Will the LG 55EF9500 pass 5.1 through ARC? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 40 Old 11-26-2015, 09:52 PM - Thread Starter
jlaavenger's Avatar
Quoted: 25 Post(s)
I have my DirectV and Blu Ray going to my TV, and My TV going to my Onkyo receiver through ARC but I'm not hear my rear speakers on any source. Is it the TV, ARC, the HDMI or the Receiver Receiver was working previous to new set up. But had to use ARC for the Lg's smart streaming of VUDU and Netflix.
jlaavenger is offline
post #2 of 40 Old 11-27-2015, 08:21 AM
Pitot Static's Avatar
Quoted: 27 Post(s)
It will, but you have to be able to force any devices plugged into the TV to send a bitstream and not just handshake for stereo PCM. ARC should get 5.1 from the TV streaming apps assuming thats setup correctly. Initially word was that it couldn't pass along 5.1 sources from external devices, and while thats not 100% true, it might effectively be the case for people with hardware you can't force to send 5.1 bitstream sources.The tricky part is just getting all of your equipment set up right.
Pitot Static is offline
post #3 of 40 Old 11-27-2015, 09:02 AM - Thread Starter
jlaavenger's Avatar
Quoted: 25 Post(s)
My Direct TV Genie doesn't have the feature to output via PCM. I did try my Sony Blu Ray Player and no luck. Even with sound set to PCM not sound to rears. But rears work. I did check that.
post #4 of 40 Old 11-27-2015, 12:57 PM
Stanton's Avatar
Quoted: 1768 Post(s)
Liked: 897
This question was asked and answered in the owner's thread, and the answer is still: run everything through your AVR, not the TV! ARC will support 5.1 for apps (and live TV), but it would still be better to use optical (Toslink) out because ARC is problematic.
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.26.00]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #5 of 40 Old 11-27-2015, 01:03 PM
HTNUT1975's Avatar
Quoted: 124 Post(s)
Liked: 59
Do we know if optical from EF9500 could pass dolby digital plus to a receiver? I ask because I have a Denon X4000 receiver, which will not be able to pass through HDR from external sources. If the TV could send DD+ signal from the apps either via ARC or optical, that would be money.
NintendoManiac64 likes this.
HTNUT1975 is offline
post #6 of 40 Old 11-28-2015, 02:11 PM
NintendoManiac64's Avatar
Quoted: 1026 Post(s)
Liked: 456
And I still think it's silly that ARC is limited to the same capabilities as optical when HDMI is clearly capable of more, because that results in you replacing both your TV and your AVR when trying to upgrade.
That doesn't sound like a conspiracy at all now.
(it's not like you have to replace your PC or your graphics card when you buy a new monitor - the only time you have to is if the PC/GPU is like a decade older than the monitor because it lacks the needed video port)
NintendoManiac64 is offline
post #7 of 40 Old 11-30-2015, 11:55 AM
Stanton's Avatar
Liked: 897
Yes: the manual even has the Dolby Digital Plus logo in the license list.
Stanton is offline
post #8 of 40 Old 11-30-2015, 04:16 PM
HTNUT1975's Avatar
Quoted: 124 Post(s)
Liked: 59
Oh wow. I'm now truly a happy camper!
post #9 of 40 Old 02-01-2016, 08:02 AM
Liked: 0
Help needed.
I must be overlooking some settings in my new system.
I have a LG55UF950T tv and a Yamaha RXA 2050 amp. TV input HDMI 1 and amp connected by HDMI cable to AMP HDMI 1 output, must I connect an optic cable from TV's output to amp's Audio input 1. All settings done according to setup manual. No sound on amp when playing You tube videos from internet. TV remote changes amp's volume.
I had a similar working setup before using a LG 55 5960 TV and a Yamaha 2010 amp. Had to replace my whole system, including cabling due to direct lightning strike
Caveman
Caveman085 is offline
post #10 of 40 Old 02-01-2016, 11:42 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
I don't believe this is correct.
