2017 LG OLED Burn In with pictures - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 125Likes
post #151 of 264 Old 03-05-2018, 02:34 PM
Quoted: 729 Post(s)
Liked: 369
Originally Posted by pazman2000 View Post
Hi guys
LG have add a new feature to the 2018 oled line up to help prevent Screen burn .
This should be added to our 2017 sets too as we are all at risk of screen burn .
The new feature dims the luminance of static logos which are the biggest cause of screen burn .
If this is something you would like to see on your set sign the petition.
https://www.change.org/p/lg-electron...share_petition
LG has had the static logo dimming feature since at least 2015 from posts of owners on AVS. I've verified it working on our B6, but it didn't help to prevent burn-in.
LG OLED65B6P
no1special is offline
post #152 of 264 Old 03-11-2018, 09:51 PM
Quoted: 26 Post(s)
Liked: 2
Is LG still not covering B6 burn-ins?
bad_oled is online now
post #153 of 264 Old 03-12-2018, 01:34 AM
Quoted: 1114 Post(s)
Liked: 636
My C6 does not dim logos only that I have seen. Is there a setting somewhere?
Can you time it...how long it takes to dim the CNN or MSNBC logos for example?
Kenbar is online now
post #154 of 264 Old 03-12-2018, 01:39 AM
Quoted: 909 Post(s)
Liked: 945
There is no setting for logo dimming on 2016 and 2017 TVs and that's the problem, it's so subtle that I'd call it useless. But it also means that it's already implemented and all LG needs to do is let us adjust how aggressively it dims.
jk82 is offline
post #155 of 264 Old 03-12-2018, 03:34 PM
Quoted: 26 Post(s)
Liked: 2
Originally Posted by akmandal View Post
No, my Galaxy S8 has no burn in. Don't know where you are getting these rumours from.
Depends on use. I had quite a few Samsung amoled devices with burn-ins.
But the difference between Samsung and LG burn-ins - Samsung fixes them under warranty, no questions asked. You send it in for repair on Monday, you get it back Wednesday with new screen installed.
I never owned an LG product, except for lcd cell phone. I want to "break" the screen so I can have it replaced under warranty. Any suggestions? Can magnets or sun or something do damage which would be covered by warranty?
P.S. Where in the manual does it talk about burn-in? All I see is nonsense like this (.pdf downloaded for B6P) -
• If you have long nails, do not open the battery cover by using your finger. Or else, your nail could break.
post #156 of 264 Old 03-12-2018, 03:44 PM
Almondo99's Avatar
Quoted: 32 Post(s)
B7 Owner. Been using as a PC monitor for a couple months as a secondary monitor - calibrated in calman at 100nits - OLED light at 22.
Screensaver comes on after 5 min, so while the TV is on for the majority of the day it's usually not displaying anything, I move any static screens off of it. Having it on but black shouldn't be a problem should it?
I play games too but not often on the OLED, is it a huge risk at that brightness? I'd like to use it more for Switch/PC games but the idea of burn in has kept me away from doing it.
I've read on here as much as I can about it but it gets a bit tricky to discern what to believe in comments.
Almondo99 is offline
post #157 of 264 Old 03-12-2018, 04:06 PM
Quoted: 4298 Post(s)
Liked: 3723
OLED light at 22 means you can use it practically any way you want without fear of BI.
video_analysis is offline
post #158 of 264 Old 03-12-2018, 04:38 PM
Quoted: 212 Post(s)
Liked: 104
Thats not necessarily true, though. The Rtings Real-Life Burn in test shows worse burn-in on thier C7 displaying at 200 Nits Max than the C7 set at max brightness. Both displaying CNN.
It's been taken as fact that lowering the birghtness reduces burn-in risk, but there may be some panel lottery making certian sets more vulnerable.
deadacclaim is offline
post #159 of 264 Old 03-12-2018, 06:44 PM
Quoted: 322 Post(s)
Liked: 185
OLED light at 22 means you can't hardly see the damn TV!
ReSultZ likes this.
Sony XBR55A1E
LG OLED55E6P
John1948 is offline
post #160 of 264 Old 03-12-2018, 07:23 PM
Liked: 3723
Apparently, it's adequate for the owner above. 35 is about as low as I go, also not conducive to causing BI (unless the set is already compromised, apparently).
post #161 of 264 Old 03-12-2018, 07:51 PM
Almondo99's Avatar
Quoted: 32 Post(s)
Haha, it looks great to me! I find HDR to be blinding at times, I do video work so 100nits calibration on all my monitors is important to me so I guess I'm used to it.
