable to continue, please check network settings. I see from the ftp logs it connects reads the version file and then disconnects. I've tried going from wireless to wired connection, disabled firewall on my pc and incrementing the version number, but still no luck.
I'm using Windows XP SP2, IIS and going through a linksys router.
This is so frustrating my dlink is essentially broken with its inability to play xvid properly since upgrading to 1.04.
freddiefenster is offline
post #672 of 1954 Old 07-13-2007, 08:45 AM
cdrsteve's Avatar
Thank you, thank you, thank you!! Successfully rolled back to 1.02 from 1.04 today. Fast, easy, and painless process thanks to your post. I now am back to in-sync XVID files. I have turned off auto-update on my two DSM-320's and my DSM-520. All future updates will be done MANUALLY BY ME (after some other brave soul performs DLINK's beta testing) ! Thanks again for a fully functional guide. AVS is such a great place to keep the learning process going.
cdrsteve is offline
post #673 of 1954 Old 07-13-2007, 09:58 AM
outatime80's Avatar
Hi Freddie
Sorry to hear your in the same position as me I tried last night a wired version, running the ftp on my laptop and then plugging it into a spare linksys router I had handy and then router to 520.....see's the upgrade.....network problem...what a bitch! I wish I knew why this keeps doing it, driving me crazy!!!!!!!!!
We must be doing something wrong, as I get it to read the version file too but thats as far as it goes!
Is there anything special you guys with BP Ftp do when setting it up?
I just can't watch anything either, I get an annoying pausing of the video each minute or so too which is soooo frustrating since the upgrade!
Someone out there must have the answer to fixing this? Is it possible anyway to upgrade via USB stick? Help!
Stuart
Originally Posted by freddiefenster View Post
outatime80,
post #674 of 1954 Old 07-13-2007, 12:07 PM
aldamon's Avatar
No.
aldamon is offline
post #675 of 1954 Old 07-13-2007, 12:46 PM
misfit410's Avatar
Also be careful with the D-Link software if you use it.
it will auto update to 1.09 and stop seeing media..
if you do a clean install of 1.09 it's fine, if you update, it goes nuts..
had it happen on 3 seperate computers.
misfit410 is offline
post #676 of 1954 Old 07-13-2007, 08:26 PM
Hi Freddie
Stuart
I would try another FTP program just in case. I know Bulletproof works fine - but try Blackmoon FTP Free Version. Maybe they is something in your setup having an issue with binary files.
post #677 of 1954 Old 07-14-2007, 08:02 PM
ablevy's Avatar
Hey guys, sorry I didn't reply earlier, I've been on vacation all week. I'm attaching my log file in the hope that it will help you.
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > connected to ip : 192.168.1.109
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > sending welcome message.
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > 220 BulletProof FTP Server ready ...
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > USER anonymous
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > 331 Password required for anonymous.
(000002) 7/5/2007 9:32:36 PM - (not logged in) (192.168.1.108) > PASS ********
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > logged in.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 230 User anonymous logged in.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > CDUP
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > asked to change directory : 'C:\\ftp\\ -> C:\\ftp\\' --> Access allowed.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 250 CWD command successful. "/" is current directory.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > TYPE I
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 200 Type set to I.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > SIZE /DSM520-VerInfo.txt
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 213 57
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > PASV
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 227 Entering Passive Mode (192,168,1,109,185,57)
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > RETR /DSM520-VerInfo.txt
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > asked to download 'C:\\ftp\\DSM520-VerInfo.txt' --> Access allowed.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 150 Data connection accepted from 192.168.1.108:1084; transfer starting for DSM520-VerInfo.txt (57 bytes).
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > started downloading 'C:\\ftp\\DSM520-VerInfo.txt'.
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > finished downloading 'C:\\ftp\\DSM520-VerInfo.txt' - (00:00:01 - 0.056 KB - 0.056 KBytes/s)
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 226 Transfer ok
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > QUIT
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > 221 Bye bye ...
(000002) 7/5/2007 9:32:36 PM - anonymous (192.168.1.108) > disconnected. (00:00:00)
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > connected to ip : 192.168.1.109
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > sending welcome message.
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > 220 BulletProof FTP Server ready ...
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > USER anonymous
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > 331 Password required for anonymous.
(000003) 7/5/2007 9:32:42 PM - (not logged in) (192.168.1.108) > PASS ********
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > logged in.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 230 User anonymous logged in.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > CDUP
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > asked to change directory : 'C:\\ftp\\ -> C:\\ftp\\' --> Access allowed.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 250 CWD command successful. "/" is current directory.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > TYPE I
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 200 Type set to I.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > SIZE /DSM520_2006.06.12-2043__1.02
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 213 8006912
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > PASV
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 227 Entering Passive Mode (192,168,1,109,130,243)
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > RETR /DSM520_2006.06.12-2043__1.02
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > asked to download 'C:\\ftp\\DSM520_2006.06.12-2043__1.02' --> Access allowed.
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > 150 Data connection accepted from 192.168.1.108:1086; transfer starting for DSM520_2006.06.12-2043__1.02 (8006912 bytes).