VUDU has some free Dolby Atmos demo treats encoded in DD+.
Played from my Bluray player, my receiver gets Atmos (meaning it is being sent eith DD+ and the embedded Atmos metadata is being recognized by the receiver), but when played from the EF9500 set to 'bitstream' over ARC, my receiver is only getting 5.1 (meaning Dolby Digital, not DD+).
If anyone has successfully passed DD+ from their EF9500 through ARC or optical, I'd be very interested to know how and how they tested/confirmed their success...
fafrd is offline
post #11 of 40 Old 02-01-2016, 02:37 PM
valvaholic's Avatar
Quoted: 97 Post(s)
Liked: 44
I get DD+ on my 9300 via ARC kinda like dis:
LG Netflix app > HDMI ARC > OPPO 103D > HDMI > Arcam AVR750
valvaholic is offline
post #12 of 40 Old 02-01-2016, 02:50 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
How do you know that your AVR is getting DD+?
Can you point me to a couple examples of Netflix content that is streaming in DD+? Everything I have seen on Netflix is only in 5.1 (DD or DTS)...
fafrd is offline
post #13 of 40 Old 02-02-2016, 12:51 AM
valvaholic's Avatar
Quoted: 97 Post(s)
Liked: 44
"Dolby Digital +" appears on the Arcam display.
I'm on holiday skiing the steep & deep, but I'll report back in a couple weex
post #14 of 40 Old 02-02-2016, 12:29 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
Great - thanks.
fafrd is offline
post #15 of 40 Old 02-03-2016, 08:46 AM
Stanton's Avatar
Liked: 897
So would I, because now that I actually use Vudu--and see the DD+ on the screen--I can verify my AVR is only getting DD via optical out (don't do ARC).
Stanton is offline
post #16 of 40 Old 02-03-2016, 10:26 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
Same with me. When I use my Bluray player to stream the same content, my AVR gets DD+ (actually Atmos, because of the metadata).
Through the 65EF9500 with ARC, the same VUDU Atmos demo streams only reach my AVR as 5.1 DD .
fafrd is offline
post #17 of 40 Old 02-04-2016, 09:19 AM
Stanton's Avatar
Liked: 897
I keep thinking there's go to be a way to get DD+ out of this TV, but I don't see anything in the service menu (and I don't have a manual) that would suggest otherwise. Why would a (new) TV have any different streaming hardware than a DVD/BD player??
Stanton is offline
post #18 of 40 Old 02-04-2016, 10:25 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
Bluray player has HDMI.
TV had optical that was then morphed into ARC.
ARC may impose limitations on TV audio out that do not apply to Bluray players.
fafrd is offline
post #19 of 40 Old 02-04-2016, 12:45 PM
Stanton's Avatar
Liked: 897
What kills me is we know optical (and coax) can pass 1.5 Mbs, which would support DD+ bit rates.
Stanton is offline
post #20 of 40 Old 02-04-2016, 01:00 PM
Alamei's Avatar
Quoted: 109 Post(s)
Liked: 98
As far as I'm aware, all current televisions are limited to outputting a maximum of basic 5.1 Dolby Digital signals via toslink or HDMI ARC. I haven't seen a single model that can output Dolby Digital Plus (which is the primary format used by Netflix and Amazon these days) or any other higher quality format through their internal apps. I'm not sure why, exactly, that limitation is in place, but I believe it has to do with wanting the audio signal to be the identical when it's outputting via HDMI and via optical toslink (which isn't compatible with any of the new encoding formats). It's one of the factors that can make external streaming devices more desirable with higher end setups: they can output higher quality (DD+) or even, in some cases, lossless (Dolby TrueHD or DTS-MA) formats if you run them straight into your receiver.