It's discouraging that it might be down to a panel lottery :/ I've been debating getting a cheap TCL 4K TV on Amazon for this reason - as even OLED light seems like it doesn't affect the potential for BI too much?
post #162 of 264 Old 03-12-2018, 10:27 PM
Liked: 3723
IIRC, everyone who's reported BI so far has used OLED light settings of 50 or above.
Kenbar and no1special like this.
post #163 of 264 Old 03-13-2018, 01:35 AM
Quoted: 729 Post(s)
Liked: 369
No setting for it on the B6. It works automatically. It's hard to say exactly when it starts dimming, as it does it very gradually, but usually after about 3-5 minutes, it should be sufficiently dimmed that by pressing one of the volume buttons on the remote should immediately return it to full brightness.
If you're using your LG OLED as a monitor, you should turn it off with the remote at least once a day so that the automatic compensation cycle can run. This should help clear any temporary IR. It may also have some other undocumented benefits. I don't think these TVs are meant to be on all the time.
It's unlikely that what we're seeing on the Rtings CNN 200 nits OLED light set is actually burn-in. OLED burn-in typically appears darker, not brighter than the surrounding area. This is more likely threshold shift related temporary IR that the auto compensation cycles have failed to clear for some reason.
LG OLED65B6P
post #164 of 264 Old 03-13-2018, 01:37 AM
Quoted: 729 Post(s)
Liked: 369
This is true for most folks using their OLED as a TV and watching from a greater distance. For someone using as a monitor, and sitting relatively close, I can see lower settings like this working.
LG OLED65B6P
post #165 of 264 Old 03-13-2018, 02:12 AM
Quoted: 909 Post(s)
Liked: 945
Oled-light 20 is about as bright as my 2012 panasonic plasma, for a darkened room that can be fine.
jk82 is offline
post #166 of 264 Old 03-13-2018, 04:41 AM
Wizziwig's Avatar
Quoted: 2237 Post(s)
Liked: 1520
I don't think it matters whether this is traditional burn-in or some fault with compensation. What matters is the end result - a panel with visible and permanent damage. I would only make the distinction if this really is "temporary IR" and can be removed somehow. The calibration rectangle has thus far not disappeared so you might as well call it burn-in unless they keep displaying it repeatedly and not allowing it to fade. I've asked rtings to clarify a few questions about that rectangle. It would be interesting if they gave the CNN set a break for a few days with some other content and allowed it to run multiple compensations to verify if anything fades away. Maybe one cycle is not enough to clear it.
Wizziwig is offline
post #167 of 264 Old 03-14-2018, 04:06 PM
Roborope's Avatar
Quoted: 57 Post(s)
Liked: 38
Not a lot but a little is enough for me. LG should be replacing my screen under warranty in few days.
I have 2600 hours on the screen.
Roborope is offline
post #168 of 264 Old 03-14-2018, 05:09 PM
Almondo99's Avatar
Quoted: 32 Post(s)
Attachment 2375366
Attachment 2375368
Attachment 2375370
Attachment 2375372
Attachment 2375374
Yikes! Glad you're getting a replacement though - how'd you manage that? And what OLED light level was the TV at?
post #169 of 264 Old 03-15-2018, 03:59 AM
Roborope's Avatar
Quoted: 57 Post(s)
Liked: 38
I think it was at 80 and I'm not entirely sure how it happened. I watch a lot of network TV more than I stream over the course of a day every day.
This is my first OLED tv and I just didn't think about BI. Now that I know and even though the screen is being replaced I think my viewing habits are directing me to move this TV to another less used room, use it for streaming and will pick up a LCD TV. LG has a new one that is coming out SK9500P that I'm probably going to pick up or one of those inexpensive off name brand TVs under a grand.
Roborope is offline
post #170 of 264 Old 03-15-2018, 12:48 PM
Quoted: 723 Post(s)
Liked: 238
I'm not seeing it here, but I'm sure I'm missing something. Where's the BI?
Setup:
Spoiler!
dkfan9 is offline
post #171 of 264 Old 03-15-2018, 01:18 PM
QN52's Avatar
Quoted: 69 Post(s)
Liked: 54
Bottom right - I could only see it on the green picture
dkfan9 likes this.
