LG OLED 65W7P and 77W7P Owners Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 163Likes
post #151 of 325 Old 07-29-2017, 08:12 AM
Ken Ross's Avatar
Quoted: 7370 Post(s)
Liked: 8247
Originally Posted by sundiego View Post
Yes indeed this promotion is still valid! Just call the LG signature phone line and they confirmed the exact promotion as listed above. Once you register it takes about six weeks to receive the gift card and tablet. Pretty cool!
I registered, but it's odd that there was no indication or confirmation of any promotion. I called [email protected] and even he wasn't sure about it and indicated LG had given dealers no definitive information on this. The W is definitely part of this program, but the G seemed to be unconfirmed.
Ken Ross is offline
post #152 of 325 Old 07-29-2017, 09:14 AM
Ken Ross's Avatar
Liked: 8247
So I got the courage to do a 5% and it's pretty much as I thought. Very light banding, but with actual content, it's almost impossible to see. I've seen evidence of it only once or twice. Actually a bit of reverse vignetting is more visible, but again, very very rarely.
Edit: I should add that I haven't yet run the display for 4 hours straight, so I don't even know if I've had one compensation cycle yet.
kittycarole and Gillietalls like this.
Ken Ross is offline
post #153 of 325 Old 07-29-2017, 10:31 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6662 Post(s)
Liked: 6647
Cleveland Plasma is offline
post #154 of 325 Old 07-29-2017, 11:42 AM
Quoted: 4298 Post(s)
Liked: 3723
Never found an OLED (after going through 7) where such anomalies on slides don't show up in content. They took me out of the experience of Game of Thrones last night on my 77" G6.
A little too bright for me to tell, but that looks like a lottery winner, Ken.
Ken Ross likes this.
video_analysis is offline
post #155 of 325 Old 07-29-2017, 01:51 PM
Ken Ross's Avatar
Liked: 8247
I think so too. The only thing I can see are several thin, light bands, that are almost never there in content.
Ken Ross is offline
post #156 of 325 Old 07-29-2017, 05:02 PM - Thread Starter
Al Leong's Avatar
Quoted: 2007 Post(s)
Liked: 2257
That looks great for out-the-box.. you won't see anything in content playback.. Signature.. it's worth the investment!
Al Leong is offline
post #157 of 325 Old 08-05-2017, 10:23 PM
bgwelistyl's Avatar
I'd like to actually hook up my Amazon Echo dot to the soundbar...
Does anybody know if you can play music on the soundbar without turning on the TV?
bgwelistyl is offline
post #158 of 325 Old 08-06-2017, 05:15 AM
Ken Ross's Avatar
Liked: 8247
^ I don't know for sure, but I'd be surprised if you can.
Ken Ross is offline
post #159 of 325 Old 08-13-2017, 07:16 PM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
Angry
Anyone having any issue's playing these files directly from the TV to let it decode?
Game.of.Thrones.S01E01.1080p.BluRay.HEVC.ATMOS.7.1-Absinth.mkv
General
Unique ID : 188568816632466223191159717237666880714 (0x8DDD0876298AF6BA8DFCE4E9E2A01CCA)
Complete name : D:\_Temp\Game of Thrones 2011 Season 1-6 1080p BluRay HEVC TrueHD Atmos 7.1\S01\Game.of.Thrones.S01E01.1080p.BluRay.HEVC.A TMOS.7.1-Absinth.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 4.08 GiB
Duration : 1 h 1 min
Overall bit rate mode : Variable
Overall bit rate : 9 480 kb/s
Encoded date : UTC 2017-08-13 22:07:04
Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 4 343 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.087
Stream size : 1.87 GiB (46%)
Writing library : x265 1.9+3-548a45bbf223:[Windows][GCC 5.3.0][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=2 / tu-inter-depth=2 / me=3 / subme=3 / merange=57 / rect / amp / max-merge=3 / temporal-mvp / early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=60 / lookahead-slices=1 / bframes=8 / bframe-bias=0 / b-adapt=2 / ref=4 / limit-refs=2 / limit-modes / weightp / weightb / aq-mode=3 / qg-size=16 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=6 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / no-rd-refine / signhide / deblock=-2:-2 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=23.5 / qcomp=0.80 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.10 / pbratio=1.10
Default : Yes
Forced : No
Audio
Format : Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 5 059 kb/s
Maximum bit rate : 7 887 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 spf)
Compression mode : Lossless
Delay relative to video : 1 ms
Stream size : 2.18 GiB (53%)
Language : English
Default : No
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 0 min
Bit rate : 9 418 b/s
Count of elements : 1290
Stream size : 4.06 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:00:06.006 : en:00:00:06.006
00:07:16.436 : en:00:07:16.436
00:08:56.536 : en:00:08:56.536
00:18:14.510 : en:00:18:14.510
00:28:46.558 : en:00:28:46.558
00:39:35.582 : en:00:39:35.582
00:50:00.039 : en:00:50:00.039
01:00:32.629 : en:01:00:32.629
When I start the play in the top right it says audio format not supported. Works fine of my desktop PC.