I can understand using ARC to get audio from the television's internal apps, since there really isn't any better option available, but why would you run an external device to the television and then route the sound back to the receiver rather than just plugging the device into the receiver and letting it pass through the video signal?
Alamei is offline
post #21 of 40 Old 02-04-2016, 05:34 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
Here is at least one TV that claims it can pass Atmos (encoded within DD+) to an AVR over ARC: http://icdn2.digitaltrends.com/image...3ce998838d.jpg (last pictograph).
I am still awaiting from the lone R65 owner we have here on AVS for confirmation of this, but it suggests that it is possible.
The importance of this is only for streaming HDR/4K streams directly into your smart TV and wanting DD+/Atmos sound (which is precisely what VUDU is streaming).
With an external streaming box (including a UHD Bluray player that can stream HDR/4K, this is a non-issue...
fafrd is offline
post #22 of 40 Old 02-04-2016, 07:21 PM
Maverick0984's Avatar
Quoted: 338 Post(s)
Liked: 145
I've been struggling trying to get ARC to work with my 65EF9500 and Denon x2200w. The consensus I guess is to just forget about it and go optical like it's 2003?
I only care because I want Netflix/Amazon in 4k/HDR and see no reason to buy a secondary box that only serves to replicate functionality I already have on other devices. I had considered the Nvidia Shield for a short time, but that doesn't do Amazon Video. I use an Xbox One for local content via Plex. The Nvidia Shield would at least handle that via Kodi/Plex + Netflix but leaves me dry on Amazon Video.
Maverick0984 is offline
post #23 of 40 Old 02-04-2016, 08:16 PM
dkwong's Avatar
Quoted: 728 Post(s)
Liked: 404
I got ARC to work with my 65EF9500 and my Onkyo 646 but disabled it a couple of days later. Turning on ARC requires also turning on CEC, which caused my receiver to switch inputs and power off at seemingly random times. Optical is another cable but it's much more predictable. I don't know what idiot decided to make ARC depend on CEC.
dkwong is offline
post #24 of 40 Old 02-04-2016, 08:53 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
ARC to my Marantz NR1606 is working fine. The only occasional issue is that upon power-up, it sometimes switches back to HDMI 2 after I selected Live TV (and I need to reselect Live TV a second time as a result).
fafrd is offline
post #25 of 40 Old 02-04-2016, 09:38 PM
dkwong's Avatar
Quoted: 728 Post(s)
Liked: 404
That's the same problem I had. Happens about 25% of the time. Annoyed the hell out of me. Optical just works.
dkwong is offline
post #26 of 40 Old 02-04-2016, 09:47 PM
Quoted: 338 Post(s)
Liked: 145
Yeah, it just seems like there is too much headache surrounding it. There shouldn't be any occasional issues or salt throwing necessary. Especially with others (the wife) using it that aren't as forgiving as we might be.
dkwong likes this.
post #27 of 40 Old 02-05-2016, 07:12 AM
Alamei's Avatar
Quoted: 109 Post(s)
Liked: 98
Here is at least one TV that claims it can pass Atmos (encoded within DD+) to an AVR over ARC.
That's definitely interesting. I understand a desire for backwards compatibility, but it really does hold the whole industry back, so it would certainly be nice to see some manufacturers starting to support newer standards through ARC.
Alamei is offline
post #28 of 40 Old 02-05-2016, 07:00 PM
Quoted: 338 Post(s)
Liked: 145
Well, I tried one more time and was able to get things working with my x2200w. As it turns out, I am getting DD+
For those curious, it is coming from Netflix.
post #29 of 40 Old 02-05-2016, 11:07 PM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 4772
Can you post your settings and the piece of Nerflix content you are using?
fafrd is offline
post #30 of 40 Old 02-06-2016, 12:43 AM
dkwong's Avatar
Quoted: 728 Post(s)
Liked: 404
How do you know you're getting DD+?
dkwong is offline
Reply OLED Technology and Flat Panels General