(000003) 7/5/2007 9:32:42 PM - anonymous (192.168.1.108) > started downloading 'C:\\ftp\\DSM520_2006.06.12-2043__1.02'.
(000003) 7/5/2007 9:32:50 PM - anonymous (192.168.1.108) > finished downloading 'C:\\ftp\\DSM520_2006.06.12-2043__1.02' - (00:00:08 - 7819.250 KB - 977.406 KBytes/s)
(000003) 7/5/2007 9:32:50 PM - anonymous (192.168.1.108) > 226 Transfer ok
(000003) 7/5/2007 9:32:50 PM - anonymous (192.168.1.108) > QUIT
(000003) 7/5/2007 9:32:50 PM - anonymous (192.168.1.108) > 221 Bye bye ...
(000003) 7/5/2007 9:32:50 PM - anonymous (192.168.1.108) > disconnected. (00:00:07)
Unfortunately, at first glance I don't see anything that should cause the problem.
Alan
ablevy is offline
post #678 of 1954 Old 07-16-2007, 10:29 PM
I contacted Dlink support and described the issue with the pausing xvid. They suggested using just Media server 1.08 and not to upgrade to 1.09. I have to say that 1.08 with the 1.04 firmware is much more stable, although it hasn't eliminated the pausing completely.
I still haven't given up trying to roll back my firmware. My next step will be to try using Bulletproof ftp, although I'm seeing the same problem as Stuart. It connects downloads the version file, quits but doesn't seem to reconnect as is the case with Alan... annoying
post #679 of 1954 Old 07-16-2007, 11:01 PM
Try these downgrading instructions. More steps, but it allows you some more control as well. Good luck!
http://forums.tversity.com/viewtopic...ight=downgrade
post #680 of 1954 Old 07-18-2007, 06:13 AM
virginian's Avatar
I contacted Dlink support and described the issue with the pausing xvid. They suggested using just Media server 1.08 and not to upgrade to 1.09. I have to say that 1.08 with the 1.04 firmware is much more stable, although it hasn't eliminated the pausing completely....
I second it. My computer always crashed when I tried upload/download files while running Media Server 1.09. Everything was fixed after I removed 1.09 and installed 1.08.
1.4/1.08 bundle still has the issue with the sound delay on some Xvid files, but just on a few.
Does somebody know how to disable the annoying "Update" reminder?
virginian is offline
post #681 of 1954 Old 07-18-2007, 06:39 AM
aldamon's Avatar
nm.
aldamon is offline
post #682 of 1954 Old 07-19-2007, 09:04 PM
virginian's Avatar
Well, not a big deal.
Open consumer.ini file
Edit [Version] section, replace "currentver=1.08.RC08"
by "currentver=1.09.RC08". Bingo!
post #683 of 1954 Old 07-23-2007, 02:51 PM
jowes's Avatar
I was also burned by loss of audio for MP4s with the 1.0.4 firmware upgrade. I also posted to dlink's customer support and never received a response.
I've been holding off on the downrev process hoping a better solution would come out but I now have the feeling it won't.
The part that seems fishy to me is that downrev to 1.0.3 and then upgrade to 1.0.4 works. Has anyone tried just a downrev to 1.0.4?
It almost suggests dlink may have noticed the mp4 problem and re-released a new 1.0.4 that doesn't have that problem without saying anything. Those who upgraded too soon were burned. Those who upgrade now aren't. I'm aware of other companies having done this sort of thing in the past...
Just a thought. I'll give it a try over the weekend.
jowes is offline
post #684 of 1954 Old 07-23-2007, 07:08 PM
nvdfw's Avatar
Interesting. I will try this before giving up and downgrading everything to the previous. There is something weird on this, I am still surprised the latest FW&Server are failing for we all.
nvdfw is offline
post #685 of 1954 Old 07-23-2007, 09:45 PM
kxmas's Avatar
I down-reved to 1.02. It was great before the upgrade, horrible after, and great again with 1.02.
1.02 is the only firmware for me.
kxmas is offline
post #686 of 1954 Old 07-25-2007, 08:10 PM
lawrence07's Avatar
Hi Everyone
Try putting both files on a usb stick then power up dlink. It works
Lawrence
lawrence07 is offline
post #687 of 1954 Old 07-25-2007, 08:11 PM
nvdfw's Avatar
Originally Posted by lawrence07 View Post
Hi Everyone
Lawrence
excellent thanks for sharing the trick
nvdfw is offline
post #688 of 1954 Old 07-25-2007, 08:17 PM
lawrence07's Avatar
np
I had to do this in order for my HP media vault 2010 to work with the DSM520
Lawrence
since i cannot post a link yet search for this guy k0lee he has a website with some facts look for the media fault fact link
post #689 of 1954 Old 07-25-2007, 08:18 PM
lawrence07's Avatar
sorry media vault fact link from his home page
post #690 of 1954 Old 07-26-2007, 02:53 PM
Aaron_LC's Avatar
If nobody else has read it, http://active-tv.blogspot.com/
Pretty interesting if you aren't aware .
-Aaron
Aaron_LC is offline
