Weird Pixelation on Letterboxed Movies - LGOLEDB655 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Esilbe1
post #1 of 10 Old 05-30-2017, 12:40 PM - Thread Starter
Esilbe1's Avatar
I recently discovered pixelation on the upper left-hand corner of my screen. So far, I've only noticed it when watching movies with letterboxing, and mostly on Showtime.
Is anyone familiar with this issue and how to resolve it?
I contacted LG support who told me to call a local service tech to assess it further. I'm reluctant to engage a tech if it's something I can fix myself. I suppose they want to verify if the TV is damaged, which it is not. I bought it a few weeks ago.
I appreciate your help.
Esilbe1 is offline
post #2 of 10 Old 05-30-2017, 12:44 PM
wxman's Avatar
Quoted: 5497 Post(s)
Liked: 3901
Try turning off Pixel shift on the tv. Does it do that when watching blu ray movies that have letterbox bars? If it's only occurs through your cable box or while watching Showtime, it's either the cable box or Showtime.
LG 65E6P OLED - LG 65EF9500 OLED - OPPO 203 - OPPO 103D
wxman is offline
post #3 of 10 Old 05-30-2017, 01:49 PM
Patsfan123's Avatar
Quoted: 511 Post(s)
Liked: 329
Try turning off Just Scan in the Aspect Ratio settings.
LG 65C6P FW: 05.30.70 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #4 of 10 Old 05-30-2017, 01:52 PM - Thread Starter
Esilbe1's Avatar
Do you mean Screen Shift under OLED Panel Settings?
Other settings are:
Noise Reduction: Off
MPEG Noise REducation: Off
Real Cinema: On
Motion Ey Control Off
Tru Motion: Off
I turned that off to no avail.
Is it possible this is related to signal noise ratio -- too high or too low?
Esilbe1 is offline
post #5 of 10 Old 05-30-2017, 02:06 PM
wxman's Avatar
Liked: 3901
Other settings are:
Real Cinema: On
Tru Motion: Off
I meant screen shift. Do you have just scan turned on?
wxman is offline
post #6 of 10 Old 05-30-2017, 02:21 PM - Thread Starter
Esilbe1's Avatar
Turning off "Just Scan" did the trick!!!
wxman likes this.
Esilbe1 is offline
post #7 of 10 Old 05-30-2017, 02:23 PM
wxman's Avatar
Liked: 3901
For blu ray movies, turn just scan back on.
wxman is offline
post #8 of 10 Old 05-30-2017, 02:53 PM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
Interesting? So for cable / satellite you have just scan off and then for blu rays you turn it back on?
LG OLED 65B6P
Panasonic VIERA TC-P65VT30
OPPO UDP-203 4K Ultra HD Blu-Ray Player
Sony PlayStation 4 Pro
Nintendo Switch
Sony PlayStation 3
Superman23 is offline
post #9 of 10 Old 05-30-2017, 03:33 PM
wxman's Avatar
Liked: 3901
I have just scan turned on for everything. I have DirecTV, and have no issues. Just scan gives perfect 1:1 pixel mapping. With some cable tv boxes, it could be using some sort of overscan, which would show noise in the black bars if 1:1 pixel mapping is used. By turning off just scan, you actually add some slight zooming to the picture, which would get rid of that noise, but you lose some detail, thus the reason why you should use 1:1 pixel mapping (just scan) to see exactly what was meant to be seen.
wxman is offline
post #10 of 10 Old 05-30-2017, 03:47 PM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
Understood. Thank you. I have DirecTv too so I'll set the same as you.
LG OLED 65B6P
Nintendo Switch
Sony PlayStation 3
Reply OLED Technology and Flat Panels General
lgoled55b6 , oled , pixels
