LG 55EF9500 and 65EF9500 OLED Owners Thread - Page 222 - AVS Forum | Home Theater Discussions And Reviews
 36646Likes
post #6631 of 24645 Old 11-05-2015, 07:50 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6675 Post(s)
Liked: 6670
Originally Posted by Blake2163 View Post
The 9500 is no doubt awesome but the processing kinda sucks now this is the only 4K I have so as far as I know it could be this way across the board but the eg9100 meets or beats the 9500 on 1080i and under. 1080p about the same on most things. Price doesn't bother me but I want my cake and eat it too and at this price point I should have just that. I know for my cable feed the eg9100 is a cleaner picture... But I don't like curved tv's and want to see what HDR is all about. So it's a catch 22.
Now how far away where you from each set ? Where you the same distance away ? Are they the same size TV ?
Cleveland Plasma is offline
post #6632 of 24645 Old 11-05-2015, 08:14 AM
Nillaz's Avatar
Quoted: 499 Post(s)
Liked: 337
[quote=Jschwim;38675393]
Originally Posted by Nillaz View Post
Nillaz, I've been searching through this myself. If you still want the OLED and can handle flat, the EC9300, which best buys will still carry, is for you. 20ms response. Still not amazing, but for a big screen, pretty good. That is only 1080p though. I think it might be some time before we see 4k games...
Thanks for the suggestion I might consider this.
Nillaz is offline
post #6633 of 24645 Old 11-05-2015, 08:27 AM
Liked: 1
Ordered a 65EF9500 via HHGregg 3 weeks ago and had it delivered last Thursday 509 S/N. All was great till last night as I was watching Direct TV the screen went black. I pressed the power button and blue and green streaks came across vertical on the bottom half of the screen. TV gets power, disconnected all HDMI cables, I push the power button on the remote the LG light flashes for a few seconds and nothing on the screen. Anyone heard of this happening at all?
dolfer likes this.
tonnyd76 is offline
post #6634 of 24645 Old 11-05-2015, 08:31 AM
DavenLei's Avatar
Quoted: 42 Post(s)
Liked: 34
Originally Posted by Koolice View Post
i was waiting for the HDR pop up because i saw that on the sample videos i downloaded. I never saw it and when i hit the info button it only ever says HD1080p. I watched 3 episodes of Red Oaks and it never happened.
There are two different feeds for Red Oaks. You need to make sure you select the UHD version and not the HD version. I made that mistake once.
Koolice likes this.
DavenLei is offline
post #6635 of 24645 Old 11-05-2015, 08:47 AM
Blake2163's Avatar
Quoted: 257 Post(s)
Liked: 100
Yeah both 55" at 7ft. There is a lot more blocky artifacts with the 55ef9500 on cable and other sources such as Netflix. The color is still better on the 9500 though. I know Netflix is not a good source to test from but the eg9100 doesn't have this problem it's crystal clear.
LG 65c6p
Denon avr590
(2) paradigm studio 10's
Velodyne 12 sub
PS4 pro, Apple TV (3rd gen), My Cloud 3tb nas
Blake2163 is offline
post #6636 of 24645 Old 11-05-2015, 08:55 AM
Koolice's Avatar
Quoted: 30 Post(s)
well that's not annoying at all! lol thank you!
Koolice is offline
post #6637 of 24645 Old 11-05-2015, 08:55 AM
comptr's Avatar
Quoted: 166 Post(s)
Liked: 24
Originally Posted by HD LUVA View Post
This is a question for all you owners on here who are rockin' a Marantz SR7010 receiver (or 6010 or maybe even a 5010?) with this TV. I'm sure some of you without this receiver can answer as well but I figured it made sense to ask those with the same set up as me. Of course I welcome all responses.
I have the TV and receiver connected to one and other thru their respective ARC HDMI ports and I get a 5.1 signal from all content whether it be cable (I have FIOS), aps from the TV like Netflix or Amazon or Blu-Rays from the PS4.
My question is 2-part and pertains to video quality. I have my cable box and PS4 connected to the receiver as opposed to the TV and I originally had the receiver set to pass through and both conversion and i/p scaling set to off. When I would take the TV's "magic remote" and put the cursor on the top of the screen it would tell me the picture was 1080p. Yesterday I switched the conversion and i/p scaling on and now when I check the top of the screen with the remote it says the picture is 2160. Is the receiver doing the upscaling or the monitor? Should I connect both the cable box and the PS4 directly to the TV instead and if I do this will the picture improve and continue to read as 2160 regardless of content?
Thanks in advance for your replies and advice.
I have a 5010. From what you wrote it's the receiver as in the settings of the Marantz if you trun on the i/p scaller the receiver is then doing the up scaling.
comptr is offline
post #6638 of 24645 Old 11-05-2015, 08:57 AM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
i agree. i like the ability to see a dedicated 4k section but if I select a title thats not in the 4k section but offers 4k streams, it should stream in 4k if you have capable device(s).
