LG OLEDs - how to enhance near black detail - Page 87 - AVS Forum | Home Theater Discussions And Reviews
 836Likes
post #2581 of 2617 Old 07-29-2019, 07:23 AM
wxman's Avatar
Quoted: 5810 Post(s)
Liked: 4168
Originally Posted by Overrid3 View Post
Level 18 is the same as a 1% window, and 17 is 0.5%, right?
I've got mine calibrated so I can just barely see a 1% window pattern in a dark room. I've found that trying to get 17 visible, while still keeping near blacks looking respectable, is just not a reality with this TV.
Correct. People seem to forget that with OLED, 0% is true black. 0.5% on OLED is so close to absolute black, that 17 would be extremely hard to see with the human eye, unless in a totally dark after allowing eyes to adjust, and even then it would be extremely faint. The reason why 17 is so easily seen on LCD is because their equivalent 0% looks like flashing bar 19 or 20 on OLED.
wxman is online now
post #2582 of 2617 Old 07-29-2019, 02:27 PM
mrtickleuk's Avatar
Quoted: 6258 Post(s)
Liked: 9106
^^ This!
I used to stress when looking at Wizziwig's excellent 17-27 torture test grid, that I couldn't see 17. That was before I read that you should only be able to see 17 if it isn't sharing the screen with anything brighter than 17! Ie only a test pattern. In terms of nits, it's ludicrously dark.
So - TL;DR - forget 17, get 18 to be visible and the darkest you can see. Also there are some rather nasty rounding errors when it comes to these percentages - there is maths and then there are "video conventions" whereby some software will round in an odd way (eg with value 22, which is sometimes 2.5, or 2.6, or 2.7!).
EDIT: With Calman's "dark detail" workflow, the darkest patch is measures is 20, which is 1.8182% (which Calman calls "2.0%"). The Calman Data Table shows that the target luminance for this (calculated back from ~120nits peak IIRC), with gamma 2.4, was:
0.0089 nits.
... and that's for value 20. So 19 and 18 will both be even darker!
Forget 17!
Name:	Dark Detail rgb rounding values.png
wxman likes this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #2583 of 2617 Old 07-30-2019, 07:27 PM
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Originally Posted by mrtickleuk View Post
^^ This!
0.0089 nits.
Forget 17!
Thanks, guys. That actually makes a lot of sense. I guess I was just used to calibrating LCDs, where 17 and up should be visible. OLED is a whole new ballgame.
Overrid3 is offline
post #2584 of 2617 Old 07-31-2019, 06:22 PM
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Also, just wondering how visible a 1% window is on your sets? In a dark room, I can just barely see it from my seating position. In some programs, blacks appear slightly crushed, but I think this is about the best I can do.
Overrid3 is offline
post #2585 of 2617 Old 08-01-2019, 01:55 PM
mrtickleuk's Avatar
Liked: 9106
For me, 1% window (10% size) in a pitch black room is only visible with my nose inches away from the screen.
Forget 17!
_______________
post #2586 of 2617 Old 08-04-2019, 12:16 PM
NismoZ's Avatar
Quoted: 151 Post(s)
Liked: 60
On a C9, I tried bumping up the darks only using this thread. It seemed to work for ISF Dark SDR modes, but not for Cinema User HDR or Cinema Dolby Vision picture modes. In the HDR modes, I did not get the menu setting of Adjusting Luminance to appear.
Check out the screen caps attached. First one is SDR mode ISF Dark where I can adjust it. The 2nd one is HDR Cinema User and the third is Cinema Dolby Vision.
ID:	2598260   Click image for larger version
ID:	2598262   Click image for larger version
NismoZ is offline
post #2587 of 2617 Old 08-05-2019, 12:22 PM
Overrid3's Avatar
Quoted: 197 Post(s)
Liked: 104
Forget 17!
Cool, thanks. Things are looking better after dropping back down to 50, and not boosting the 5 IRE luminance. I'm seeing a lot less garbage and artifacts, especially on crappy cable and streaming.
mrtickleuk likes this.
Overrid3 is offline
post #2588 of 2617 Old 09-24-2019, 10:52 AM
Quoted: 155 Post(s)
Liked: 54
On my C8 65, with brightness set to anything lower than 56, black detail is crushed, and that is with luminance IRE 5 set to 12 and IRE 10 set to 10.
