How to: Turn off ASBL on LG OLED TV - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #331 of 346 Old 02-05-2020, 06:39 AM
avernar's Avatar
Quoted: 622 Post(s)
Liked: 625
Originally Posted by Duc Vu View Post
Did you buy the one in the picture I posted?
The power button on mine is a little darker.
Bought it off Amazon.
Do not press IN STOP to exit the service menu.
avernar is offline
post #332 of 346 Old 02-05-2020, 12:11 PM
wxman's Avatar
Quoted: 5743 Post(s)
Liked: 4112
Originally Posted by Irrequieto View Post
Anyone can explain me the procedure to enter in service menu whit this remote? I need to turn off ASBL! I have to sync the remote with the tv first?
Hit the In Start button on remote.
Enter 0413
Arrow down on remote to OLED
Hit right arrow on remote
TPC Enable is ASBL. Turn it off. Use right arrow button to turn off.
Hit Exit button on remote.
You have now turned off ASBL successfully.
DaverJ and srijan like this.
wxman is offline
post #333 of 346 Old 02-06-2020, 09:40 AM
Liked: 0
Enter 0413
Thank you so much!!!
Irrequieto is offline
post #334 of 346 Old 02-07-2020, 11:13 AM
beardmoen's Avatar
Quoted: 22 Post(s)
Liked: 3
Originally Posted by TotesBreakfast View Post
I own an E8 and a B9. A few months ago I bought the following remote and it was a breeze to enter the service menu and turn off ASBL on both TVs:
https://www.ebay.com/itm/US-New-MKJ3...kAAOSwP4FaTeku
I use the E8 primarily for movies/shows and my B9 primarily as a PC monitor and I've had no issues since disabling. I'm a lot happier with it off.
Can I ask what your picture setting are for the B9?
beardmoen is offline
post #335 of 346 Old 02-08-2020, 06:28 AM
gene9p's Avatar
Quoted: 171 Post(s)
Liked: 122
I just ordered one..thanks....
gene9p is offline
post #336 of 346 Old 02-09-2020, 05:16 AM
Dick Emery's Avatar
Quoted: 301 Post(s)
Liked: 138
I have not seen dimming that often but saw it clearly on Gemini Man and it peeved me so. Thankfully I found out by checking with My Harmony with my Logitech remote someone added the service menu and in_start/out_start options. Synced up. Hit in_start and banged in the code. Thanks to this guide I now have it disabled. THANK YOU!!!
Dick Emery is offline
post #337 of 346 Old 02-09-2020, 11:17 AM
Quoted: 26 Post(s)
Liked: 5
I'm probably not the person to ask. I have a 65E8 that I use as my primary TV for movie watching. I use my B9 almost exclusively for gaming so I just use the HDR/SDR Game modes at their default settings. As with all of my TVs I just make sure to turn off pretty much all of the processing stuff with the exception of dynamic tone mapping for HDR10.
TotesBreakfast is offline
post #338 of 346 Old 02-12-2020, 02:15 PM
Liked: 0
thanks for the link to the ebay listing for the remote.
when using these screens as PC monitors for normal usage, the dimming is pretty extreme. i've had somethings go so dark they it's hard to read text, etc. i barely notice it watching tv/movies/gaming, though.
guy_fieri_fan420 is offline
post #339 of 346 Old 02-16-2020, 07:41 AM
gene9p's Avatar
Quoted: 171 Post(s)
Liked: 122
Enter 0413
done...very EZ thanks!
gene9p is offline
post #340 of 346 Old 02-20-2020, 09:53 AM
thegam3's Avatar
Quoted: 137 Post(s)
Liked: 70
Originally Posted by vatten View Post
Here is another test after set TPC to OFF.
This time the test pattern is not a white static background, but real web surfing usage, with a small window of white on corner cameraed, and I constantly scroll in web browser reading different contents, mixed image and video etc
Now the dimming kicks in much quicker, in just 150 seconds it start to dim down, shutter speed went from 1/320 to 1/250, and then in another minute it dim down again, shutter speed reached 1/200. However it just stopped there until some time later it will randomly brighten up, shutter speed back to 1/320
So it seems there are two different dimming algorithm running, one is for TPC, and works for any static contents, and another one is for normal display with varying contents , this one kicks in much quicker but only cut the illuminance less than half, so it is still tolerable, but the triggering mechanism is not understandable
i guess no one has found a way to get rid of this second dimming
thegam3 is offline
post #341 of 346 Old 02-24-2020, 01:55 AM
Liked: 0
Just installed my 55C9 and the first thing I noticed, after disabling all of the eco-settings, is the ABL (Auto Brightness Limiting) kicking in when a certain percentage of the screen is bright. ABL is different from ASBL, Auto Static Brightness Limiting, a.k.a. TPC, Temporal Peak Luminance Control, which you can disable in the service menu.
Is there a way to disable ABL?
jelbo is offline
post #342 of 346 Old 02-24-2020, 02:05 AM
Liked: 0
Ok, so ABL can't be turned off. What an absolute shame...
jelbo is offline
post #343 of 346 Old 03-13-2020, 09:55 AM
thepiecesfit's Avatar
Quoted: 269 Post(s)
Liked: 143
Look on the bright side you got the best TV on the market. During most movie watching this is not even noticable
jelbo likes this.
HT: LG C8 65" | Denon X4440H | Left/Right: Polk LSiM 705 (2) | Center: Polk LSiM 706c | Rears: Polk FXi A4 (2) | Sub: Rhytmik E15HP | Amp: Outlaw 2200 (3)
thepiecesfit is offline
post #344 of 346 Old 03-16-2020, 08:30 AM
Liked: 0
Yes, that's true. The ABL kicking in got a little less somehow after a firmware update. In a Switch game I played I could reproduce it in a menu (switching between modes on the title screen of Captain Toad Treasure Tracker dimmed the screen every time) until after that update. Now it's good, even with very bright OLED light and Contrast settings.
I also did actually watch things on my TV the past few weeks and I'm very content with it
jelbo is offline
post #345 of 346 Old 03-20-2020, 07:04 AM
teiresias's Avatar
Quoted: 94 Post(s)
Liked: 36
This seems to have worked to resolve the issues I was having on my 65C9, so thanks for all the info everyone!! One question, I assume TPC can be left disabled without worry when upgrading the firmware?
teiresias is offline
post #346 of 346 Old 03-20-2020, 12:50 PM
wxman's Avatar
Liked: 4112
Yes, you can leave it disabled. FW updates will not change the setting.
wxman is offline
Reply OLED Technology and Flat Panels General
asbl , dim , dimming , oled , service menu
