Sony A1E Dimming Defect - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 97Likes
post #31 of 468 Old 04-10-2018, 05:19 PM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
Originally Posted by dcbaros View Post
Do any of you have eco mode on by any chance?
Nope...again, this issue is not a feature of the set. It was not present when the set was released and did not occur until the DV firmware update (or maybe the FW update after...I am not sure which one introduced the issue as they were relatively close together).
caitsith01 likes this.
Sony XBR-65A1E // Denon X6300H // Klipsch RF-7ii (x2), RC-64ii, RB-51ii (x4) // SVS PB12-Plus // Xbox One X // WDTV Live // Sony UBP-X700 // Chromecast Ultra // Harmony 670
Nickff is offline
post #32 of 468 Old 04-10-2018, 05:20 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
I.e., it is just like the overly aggressive ABSL in 2015 LG OLEDs.
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / Uverse / Roku Ultra
AVRX6500H / RP-8000F / RP-504C / RP-502S / RP-500SA / FV15HP (5.1.2)
gadgtfreek is offline
post #33 of 468 Old 04-10-2018, 05:21 PM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
I chatted on-line with Sony Support and they were going to "remotely access my A1E". I was out of time and had to leave for an appointment. Has anyone with this issue had their set remotely accessed by Sony Support? Has anyone tried a factory reset?
Nickff is offline
post #34 of 468 Old 04-10-2018, 05:23 PM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
I have never owned a 2015 LG OLED, but if they suffered from an unintentional "bug" introduced by a firmware update approximately one year after release...then yes it is just like that.
Nickff is offline
post #35 of 468 Old 04-10-2018, 06:12 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
I think it is naive to assume they turned on something LG has been using since 2015 by accident.
post #36 of 468 Old 04-10-2018, 06:52 PM
statealum's Avatar
Quoted: 248 Post(s)
Liked: 218
-Yes I have had my set remotely accessed by Sony Support. All they are going to do is check your settings to make sure you don't have eco mode engaged or the light sensor engaged. When that doesn't work the person I had asked me to do a panel refresh to see if that fixes the issue which it did not.
-Support is going to ask you to do a factory reset and something they call a "forced reset". The forced reset is when you turn the tv off and hold the power button and - volume button that's on the back of the tv while unplugging the cord from the outlet. Once you plug the cord back in after a short period you release/stop holding the buttons on the back of the tv. That does not fix the issue either.
-You are going to get forwarded to their next tier of support eventually. They are going to ask you to do the same reset, internal picture test demo, etc over again.
-Eventually (after days) they are going to ask you to send in a picture of the front of your tv with all 4 corners visible, the back of your tv showing model number and serial number. They are going to ask you to upload a video of the issue to their provided link.
-The link is only has space for 10mb files so even a 4 minute 1080p video will have to be severely compressed to even be able to be uploaded.
-After they review the severely compressed video (after some days) they will tell you the television is operating within specifications there is nothing more they can do and the case is closed.
Heavie and DeathlessOne like this.
Set up 1|Sony XBR65A1E|Pioneer SC-97|Panasonic DMP-UB900|PS4 Pro|Xbox One X|Apple TV|5.2.4 Dolby Atmos|Nintendo Switch|
Set up 2|LG OLED65C8|Pioneer SC-LX502
|Sony UBPX-X700|Xbox One X|PS4|Nintendo Wii U|Apple TV 4K|3.2.2 Dolby Atmos|
Other|LG 55EF9500|Sony XBR-55HX929|Yamaha RX-A1060BL|
statealum is offline
post #37 of 468 Old 04-10-2018, 07:12 PM
Shayd's Avatar
The 2017 Sony A1E Uses LG's 2016's OLED Panel and is bit more prone to burn in the dimming you're experiencing is called ABL like someone set and it has been boosted to limit brightness whether possible to reduce burn of the panel which in this TV seems to be extreme.
Shayd is offline
post #38 of 468 Old 04-10-2018, 07:15 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
Um, you are wrong on many levels. This not ABL for one...
post #39 of 468 Old 04-10-2018, 07:23 PM
Quoted: 339 Post(s)
Liked: 136
hopefully they fix this ,I just bought the af8 and hopefully the dolby vision update won't cause this on the new sets ,if they ever release it
greatone99
Dave Scurrah is offline
post #40 of 468 Old 04-11-2018, 03:37 AM
chunon's Avatar
Quoted: 3889 Post(s)
Liked: 3889
I don’t think you understand abl , and the panel info is just flat out wrong .