The picture does look a tiny bit washed out, guessing because brightness is too high?
What is the best cause of action here? I thought about raising the IRE luminance levels some more.......is it OK to do that? or will that cause any side-effects?
jonclarkccnp is offline
post #2589 of 2617 Old 09-24-2019, 11:59 AM
wxman's Avatar
Liked: 4168
Give this a try. In a totally dark room, at night, open the youtube app and search for 10 hours HD black screen. Play that video. Let your eyes adjust. If the screen glows, your brightness is too high. Lower brightness until the screen is black. Next adjust 5 IRE up until glow returns, and then lower 1 click at a time until it's black. That's about the best you can do.
mttpalmer, gymnos, Cam1977 and 1 others like this.
wxman is online now
post #2590 of 2617 Old 11-13-2019, 02:11 PM
Fush's Avatar
Quoted: 66 Post(s)
This is a really interesting thread! I just got a B9 a couple of weeks ago. I have to raise brightness to 55 and IRE 2.5% to +8 in order to see the near blacks properly. That goes for both ISF Bright at 2.2 gamma and ISF Dark at BT.1886.
This does not introduce any glow, as far as I can tell. And my X-rite colorimeter measures 0% grey at Y 0.000. So it's all good then, isn't it? All the people here who are adamant about keeping brightness at 50 are making me question my settings.
Fush is offline
post #2591 of 2617 Old 11-13-2019, 02:48 PM
NismoZ's Avatar
Quoted: 151 Post(s)
Liked: 60
I've read through the thread and can make these adjustments. This is only for SD modes , correct? I switched over to a HDR mode and did not see the same settings. Are we able to adjust near black up higher like this for HDR and DV modes?
gymnos likes this.
NismoZ is offline
post #2592 of 2617 Old 11-13-2019, 03:34 PM
mrtickleuk's Avatar
Liked: 9106
Brightness=50 is required for Calman's 1DLUT to be correct, but you can change it if you're using the default factory 1DLUTs, and many people find they have to to avoid slight black crush. That said, the panel changes a LOT with age as well.
Sounds good but are you chasing two different aims? Do you want accuracy first, or do you just want to "enhance" the near black detail so that it's easier for you to "see"?
In other words, when you boost the level of 2.5% grey using the +8 value in the menus, is that to make it possible or easier for you to "see", or does that bring the Y luminance in line with where it should be using the gamma formula? (Maybe both)
btw I don't know which RGB level that is. if 16=black, then 21=2.2727%, 22=2.7273%, so probably one of those with rounding?
@NismoZ yes this is SDR only, can't be done like this for HDR.
_______________
post #2593 of 2617 Old 11-13-2019, 04:28 PM
NismoZ's Avatar
Quoted: 151 Post(s)
Liked: 60
Thank you. Is there anything that can be done for HDR to raise the bottom end of blacks? I also feel like I am loosing dark color depths as well, like a dark color shirt, etc. Is this just how HDR is supposed to look? Indoor scenes seem the worst. Outdoor in natural light gets better. TV settings are near Rtings, with some slight tweaks for myself and I've tried to get more definition from the darker end stuff, can't seem to get there.
gymnos likes this.
NismoZ is offline
post #2594 of 2617 Old 11-14-2019, 10:45 AM
mrtickleuk's Avatar
Liked: 9106
You would need a proper calibration to improve HDR.
tomolav1980 likes this.
_______________
post #2595 of 2617 Old 11-14-2019, 01:32 PM
NismoZ's Avatar
Quoted: 151 Post(s)
Liked: 60
With these OLEDs, has calibration been able to improve near blacks and dark color detail and definition like I talked about? Is it possible for calibrators to actually come see issues like this and for them to be able to say whether they can correct them or not (improving near blacks and dark color details)? Maybe I could take it a different way... If I wanted to take pictures of some scenes and then post them, I could compare those details with other forum users calibrated TVs, and see if mine is that much off. I guess I'd have to do that in the specific C9 owners thread.
NismoZ is offline
post #2596 of 2617 Old 12-08-2019, 07:08 PM
PittyH's Avatar
Quoted: 157 Post(s)
Liked: 101
I remember the old days when you could adjust brightness and contrast and be done with it.
