Sony A1E 4K HDR OLED TV Thread (No Price Talk) - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 14442Likes
post #2791 of 8186 Old 05-03-2017, 02:07 AM
Quoted: 81 Post(s)
Liked: 161
Originally Posted by Callsign_Vega View Post
Hmm, this review says using motion-flow frame interpolation raises the input lag to an unbearable 100+ms:
https://www.avforums.com/review/sony...v-review.13313
What is the relationship of the motion-flow and "Clearness" setting?
There is no difference with input lag with Clearness on high or low or off (in game.mode). Clearness is the only option available in game mode when you turn on motion flow, it disables whatever else motion flow does while in game mode so it doesn't add any processing hence no increase in input lag. I didn't look at the review but if you enable motion flow in any other mode it is not just turning on Clearness, everything is enabled and thus all that processing is adding to the input lag..which is already higher since you aren't in game mode.
Somebody mentioned they saw slight flickering on the title of Horizon in the white area (apparently not in-game as they mentioned just the title screen) but I didn't have any flickering on the title screen (and Im not insensitive to flickering) so not sure what's going on there.
Ness Roman is offline
post #2792 of 8186 Old 05-03-2017, 02:45 AM - Thread Starter
Sebring5's Avatar
Quoted: 342 Post(s)
Liked: 249
Originally Posted by SK84375 View Post
Does anyone know if the A1 will output sound to tv speakers and optical out or arc simultaneously. Or if an owner could check. Would help with my install wiring before tv arrives - none on display in UK near me yet so can't check
Thanks for any guidance
The choice is tv speakers or audio out. You cannot select both. No simultaneous sound using just the Sony.
Meridian Audio G65 Sound Processor/UHD 722 HDMI Audio Processor/M6 Active Speakers, Sony A1E 65" OLED 4k UHD, Apple TV, Sony UBP-X1100ES
Sebring5 is offline
post #2793 of 8186 Old 05-03-2017, 06:20 AM
Quoted: 230 Post(s)
Liked: 482
Originally Posted by Zero/One View Post
I have an issue with this Sony. Everytime I want to watch Blu-rays the TV either displays a blue or pink hue with the picture. I have to turn everything off and back on again several times in order to get it to work properly. Any ideas to what's happening?
I have an Oppo 203 and a Denon 6300 all hooked up to the HDMI 2 on the TV.
I have a similar setup -- A1E HDMI 3 -> Denon X4300H -> All other components including my OPPO UDP-203. I've had zero issues since A1E installation.
BUT... I did have issues with various anomalies requiring me to power on/off components, before my A1E and it's new 25' premium high-speed HDMI were installed to the AVR. I have only Monoprice certified premium high-speed HDMI between components and the AVR. I firmly believe my 10 YO plasma and/or my old HDMI 1.3-era cable were my problem. The only other thing I found after installing my A1E (and first 4K TV) was my Roku would not initially pass HDCP 2.2 handshake as I tried to configure it for 4K -- that was resolved by reseating the HDMI cable going into the Roku (the certified premium Monoprice cables are pretty stiff, and the HDMI connector is upside down from the way the cable wanted to lay without some coaxing.)
NET: Rule out your cables and their connectivity being a possible issue. Good luck.
rsonnens likes this.
BertL is offline
post #2794 of 8186 Old 05-03-2017, 07:38 AM
raurau's Avatar
An order has been placed for the 65" version with a delivery date set to 18th of May
The strange thing in Norway is that the A1 is a couple of hundred dollars cheaper then the C7.
How to make time go fast until the 18th??
No cryogenic chambers close by
Thank you owners for your dedication and feedback!
Cheers!
raurau is offline
post #2795 of 8186 Old 05-03-2017, 08:53 AM
Quoted: 25 Post(s)
Liked: 2
Got the 55" A1E from my military exchange for only $3,299 and also picked up the 55" C7 for $2,299 and no tax. Will be an interesting side-by-side.
I just had BB match the price of the exchange. Happy with the TV so far, just wished they had left some space on the bottom (I want to keep my fingers intact) for when you place the TV on it's stand. Which also brings another point... when placed on the stand the TV is not on a 90 degree angle (I'm guessing it's because of the weight) which doesn't affect viewing but will take time getting used to the reclining screen.
Locotl is offline
post #2796 of 8186 Old 05-03-2017, 09:01 AM
vaktmestern's Avatar
Quoted: 826 Post(s)
Liked: 610
Cheers!
Says there in stock at Elkjøp the 55" and 65" A1 now.
vaktmestern is offline
post #2797 of 8186 Old 05-03-2017, 09:15 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7035 Post(s)
Liked: 7069
Originally Posted by Nick Martelli View Post
I have 2 sources that say this is the correct price. Sony could change though.
Yep, and that the problem, its happened before.........
