Best HDMI For LG OLED - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Latinoheat
  • 4 Post By loki99301
post #1 of 7 Old 10-13-2015, 09:35 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 4
Looking for very high quality picture HDMIs for my LG EG9600, but I also don't want to break the bank. Please let me know the best option. Thanks!
jkratt14 is offline
post #2 of 7 Old 10-13-2015, 09:47 PM
Latinoheat's Avatar
Quoted: 1496 Post(s)
Liked: 1508
Here's a few samples.
http://www.amazon.com/HDMI-Cable-6ft.../dp/B00NQ9OQU2
http://www.amazon.ca/Seiki-SU4KC1-U-.../dp/B00IE5C6LO
http://www.monoprice.com/Product?c_i...seq=1&format=2
John Sully likes this.
Media room- 65" Panasonic FZ950 OLED, Pioneer Elite VSX-90, Panasonic UBD-820 4K, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 7 Old 10-13-2015, 09:52 PM
John Sully's Avatar
Quoted: 249 Post(s)
Liked: 172
Amazon Basics seem pretty good. Monoporice also. If you want to spend a bit more Blue Jeans has some good stuff. I got one of their Tartan line for my receiver to TV link and it works great.
Receiver: Denon AVR X3400H/Display: Vizio P65-E1
Blu-Ray: Sony UBP-X700/LaserDisc: Panasonic AG-LD20/Streamer Amazon FireTV 4K
Satellite: Dish Hopper w/Sling
Speakers: SVS Prime Tower/SVS Prime Center/SVS Prime Surround/Velodyne HGS-15
John Sully is offline
post #4 of 7 Old 10-13-2015, 10:09 PM
Quoted: 21 Post(s)
Hdmis is hdmis as long as you don't buy something that just falls apart. It's a digital signal..it either works or it doesn't. Get your cables from monoprice..there is no need to spend more. Plus monoprice cable are good quality.
Tompa, Stanton, Cyberius and 1 others like this.
loki99301 is offline
post #5 of 7 Old 10-14-2015, 12:58 AM
NintendoManiac64's Avatar
Quoted: 1037 Post(s)
Liked: 463
The only thing to really be concerned about regarding HDMI or digital cables in general is that you'll need a heavier gauge cable for longer lengths (greater than 10 feet) at higher bandwidths.
If you look at the description on Monoprice they'll say what the gauge is and what resolutions should be guaranteed to work.
NintendoManiac64 is offline
post #6 of 7 Old 10-14-2015, 01:56 AM
comptr's Avatar
Quoted: 188 Post(s)
For my EF9500 I went with Blue Jeans cables.
comptr is online now
post #7 of 7 Old 10-15-2015, 07:24 PM
Cyberius's Avatar
Liked: 0
As long as the runs aren't very long you will be fine with any HDMI cable. I have used Monoprice for over 20 HDMI cables with lengths from 3 feet to 50 feet. No problems with any of them. As mentioned before in this thread: it either works or it doesn't.
Cyberius is offline
Reply OLED Technology and Flat Panels General