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is offline
post #41 of 468 Old 04-11-2018, 07:20 AM
Liked: 0
I am also experiencing the dimming issue. I notice it mostly when I am playing on my xbox one. It seems to dim after about one minute and if I cause a large change in the picture it brightens back up again. Another question that I have, and I know this is not the right thread. Is that when I play games, namely far cry 5 and halo 5. I notice that when I begin to move my character the screen gets blurry and fine textures seem to almost shimmer if that makes any sense. When I say move my character I mean slowly move, like so slow there is no motion blur. It does this on every game I play. I don't notice it as bad on cod ww2 but I know that is running in native 4k. Does anyone know what this is? Is it something wrong with the tv or is it normal? I have also notice on skyrim the sky flashes with motion but i believe this is an issue with the game and not the tv. I have only had my a1e since friday so I am fairly new to this. Thanks. I own the 55" A1E by the way.
kamohoalii9296 is offline
post #42 of 468 Old 04-11-2018, 11:12 AM
rocky1's Avatar
Quoted: 542 Post(s)
Liked: 179
As of yet I haven't had any dimming issues with my A1E and I did do the DV update via the tv not usb I believe it was in march. When I first got my tv cpl weeks prior to DV update I was prompted to do updates as it was new and I don't think it had any updates since it took awhile..So the DV update came later.Wondering what HDMI input everyone is using either ARC or other like input 2.I use input 2 as I don't use arc and no dimming issues so far.Just curious
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
post #43 of 468 Old 04-14-2018, 07:33 AM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
I experience the dimming when gaming in 4k HDR. My Xbox One X is routed through a Denon 6300H to HDMI 3 on the A1E. When I get a chance, I will remove the AVR from the chain and see if that makes any difference (I suspect it will not as this did not occur until one of the last two A1E firmware updates). I have attached pictures of my settings and software build.
ID:	2390346   Click image for larger version
Name:	Brightness Settings.jpg
ID:	2390348   Click image for larger version
Name:	Color Settings.jpg
ID:	2390350   Click image for larger version
Name:	Clarity Settings.jpg
ID:	2390352   Click image for larger version
Name:	Motion Settings.jpg
Name:	Video Options.jpg
ID:	2390356   Click image for larger version
Name:	A1E Software Version.jpg
Nickff is offline
post #44 of 468 Old 04-14-2018, 07:48 AM
rocky1's Avatar
Quoted: 542 Post(s)
Liked: 179
Good to know for those who are getting the dimming.Are you only getting it while gaming and in game mode? I had posted before that thought it would be an idea for those who are getting the dimming to post their modes and settings to find out when and where they get the dimming ,maybe arrive at a consensus...
Just remembered you had done both updates? The original in January I believe for the DV and then again in March(the latest)? Was this occurring after the first or just after the second on in march?cant remember
rocky1 is offline
post #45 of 468 Old 04-14-2018, 07:49 AM
statealum's Avatar
Quoted: 248 Post(s)
Liked: 218
When reporting the problem to Sony customer support one of the things they asked me to do was unplug my AVR and everything else from the television and try using the tv's internal apps to see if the dimming still happened. In my case removing the AVR did not help; the television still dimmed when using internal apps.
post #46 of 468 Old 04-14-2018, 08:56 AM
bootymonger's Avatar
Quoted: 361 Post(s)
Liked: 275
Originally Posted by rnk21 View Post
We need John Archer or Vincent Teoh to report on this..
In Vincent's review of a Loewe OLED (not available in the US), he mentions that there is luminescence fluctuation in the iTunes version of Transformers: The Last Knight caused by the Dolby Vision library in the box, not the TV. I'm not sure if that's at all related to what people are seeing in this thread.
(go to time 8:26).
SuperFist likes this.
bootymonger is offline
post #47 of 468 Old 04-14-2018, 01:55 PM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
My settings are just above your post. I have only seen it while gaming in 4k HDR. If I see it under different circumstances...I will let the thread know.
Nickff is offline
post #48 of 468 Old 04-15-2018, 01:22 AM
scott967's Avatar
Quoted: 42 Post(s)
Just a guess that setting peak luminance to high contributes to the dimming issue. Curious if anyone with the issue has tried changing that and see if it makes a difference.
scott s.
Sony XBR-65A1E
scott967 is offline
post #49 of 468 Old 04-16-2018, 07:24 AM
Liked: 8
Hey guys so I have been on the phone with support today after they followed up on my previous ticket. They have asked for another video of the dimming so they can try escalate the issue to engineers in Japan. This is the video I provided:
https://drive.google.com/file/d/1wm-...ew?usp=sharing
As you can see the dimming happens pretty quickly and drastically exactly the 1 minute mark. They said that more people will need to contact support so they can help fast track a firmware update otherwise it could take 2-3 months to fix. I'm in Australia btw so my support was on the Asia Pacific division and so far they have been pretty nice and helpful.
Edited: link should be working, please let me know if it doesn't work!
sonoi100, DVnt, jb442386 and 1 others like this.
Sony KD65-A1
Vivek Vastrad is offline
post #50 of 468 Old 04-16-2018, 08:27 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
We watched Incredible Hulk UHD Blu last night. I paused at the beginning, like I usually do to check the 203 and A1E settings and pic mode, and it dimmed down by the time I had done all that. Once I pressed play it went back to torch mode.
SuperFist and chunon like this.
post #51 of 468 Old 04-17-2018, 10:39 AM
Nickff's Avatar
Quoted: 435 Post(s)
Liked: 242
As I mentioned in the owner's thread...I think they purposefully implemented the dimming in one of the recent FW updates...but it has a few kinks. I think the set dims when it is not supposed to...like while actively gaming (not a static screen).
