TCL LCD tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-26-2009, 04:23 AM - Thread Starter
saycheez's Avatar
Hi ... Pretty happy when purchased bargain 2nd/hand flat panel tv.
Has all I need, but now and then switches off for no reason
Is there a remedy? Or should I be worried sick?
Help appreciated ... and even more appreciate if simple fix.
Cheers and many thanks,
Les
saycheez is offline
post #2 of 4 Old 09-27-2009, 05:48 AM - Thread Starter
saycheez's Avatar
Um, um... is still doing it
saycheez is offline
post #3 of 4 Old 09-27-2009, 09:07 AM
videoguy60467's Avatar
Quoted: 174 Post(s)
Liked: 203
Les
I'd say worried sick.
Return it if you can. Last time I checked, TCL does not actually manufacture LCD TV, but re-badged them from other OEMs... (ALA TTE/RCA in USA)
Oops ... updated.... I just checked, they are building some sets as of the last year or so, and just expanded some production in China. If your set is used, it may not be TCL built depending on the age.
I used to work for a division of TCL. They are known for some pretty low end stuff. My company sold TVs, but they were built by a Korean OEM. They were decent Tier 3 stuff.
TCL used to be a big private label supplier of Durabrand CRTTV to Wal-Mart.
Chances are if you need a repair, it will negate whatever you saved buying a cheap second hand set.
videoguy60467 is offline
post #4 of 4 Old 09-28-2009, 01:08 AM - Thread Starter
saycheez's Avatar
Holy cow
Thanks for that videoguy60467 (I think), but, but... can this get worse do you reckon? If not, then I can live with it happening now and then.
But ifit starts smokin and leaking oil... hmm?
Much appreciated,
Les
saycheez is offline
Reply OLED Technology and Flat Panels General