Originally Posted by amro View Post
So, I've had my 65A1E over the weekend, and I can safely say I'm very happy with it. Now, I'm coming from a Panasonic TC-P65VT50 which was a fantastic 1080P plasma display (never went to LCD/LED)
Plasma guys really dig these OLED's
WOLVERNOLE likes this.
Cleveland Plasma is online now
post #2798 of 8186 Old 05-03-2017, 09:22 AM
raurau's Avatar
Yep that is where i bought it from.
Hopefully they can deliver sooner.
vaktmestern likes this.
Onkyo TX-SR607 | Sony 65A1E OLED | Apple TV 4th Gen | Logitech Harmony Elite
raurau is offline
post #2799 of 8186 Old 05-03-2017, 09:51 AM
10k
10k's Avatar
Quoted: 2143 Post(s)
Liked: 2382
Originally Posted by jrref View Post
Anyone have any comments on the Cinemotion control? By default it's set to high but i'm not exactly sure what it's supposed to do. I wish Sony would have some documentation on their controls lol
cinemotion low is detection and proper handling of 24fps content in 60hz signal. Medium and highbrefer to frame interpolation in the control description, but enabling them do not seem to cause SOE.
I use low since there are no downsides.
That said, if you read rtings review of the z9, it seems the cinemotion. Control does nothing as the z9 does not handle 24fps in 60hz content correctly. I believe the 930e got a passing grade there so maybe the A1 is ok.
paranoyd androyd and jrref like this.
10k is offline
post #2800 of 8186 Old 05-03-2017, 10:29 AM
chunon's Avatar
Quoted: 3899 Post(s)
Liked: 3908
are you a veteran ?
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is online now
post #2801 of 8186 Old 05-03-2017, 10:49 AM
bobbino421's Avatar
Quoted: 1343 Post(s)
Liked: 863
Originally Posted by leftyguitar1963 View Post
BB just denied Price match for Shopmyexchange.com They said their store had to be within 25-mile radius. Closest store is in Dallas. Typically, BB does NOT price match members only stores.
You can still negotiate. I have in the past. It wouldn't hurt. You can always walk out go somewhere else or another bb
bobbino421 is offline
post #2802 of 8186 Old 05-03-2017, 11:26 AM
robert9674's Avatar
Quoted: 1257 Post(s)
Liked: 792
Hey so does anyone know how many hours before the A1E does it's first compensation cycle?
Sony A1E
Triton one
robert9674 is offline
post #2803 of 8186 Old 05-03-2017, 11:29 AM
Quoted: 30 Post(s)
Liked: 5
I know starting from 1000 nit peak brightness is great for LED , But i don't know what is the best peak brightness for OLED to make it brighter like LED ?
What is the peak brightness ( number of nits ) for :- Sony A1E / LG OLED G7P / Sony Z9D ?
Thanks in advance
mms_medo is offline
post #2804 of 8186 Old 05-03-2017, 11:40 AM
chunon's Avatar
Liked: 3908
my question is why would Best Buy honor a price match guarantee for something you are not eligible to buy at that price ?
LG 77C8
LG 55B7A
post #2805 of 8186 Old 05-03-2017, 11:42 AM
Quoted: 2509 Post(s)
Liked: 1210
Before the moderators come and do it...
NO PRICE TALK!
Dhalmo likes this.
Shopping List:
TV: LG CX/GX
Blu-ray: Panasonic UB820
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is offline
post #2806 of 8186 Old 05-03-2017, 11:42 AM
Smackrabbit's Avatar
Quoted: 157 Post(s)
Liked: 410
Thanks in advance
That is going to depend on how you measure nits. The most common method is with a 10% window, and there a Z9D will do around 1800 while the OLED are going to be in the 650-750 range, depending on the panel you got.
However, if you do a highlight inside of real content you'll start to see more differences. The Z9D will still top, but the OLEDs won't drop at all while some other LCDs that aren't full-array backlights can have a significant drop-off. There are many ways to measure peak nits, but it doesn't always mean the number is going to align with real-world content.
10k, dominica, cockatiel and 1 others like this.
Chris Heinonen, ISF Level II Certified Calibrator
Senior Staff Writer, Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
post #2807 of 8186 Old 05-03-2017, 11:48 AM
Liked: 1210
And with OLED - the blacks are BLACK.
So in movie theater viewing conditions - the highlights (brightness) will appear brighter than their nit value in comparison to LCD TVs.
Shopping List:
TV: LG CX/GX
New24K is offline
post #2808 of 8186 Old 05-03-2017, 12:44 PM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
Itching to wall-mount and set it up!
Spizz, shyguy3763, skip61 and 3 others like this.
