Sony A1E OLED 4K Ultra HD Owners Only Thread [No Price Talk] - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 28419Likes
post #3601 of 7683 Old 01-24-2018, 06:29 PM
dancolt's Avatar
Quoted: 518 Post(s)
Liked: 400
Originally Posted by Baby Jocko View Post
Try to see if it also resolves the raised black level issue. The best way to detect it may be with a letterbox movie and a bright outdoor scene. The black bars should remain absolutely black.
I am betting passing the metadata independent from the video signal will also resolve the raised black issue.
Do you know of a good test on Netflix or Amazon that is known to have the issue?
Dan
Equipment:
Sony XBR65A1E / Denon AVR-X4400H / Outlaw 5000 amp / Apple TV 4K /
Playstation 4 Pro / Bowers & Wilkins 685, HTM62, M1 / Klipsch KSW-15 /
Ubiquiti Unifi Network
dancolt is offline
post #3602 of 7683 Old 01-24-2018, 06:46 PM
Baby Jocko's Avatar
Quoted: 124 Post(s)
Liked: 104
Dan
The following is from John Archer's article regarding this issue:
If you have an Apple TV 4K with a Dolby Vision OLED TV and want to see the problem for yourself, I know that Mindhunter and Godless on Netflix are definitely affected by it. For instance, if you fire up Mindhunter Episode 8 and start watching from around 8 minutes and 25 seconds in, you can clearly see big shifts in the image’s black levels as the picture shifts from the bright school interview to Holden sitting on a step outside his girlfriend’s flat.
There’s another big shift during a cut within this exterior night-time sequence too, and the black bars above and below the picture clearly drop back to their normal inky depths once the action cuts to the brighter interior of the girlfriend’s house.
The fact that the problem impacts the black bars above and below wide aspect ratio pictures makes it more distracting - and suggests that some instruction in the Dolby Vision metadata is pushing the OLED TV out of its brightness comfort zone.
Even better, click here for an AVS Forum post with pic.
Sony XBR-65A1E
LG 55EG9600
Oppo UDP-203
Baby Jocko is offline
post #3603 of 7683 Old 01-24-2018, 07:09 PM
cuibap's Avatar
Quoted: 129 Post(s)
Liked: 33
Originally Posted by jrref View Post
So here is the Big question. Once Oppo, for example, starts sending the new DV profile, with the current version of AVRs that currently pass DV, will they be able to pass the new DV profile data?
That's my concern too. I have A1060 and A1070 and don't know if Yamaha updates the firmware to pass dynamic metadata to the TV.
Sent from my SM-G935T using Tapatalk
Sony XBR-X940E; Yamaha RX-A1060; Nvidia Shield TV; OPPO BDP-93; Yamaha RX-A1070
cuibap is offline
post #3604 of 7683 Old 01-24-2018, 07:11 PM
Baby Jocko's Avatar
Quoted: 124 Post(s)
Liked: 104
Your AVR will need an update. HDMI < 2.1 cannot pass dynamic metadata without a firmware update. But, don't take my word for it. I don't have the ATV4K beta. Ask someone who does and who also integrated it with an AVR.
Sony XBR-65A1E
LG 55EG9600
Oppo UDP-203
post #3605 of 7683 Old 01-24-2018, 07:12 PM
cuibap's Avatar
Quoted: 129 Post(s)
Liked: 33
Originally Posted by aaz View Post
Public beta should be out in a day or two - will let you know then. Maybe if someone has the developer beta they can check?
I would be careful with the beta though - I've found that they really can be unstable at times and I've had to unplug the ATV a few times to get a signal back.
Can you confirm if your ATV4K connects directly to the TV or to a receiver?
cuibap is offline
post #3606 of 7683 Old 01-24-2018, 07:27 PM
dancolt's Avatar
Quoted: 518 Post(s)
Liked: 400
Looks perfect to me.
Check it out and let me know what you think:
https://www.dropbox.com/s/lgixzb6qa0...%20PM.mov?dl=0
Dan
Baby Jocko, camacho8 and m_snow like this.
Equipment:
dancolt is offline
post #3607 of 7683 Old 01-24-2018, 07:38 PM
Baby Jocko's Avatar
Quoted: 124 Post(s)
Liked: 104
Dan
Yep! Looks perfect. Thanks!
