LG C7 ARC & Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-22-2017, 08:33 PM - Thread Starter
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
LG C7 ARC & Remote
Two questions about the LG C7:
1. I plan on using the TV apps to stream content, but want the sound to come only from my 5.1 setup, not the TV speakers. If I connect the ARC HDMI from the TV to the same on the receiver, that should work, right? I have a Sony STR-DH550.
2. Can the C7's remote also control the receiver? It would be nice to only have that rather than having to adjust the volume with the receiver remote. Not sure how it would work though, if even possible, since it seems like changing the receiver volume would also change the TV's volume, which I want to remain at zero.
ROMIL is offline
post #2 of 3 Old 06-23-2017, 08:26 AM
smoore's Avatar
Quoted: 173 Post(s)
Liked: 99
I don't have the Sony receiver but you can set the TV to output sound (sound settings cannot recall the particulars) through the HDMI connection. On my Yamaha I can adjust the volume from the LG remote. You need to have CEC activated on the TV and the receiver.
smoore is offline
post #3 of 3 Old 06-23-2017, 10:42 AM - Thread Starter
ROMIL's Avatar
Quoted: 512 Post(s)
Liked: 238
Sounds good, thanks for the info.
ROMIL is offline
Reply OLED Technology and Flat Panels General
