OLED Screen Uniformity Discussion-Banding and Vignetting - Page 248 - AVS Forum | Home Theater Discussions And Reviews
 3479Likes
post #7411 of 8433 Old 07-11-2019, 12:47 PM
Ruppgu's Avatar
Quoted: 503 Post(s)
Liked: 564
It might get better but like Cam said, it's hard to say. The first 200 hours things can change a lot. Once you hit 200 I wouldn't expect major changes.
TV: Sony A9G 77" Oled & LG B7A 65" Oled
AVR: Denon AVRX4300H
F/L: Emotiva Airmotiv T2, Center: Emotiva Airmotiv C2, Surround: Emotiva Airmotiv B1 x4, Atmos: Elac A4 x4, Subwoofer: PSA V1811, Actuator: Crowson x2
4k Player: Panasonic UB 820
Ruppgu is offline
post #7412 of 8433 Old 07-11-2019, 01:20 PM
Quoted: 243 Post(s)
Originally Posted by macmane View Post
This is a c9 and that black strip across the top on the 5 percent gray annoys me but I dont see any visible banding or annoying banding i should say in content. My question is will that black strip at the top fade or its permanent. I've ran 1 manual and have about 80 hours on the set
Sent from my SM-G975U using Tapatalk
I have the same here
Sent from my SM-G950F using Tapatalk
Toto84 is offline
post #7413 of 8433 Old 07-11-2019, 01:25 PM
macmane's Avatar
Quoted: 1161 Post(s)
Liked: 703
How long have yours been there? I have 80 hours on this particular set
macmane is offline
post #7414 of 8433 Old 07-11-2019, 01:56 PM
CPTuell's Avatar
Quoted: 219 Post(s)
Liked: 89
I decided to play the Panel Lottery. I may have won. 3rd 65"C9 Pics below from 1st, 2nd and 3rd (Current) set in that order. 100% White & 5% Black. The Third set has the best White screen, but the 2nd set had virtually no dark screen banding. The 3rd is better than the 1st as far as dark screen banding. I've only noticed the dark bar right of center one time when I was looking for it in a dark panning sequence on NOS4A2. So it's a keeper. If it gets worse in the future I have Geek Squad 5yr warranty. The magenta and cyan tinting on the 1st 2 sets drove me nuts (Short Trip). Light colored walls, snow & light gray skies were the worst. Saw it on almost any show. Guess what they say is true about the lottery. "If you don't play you can't win."
Name:	100% White 1st Set.jpg
ID:	2589858   Click image for larger version
Name:	100% White 2nd Set.jpg
ID:	2589860   Click image for larger version
Name:	100% White 3rd set.jpg
ID:	2589862   Click image for larger version
Name:	5% 1st Set.jpg
ID:	2589864   Click image for larger version
Name:	5% Near Black 2nd Set.jpg
Name:	5% Black Current Set.jpg
PiratesCove likes this.
CPTuell
" I'm a man, I can change, If I have to......I guess. :(" Words to live by. From the Red Green Show...The Man's Prayer
LG OLED65C9PUA ,DirecTv HR-54 Genie w/4K MiniGenie, Denon AVR-X3300W, Roku Ultra 4K/HDR, Chromecast Ultra 4K/HDR, Panasonic DP-UB820P BluRay .
CPTuell is offline
post #7415 of 8433 Old 07-11-2019, 03:32 PM
guitarguy316's Avatar
Quoted: 2134 Post(s)
Liked: 808
Congrats. What month was your newest model?
guitarguy316 is offline
post #7416 of 8433 Old 07-11-2019, 04:25 PM
CPTuell's Avatar
Quoted: 219 Post(s)
Liked: 89
05/19 Assembled in Mexico
The 1st 2 were both 04/19 also Mexico.
The camera is picking up some magenta on right side, but it does not show up when looking at it live. I may have to double check and see if I sent the correct photo of the current set. Will correct if I screwed up.
