Best Warranty? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-14-2017, 08:18 AM - Thread Starter
damian069's Avatar
Best Warranty?
I plan on buying an OLED television in the next month and I'm slightly concerned with burn-ins. What company offers a warranty that actually covers burn-ins and offers the best value? Would it be the geek squad warranty, using a credit cards protection or something else?
Thank you,
damian069 is offline
post #2 of 18 Old 09-14-2017, 08:27 AM
nirvanayoda's Avatar
Quoted: 329 Post(s)
Liked: 128
Thank you,
Best Buy's Magnolia warranty is the best, as far as I could determine.
nirvanayoda is offline
post #3 of 18 Old 09-14-2017, 08:08 PM
Quoted: 789 Post(s)
Liked: 381
Is Best Buy's Magnolia warranty the same as Best Buy's Geek Squad TV protection plan? Both cover burn in?
LG OLED65B6P
no1special is offline
post #4 of 18 Old 09-14-2017, 08:59 PM
Quoted: 329 Post(s)
Liked: 128
I'm not sure if it's the same (and in fact I think that they are priced differently when the same item is available in both Best Buy and Magnolia), but the Magnolia warranty claims to cover burn in.
I'm also not sure if the Magnolia warranty is available at all stores or only the Design Center locations. I bought mine at a Design Center.
post #5 of 18 Old 09-16-2017, 09:45 PM
rondelmatryuda@shaw.ca's Avatar
Quoted: 77 Post(s)
Cool Oled77w7p
[QUOTE=nirvanayoda;54800980]I'm not sure if it's the same (and in fact I think that they are priced differently when the same item is available in both Best Buy and Magnolia), but the Magnolia warranty claims to cover burn in.
What was the additional cost for the warranty, and for what length of time?
[email protected] is offline
post #6 of 18 Old 09-17-2017, 09:50 AM
Quoted: 329 Post(s)
Liked: 128
I got a discount on the TV and I think it was $1250. But mine was a G7 and it goes by the price of the TV. I think the W7 would run $1400. It lasts 4 years.
post #7 of 18 Old 09-17-2017, 04:50 PM
WVZR1's Avatar
Quoted: 108 Post(s)
Liked: 52
I believe that if you buy 1 additional service from Best Buy (Ex: connect and put on stand $49) you can then "ask for" and very likely receive a 25% discount on the warranty packages. I don't know that there's stipulations other than just buying 1 additional service. You might need to ask but they do have actual forms used for the install/discount offerings.
GEEK SQUAD does cover "burn-in'' but if there's product on the market where it's a "known issue" I would imagine the language will be changed to something other than what their offering is presently. Every display LG that they have on the wall is likely already needing. I'd expect maybe that they might change the offerings of their "display models" to include only the manufacturers and no extended available or .................. extended with no "bun-in" coverage.
WVZR1 is offline
post #8 of 18 Old 09-17-2017, 04:57 PM
lsorensen's Avatar
Quoted: 1540 Post(s)
Liked: 896
Well it appears the warranty from best buy in the US covers burn in. The one in Canada appears to explicitly not cover it as far as I can tell.
Len Sorensen
Sony XBR55A1E, Marantz SR6012, Benq W7000, Oppo BDP-93, PSB Image T5/C5/B4/Subseries 200
lsorensen is offline
post #9 of 18 Old 09-17-2017, 08:09 PM
WVZR1's Avatar
Quoted: 108 Post(s)
Liked: 52
I imagine the "underwriter" isn't the same here in the USA and there in Canada - I would imagine "very different language and stipulations" - LOCATION always matters - ALWAYS!!!!