Just found it odd that other file I have works just fine, Example;
G.I.Joe.Retaliation.2013.Extended.Action.Cut.1080p .BluRay.x264.TrueHD.7.1-HDWinG.mkv
General
Unique ID : 230927746598659153383287707444192400886 (0xADBB10F38F393B4CBDF44A9EC98ED5F6)
Complete name : D:\MOViES\G.I.Joe.Retaliation.2013.Extended.Action .Cut.1080p.BluRay.x264.TrueHD.7.1-HDWinG.mkv
Format : Matroska
File size : 18.9 GiB
Duration : 2 h 3 min
Overall bit rate : 22.0 Mb/s
Encoded date : UTC 2013-07-11 12:24:35
Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 132 r2323+704+51 d571b1c tMod [[email protected]:2:0 X86_64]
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.01:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=crf / mbtree=1 / crf=18.1000 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.20 / aq=4:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Language : English
Default : Yes
Forced : No
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Maximum bit rate : 6 108 kb/s
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 kHz
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Language : English
Default : No
Forced : No
Pir8pete is offline
post #160 of 325 Old 08-13-2017, 09:10 PM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
had to re-download season 1-5 with audio at 48000 Hz 6 channel and it's fine to play that. season 6 already included the correct audio the TV liked. Odd that it can't de-code the TrueHD ATMOS 7.1 with 8 channel
Pir8pete is offline
post #161 of 325 Old 08-26-2017, 05:53 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
Exclamation
Firmware version 03.60.15 has been released, I'm going to do the update manually as the TV is not doing the auto update over the network for some reason even though I have auto checked off.
Also does any1 have or know where we can look at the change log?
CA.lgtvsdp.com
<- update server?
ca.rdx2.lgtvsdp.com <- update server?
CA.info.lgsmartad.com <- Ads?
I also noticed the TV keeps connecting to the following;
Code:
2017-8-26  08:18:42    LG TV    CA.lgtvsdp.com
2017-8-26  07:18:42    LG TV    CA.lgtvsdp.com
2017-8-26  06:19:06    LG TV    ca.rdx2.lgtvsdp.com
2017-8-26  06:18:42    LG TV    CA.lgtvsdp.com
2017-8-26  05:59:05    LG TV    ca.rdx2.lgtvsdp.com
2017-8-26  05:18:42    LG TV    CA.lgtvsdp.com
2017-8-26  05:09:04    LG TV    ca.rdx2.lgtvsdp.com
2017-8-26  04:49:04    LG TV    ca.rdx2.lgtvsdp.com
2017-8-26  04:47:48    LG TV    CA.lgtvsdp.com
2017-8-26  04:46:16    LG TV    CA.lgtvsdp.com
2017-8-26  04:18:42    LG TV    CA.lgtvsdp.com
2017-8-26  00:34:32    LG TV    CA.lgtvsdp.com
2017-8-26  00:24:52    LG TV    ca.rdx2.lgtvsdp.com
2017-8-26  00:14:51    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  23:54:51    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  23:34:31    LG TV    CA.lgtvsdp.com
2017-8-25  23:04:49    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  22:44:49    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  22:34:48    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  22:34:31    LG TV    CA.lgtvsdp.com
2017-8-25  21:34:31    LG TV    CA.lgtvsdp.com
2017-8-25  21:14:47    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  20:34:31    LG TV    CA.lgtvsdp.com
2017-8-25  20:24:46    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  19:34:46    LG TV    ca.rdx2.lgtvsdp.com
2017-8-25  19:34:31    LG TV    CA.lgtvsdp.com
2017-8-25  19:27:17    LG TV    CA.lgtvsdp.com
2017-8-25  19:27:16    LG TV    CA.lgtvsdp.com
2017-8-25  17:46:40    LG TV    ca.rdx2.lgtvsdp.com
any1 know what this is all about? I don't use any of it's smart features like the apps or anything, I've deleted all pre-installed apps too
Pir8pete is offline
post #162 of 325 Old 08-26-2017, 08:11 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
I noticed after this update that I don't get the random crackle/pop in the audio.
