Tux 893's LCR and volt10xl surrounds build + 2 si18htd2 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #31 of 91 Old 12-09-2015, 01:41 PM
Quoted: 89 Post(s)
Liked: 88
Originally Posted by chrisvw16 View Post
They'll be going on top of the subs, do you guys know if it's ok to flip the speaker so the wave wide is below the mids? Otherwise the center of the wave wide is going to be at around 42.5. Which would be a 2-3" inches above ear lever.
My 88 specials are "upside down" also. Having the waveguide at ear level helped remove a null (found using REW) and I could easily hear the difference. it is obviously much easier to flip them upside down instead of trying to angle them by propping them up somehow!
bitmap42 is offline
post #32 of 91 Old 12-09-2015, 03:50 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Ok that's what I wanted to hear I'm thinking of a way to do a base for them where I could just flip them any time I needed. I'm looking into making a magnetic base probably I'll have to play around see what I can come up with.
Thanks guys
chrisvw16 is offline
post #33 of 91 Old 12-09-2015, 04:02 PM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
It's been confirmed by Tux that it's fine to invert them. I'll be doing the same
sjackson is offline
post #34 of 91 Old 12-10-2015, 10:23 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Have you started yours yet? Unfortunately I'm going out of town for 5 days so I won't be able to keep the progress going on mine. I've been really anxious to hear them for a while now.
I decided to glue up a 1/2" price of mdf on the baffles. I didn't feel good with the thickness of where the speaker mount. it seemed to thin. Now the baffle is 1 1/4 thick.
post #35 of 91 Old 12-11-2015, 12:30 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
No not yet but hoping to get to my DIY store this weekend to get MDF cut. I'll be building mine tall but shallow and taking advantage of the size/shape of MDF. Mine will be 48" tall, 10.25" wide and 8" deep. Also will be double baffled like yours (or at least for the height of the supplied baffle). I need mine to fit behind my projector screen hence the size. I'm also seriously considering wall mounting each of the speakers to a wall using two tv cantilever brackets so I can adjust toe in etc but still then tighten the brackets up so they are solid (solid enough anyway)
sjackson is offline
post #36 of 91 Old 12-11-2015, 07:50 AM
Erich H's Avatar
Quoted: 1845 Post(s)
Liked: 2631
No need to worry about a double thick baffle on these. The recesses aren't very deep and the bracing is right behind them. Plus we're removing wood from the baffle and replacing it with metal.....from the woofers frame. So they're definitely strong enough.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #37 of 91 Old 12-11-2015, 10:51 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Whoops already glued them up, I'm sure it could only help though. Is it possible to recess the woofers a little bit more to have it sit flush? Because they way they are cut the woofer sticks out about 3/16 I want them to be flush for the grill that I want to put on them to work.
post #38 of 91 Old 12-12-2015, 08:12 AM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2224
Recessing a little more is totally fine with a double baffle. Just use a pattern router bit or something and knock out the depth you need. Cool!
tuxedocivic is offline
post #39 of 91 Old 12-22-2015, 06:44 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I think this looks a lot better!
luisev likes this.
post #40 of 91 Old 12-22-2015, 07:30 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Looks great... which bit did you use? I would like to do the same to mine.
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #41 of 91 Old 12-22-2015, 11:12 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
It's a 1/2 rabbiting bit, it works like a charm !
post #42 of 91 Old 12-22-2015, 07:36 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Thanks... just ordered one through Amazon.
luisev is offline
post #43 of 91 Old 12-22-2015, 10:09 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Slow progress, I got all 3 with the first layer on the sides. It's 1/2" , I'm going to go over it with one more layer of 1/4" all around.
post #44 of 91 Old 12-22-2015, 10:44 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Here is a back shot
krholmberg, brian6751 and luisev like this.
post #45 of 91 Old 12-23-2015, 06:49 PM
Sparkygod1's Avatar
Quoted: 39 Post(s)
Liked: 37
Here is a back shot
Those look like they'll be awesome!
If it doesn't kill you...it hurts like hell.
Sparkygod1 is offline
post #46 of 91 Old 12-23-2015, 08:10 PM
krholmberg's Avatar
Quoted: 185 Post(s)
Liked: 84
That's quite the shop 👍
Sent from my LG-H901 using Tapatalk
Krister
krholmberg is offline
post #47 of 91 Old 12-23-2015, 08:59 PM
Liked: 2224
Sweet!
post #48 of 91 Old 12-23-2015, 09:06 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Thanks guys
post #49 of 91 Old 12-26-2015, 11:41 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I quickly put them together, to test them over Christmas party,, soldered the crossovers with Matt's boards. It went smoothly, they are great. And they fit perfect behind the mids and comp driver.
post #50 of 91 Old 12-26-2015, 11:44 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
In route to the house on the 24th right on time for the christmass party.
post #51 of 91 Old 12-26-2015, 11:53 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
The trio sitting where will be their permanent spot, All I can say right now is wow, they sound really good! Everyone that heard them so far liked them a lot. I'll set them up better and run mcacc later on. I'm afraid I'm not going to want to take them out of my room to finish them. I still need another layer of 1/4 mdf all around. As they are right now it's only 1/2 ". On the sides. Honestly I think they are fine like that. But when I get them back to the shop I guess I'll finish them with the other layer before I do the paint. I'll do some more listening in the next couple days and share my thoughts on how they sound.
luisev likes this.
post #52 of 91 Old 12-27-2015, 06:19 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
They look great in your room! For size comparisons, what size subs are those?
luisev is offline
post #53 of 91 Old 12-27-2015, 08:41 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
They are 18" si ht, I just finished thema few days ago! They blend really well with the 893's
post #54 of 91 Old 12-27-2015, 09:38 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Nice indeed! Flat packs from DIYSG or PE or did you build your own?
luisev is offline
post #55 of 91 Old 12-27-2015, 11:43 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I build my own, 6,5 cu ft. I have a build thread going if you want to check it out.
post #56 of 91 Old 12-27-2015, 02:49 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Found it...
https://www.avsforum.com/forum/155-di...et-volume.html
luisev is offline
post #57 of 91 Old 12-27-2015, 02:52 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I need to learn how to add the link of my builds to my sig....
post #58 of 91 Old 12-29-2015, 02:28 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Loving it! My 893s are coming along very slowly but hopefully I'll have them ready for paint by the weekend. Then tackle the Volt 8's and SI 18 HT subs. Glad to hear yours are working well together as I had no idea how the speakers and subs would integrate. My subs should be smaller though.....
sjackson is offline
post #59 of 91 Old 12-29-2015, 07:24 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Thanks, You're not going to be disappointed, Even without any dsp for the subs it sounds great. Once I get a minidsp and dial it in properly, I can't even imagine how good it will be. One word about the 893's. I ran them as "large" on the receiver just to see what they would do without the subs. Mcacc bumped up 63hz about 5db. I put on some music. These had me fooled for a sec. I had to look to make sure I didn't have the subs on. They have surprisingly good midbass, or more than I was expecting.
Do you have a build thread we can checkout?
post #60 of 91 Old 12-29-2015, 07:41 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
I believe this is his build thread:
https://www.avforums.com/threads/diy...hread.1998603/
sjackson likes this.
luisev is offline
