OLED Suggestion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-15-2019, 08:25 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
OLED Suggestion
So I have the tv I run an hdmi from my tv to my pc but just don't feel it is the top notch quality I should be getting. Any suggestions on what I am doing wrong? I am about 12ft cabel because I can't move the pc closer. So clueless to this new techno stuff :P
seanml is offline
post #2 of 9 Old 09-15-2019, 09:31 AM
bobknavs's Avatar
Quoted: 2331 Post(s)
Liked: 1662
What's your PC's graphics card?
What resolution are you using from the PC?
You may not be getting 2160p (3840 X 2160) if your graphics card doesn't support HDCP 2.2/HDMI 2.0.
bobknavs is online now
post #3 of 9 Old 09-16-2019, 02:11 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
NVIDIA GeForce GTX 960 , res I will double check tonight
seanml is offline
post #4 of 9 Old 09-16-2019, 06:21 AM
Liked: 0
The problem may be the resolution of the file that you transfer from the PC to the TV. Check it out too.
Peter_mot is offline
post #5 of 9 Old 09-16-2019, 08:32 AM
Ice Cold's Avatar
Quoted: 336 Post(s)
Liked: 103
Probably a cheap china HDMI cables happened to me before.
Ice Cold is offline
post #6 of 9 Old 09-16-2019, 12:28 PM
bobknavs's Avatar
Liked: 1662
The GTX 960 is spec'd with HDMI 2.0 and DisplayPort 1.2, so 2160p at 60 Hz should be available.
Not sure what your issue might be.
post #7 of 9 Old 09-16-2019, 02:29 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
what about media players, I use media classic. Is there anything that is better?
Maybe I just have to learn to configure all the settings proper somehow. Tv just doesnt look as amazing as the display images (in stores) lool
seanml is offline
post #8 of 9 Old 09-21-2019, 03:47 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 1
what happens if I use the other res options just above the recommended one?4096
seanml is offline
post #9 of 9 Old 09-23-2019, 07:22 AM
lsorensen's Avatar
Quoted: 1424 Post(s)
Liked: 819
It will have to scale it to fit the real pixels. Scaling from 4096 to 3840 is NOT going to be a pretty result. It will be quite blurry I suspect. Sure for photos and video it likely won't be that noticeable, but text would be unimpressed.
Len Sorensen
Sony XBR55A1E, Marantz SR6012, Benq W7000, Oppo BDP-93, PSB Image T5/C5/B4/Subseries 200
lsorensen is online now
Reply OLED Technology and Flat Panels General