As expected, this DV update kills two birds with one stone. I always figured mapping the display from the embedded metadata was the reason for the raised blacks. And, without having to extract embedded metadata frame-by-frame is a huge plus for efficiency.
I figured Sony knew the HDMI 2.1 spec would be introduced by the end of 2017, which is why they said all along that DV would be delivered then. Knowing this, they elected to save money and processing power by not having to extract embedded metadata. All they had to do was wait for HDMI 2.1 spec and Dolby would deliver the updated profile.
Dynamic metadata over HDMI sole purpose was spec'd for DV (and HDR10+).
Sony XBR-65A1E
LG 55EG9600
Oppo UDP-203
post #3608 of 7683 Old 01-24-2018, 07:40 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
Yeah, someone in the ATV4K thread noted that they had floating bars in a certain scene with their LG OLED, but they are not there on the Sony ZD9.
XBR65A9G / XBR65A8F / 55R615
ATV4K / Uverse / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #3609 of 7683 Old 01-24-2018, 09:26 PM
aaz
Quoted: 199 Post(s)
Liked: 164
I have it connected to the TV port 4 due to my receiver only supporting HDMI 2.0a, so no HDR through that. Will have to fix that at some point, but waiting for a real need and the dust to settle. Having it this way only allows me 30 fps with 4K HDR, but that is enough for movies - will have to see if DV works this way.
The ARC is on port 3, and my XboX1X is on Port 2 for 60fps. Not ideal, but alright for now.
Family Room: Sony XBR-65A1E | Yamaha YSP 5600 | Sunfire HRS10 | Shaw Gateway HD-PVR | AppleTV 4K | Sony BDP-S6200 | (soon) XBox One X | Harmony Ultimate one
Living Room: Panasonic 65VT30 | Yamaha YSP 4300 | Shaw Gateway HD-PVR | AppleTV 4 | PS3 | Harmony | Harmony one
Bedroom: LG 43UJ6300 | Shaw Gateway HD-PVR | AppleTV 3 | Harmony one
aaz is offline
post #3610 of 7683 Old 01-25-2018, 01:11 AM
mr. wally's Avatar
Quoted: 250 Post(s)
Liked: 152
Originally Posted by jwstegbauer View Post
Check the Firmware Version of the TV
Turn on the TV.
On the TV remote control, press the HOME button to open the TV Home Menu.
From the Settings category, navigate to the Help (question mark) icon.
Help Screen
With the Help icon selected, press the OK button on the remote control.
If the software version displayed is PKG6.2818.0075NAA or higher, your TV doesn't need this update.
Software Version-screen
Thank you
This is one of more complex interfaces I've encountered on any AV device.
I'm hard wired to modem via Ethernet and software shows as 0070NAA.
After all the bugs reported, do majority suggest updating via USB or waiting for Sony?
Sony Bravia 65 A1e, Oppo 203, Denon X4400H, Hsu VTF-3 Subwoofer,
Ascend HTM 200se, Emotiva air motiva E1, 5.1.2 audio surround, Monoprice certified, premium 18mg, 2.0a HDMI cables
mr. wally is offline
post #3611 of 7683 Old 01-25-2018, 01:20 AM
aaz
Quoted: 199 Post(s)
Liked: 164
Originally Posted by mr. wally View Post
Thank you
I've found the update is pretty good, though there have been some complaints about sound pops that I personally have not experienced. Everything else operates more smoothly, and DV with internal apps is quite good. I'll soon have the AppleTV 11.3 update and am looking forward to DV on that as I do find the HDR from that a bit lacking.
aaz is offline
post #3612 of 7683 Old 01-25-2018, 05:10 AM
rlb
rlb's Avatar
Quoted: 2274 Post(s)
Liked: 1918
Originally Posted by BRAC View Post
Relax people...a half baked version of Dolby Vision is better than no version at all. And, based on what I’m seeing with Netflix DV, it’s a significant step up from HDR10. Both Sony and Dolby share equal blame if you ask me, but I’m still confident they’ll get it all sorted out sooner than later.
My only concern going forward is whether or not my Denon 4300H HDMI passthrough will be compatible with this new version of DV.