Nickff is offline
post #52 of 468 Old 04-17-2018, 10:44 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
I had posted this earlier, LG's implementation in 2015 used APL, which it was too aggressive and kicked in on long scenes that maintained a tight APL.
chunon likes this.
post #53 of 468 Old 04-17-2018, 03:52 PM
statealum's Avatar
Quoted: 248 Post(s)
Liked: 218
This is a copy/paste of my link in the owners forum
https://drive.google.com/file/d/1b95...9d0ZgT5BW/view
I believe the link works now. The dimming is more noticeable in person. My camera brightens up the image but the video gives you an idea of some of the contrast/color loss that I see. To get an idea compare the image at 30sec to the image at 1:30 sec. The rest of the video is me attempting to show that neither eco mode or the light sensor were engaged. I also tried to show how some of the brightness/contrast returns after hitting the home button. This was from a paused video of a basketball game I had on dvr.
post #54 of 468 Old 04-17-2018, 06:34 PM
Liked: 8
So a rather disappointing follow up from the service rep at Sony:
Hi Vivek,
Thank you for providing me the sample videos of the issue. I just got a word from our Sony Engineers about the Dimming issue on your Sony OLED.
Based from our Engineers all OLED models does have a function that auto-dims the set when a static is detected to prevent burn-in also known as image retention. As the technology of OLED is more prone to burn-in or image retention the split second of auto-dimming feature is required. It is possible that the latest firmware update did increase the amount of dimming to prevent the image retention for OLED models. This condition is normal and not a malfunction on the TV.
Kind Regards,
Kris
I'm going to hazard a guess that they didn't really expect that increasing of the auto-dimming feature would adversely affect gaming or watching sports as much as it does now. Don't fret though just keep pushing them on the issue guys, for all we know they could already be working to resolve it. If you haven't already submitted a support ticket, I would highly suggest doing so as the issue needs to reach more engineers in Japan so they can see that it's a major issue.
Sony KD65-A1
post #55 of 468 Old 04-17-2018, 09:08 PM
statealum's Avatar
Quoted: 248 Post(s)
Liked: 218
Hi Vivek,
Kind Regards,
Kris
I like your optimism unfortunately I do not believe they are going to fix this. I hope they at least implement an improved version where it takes longer than a minute for the screen to start dimming.
post #56 of 468 Old 04-18-2018, 05:59 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6104
I like the concept, they just need to do like LG did, delay it further.
post #57 of 468 Old 04-18-2018, 08:46 AM
rnk21's Avatar
Quoted: 145 Post(s)
Liked: 139
I don't think it should ever be implemented during a moving screen. A static screen, i'm fine with, it's called a screen saver. Especially coming from a gaming company, who started the push for HDR gaming, it's unbelievable that Sony couldn't see that having the picture dim after a 1 minute of no average picture level change, would severely hinder the picture quality of said game. It is not uncommon at all during open world games for the picture to retain the same APL for significantly longer than 1 minute.
Bottom line is, this wasn't there when we made the decision to buy the set, and had it been, I probably would have gone another direction. I researched sets substantially before buying, to make sure that the one I bought would fit my needs. As someone who loves watching sports, and the occasional gaming session every now and again, this added "feature" that Sony saw fit to implement without my consent has hindered my enjoyment of what was an amazing TV, and they NEED to issue a fix.
Sony XBR65A1E : Sony X800
rnk21 is offline
post #58 of 468 Old 04-18-2018, 08:52 AM
rnk21's Avatar
Quoted: 145 Post(s)
Liked: 139
Originally Posted by ghemassageservice View Post
That's EXACTLY the way I feel. The worst part is that Sony won't acknowledge that there is an issue. I urge anyone who has gotten Sony to warranty replace their set to post here and let us know.
It simply can't be denied anymore. There are now videos showing what the problem is, and that wasn't a problem before. This is something Sony clearly added to cover their asses from burn in claims. We can pinpoint the update that added it, and now it is on them to remove it before they have a major problem on their hands. Don't shout to me about the nits of your set and it's great HDR ability when you then add a "feature" that allows me to only enjoy it for a minute at a time.
All that being said, this isn't a warranty issue. There is nothing wrong with our tv's. Sony did this, and now they need to fix it.
rnk21 is offline
post #59 of 468 Old 04-18-2018, 05:44 PM
Liked: 8
From Sony support again...
Hi Vivek,
Unfortunately, We cannot downgrade the software of the TV. As such I have since forwarded your comments to our Sony Engineers. All customer comments and queries greatly assist us in the development of our offerings to you, the customer. Therefore, I am confident that they will find your comments most useful.
So frustrating, the TV was actually perfect before, and now when gaming it has become useless if playing a game that has any sort of overlay or menu on the screen all the time.
Sony KD65-A1
post #60 of 468 Old 04-18-2018, 05:57 PM
Quoted: 1130 Post(s)
Liked: 663
Sounds to me like they took a generally good idea, and over did it.
Voted most desirable mate by the ladies every year! Klan leader! Mob boss! Love advice expert! Credit cards accepted.
Kenbar is offline
Reply OLED Technology and Flat Panels General