Nowadays you need a whole studio of equipment and 20 man team to adjust your TV :P
Cam1977 and RoadLizard like this.
PittyH is offline
post #2597 of 2617 Old 12-08-2019, 07:13 PM
Cam1977's Avatar
Quoted: 3386 Post(s)
Liked: 4169
^I couldn't help but chuckle at this🤣🤣🤣
Cam1977 is online now
post #2598 of 2617 Old 12-09-2019, 06:54 AM
Patsfan123's Avatar
Quoted: 554 Post(s)
Liked: 360
Ironically TVs are so much more accurate out of the box now yet we have much more control.
Sure calibration will bring you closer to reference, but I am not convinced most people would find the value in a calibration.
LG 65C6P FW: 05.30.85 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #2599 of 2617 Old 12-09-2019, 01:10 PM
RoadLizard's Avatar
Quoted: 1562 Post(s)
Liked: 1583
Very true - I found that our 2016 OLEDs if you use Expert ISF Bright/Dark are pretty good right out of the box. Those are what most of my settings are based off of with a few tweaks here and there. I was thinking of having my set professionally calibrated but then decided not to. It looks freeging damned good right where I have it. Just no need to spend the money, IMO.
Cam1977 likes this.
LG OLED65E6P, Samsung PN64H5000
LG UBK-90
Polk RTi Towers, STi surrounds
Polk Subwoofer
Sony DH550 AVR
RoadLizard is offline
post #2600 of 2617 Old 02-02-2020, 03:10 AM
mindz's Avatar
Hi, great thread! With the tips here I set brightness to 53 and IRE 5 luminance to +7. With the 10 hours black video on youtube and completely dark room its easy to check if blacks float.
Question, should I do the 2-step down for higher IRE, so IRE 5: 7, IRE 10: 5, IRE 15: 3, IRE 20: 1? Or must I only use even numbers like 6, 4, 2? Cause thats what im reading here as others are doing like @wxman .
I have 65B8 with latest fw.
mindz is offline
post #2601 of 2617 Old 02-02-2020, 08:41 AM
RoadLizard's Avatar
Liked: 1583
Brightness at 53 seems high but if it’s working for you then it is! You are doing it right making sure the room is dark and your eyes are well adapted. I’m using the ramp down system for my set and am happy but if you’re content now then just leave it. Every set will be slightly different.
Have you watched some known content and verified you see improvements? That’s really the best test. Once I made my tweaks I tried out some scenes on Blu-ray Discs and whatever to validate my changes. I did notice slightly improved detail and less crush in scenes that had it before the adjustments so that sealed the deal.
Also, I went into my service menu and set my sub brightness main setting to 127. The default is 128. This allows me to use a brightness value of 52 pretty much across all modes and maintain true black. The 52 value teases out more detail than 51 so that was a good change too.
LG UBK-90
Polk Subwoofer
Sony DH550 AVR
post #2602 of 2617 Old 02-02-2020, 08:52 AM
mindz's Avatar
Thanks for the reply. My brightness is 54, so even higher(!), and IRE 5 at Luminance 6, I was mistaken! 54 on my set is still true black. The sub brightness I could also try. I noticed an improvement right away (but maybe only psychological :P)! I now applied the 2-step ramp down for IRE 10 and 15. Tonight I will do the 10 hr YT video and check blacks. Ill then do the sub b aswell :—-).
Still getting an E9 though when prices come down :-o!
mindz is offline
post #2603 of 2617 Old 02-02-2020, 10:41 AM
RoadLizard's Avatar
Liked: 1583
Cool! Im am also getting the upgrade itch but I want to go 77" so Ill have to wait a bit longer. The newer sets are better regarding near black so that'll be nice.
hughh likes this.
LG UBK-90
Polk Subwoofer
Sony DH550 AVR
post #2604 of 2617 Old 02-02-2020, 11:08 AM
mindz's Avatar
Question.
