LG 55EF9500 and 65EF9500 OLED Owners Thread - Page 677 - AVS Forum | Home Theater Discussions And Reviews
 36645Likes
post #20281 of 24622 Old 05-25-2016, 03:28 PM
chunon's Avatar
Quoted: 3778 Post(s)
Liked: 3606
Originally Posted by BigCoolJesus View Post
I posted this in the Calibration forums but also thought I'd check with those in here who also calibrate:
Basically having issues getting patterns generated by my PC via HDMI out to the EF9500 to produce the same measurements as those off of the AVS 709 Bluray (both my Xbox One and Samsung UHD player have nearly identical readings at 5% and 100% IRE). The Xbox One is set to Standard range (Limited RGB) and the Samsung UHD player is set to Auto. No combination of the Intel Graphics settings I have tried seem to have worked. Would obviously love to have the PC HDMI set correctly to expedite future calibrations and also ensure if I ever stream 4k content via my PC it's accurate to "video" standards.
I changed laptops because of that could never get the intel laptop patterns right. Second laptop had a Radeon video card no issues with that using madtpg. I personally think Calman is buggy in that area. Never had a problem in HCFR.
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is offline
post #20282 of 24622 Old 05-25-2016, 03:33 PM
Quoted: 55 Post(s)
Regarding firmware: I'm still stuck at 04.20.70. Can I download firmware from another country? LG Sweden has no firmware on their support site..
ohnder is offline
post #20283 of 24622 Old 05-25-2016, 03:34 PM
10k
10k's Avatar
Quoted: 2143 Post(s)
Liked: 2378
I've been contemplating getting a GTX950 for the reasons you listed but was waiting to see if the new GTX1070 is releasing in an ITX form factor first.
If I'm merely changing the settings you suggested on my Intel, will not having btb/wtw affect the 20pt grayscale calibration? I know for streaming actual content it matters but if I just want to get it working as is for generating patterns for CalMAN will it work fine (reference)?
Sent from my SM-G920V using Tapatalk
losing wtw/btb will have no noticeable impact so I wouldn't worry about it.
I agree that waiting for a 1070 or 1060 might be the best approach at this point.
10k is offline
post #20284 of 24622 Old 05-25-2016, 03:38 PM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
definitely wait
metalsaber is offline
post #20285 of 24622 Old 05-25-2016, 03:45 PM
BigCoolJesus's Avatar
Quoted: 2092 Post(s)
Liked: 1702
Awesome.
Can you give a little more pointers to change the necessary settings for the Intel graphics adapter? As stated, all I want to do is the 20pt patterns using CalMAN and MadTPG so they are as accurate as using the AVS 709 disc. I can check brightness and all the other specialty patterns off the disc after calibration so I don't lose wtw.
BigCoolJesus is offline
post #20286 of 24622 Old 05-25-2016, 03:59 PM
Maverick0984's Avatar
Quoted: 338 Post(s)
Liked: 145
Originally Posted by gadgtfreek View Post
Calm down chief, you are overthinking the issue. Uhaul sells flat panel tv boxes. I used one to ship a 64" D7000 Samsung plasma once, freight!
I wasn't aware of this so I checked their website. They state it accommodates TV's with a thickness of 1" to 4". Since our OLED is much thinner than 1" on top, do you expect it to still work? Maybe there is a different kit that goes thinner? Or do you expect to just stuff in other packing material to cover the gap?
I held on to my box but it sure is big, heh
Maverick0984 is offline
post #20287 of 24622 Old 05-25-2016, 04:13 PM
FredB51's Avatar
Quoted: 46 Post(s)
Well. Ran into some software issues so no full calibration today. I did get the brightness dialed in. Got 17 to crush and 18 to show up with Gamma set at 2.2
Here is my 5% after about 100 hours and four or five comp cycles minimum:
Thoughts?
Not perfect but pretty good, IMO. I would be a little concerned about the two vertical bands if they are showing up in content but often the low light photos exaggerate the contrast. They should continue to decline with time as well.