Koolice likes this.
metalsaber is offline
post #6639 of 24645 Old 11-05-2015, 09:13 AM
CJArciola, III's Avatar
Quoted: 188 Post(s)
Liked: 159
Originally Posted by mckinlyjoe View Post
same result with gravity blu-ray. default expert 1. I had zero issue with my 508 at expert1 settings out of the box. Nothing has changed but the tv.
Check if Energy Saver setting is set to off. This may affect picture if I recall.
CJArciola, III is offline
post #6640 of 24645 Old 11-05-2015, 09:17 AM
HD LUVA's Avatar
Guys, thanks for the responses. Can anyone here tell me when you are directly connected from your cable (or satellite) box to the TV if you click the "magic" remote at the top of the screen does it say 1080p or 2160p? I think I remember Buzz or someone mentioning that if it didn't convert the incoming signal to 2160 it would only cover 1/2 the screen? If that is the case then shouldn't it read 2160 or do I have it backwards and its telling us what is being input not output? I'm planning on checking this out when I get home but figured I'd kill some time during lunch and ask. Gracias.
HD LUVA is offline
post #6641 of 24645 Old 11-05-2015, 09:21 AM
Stanton's Avatar
Quoted: 1775 Post(s)
Liked: 899
Yes...guess you haven't read through this thread. There's been a few of us, but I was the first to report; waiting for a replacement (main) board. BTW, I have a 509 S/N.
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.26.00]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #6642 of 24645 Old 11-05-2015, 09:21 AM
Blake2163's Avatar
Quoted: 257 Post(s)
Liked: 100
It's telling you what the incoming signal is
LG 65c6p
Denon avr590
Velodyne 12 sub
post #6643 of 24645 Old 11-05-2015, 09:27 AM
HD LUVA's Avatar
That makes sense, thanks. What about audio? Does everything coming in from cable ( I have FIOS if it matters) come up as PCM? I don't remember seeing anything else up there but I've only recently started checking.
HD LUVA is offline
post #6644 of 24645 Old 11-05-2015, 09:34 AM
tsummerall's Avatar
I'm seriously considering the 55". I just did a quick read about motion-blurring and learned about black frame insertion. What do these sets do to decrease motion blurring and how effective is it?
I'm going to be watching a lot of 1080i Dish network content.
tsummerall is offline
post #6645 of 24645 Old 11-05-2015, 09:38 AM
Quoted: 25 Post(s)
Originally Posted by hobbs47 View Post
To those that have received delivery from Best Buy, did he tv box have shipping straps around the box. Just curious........
I was wondering about this too...
My initial 508 had only shipping straps and the replacement 510 had only clear tape along the box which made me concerned it may have been a return. It looked all okay inside box though.
mnam0711 is offline
post #6646 of 24645 Old 11-05-2015, 09:43 AM - Thread Starter
buzzard767's Avatar
Quoted: 1668 Post(s)
Liked: 2459
Nope. If you select the 2K version is does not switch to 4K.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #6647 of 24645 Old 11-05-2015, 09:48 AM
Quoted: 25 Post(s)
Originally Posted by DrBoogie View Post
Anybody who has apple tv 4 can comment on background uniformity on the home screen? I see yellow bands on it. I tried not to look for them on my TV but whitish back ground made them stand out.
Just set up the new Apple TV yesterday and was very disappointed to notice an amorphous white uniformity issue. I did not notice any true yellow bands but uniformity was noticeably off particularly central screen.
mnam0711 is offline
post #6648 of 24645 Old 11-05-2015, 09:53 AM
SledgeHammer's Avatar
Quoted: 1135 Post(s)
Liked: 393
I've had 2 delivered so far (and a 3rd this Saturday) and none had the shipping straps still on. I wonder why they are taking them off? Not like it ships like that. You can tell inside if the TV has been unpacked though.
SledgeHammer is offline
post #6649 of 24645 Old 11-05-2015, 09:55 AM
VidPro's Avatar
Quoted: 1485 Post(s)
Liked: 1237
Yeah I set it up last night on my 500M and saw them. Did a double take thinking here goes my TV. A part of me was a bit excited thinking I could go to the wife with it's broken and we need an OLED NOW!!!
The television screen is the retina of the mind's eye.