QN52 is offline
post #172 of 264 Old 03-15-2018, 01:30 PM
Quoted: 212 Post(s)
Liked: 104
That dot in the bottom right. It's pretty clearly visible in every picture...
There is also some letters in the bottom right, although much more faint. MSNBC?
ReSultZ and dkfan9 like this.
post #173 of 264 Old 03-15-2018, 01:46 PM
Roborope's Avatar
Quoted: 57 Post(s)
Liked: 38
Could be I watch MSNBC in the mornings before work for a couple of hours and another couple when I get home. All I really notice the most when watching programs is the green blotch.
Roborope is offline
post #174 of 264 Old 03-15-2018, 02:00 PM
Quoted: 212 Post(s)
Liked: 104
If you had to guess, what would be your cumulative watch time? Is this the E7?
post #175 of 264 Old 03-15-2018, 03:54 PM
Roborope's Avatar
Quoted: 57 Post(s)
Liked: 38
For MSNBC? I don't know 4 hours a day 7 days a week since August. My total watch time is around 2600. My best guess is the BI happened around 2000 hours. Yes it's the E7.
no1special likes this.
Roborope is offline
post #176 of 264 Old 03-15-2018, 07:32 PM
Quoted: 24 Post(s)
Liked: 5
I keep getting browser address bar retention even with more careful settings. Pixel refresh seems to fix it. Keep in mind this is with no screen saver at all.
I moved to Quantum Firefox browser it let's you hide the address in fullscreen mode. I should be good now I hope.
I almost bought a 70" M Vizio at a heavy discount but the responce time is 6ms and I kept looking at what tv's are best at certain things and they all recommend my B7A Looooool
derail30 is offline
post #177 of 264 Old 03-15-2018, 08:09 PM
Quoted: 723 Post(s)
Liked: 238
Ah I see it now. Yes and the MSNBC letters, but that dot is strange. I noticed it in the orange picture first time around but thought it was an artifact or something on my screen...
Setup:
Spoiler!
dkfan9 is offline
post #178 of 264 Old 03-15-2018, 09:10 PM
Quoted: 24 Post(s)
Liked: 5
The lowest settings I use are in the 40's for web browsing. I can't really see anything comfortably below 40 and I'm in a dark room. I try not to use it for the internet too much because of the possibility of burn in.
I have a 34" LG ultrawide monitor on the side I use for internet while I watch my OLED at full brightness as a main screen in multi monitor mode.
I mainly use my OLED at HDR 100 backlight 44 brightness for tv/movie (no news channels) and 90 backlight 49 brightness for PC gaming (40min to 1 hour sessions). According to Rtings OLED testing it can go quite a few hundred hours before the risk of burn in.
It's a shame for us heavy internet users. I can say for sure this tv isn't cut out for web browsing. I would recommend using another display for long web browsing sessions. I'm at 200hrs now probably 80% of that was used for web browsing and haven't noticed burn in except for address bar retention.
derail30 is offline
post #179 of 264 Old 03-25-2018, 11:28 AM
venus933's Avatar
Quoted: 2365 Post(s)
Liked: 1942
I've had my C7 since early May and have accumulated almost 2000 hours of usage.
I lowered my OLED Light to 60 last Summer when I heard that this might mitigate OLED burn in potential.
Apparently that wasn't soon enough or it didn't matter and I spend too much time in the YouTube menus as I have burn from using the app. The burn in is composed of the two small rectangular shortcut boxes in the lower right hand corner of the app. I don't have a high quality camera on my phone but you can make out one of the rectangles. And no I don't spend all day on YouTube, far from it.
This TV has to go and I'll need to find a LCD that I can live with. I plan on keeping the EG9100 as it's not used nearly as much as my main TV.
Anyone who has participated in some of the threads that I participate in will know I'm a big advocate for OLED so I don't enter this post lightly.
LG 65B8 - Primary
LG 55EG9100 - Bedroom
Sonos Playbase
MS Xbox One S (using strictly as a disk player)
venus933 is offline
post #180 of 264 Old 03-25-2018, 06:27 PM
Quoted: 723 Post(s)
Liked: 238
Sorry to hear that. I don't see the picture, though.
dkfan9 is offline
Reply OLED Technology and Flat Panels General
2017 , lg oled , oled65b7p , oled65c7p , oled65e7p