rsonnens likes this.
Pir8pete is offline
post #163 of 325 Old 08-28-2017, 09:17 AM
Ted99's Avatar
Quoted: 980 Post(s)
Liked: 441
Will an owner please comment on screen reflectivity? I've got a room with rear windows that I see clearly in the picture on my Sony XBR79. Almost unwatchable on a bright day.
JVC RS600 Chad-callibrated, 120" 1.3g in Batcave HT, Denon X8500 Polk LSiM703 fronts,
RTi-12 rears, LSiM 706 center, Monitor 40 Heights, Monitor 60 FW, FXiA4 Bi-pole sides,
LSiC CH, Infinity 6" VOG. 4X 12" subs w/mini DSP on sub 1 and nearfield 18" from sub 2.
Ted99 is offline
post #164 of 325 Old 08-28-2017, 06:19 PM
Cam1977's Avatar
Quoted: 3051 Post(s)
Liked: 3737
One of the best looking 5% out their...if it were me I probably woulndt check again lol! Funny how we all get excited looking at a gray screen...only avs😁😁😁
Radvlad likes this.
Cam1977 is online now
post #165 of 325 Old 08-31-2017, 08:40 AM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Seriously? That fixed the audio issue? I thought it was my speakers, so I bought some better speakers for the FL, C, and FR. They haven't come in yet, but I thought the crackling and pop (sounds like speaker chafing).
I'm not using my soundbar for the audio. I'm using in-ceiling speakers and have the audio/video running through a matrix. As a matter of fact, my soundbar is hidden inside the wall behind my screen, which is mounted on a brick wall. Everyone who has been to my house since it was setup has been amazed by. First of all, no one has even heard about this TV before, and the way it's setup, all that's visible is the screen attached to the brick wall. No cables and no soundbar are seen, which makes the TV look recessed, but since it's a brick wall, no one can figure it out until I show them how it's installed.
rolldog is offline
post #166 of 325 Old 08-31-2017, 04:05 PM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Here's a picture of how my W7 is installed.
rolldog is offline
post #167 of 325 Old 09-01-2017, 06:09 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
Exclamation
faults happiness, lol, the crackling is still there, dam I really thought they finally got ride of it in the newest fw version.
Yes it's a known issue with all LG TV's, I've experienced this on the 16 models too, programmers really need to fix it.
Pir8pete is offline
post #168 of 325 Old 09-01-2017, 06:11 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
Thumbs up
clean look, very nice. must have been some work to make holes for mounting and the cable in the brick
Pir8pete is offline
post #169 of 325 Old 09-01-2017, 06:13 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
it will reflect, I need to close the curtains when watching. Any shinny surface will be worse then a dull one. I remember i tried a Panasonic Plasma back in 2007 that was amazing with no reflection, but opt for the Pioneer. I'm not sure why manufactures go with a shinny surface, makes reflections bad.
Ted99 likes this.
