LG OLED ... what resolution? - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 4 Post By JimP
  • 1 Post By PioManiac
  • 1 Post By NintendoManiac64
post #1 of 12 Old 01-07-2017, 07:15 AM - Thread Starter
jorsan's Avatar
Quoted: 67 Post(s)
I have an LG OLED B6 and would like to know if there is a way to know what resolution my TV is displaying at any time. Thanks
jorsan is offline
post #2 of 12 Old 01-07-2017, 07:33 AM
PioManiac's Avatar
Quoted: 3104 Post(s)
Liked: 7494
It's a 4K 16:9 display, and will always display exactly 3840 × 2160 pixels.
There is no way to show what the panel is receiving as the input signal.
Some components, players and AVR's can indicate incoming and outgoing video and audio information, unfortunately the LG OLED's do not.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #3 of 12 Old 01-07-2017, 07:43 AM
Quoted: 1708 Post(s)
Liked: 738
I have a B6 too and found in one of the other threads about using the remote (roll the roller thingy) aim the cursor at the upper left corner and double click.
It'll display the incoming resolution off of the HDMI inputs. Not sure what it does with the built in apps.
JimP is offline
post #4 of 12 Old 01-07-2017, 07:50 AM
PioManiac's Avatar
Liked: 7494
Wow, that's cool...just tried it with my cable HDTV signal.
Does not work with Netflix or YouTube (built-in app) though
JimP likes this.
post #5 of 12 Old 01-07-2017, 07:58 AM
Liked: 738
Does not work with Netflix (built-in app) though
Hmm, wonder if there is a difference if Netflix (and others) are external rather than the internal apps.
JimP is offline
post #6 of 12 Old 01-07-2017, 08:05 AM
PioManiac's Avatar
Liked: 7494
If I use Netflix through my 4K BD player (Panasonic UB900) it works
downside is anything with Dolby Vision gets played as HDR though.
post #7 of 12 Old 01-07-2017, 08:31 AM - Thread Starter
jorsan's Avatar
Quoted: 67 Post(s)
Great, thanks to all for the information
jorsan is offline
post #8 of 12 Old 01-07-2017, 03:11 PM
NintendoManiac64's Avatar
Quoted: 1026 Post(s)
Liked: 455
You can find this out through the app itself via "stats for nerds".
George Weasley likes this.
NintendoManiac64 is offline
post #9 of 12 Old 01-11-2017, 08:22 AM - Thread Starter
jorsan's Avatar
Quoted: 67 Post(s)
Great, thanks to all for your help
jorsan is offline
post #10 of 12 Old 01-11-2017, 10:42 AM
Dick Emery's Avatar
Quoted: 301 Post(s)
Liked: 137
It will show the incoming resolution but not the Hz unfortunately. I use MadVR to see what is being sent though so not a huge issue.
Dick Emery is offline
post #11 of 12 Old 02-03-2018, 04:48 AM
Liked: 0
Wow that's brilliant, I've spent ages trying to see if my VM box input on HD channels into my LG OLED was 1080p and couldn't see any way to get the input display up. This worked first time! Had to register to say thanks for this tip!
tonbar is offline
post #12 of 12 Old 02-06-2018, 12:54 PM
jlsavs's Avatar
Quoted: 97 Post(s)
Liked: 34
THE phone app will display rez in one of the app screens .. my android app is a bit flacky but I can usually see the rez for any given Nflix content from my android phone ..
jlsavs is offline
Reply OLED Technology and Flat Panels General