WVZR1 is offline
post #10 of 18 Old 09-17-2017, 10:13 PM
Quoted: 77 Post(s)
Cool Oled77w7p
So far I'm lead to believe warrantee are the same in CDN and USA
But with what's be mentioned, I intend to reexplore the issue.
post #11 of 18 Old 09-18-2017, 10:36 AM
lsorensen's Avatar
Liked: 896
Well in https://www.bestbuy.ca/projects/geek...-en.pdf?v=1.02 I see:
General Exclusions:
The following are not covered in respect of the Services (Part 2) and Benefits (Part 3) provided by this Plan:
1.maintenance, repair or replacement necessitated by any causes other than normal usage and operation of the Product in accordance with the manufacturer’s guidelines, including, but not limited to theft, exposure to weather, moisture and other environmental conditions, negligence, accidental or intentional physical damage, including disassembly and damage due to spilled liquids (except damage that qualifies for the Accidental Damage benefit), misuse, abuse, unauthorized repairs, improper installation, transportation damage (except damage incurred by authorized shipment of Product(s) to and from an authorized service centre), improper equipment modifications, vandalism, pixel burnout in accordance with manufacturer’s guidelines, computer viruses or malware, software generated problems or acts of nature or any other peril originating from outside of the Product
Of course the "normal usage and operation" bit at the beginning makes it hard to figure out what is and isn't actually covered under what circumstances. To me that seems to read as pixel burnout is not considered normal usage, but I could be wrong.
Len Sorensen
post #12 of 18 Old 09-18-2017, 02:40 PM - Thread Starter
damian069's Avatar
So the answer is maybe Best Buy. It will be interesting to see if any of the language in these warranty change as time goes on.
post #13 of 18 Old 09-18-2017, 09:48 PM
Quoted: 77 Post(s)
Cool Oled77w7p
I'm considering Visions, but I'll need to review their warranty.
post #14 of 18 Old 09-19-2017, 08:03 AM
lsorensen's Avatar
Liked: 896
They do not cover burn in. On the other hand if you don't have a claim on the warranty, you get a store credit for the cost of the warranty at the end, which is why I went with it for my A1E.
Len Sorensen
post #15 of 18 Old 09-19-2017, 08:04 AM
Quoted: 329 Post(s)
Liked: 128
Are we sure that "pixel burnout" is the same thing as "burn in"? It sounds like a different animal.
post #16 of 18 Old 09-19-2017, 08:08 AM
lsorensen's Avatar
Liked: 896
I am. Image burn in is caused by excess wear of some pixels, hence pixel burnout.
Len Sorensen
post #17 of 18 Old 09-19-2017, 10:19 AM
Quoted: 323 Post(s)
Liked: 185
Thank you,
As background, I had a 2016 LG E6 OLED TV develop permanent burn in after less than 500 hours viewing time under low brightness conditions. LG refused to even discuss covering this clear defect under my original LG warranty.
Thus, in my opinion, the Magnolia warranty is the only way to go as, to the best of my knowledge, it is the only warranty that covers OLED burn in. I have found Magnolia great to deal with when problems arise (Magnolia covered the above TV with burn in even though I did not purchase the Magnolia warranty). Priced at $350 to cover a $2999.99 OLED TV under a Magnolia warranty for four years to hedge against OLED burn in developing, I think it is a bargain.
Additionally, in replacing the above that E6 had developed burn in, I opted to purchase the Sony AiE (rather than another LG OLED) because LG appeared to have such miserable customer service based upon my experiences with them.
Sony XBR55A1E
LG OLED55E6P
John1948 is offline
post #18 of 18 Old 09-19-2017, 12:07 PM
Quoted: 4445 Post(s)
Liked: 3889
Too bad the Magnolia warranty isn't sold separately. For the 65" G6 last year, it would have been an additional $1k unfortunately (when the TV was at SRP). I'm not concerned about burn-in, though, since I won't be watching much, if any, triggering static content. LG customer experiences are mixed. They gave me a voucher for an ugly nonuniform EF9500 (had I known said voucher wouldn't have expired until a year from issuance, I would not have rushed to buy a 2016 model so soon).
video_analysis is offline
Reply OLED Technology and Flat Panels General