CPTuell
CPTuell is offline
post #7417 of 8433 Old 07-11-2019, 04:46 PM
Liked: 808
Camera always picks up more than you see. I posted some test videos the other day that I found will point out any red tint.
post #7418 of 8433 Old 07-11-2019, 08:59 PM
Yukon Trooper's Avatar
Quoted: 140 Post(s)
Liked: 98
Hard to gauge the banding because of the pixelation, but your tinting is definitely better. What settings were you using for the tinting pictures?
Yukon Trooper is offline
post #7419 of 8433 Old 07-12-2019, 02:13 AM
sb01gt's Avatar
Quoted: 210 Post(s)
Liked: 75
I've been trying to figure out what the problem is when I'm playing 4k content with my fire tv stick 4k on my Panasonic OLED, I get really bad pixelation/banding even though I have more than sufficient connection speed, and it doesn't happen when using my internal TV apps, so I'm assuming the problem is with the firestick. I did this test though just to make sure there isn't something noticeably wrong with my panel. Wasn't sure which preset was best to use since it's not an LG/Sony, so here's the 4 main ones that would be used on this set: THX Cinema, THX Bright Room, Professional 1, Professional 2. (Professional 1 and 2 are what would be equivalent to isf day/night settings if you were to get the panel professionally calibrated)
Anything that I should be worried about from a panel point of view?
ID:	2589958   Click image for larger version
ID:	2589960   Click image for larger version
ID:	2589962   Click image for larger version
Panasonic EZ1000 65" OLED / Panasonic DMP UB400 / NAD T758v3 / Nvidia Shield TV
5.1.2 speaker setup - KEF R300 / R600c / Q50a / Focal Chorus SR800V / HSU ULS-15 mk2
sb01gt is offline
post #7420 of 8433 Old 07-12-2019, 09:49 AM
Quoted: 140 Post(s)
Liked: 98
Looks pretty average to me, at lest for prior years sets. Thanks for posting pictures at different settings. Goes to show how important settings are when trying to show the banding.
One thing I will say is it seems LG has improved on removing a lot of the hard lines and lighter, larger bands in the 2019 sets. I don't really have any of those on my C9. Mostly just darker streaks without hard edges that fade into the surrounding areas.
post #7421 of 8433 Old 07-12-2019, 10:07 AM
Ruppgu's Avatar
Quoted: 503 Post(s)
Liked: 564
Yep, which is really important on if it shows up in content.
My B7A has a good amount of bands if I look at the 5% slide but there are only 2 that show up often (1 VERY often and 1 somewhat often). I have seen the other bands maybe 2 or 3 times over the past year. However, I see my one prominent band a few times in nearly every movie I watch. Why is this compared to my other bands? Because the difference between adjacent areas is severe in these 2 instances (light vs dark) and they are very uniform (straight vertical lines). The 2019's do look much better in these cases.
I'll know for sure when my A9G comes soon (getting calibrated Monday at VE).
Ruppgu is offline
post #7422 of 8433 Old 07-14-2019, 03:48 PM
Quoted: 243 Post(s)
Around 150 hours
Toto84 is offline
post #7423 of 8433 Old 07-16-2019, 11:17 AM
Quoted: 14 Post(s)
Liked: 1
How does mine look? I feel it could be better...
Toto84 likes this.
bogardon is offline
post #7424 of 8433 Old 07-16-2019, 12:38 PM - Thread Starter
VidPro's Avatar
Quoted: 1521 Post(s)
Liked: 1287
Without the two lighter strips that would look good. Whats the hours on it? What model is it?
The television screen is the retina of the mind's eye.
Sony XBR-65A1E OLED/Denon X4300H/Carver M-500t/Oppo 203/Klipsch RVX‑42/PS4 Pro/Xbox One X/5.1.2
VidPro is offline
post #7425 of 8433 Old 07-16-2019, 12:54 PM
Quoted: 14 Post(s)
Liked: 1
It's a third party refurbished 65A9F and I've only used it for a couple hours at this point. According to the service menu it was at 0 hours when I got it, but I've been told that these numbers can be reset back to 0 as well... assuming these numbers can be trusted, I plan to use it for a couple more weeks before deciding if I should return this.
bogardon is offline
post #7426 of 8433 Old 07-16-2019, 01:00 PM
Liked: 808
Red tint on the sides
post #7427 of 8433 Old 07-16-2019, 07:35 PM
Liked: 0
LG C9, 130 hours.