LG 65EF9500 · oppo BDP-103
Yamaha RX-V481
Klipsch 5.1 in wall speaker system
FredB51 is offline
post #20288 of 24622 Old 05-25-2016, 04:27 PM
Liked: 1702
I forgot to include the usual disclaimer that it looks worse in the photo than it does in person.
post #20289 of 24622 Old 05-25-2016, 04:44 PM
sillysally's Avatar
Quoted: 1174 Post(s)
Liked: 1050
@bcj
"When I run "madLevelsTweaker", the information box that shows up just tells me the Display, Graphics card, Hardware ID, Registry Path, and gives only one option which is to force PC Levels 0-255...is there something I am missing in terms of it telling me what settings the Graphics card is using/outputting and being able to change them?
- Under the Intel Graphics Card properties for the EF9500 display, I have the option of enabling or disabling YCbCr...which one should I use?
- Under the same properties I have the option of choosing "Quantization Range" of Limited or Full...again, which one should I use?"
Did you right click (administrator) on install in the madVR/TPG folder.
"madLevelsTweaker" is to force your video card to Full range. Drag and drop the "madLevelsTweaker" window to your display window and check the force box, close and restart your PC.
Use RGB.
Turn off any ICC profiles in "display" menus.
Make sure madTPG is set to output 16-235 and not to use video card profiles.
The last time I used madVR/TPG, I turned on madTPG before starting Calman.
I use madTPG mainly for argyllCMS, then use a Lumagen as pattern generator and Calman to run my calibration reports.
Once you have your video card kinks iron out, madTPG will give you reference patches.
If you would rather use a stand alone pattern generator then take a look at the DVDO AVLab TPG - 4K Test Pattern Generator, cost should be around $600.
Here is a link to Calman's madTPG PDF guide.
http://calman.spectracal.com/user-guides.html
ss
"Don't worry be happy"
LG77C8, Klein K10-A, Jeti 1211, CMS Lightspace, Calman home plus licence for K10-A, Murideo 6G.
sillysally is offline
post #20290 of 24622 Old 05-25-2016, 05:01 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5933
My D7000 wasn't that thick in parts either. I think I had an old wrap that came on my newer tv that I wrapped around it and taped it up well. The kit I used, and they may have changed it, had foam blocks you kind of popped off to fit what you needed. Might could check one out locally, one of our local large stores had them in stock.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #20291 of 24622 Old 05-25-2016, 05:08 PM
Liked: 1702
@sillysally
I did run install as administrator.
Do I need to change any settings in CalMAN or still leave it set to Video (16-235)?
I now understand using "madLevelsTweaker" to force Full Range RGB (0-255) thanks!.
But how do I set madTPG to output 16-235? When I open madTPG there is no options tab or settings. Do I have to set this through the CalMAN interface?
Lastly, will doing these steps correctly bypass the need to change any of the Intel Graphics properties myself...madVR will take care of what it needs to behind the scenes basically?
post #20292 of 24622 Old 05-25-2016, 05:11 PM
webminster's Avatar
Quoted: 64 Post(s)
Liked: 29
Originally Posted by kylem83 View Post
Thanks that first link worked.
My set suddenly started with terrible judder during sports, hoping this new FW will fix it.
I'd be interested in your experiences with the firmware, if it works and solves any problems.
webminster is offline
post #20293 of 24622 Old 05-25-2016, 05:32 PM
Quoted: 338 Post(s)
Liked: 145
My D7000 wasn't that think in parts either. I think I had an old wrap that came on my newer tv that I wrapped around it and taped it up well. The kit I used, and they may have changed it, had foam blocks you can of popped off to fit what you needed. May could check one out locally, one of our local large stores had them in stock.
Good to know. I would love a legitimate reason to not have to keep the box. Traditionally I keep all of my TV boxes and it has proved handy when moving.
macmane likes this.
post #20294 of 24622 Old 05-25-2016, 07:01 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5933
I give it a week or two of usage, usually, and my tv boxes meet this:
Stanton and chunon like this.