When i set my oled light from 0 (I use 0 for ISF dark room) to 5 the brightness and IRE controls work totally different. At oled light 5 brightness 52 gives floating blacks, only 51 is true black. The 5% IRE doesnt do anything, even at luminance 50. How come?
mindz is offline
post #2605 of 2617 Old 02-04-2020, 10:37 PM
Quoted: 62 Post(s)
Been trying to fix the glowing blacks on my C9 in HDR10 mode (Dolby Vision somehow works just fine). When I set brightness at 50 and dynamic tonemapping ON (Technicolor HDR) the blacks glow in a lot of content. I set brightness to 48 and bam it's fine now. But when I check HDR pattern the black bars are crushed up to 96. However I see no difference with tonemapping ON or OFF. Is the feature not working on a calibration screen? The blacks don't look crushed in normal content.
In any case, I don't get why blacks in Dolby Vision never glow but with standard HDR10 it's all over the place. I watch 4K blu-rays so the source should be fine.
gymnos likes this.
ohnder is offline
post #2606 of 2617 Old 04-02-2020, 01:06 AM
Franconian's Avatar
Quoted: 48 Post(s)
Liked: 40
I'm hoping that somebody could help me. I have an uncalibrated B8 with the following SDR key settings:
isf Expert
OLED Light 40
Contrast 85
Gamma 2.2
Brightness 54
I used the AVS black clipping test in a pitch black room to adjust the brightness, to see minimal flashing at bar 17. Recently I tried OLED 50 and contrast 90 but it seemed a little bit to bright after using 40 and 85 for almost a year.
Now a few people told me to try gamma 2.4. When using that, I need to adjust the brightness to 59 to see bar 17 flashing again.
I put each 2.2 and 2.4 to isf dark and bright and switched within several movies/scenes. It seems 2.4 gives me a little bit richer colors and dephts, especially noticable in cartoons/animation content, 2.2 looks washed out in comparison but I don't know if that is really the case or just because its a little bit brighter.
What can I improve here? I don't have a feeling anymore what the "right" setting is. And I'm wondering why my brightness setting is so high since most people say to stick around 50.
I never touched the IRE settings. Would be this was wxman said helpful for my me?
What about the other IRE settings? Is adjusting 5 IRE enough?
Thanks in advance.
LG OLED 65B8 | Denon AVR-X3500H | Zidoo X9S | Panasonic DP-UB824 | Nubert nuLine 84 / CS-44 / 24 / AW-600 | Xbox One X | PS4 | Synology DS216+II​
Franconian is offline
post #2607 of 2617 Old 04-02-2020, 01:14 AM
wxman's Avatar
Liked: 4168
Originally Posted by Franconian View Post
I'm hoping that somebody could get me. I have an uncalibrated B8 with the following SDR key settings:
isf Expert
OLED Light 40
Contrast 85
Gamma 2.2
Brightness 54
Thanks in advance.
Without calibration equipment, I would not mess with anything above 5 IRE.
Franconian likes this.
wxman is online now
post #2608 of 2617 Old 04-02-2020, 02:13 AM
Franconian's Avatar
Quoted: 48 Post(s)
Liked: 40
Thanks for the fast reply, I'll give it a shot tonight with 5 IRE then. What is your take on the gamma, which one are you using?
post #2609 of 2617 Old 04-02-2020, 03:54 AM
Quoted: 1053 Post(s)
Liked: 756
If you want to reduce black crush and enhance shadow detail near black, then use gamma 2.2. It only "appears" washed out when compared to 2.4. Personally, I could never find a "right" setting for me when adjusting IRE 5. All I managed to do was make noise and artifacts near black more visible. I left IRE alone and went with 2.2 gamma. It's not perfect, but good enough without a calibration.
Franconian and mrtickleuk like this.
LG OLED65B6P
no1special is offline
post #2610 of 2617 Old 04-02-2020, 09:10 AM
mrtickleuk's Avatar
Liked: 9106
Don't forget, you're not supposed to be able to see 17 on that pattern. It's INCREDIBLY dark, and should only be visible if 17 is the only thing in a patch on the screen with black and nothing brighter at all with it.
Otherwise, your iris opens too much when the other brighter patches (such as 19) completely swamp it in brightness, and you adjust the TV by too much to see it making level17 brighter than it should be.
It is normally for you not to be able to see 17. It's better to have black + 19,20 etc "correct" than 17 visible + 19,20 pushed much brighter than they are supposed to be. Sometimes you have to compromise.
This was covered earlier in the thread - try around here but if that's not he place just go a bit further back! HTH
Franconian and no1special like this.
_______________
Reply OLED Technology and Flat Panels General