Sony XBR-65A1E OLED/Denon X4300H/Oppo 203/Klipsch RVX‑42/PS4 Pro/Xbox One X/5.1.2
VidPro is offline
post #6650 of 24645 Old 11-05-2015, 09:55 AM
macmane's Avatar
Quoted: 1081 Post(s)
Liked: 661
Do u guys think its safe to place this tv in front of a window?
macmane is offline
post #6651 of 24645 Old 11-05-2015, 09:58 AM
Liked: 393
Reflection on the screen is very high IMO, so I wouldn't place it next to a window.
post #6652 of 24645 Old 11-05-2015, 10:02 AM
dreamtheatre's Avatar
Quoted: 60 Post(s)
Liked: 38
Just received my 510 from BB. My wife took delivery as I am at work, but I had her verify the serial # and that it at least powered up OK. Will report back tonight.
wxman, shyguy3763, Koolice and 1 others like this.
LG 65EF9500 OLED Display
Oppo BDP-203,Schiit Bifrost Multibit DAC, MF V-LINK 192
Parasound P5, Marantz SR-6010, EAD PM 1000 and PM 500 amps
NHT 2.5i (2), NHT AC-1 (1), NHT 1.5 (2), PSB XA (4)
Outlaw Ultra X12 and LFM-1 EX subwoofers
dreamtheatre is offline
post #6653 of 24645 Old 11-05-2015, 10:31 AM
metalsaber's Avatar
Liked: 858
i know. I'm saying that it should do that if you have a capable 4k device and the title is offered in the 4k section.
Essentially Amazon should mirror Netflix. They have a dedicated 4k section but if you get a title thats 4k in another category it will stream in 4k.
post #6654 of 24645 Old 11-05-2015, 10:51 AM
DavenLei's Avatar
Quoted: 42 Post(s)
Liked: 34
When I asked the delivery guy about that (mine had no straps but you could see that it used to), he said he removes the straps and checks the TV screen for damage before loading it into the truck so it will not waste everyone's time by delivering a physically damaged TV.
DavenLei is offline
post #6655 of 24645 Old 11-05-2015, 11:01 AM
metalsaber's Avatar
Liked: 858
thats what my delivery guys said too.
post #6656 of 24645 Old 11-05-2015, 11:08 AM
TallCoolOne's Avatar
Quoted: 235 Post(s)
Liked: 164
Not sure if everyone's seen this (I don't recall seeing it posted here or in the 9600 thread), it's a bit old now but has some very interesting comments about some of the issues people here are seeing. It is comparing the 9600 to the Samsung but I think their points apply to the 9500 also:
http://www.displayandsoundcalibratio...sung-55js9000/
They talk about the vignetting, vertical bands, and banding and blotchiness. On the blotchiness/grainy picture in dark scenes some people report, I think this statement hits it dead on:
"The cause of these problems is excessive compression of the source and not the TV itself. It would appear that current compression algorithms allocate fewer bits to the very lowest luminance, relying on most TVs inability to display such low level details. The gradations further up are visible on any technology but are smoother than the blotches at the bottom end."
Their take on the darker edges and vertical bands as well as motion processing is also an interesting read.
DrBoogie, 10k, stsjfsd and 3 others like this.
TallCoolOne is offline
post #6657 of 24645 Old 11-05-2015, 12:09 PM
nandopr's Avatar
Quoted: 98 Post(s)
When I got my lg oled tv the salesman told me not to get concern when I see the box open. They checked before delivery to verify it is not broken/damage. He mentioned this because he had customers going back to the to complain about an open box.
nandopr is offline
post #6658 of 24645 Old 11-05-2015, 12:11 PM
Liked: 393
As a customer, I'm not too impressed with BB tbh. Had 2 TVs delivered so far. One was delivered an hour before my 2 hr window and the 2nd one was delivered 3 hrs before my 2 hr window. And thats after getting an original 12 hr window lol. Even the cable company gives you a 4hr window.
I'd rather they be early then late obviously, but the 3hrs early was a bit inconvienient LOL... the 1 hr early one actually worked out better for me though.
post #6659 of 24645 Old 11-05-2015, 12:34 PM
wxman's Avatar
Quoted: 5399 Post(s)
Liked: 3821
If box is open, make sure serial number on box matches what is on the tv.
rogershomework likes this.
wxman is offline
post #6660 of 24645 Old 11-05-2015, 12:44 PM
dfgalletta's Avatar
Quoted: 60 Post(s)
What to do with the free 49" tv
Mine will be delivered Nov 16 from Best Buy, when our new entertainment unit arrives. I ordered it about 3 or 4 weeks ago.
My free 49" UHD LG tv is still sitting in the box in which it was delivered. Has anyone tried to "trade it up" for a better unit? I wouldn't mind spending a couple hundred extra to get a 3D version or even more to get an OLED 1080. Is this an easy one or would I likely be fighting city hall on this?
Last edited by dfgalletta; 11-05-2015 at 12:44 PM. Reason: Extra line feeds for some reason
dfgalletta is offline
Reply OLED Technology and Flat Panels General
robert macintyre 855-400-4640