XBR65A9G / XBR65A8F
post #20295 of 24622 Old 05-25-2016, 07:25 PM
Liked: 1702
Curious: since the EF9500 is a 10 bit panel is there any benefit to setting my Xbox One to output 30 bit color depth instead of 24 bit?
post #20296 of 24622 Old 05-25-2016, 08:30 PM
Liked: 1702
Also, I have Deep Color enabled on the LG but when I try to enable it on the Samsung UHD player the screen goes black and I have to reset the player to turn it back off.
post #20297 of 24622 Old 05-25-2016, 08:41 PM
Quoted: 338 Post(s)
Liked: 145
Are you positive your HDMI cables are compliant?
post #20298 of 24622 Old 05-25-2016, 08:47 PM
Liked: 1702
Absolutely. When I set my media player device to 10 bit deep color the setting works. Using the same high speed 3ft HDMI cables from Monoprice on all my components.
post #20299 of 24622 Old 05-25-2016, 08:47 PM
Cam1977's Avatar
Quoted: 2899 Post(s)
Liked: 3472
I left the deep color on the player off and on the set on...and works fine.
Cam1977 is offline
post #20300 of 24622 Old 05-25-2016, 08:50 PM
Liked: 1702
It works fine when Deep Color is set to On for the LG and off for the UHD player. It's only when I turn it on for the player does it go blank and need reset. Didn't know if this is normal for some known reason or not.
Cam1977 likes this.
post #20301 of 24622 Old 05-25-2016, 08:57 PM
Cam1977's Avatar
Liked: 3472
I fooled around with it first when I bought and never had that trouble...of course since then I left it off.
Cam1977 is offline
post #20302 of 24622 Old 05-26-2016, 03:23 AM
Quoted: 482 Post(s)
Liked: 308
Turning Deep Color ON in Samsung's Blu Ray Player forces it to output 12bit - so don't use it. It's a legacy deep color setting for certain old blu rays that used it.
Just use the HDMI Ultra Deep Color setting on the TV.
gadgtfreek likes this.
Current: LG 77C9 OLED, Denon x6500H @ 7.2.4, Xbox One X, PC w. RTX2080ti
LG 55E6P OLED (Self calibrated with Colormunki Display and HCFR)
Previous: LG 55" EF9500 OLED (Self calibrated with Colormunki Display and HCFR)
Tomcup is offline
post #20303 of 24622 Old 05-26-2016, 04:35 AM
Liked: 1702
Gotcha. Thanks!
post #20304 of 24622 Old 05-26-2016, 05:59 AM
Quoted: 55 Post(s)
So I asked LG Sweden why there was no new firmware past 4.20.70 and received an answer saying there was either no need for new firmware or they had not received a newer one updated with specific country settings.
So while I updated my firmware yesterday from LG UK site and it is working, was that wrong of me?
Still clueless what exactly was changed from 4.20.70 to 4.20.90..
ohnder is offline
post #20305 of 24622 Old 05-26-2016, 06:03 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5933
I have been updating to the Korean FW each time it comes out, but I have not gotten the one posted a couple of days ago. Everything is working fine for me, so I prob won't mess with it.
XBR65A9G / XBR65A8F
post #20306 of 24622 Old 05-26-2016, 06:34 AM
dianebrat's Avatar
Quoted: 360 Post(s)
Liked: 323
That's not new, it's the same link for 100 (.00) posted in April.
dianebrat is offline
post #20307 of 24622 Old 05-26-2016, 06:38 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5933
Well I thought a couple of posters claimed it was new. I haven't looked.
XBR65A9G / XBR65A8F
post #20308 of 24622 Old 05-26-2016, 07:44 AM
lujan's Avatar
Quoted: 4363 Post(s)
Liked: 2448
Wide Color Gamut
You can use Standard or Wide from the menu.
I finally got a chance to watch a UHD HDR title last night and sure enough I'm using WCG. Are we supposed to have separate calibration settings for regular sources and HDR sources?
lujan
516 Ultra HD
724 HD
4 SD
lujan is online now
post #20309 of 24622 Old 05-26-2016, 07:57 AM
Liked: 1702
Hitman, over in the calibration forums, got me all sorted out for my PC to EF9500 HDMI connection for calibration. Seems I am good to go.
Anyone who had trouble with trying to use an Intel integrated graphics CPU with CalMAN+MadTPG or similar setups for calibration, check out my thread in the Calibration forums for a very detailed how to courteous of Hitman!
10k likes this.
post #20310 of 24622 Old 05-26-2016, 10:20 AM
Quoted: 48 Post(s)
I don't think that is new I had requested a repost of the download link since the once posted from April wasn't working =)
I'm gonna install it this weekend and hope it fixes my judder issues!
kylem83 is offline
Reply OLED Technology and Flat Panels General
robert macintyre 855-400-4640