Nickff is offline
post #2809 of 8186 Old 05-03-2017, 12:50 PM
Quoted: 826 Post(s)
Liked: 610
Still less bright hdr details
post #2810 of 8186 Old 05-03-2017, 01:04 PM
10k
10k's Avatar
Liked: 2382
This is a pretty important point. FALD without sufficient zones will either have bad black levels around highlights in HDR, or will have significantly reduced highlights.
In fact, here's a summary of 12 recent TV tested by rtings with 10% window and "real scene" peak brightness
It quickly becomes clear that the "LCD HDR brightness advantage" is only reserved for a small portion of the high end market. The further to the left that a dot is from the black line, the more of a drop off you'll see in real content vs the standard 10% window brightness test.
(source: http://www.rtings.com/tv/tests/pictu...ness?uxtv=b5d0 sets included in graph: Sony Z9D, Sony X930E, Sony X900E, Vizio P Series 2016, Sony X700D, Samsung MU8000, Samsung Q7F, LG B6, LG C6, LG E6, LC C7)
:edit: fixed axis scales
tanman, KMFDMvsEnya and chunon like this.
10k is offline
post #2811 of 8186 Old 05-03-2017, 01:51 PM
Quoted: 30 Post(s)
Liked: 5
Thank u for your reply . Through what I see i can say a little more of brightness For current OLEDs (1000 - 1200 nits ) , they can beat any LED TVS .
mms_medo is offline
post #2812 of 8186 Old 05-03-2017, 01:51 PM
Al Leong's Avatar
Quoted: 2007 Post(s)
Liked: 2257
In reality, a LCD TV is not being viewed at its max brightness, it would wash out the black details.
I would say an OLED brightness is more effective in HDR than a LCD brightness because if the LCD want to achieve any kind of acceptable black level performance, the brightness controls must be hedged.
LCD have to find some way to keep those black aspect ratio bars in most films black, right?
New24K likes this.
Al Leong is offline
post #2813 of 8186 Old 05-03-2017, 02:21 PM
Quoted: 826 Post(s)
Liked: 610
True but we still missing details in the bright parts the lcds can show.
Looks still good but can be improved on in future gens of oleds.
post #2814 of 8186 Old 05-03-2017, 03:00 PM
Are you sure? Normally the optical out is always "live" on TVs?
c__w is offline
post #2815 of 8186 Old 05-03-2017, 03:45 PM
Quoted: 14 Post(s)
Can anyone with an A1E try this and find out for sure? Thanks
jfh24 is offline
post #2816 of 8186 Old 05-03-2017, 04:20 PM
Callsign_Vega's Avatar
Quoted: 547 Post(s)
Liked: 379
Ya, there is some dynamic here that I have to get to the bottom of. I am a motion clarity whore.
I hope it doesn't flicker/strobe at 60 Hz or that would make my purchase a complete waste of time!
Callsign_Vega is offline
post #2817 of 8186 Old 05-03-2017, 04:41 PM
Quoted: 157 Post(s)
Liked: 410
(image removed)
I went to Rtings and grabbed some of the data as well, but charted differently. Looking to see what falls off the most with real scene content, a few things stand out:
- The 2017 OLEDs so better than 2016 it seems
- Vizio gains brightness in the test
- The largest drop-off is the full array Samsung, which is surprising
I'm sure Rtings will test the Sony and we will see how it does.
Name:	Real Scene vs Window Nits.JPG
ID:	2115857   Click image for larger version
Name:	Nits Fall Off.JPG
10k likes this.
post #2818 of 8186 Old 05-03-2017, 04:47 PM
jermar's Avatar
Quoted: 55 Post(s)
Liked: 32
I just received my 65" A1E last eve. Awesome picture! I have a newb question. I have not seen any 4k content. I have Ethernet plugged in. On Amazon, I went to "The Grand Tour", but the bottom bar reads 1080p. I tried Standard and Cinema Pro. Any other free content I might check? What am I doing wrong? Thanks
jermar is offline
post #2819 of 8186 Old 05-03-2017, 04:48 PM
10k
10k's Avatar
Liked: 2382
good stuff. For me the key takeaway is that if you care about HDR and aren't buying a z9, you should get oled.
The 930e has too few zones and has blooming in subtitles and hdr movies so is disqualified (in my view). All other LCD have minimal/no brightness advantage over oled.
I'd like to see Sony 940e and Samsung q9 as well
10k is offline
post #2820 of 8186 Old 05-03-2017, 05:01 PM
CHASLS2's Avatar
Quoted: 1112 Post(s)
Liked: 497
I'm not digging at over a 4K price tag.
Sony 65" A1E Pioneer Elite DV-59 AVI
OPPO203,103&83 Sony BD player
Pioneer Elite SC61 AVR Acurus 200x 3
Paradigm 60V5'S 490 CC V5
B&W 685 S2's 2 SVS subs
CHASLS2 is offline
Reply OLED Technology and Flat Panels General
settings