Pir8pete is offline
post #170 of 325 Old 09-01-2017, 06:20 AM
Pir8pete's Avatar
Quoted: 33 Post(s)
Liked: 31
I'm going to post my calibration settings soon as I get some time. I know each TV is a little different but at least it will give you guys a good starting point, or almost be right on the money.
Pir8pete is offline
post #171 of 325 Old 09-01-2017, 09:19 AM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Yes it was, but I didn't want the soundbar to be seen since I'm not using the speakers in it. I called LG and all their authorized parts distributors trying to find another extension like the one it came with, but no one sells this cable by itself. Even the tech support guy at LG Sent me a schematic of the TV, which listed every single part of the TV but the cable wasn't even listed as an option. So, the soundbar is mounted to the inside of the wall.
rolldog is offline
post #172 of 325 Old 09-01-2017, 09:38 AM
Industry Insider
Liked: 6647
post #173 of 325 Old 09-01-2017, 11:28 AM
Wizziwig's Avatar
Quoted: 2231 Post(s)
Liked: 1518
Nice setup but you may want to rethink your choice in TV programming given the recent burn-in examples posted on the forum from news stations. At the very least, maybe zoom and pan those bright static elements via all-direction-zoom so they're not always visible. Would hate to see this expensive TV ruined prematurely.
Wizziwig is offline
post #174 of 325 Old 09-01-2017, 04:14 PM
Quoted: 108 Post(s)
Liked: 77
Slight off topic but intresting anyway...
New wall paper Oled shown at ifa 2017 from Toshiba.
With a smaller hdmi box than Lg W7 big sound bar.
hobbs47, Ted99, shyguy3763 and 3 others like this.
xSAMCOx is offline
post #175 of 325 Old 09-02-2017, 08:08 AM
Ted99's Avatar
Quoted: 980 Post(s)
Liked: 441
I hope LG is listening to the posters on their site objecting to the components in a mandatory soundbar. I'd be purchasing this TV, but I'll wait until 2018 models come out to see if I can get it without the soundbar. It's a dealbreaker for me.
shyguy3763 and xSAMCOx like this.
Ted99 is offline
post #176 of 325 Old 09-02-2017, 08:42 AM
Industry Insider
Liked: 6647
^^^ The sound bar is where the brains are for the TV, there will always be a separate box or something for the brains, power supply, cable hookups, ect ect........
post #177 of 325 Old 09-02-2017, 10:12 AM
Quoted: 108 Post(s)
Liked: 77
Just needs to be a smaller box that easy to hide inside a tv table or so ...
xSAMCOx is offline
post #178 of 325 Old 09-02-2017, 12:56 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
A small sleek one connect like box with a longer more durable non ribbon cord would be great. The W7 or 8 would be a real winner.
Lozin is offline
post #179 of 325 Old 09-03-2017, 10:40 AM
Ted99's Avatar
Quoted: 980 Post(s)
Liked: 441
Absolutely. Can't put all those electronics in "wallpaper". I'd like something like my one-connect box which I can bury in a cabinet and keep the bundles of cables off the top of the cabinet below my TV. Still have to have a place for the Blu-ray and receiver, so a cabinet is still in the cards. Ribbon or wire, all the same to me. If one is doing separate speakers, putting a cabinet under the TV doesn't mess up the aesthetics too much. I suppose if I valued form over function and was looking for a spread in a "decorator" magazine, I'd want the wallpaper TV, a built-in sound bar as in the video and a wall hanging vertical B&O blu-ray player. But, I don't so I'll be waiting for a one connect-type box sans speakers. But, I'd really appreciate it if it were a little thicker and had the Sony-type screen speakers with an external 8 ohm analog input, so I could use it as the center speaker!
Ted99 is offline
post #180 of 325 Old 09-03-2017, 12:39 PM
Quoted: 51 Post(s)
So he's not allowed to watch CNBC because it might burn in? What's the point in buying a TV if he can't watch the channels he wants?
shyguy3763 and Latinoheat like this.
heynowbababooey is offline
Reply OLED Technology and Flat Panels General
