Official Elusive 1099 Speaker Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #31 of 307 Old 11-15-2015, 02:57 PM
Baron5's Avatar
Quoted: 117 Post(s)
Liked: 53
Any ideas when the next preorder for the 1099 will be? I just order crossovers for them and need to kind of plan when to put my JTR's for sale. Can't believe I'm even saying that.
Baron5 is offline
post #32 of 307 Old 11-15-2015, 03:24 PM - Thread Starter
Erich H's Avatar
Quoted: 1845 Post(s)
Liked: 2631
I need to talk with Celestion and find out when the midranges will be delivered.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #33 of 307 Old 11-15-2015, 04:07 PM
Baron5's Avatar
Quoted: 117 Post(s)
Liked: 53
Thanks Erich. Am I right in reading at the DIY site that I have to order the speaker packages with the cross over components?
Baron5 is offline
post #34 of 307 Old 11-19-2015, 04:39 PM
Baron5's Avatar
Quoted: 117 Post(s)
Liked: 53
I'm thinking of building the cabinets myself while waiting for the baffle and speakers kits to get back I stock. I see the dimensions on the DIY website but can't tell what is width vs depth.
12.5" x 36.25" x 14.5"
W x H x D?
Also is there any suggestions about the thickness of the wood used?
Thanks for tolerating my questions. I looked through the FAQ and a few builds and couldn't find the info.
Baron5 is offline
post #35 of 307 Old 11-19-2015, 06:04 PM
brian6751's Avatar
Quoted: 1672 Post(s)
Liked: 1648
W x H x D?
W x H x D correct. use 3/4"
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #36 of 307 Old 11-19-2015, 06:23 PM
Baron5's Avatar
Quoted: 117 Post(s)
Liked: 53
Thanks Brian
brian6751 likes this.
Baron5 is offline
post #37 of 307 Old 11-19-2015, 06:30 PM
brian6751's Avatar
Liked: 1648
np. dont put the bracing in until you have the baffle. It has to line up just right with the openings.
FOR SALE:
post #38 of 307 Old 11-19-2015, 07:05 PM
Baron5's Avatar
Quoted: 117 Post(s)
Liked: 53
I was just wondering about the sealed mid enclosure and if those pieces come with the flat pack or not. Also was wondering if the depth dimension was including the baffle. If so I would need to know how thick the baffle is to subtract from the box. Nothing is easy.
Baron5 is offline
post #39 of 307 Old 11-19-2015, 08:05 PM
brian6751's Avatar
Liked: 1648
the sealed mid enclosure is created by using two closed bracing sections. They are included with the seperate available flat pack but not the normal speaker kit that you get the baffle with. The depth includes the 3/4" baffle so if you are building a box you would want to subtract 3/4" from it so it would be 13.75" deep
FOR SALE:
post #40 of 307 Old 11-22-2015, 08:41 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
So I am almost finished. I have some insulation laying around and want to use that to stuff. How much should I use in each compartment? Stuff it full?
Claybe is offline
post #41 of 307 Old 11-23-2015, 08:32 AM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2224
Stuff the mid chamber fairly full. The woofer chambers should be more "lined". Stable or glue about 2" thick throughout and avoid blocking the ports.
tuxedocivic is offline
post #42 of 307 Old 11-23-2015, 08:46 AM
brian6751's Avatar
Liked: 1648
if using egg crate for the woofer area, would you use 1.5" or 2.5" ? I have both.
FOR SALE:
post #43 of 307 Old 11-23-2015, 08:51 AM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
I'd like to order a complete L/C/R kit with flat pack and completed crossover. Is now a good time, or is there a big/long backlog? Anyone know?
jjackkrash is offline
post #44 of 307 Old 11-23-2015, 09:05 AM
Liked: 2224
2.5
post #45 of 307 Old 11-23-2015, 06:10 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
Thanks. I couldn't wait, so I put a ton of insulation in the woofer compartments and not a lot in the mid chamber. Should I take some out of the woofer areas and add some to the mid area??? What will having a lot of insulation in the woofer compartments do to the sound?
Claybe is offline
post #46 of 307 Old 11-23-2015, 07:53 PM
Liked: 2224
Filling the woofers a lot will just kill some of the bass output. Especially if the ports are impeded.
Filling the mid chamber up is about killing reflections. Not the end of the world. I would probably change them, unless it's a major pain.
post #47 of 307 Old 11-24-2015, 08:42 AM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
Yeah I went ahead and changed it this morning and immediately noticed more bass. Here's what I ended up with.
Claybe is offline
post #48 of 307 Old 11-24-2015, 08:42 AM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
I didn't put any stuff on the port sides. Hope that is okay too. Sounds fine.
Claybe is offline
post #49 of 307 Old 11-24-2015, 08:59 AM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
And 1 more thing...how should these be positioned? Horns at ear level? What is the best listening position?
Claybe is offline
post #50 of 307 Old 11-24-2015, 10:33 AM
Quoted: 142 Post(s)
Liked: 120
Horns at ear level is best.
Take a quick look at the "setup of WG speakers" pdf at the start of this thread:
https://www.avsforum.com/forum/155-di...ying-here.html
dorri732 is offline
post #51 of 307 Old 12-16-2015, 12:10 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
Hi guys, quick question please. I want to post pics of my new bamboo 1099 cabs but can't figure out how to do it. I looked but could not find a tutorial on how to do it. Can someone point me in the right direction. Thanks
Mario
Modicen is offline
post #52 of 307 Old 12-16-2015, 12:24 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
If you click on advanced reply and then midway in the page is a way to attach / manage images. The easiest way is to host the pictures somewhere on-line and then click the inset image icon... past the URL to the image and done. If you need a place to host them temporarily, shoot me a PM and I'll host them for you.
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #53 of 307 Old 12-16-2015, 12:36 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
My new L/C/R bamboo cabs, my first time posting pics. Hope this works
luisev, tuxedocivic and AVSF458 like this.
Modicen is offline
post #54 of 307 Old 12-16-2015, 12:38 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
Luisev, thank you for helping me out, much appreciated.
luisev likes this.
Modicen is offline
post #55 of 307 Old 12-16-2015, 12:42 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
Got my new bamboo cabs from Erich this weekend and I must say that are gorgeous. Erich and his woodworking guy did an awesome job. Here are some pics. Sorry for the crappy lighting.
Modicen is offline
post #56 of 307 Old 12-16-2015, 12:45 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
One more
Modicen is offline
post #57 of 307 Old 12-16-2015, 12:50 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
Can't figure out how to get more than one attachment in a post, but here is one more.
Modicen is offline
post #58 of 307 Old 12-16-2015, 12:50 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Anytime... glad I was able to help.
Awesome cabinets... congrats! I don't see them on the website, is there a set price for these? I wonder if they are made for the 893 design.
luisev is offline
post #59 of 307 Old 12-16-2015, 12:51 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Ha... in that same advanced screen, you should be able to manage and attach more than one photo.
Modicen likes this.
luisev is offline
post #60 of 307 Old 12-16-2015, 01:12 PM
Modicen's Avatar
Quoted: 122 Post(s)
Liked: 53
Thanks. The cabs are sweet, nice and solid. I ordered these right after Erich posted the pics of the proto types a couple months ago so they are not on the site yet. I believe Erich said he was going to take orders for them for the next preorder coming up and was going to put them up on the site as well.
Modicen is offline