On the Z9D thread, a Marantz 7011 owner said that his AVR passed the "low latency" DV input from a beta firmware ATV. The Marantz and Denon (same manufacturer) 2016 models all received DV pass through via firmware update. You would think that if one of their updates supported the low latency version, they all would.
typ44q, BRAC, lsorensen and 1 others like this.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #3613 of 7683 Old 01-25-2018, 05:41 AM
jwstegbauer's Avatar
Quoted: 133 Post(s)
Liked: 122
Thank you
You are on the firmware version just right before the update.......I updated via USB.....but would suggest waiting for Sony's next update.
Sony XBR-65A1E OLED | Harman Kardon PA-2200 Amp | Panamax MR4300 | Apple Tv 4K
Sony Receiver STR-ZA3100ES | Sony UBP-X700 | Oppo UDP -203 4K UHD Blu-ray Player
4 - Klipsch RP-250F Floorstanding Speaker | Klipsch RP-240S Surround Speaker (Pair) | Klipsch RP-440C Center Channel Speaker
Klipsch R-112SW Sub | Klipsch RP-140SA Dolby Atmos Speaker (Pair) | Playstation 4 Pro
jwstegbauer is offline
post #3614 of 7683 Old 01-25-2018, 05:47 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
When I get the beta update, Ill be curious to test my Yamaha A3060.
danielsullivan likes this.
post #3615 of 7683 Old 01-25-2018, 06:16 AM
VidPro's Avatar
Quoted: 1488 Post(s)
Liked: 1243
My ATV 4K will not update properly. I'm in the beta program, but each time I update it goes through the motion of updating without updating. I'll see if there's an update again and it goes through the process again, but no update.
The television screen is the retina of the mind's eye.
Sony XBR-65A1E OLED/Denon X4300H/Oppo 203/Klipsch RVX‑42/PS4 Pro/Xbox One X/5.1.2
VidPro is offline
post #3616 of 7683 Old 01-25-2018, 06:20 AM
Quoted: 44 Post(s)
Probably a topic for the ATV4K forum. Back to the new issue... where the heck is our eARC?!?! This is crazy. It January 2018 for gosh sakes. . (DV update works great in my setup from my ATV4K to my A1E. Well done Sony and I blame Dolby for the confusion.). Enjoy!
Sent from my iPhone using Tapatalk Pro
wasima likes this.
Main: YouTubeTV -> Apple TV 4k -> Anthem MRX 720 (5.1.2 DTS:Neural X) <-> Sony 65A1E
Den: Apple TV -> Pioneer Kuro PDP-5010FD
DTS beats Dolby.
purduelion is offline
post #3617 of 7683 Old 01-25-2018, 06:22 AM
VidPro's Avatar
Liked: 1243
Originally Posted by purduelion View Post
Probably a topic for the ATV4K forum. Back to the new issue... where the heck is our eARC?!?! This is crazy. It January 2018 for gosh sakes. . (DV update works great in my setup from my ATV4K through my pioneer to my A1E. Well done Sony and I blame Dolby for the confusion.). Enjoy!
Thanks. I'm hailing a taxi to go over there now.
VidPro is offline
post #3618 of 7683 Old 01-25-2018, 06:26 AM
256k's Avatar
Quoted: 387 Post(s)
Liked: 68
Best way to see if there's raised blacks
Buy Interstellar in AppleTV 4K -> Go to the credits, that scene is totally gray in my LG, if the black is fixed, won't appear gray on SONY
Also there's a scene with raised blacks that creates lots of artifacts on my LG cause of that, go to the scene where Cooper wakes up and Murph talks with him while he's in the bed, at the beginning of the movie, that scene has raised blacks too on my LG
If you don't want the movie, just refund it after testing it
OLED E6 USER
256k is offline
post #3619 of 7683 Old 01-25-2018, 07:52 AM
Baby Jocko's Avatar
Quoted: 124 Post(s)
Liked: 104
You can refund a movie?
wasima likes this.
Sony XBR-65A1E
LG 55EG9600
Oppo UDP-203
post #3620 of 7683 Old 01-25-2018, 07:54 AM
256k's Avatar
Quoted: 387 Post(s)
Liked: 68
Yes, if you don't like it or have problems you can, but don't abuse the system or they'll ban you
256k is offline
post #3621 of 7683 Old 01-25-2018, 08:07 AM
GAM5's Avatar
Some positive news:
https://www.forbes.com/sites/johnarc.../#7a9b7160623e
eternal21 likes this.