Sometimes screen looks better, sometimes worse.
What do you think?
Wysłane z mojego SM-G965F przy użyciu Tapatalka
Grzegorz Cholewa is offline
post #7428 of 8433 Old 07-16-2019, 08:08 PM
Cam1977's Avatar
Quoted: 3198 Post(s)
Liked: 3954
^that's how it is with these...but I would still keep yours.
Cam1977 is online now
post #7429 of 8433 Old 07-16-2019, 08:16 PM
JD23's Avatar
Quoted: 761 Post(s)
Liked: 461
65" A9G with approximately 80 hours. I haven't noticed any low luminance banding or non-uniformity during content, but I do have a slight magenta tint on the right side that is visible on some earth tones, like beige or brown.
ID:	2591646   Click image for larger version
JD23 is online now
post #7430 of 8433 Old 07-17-2019, 02:05 AM
tesna's Avatar
55C8 here, 0 hours, just opened from the box. Looks ok? might improve after some time?
tesna is offline
post #7431 of 8433 Old 07-17-2019, 02:19 AM
Cam1977's Avatar
Liked: 3954
^congrats...that's a keeper, and should improve over the first 100-200 hrs.
post #7432 of 8433 Old 07-17-2019, 05:42 AM
zeromothra's Avatar
Quoted: 94 Post(s)
Liked: 51
That red tint would be a show stopper for me. Haven't been on this thread for quite a while and jeeze, nothings changed. Panel lottery and no overall progress on these issues IMO.
zeromothra is online now
post #7433 of 8433 Old 07-17-2019, 06:28 AM
Liked: 808
I don't know if you used ISF dark 35 oled light but that looks pretty good. These all have bands but not having "sharp" differences between the bands is good. If you have not tinting on 100% or minimal, I'd say you got a great C8.
post #7434 of 8433 Old 07-17-2019, 08:09 AM
Quoted: 14 Post(s)
Liked: 1
Do you know if tinting will go away with time? Here's another pic after using it for a few more hours:
bogardon is offline
post #7435 of 8433 Old 07-17-2019, 08:14 AM
Liked: 808
Tint doesn't really change, some people say they see a slight improvement but it'll never go away. Here's a video I stumbled upon a while ago that will really show the extent of red tint.
post #7436 of 8433 Old 07-17-2019, 10:49 AM
Quoted: 14 Post(s)
Liked: 1
https://youtu.be/kgfR4LJEgVI
That doesn't look so bad, hopefully I'll just forget about it as time goes on. That said, I found that the red tint (dis)appears depending on the viewing angle...
bogardon is offline
post #7437 of 8433 Old 07-17-2019, 10:58 AM
Liked: 808
Yeah it doesn’t depending on how left or right you go, or up and down angles looking at the panel. For 2019 models both LG and Sony this is the norm, some are better and some are worse but earth tones is where it really sticks out.
post #7438 of 8433 Old 07-17-2019, 11:28 AM
Adamd's Avatar
Quoted: 1258 Post(s)
Liked: 715
Tinting and oled is so common. I’ve had 4 diff models over the years 55 65 and 77 and a number of exchanges and they all showed some kind of tinting. Some worst then others. I think my 65 had the worst tinting and my 55 b7 the least.
Adamd is offline
post #7439 of 8433 Old 07-17-2019, 02:53 PM
zeromothra's Avatar
Quoted: 94 Post(s)
Liked: 51
It does not go away. Watching a classic like 'Lawrence Of Arabia' on that set would be painful IME. Ask me how I know .... :>/
post #7440 of 8433 Old 07-18-2019, 05:19 AM - Thread Starter
VidPro's Avatar
Liked: 1287
Yellow tint kind of kills the joy of watching a black & white movie too. It is what it is. I just wish I didn't spend so much for the joy.
VidPro is offline
Reply OLED Technology and Flat Panels General
burn-in , compensation , correction , oled , uniformity
