Little Bro to the 1099 - Development thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #421 of 437 Old 03-02-2016, 05:50 PM - Thread Starter
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2232
No, I don't think that's normal. There's nothing hooked up to the speakers at all, and you can hear hum?
tuxedocivic is offline
post #422 of 437 Old 03-02-2016, 07:45 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
+1... I've heard amps whine or whistle through speakers when they dissipate power while shutting down, but never heard a speaker hum for a few days... especially without being connected. Strange voodoo going on.
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #423 of 437 Old 03-02-2016, 09:20 PM
Erich H's Avatar
Quoted: 1919 Post(s)
Liked: 2764
Not just hum, I've heard a woofer picking up things a few times when everything was turned off and figured it must be normal. Very faint, but either music, or talking. I remember mentioning it to Bwaslo when he was at my house and he thought I was crazy. I think he said maybe it was a high efficiency woofer that was picking something up, but still said I was crazy.
I have an old house and thought all the wiring may not be grounded right and something is getting picked up and pushed through to the speakers. But I'm 100% sure I heard the Cheap Thrills speaker picking something up even when it wasn't wired up to anything. That used a 15" Celestion and I believe the first time I heard it.
About 15 years ago I had a really old customer that said there was a local AM radio station that had such a powerful antenna (700 WLW) that you could hear what they were pumping out through different things in your house. He said something about hearing it through metal fencing somehow, but can't remember how. I just said "wow". He said they were eventually forced to cut back on the power due to complaints. He was an engineer that retired from GE, so I didn't doubt him.
luisev likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #424 of 437 Old 03-03-2016, 02:17 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Great thanks.... At least I don't have to call an exorcist now
luisev likes this.
__________________________________________
DIY Sound Group 893 & Volt 8's Build Thread
sjackson is offline
post #425 of 437 Old 03-03-2016, 02:21 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Yep completely weird..... I had them unplugged for a day or two (I think) and had to move the speakers so my ear was quite close to the mids. I could hear like a faint hum quite similar to an amp hum. I must try and plug them out again tonight and see if I can hear it.
sjackson is offline
post #426 of 437 Old 03-03-2016, 05:22 PM
sdaddy's Avatar
If you can hear it this time, short the input and see if it goes away. Just curious.
sdaddy is offline
post #427 of 437 Old 05-14-2016, 08:58 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Originally Posted by ccssid123 View Post
Mind you, I am not the best at critiquing speakers. But I do want to compare to my Salk SS8. I will have my Golden Ears brother-in-law over for a listen...he does have exceptionally good hearing and appreciation for music.
But, my first impression......VERY GOOD.
Just checking in to see if you were able to compare them to the Salks... just curious.
luisev is offline
post #428 of 437 Old 05-24-2016, 08:49 AM - Thread Starter
Liked: 2232
I finally made a trim ring for the woofers.
Sent from my SGH-I747M using Tapatalk
My youtube channel: Impulse Audio
post #429 of 437 Old 05-24-2016, 09:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2732
How did you make that ? That looks awesome Ryan!
Mfusick is offline
post #430 of 437 Old 05-24-2016, 10:01 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2732
I see potential for a design here. A haunted speaker! Ghosts!
Mfusick is offline
post #431 of 437 Old 05-24-2016, 10:39 AM - Thread Starter
Liked: 2232
Thanks. I used a CNC and Sintra plastic. It isn't cheap material but the fake Sintra is not as good. I looks even better with a black baffle. You can see the Fusion max with trim rings at impulseaudio.ca with a black cab. Looks wayyyy better than the foam gasket.
post #432 of 437 Old 05-24-2016, 10:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2732
http://impulseaudio.ca/cinema-speakers/cinema-max.html
Looks great ^
You own a CNC ? I did not know that. At any rate I really like it. Well done.
Mfusick is offline
post #433 of 437 Old 05-24-2016, 12:54 PM
JohnDean's Avatar
Quoted: 568 Post(s)
Liked: 266
Is the plastic that thin or are you creating a recess bigger than the speaker for it to sit in?
JohnDean is online now
post #434 of 437 Old 05-24-2016, 01:14 PM - Thread Starter
Liked: 2232
Its 1/4" thick. I remove the foam gasket from the woofers. The trim ring is machined to allow for the lip on the woofer frame (3/16th inch thick on the circumference) and picket some holes to allow the screws to clear.
Ill get more info but I'd like to make them available to people.
luisev and ccssid123 like this.
post #435 of 437 Old 05-24-2016, 03:49 PM
ja00's Avatar
Quoted: 225 Post(s)
Liked: 150
Maybe it's an optical illusion but is the ring flat or does it have a concave shape to it?
ja00 is offline
post #436 of 437 Old 05-24-2016, 10:50 PM - Thread Starter
Liked: 2232
It's flat. Ill get more pics up tomorrow which will hopefully help make more sense. Ill show them on a black baffle.
ja00 likes this.
post #437 of 437 Old 05-25-2016, 10:41 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
@tuxedocivic I've been going back and forth recently between ported 893 towers vs 1099s on stands to use with my 893 center. Although they are a similar design and use the same CD, would there be any voicing differences if I go with the 1099s as L&R paired with the 893 center? I know there's a sensitivity difference, but curious as to sound differences... if any. I was thinking of going with the 1099s and their flat pack instead of building the ported towers for the 893s. Just curious as to your thoughts...
luisev is offline