Sony XBR-65A1E
GAM5 is offline
post #3622 of 7683 Old 01-25-2018, 08:34 AM
Liked: 0
I am having black flashing from my dishnetwork since the Dolby Vision update all other devices are fine Apple TV bdp 800 every thing goes thru my denon 7200wa dot know what the fix is restarted all devices saw this glitch with direct tv also
Sony XBR65A1E denon7200wa Sony ubp800 Apple TV 4k ubp700
AJSKIER is offline
post #3623 of 7683 Old 01-25-2018, 08:41 AM
tarainfo's Avatar
Quoted: 26 Post(s)
According to some
The newest beta update for Apple TV4K now supports HDMI Dolby Vision Support on Sony Tv's with the latest
Firmware
As seen as Apple TV owners thread
Sony XBR-55A1E
Oppo UDP-203
tarainfo is offline
post #3624 of 7683 Old 01-25-2018, 08:42 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
Is it a Dish client or HDDVR? I am not having any problems with the UBP-X700, the ATV4K or my Directv HDDVR. My Directv client does flash.
post #3625 of 7683 Old 01-25-2018, 09:15 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6763 Post(s)
Liked: 6766
Cleveland Plasma is offline
post #3626 of 7683 Old 01-25-2018, 09:27 AM
Quoted: 69 Post(s)
Originally Posted by Chris-Tish View Post
I cannot play HDR versions on these movies on iTunes HDR:
Blade Runner 2049
Maze Runner
The Dark Knight
Any ideas?
XBR55-A1E
Sonos PlayBar/Sub/1/3/5
AppleTV 4K
Chris-Tish is offline
post #3627 of 7683 Old 01-25-2018, 09:31 AM
jerrolds's Avatar
Quoted: 130 Post(s)
Liked: 46
Should we be updating to the latest firmware? I havent updated mine yet (always skipped)
Wonder if i need to do anything on my AVR side (Denon X3300W)? I guess the best way to watch DV is via Netflix app and optical to AVR? Which means DTS 5.1 core?
TV: 65" Sony OLED XBR65A1E Speakers: KEF LS50 LCR Front Stage Subs: SVS PB2000 & PB1000 [B] AVR: Denon X3300W DSP: Dirac Live Full Suite
jerrolds is offline
post #3628 of 7683 Old 01-25-2018, 09:35 AM
edtorious's Avatar
Quoted: 49 Post(s)
So even if Oppo and ATV 4K released a firmware to enable DV over HDMI. Did Sony lived up to it's promise? Did we get our money's worth? Is it still better than other TV specifically LG OLED ones?
SinGA likes this.
65" Sony A1E OLED TV
55” TCL C803 TV
55” Sony HX929 TV
Sony HT-ST5000 Soundbar
Oppo UDP-203 UHD Player
edtorious is offline
post #3629 of 7683 Old 01-25-2018, 09:42 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
If you care about motion, image processing and near black, yes, it's better. I also think Sony's choice for tone mapping in 2017 is better than LG's decision.
Couch Viking likes this.
post #3630 of 7683 Old 01-25-2018, 09:47 AM
PeterUbers's Avatar
Quoted: 484 Post(s)
Liked: 146
This is great news ... tempted to allow beta updates on my atv.... bad idea?
1) 7.2.4 Atmos; Marantz 8802a; Parasound A51; Parasound 1250; Oppo BDP203; AppleTV4K; Harmony Hub; Paradigm Prestige 95F; ML Descent-i; Prestige 2000sw; 4x SA-ADP paradigm in walls surrounds; 4x paradigm ceilings, angled; Furman; XBR-77A1E; xfinity x1; 2) 5.1; Marantz 7702; Emotiva XPA-5; Monster Power Center; Oppo-BDP93; Apple 2K; Harmony Hub; Paradigm Studio 100 v.5, CC-690, SA-ADP in-walls; Paradigm Sub 15; Panasonic ZT60 65"; Xfinity X1
PeterUbers is offline
Reply OLED Technology and Flat Panels General
a1e , oreo , software update , v6.6510
