Tux 893's LCR and volt10xl surrounds build + 2 si18htd2 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #61 of 91 Old 12-29-2015, 08:05 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Originally Posted by luisev View Post
I believe this is his build thread:
https://www.avforums.com/threads/diy...hread.1998603/
Yep, that's the thread over on the UK forums (I've also updated my signature)
__________________________________________
DIY Sound Group 893 & Volt 8's Build Thread
sjackson is offline
post #62 of 91 Old 12-29-2015, 01:47 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I'm liking what you're doing so far! How do you out a link on your signature?
chrisvw16 is offline
post #63 of 91 Old 12-29-2015, 11:47 PM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Go into the "Edit Signature" setting (from the menu bar at the top of the page go to Tools -> User CP -> Edit Signature).
Type some text into the box and then highlight it with your mouse. Then in the little icons just above the text box, click the one that looks like the Earth with a chain at the bottom of it. That's the "Insert Link" button.
sjackson is offline
post #64 of 91 Old 12-31-2015, 11:27 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Any photos or info on how you stuffed them and how much you used? Wondering whether to glue the stuffing to the sides and rear now (before I glue the baffles on) or do it later
sjackson is offline
post #65 of 91 Old 12-31-2015, 12:16 PM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2225
That setup looks great. I really like the form factor of the 893. I'm not surprised about the comment about integrating with the subs either. The sealed roll of is good for that.
I hope they continue to impress
tuxedocivic is offline
post #66 of 91 Old 12-31-2015, 12:29 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
I used spray adhesive and two layers of 1/2" thick poly batting on the sides as well as on the braces. Going to place some additional loose polyfill into the cabinets behind the woofers.
sjackson likes this.
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #67 of 91 Old 12-31-2015, 12:33 PM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Great, thanks. So about an inch on the sides and maybe the same at the back. Is it ok to cover the crossover with polyfill etc?
sjackson is offline
post #68 of 91 Old 12-31-2015, 01:12 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
That's what I did... 1" - 1.5" on the side walls and back. I covered the XO as well with slightly less than the walls... I glued the poly to the poly on the walls... not the XO. I checked my B&Ws and the XOs have been completely covered for close to 20 years without issue, so I covered them on the 893. I'm going to place some loose batting behind the woofers as a "just in case".
luisev is offline
post #69 of 91 Old 12-31-2015, 04:06 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I just stuffed them with polifill, a couple handfuls on each, just enough so it's nice and full, without been too packed. I had asked tux and he basically said its not critical. I'm guessing since the kids are closed back, it does make a huge difference.
post #70 of 91 Old 01-01-2016, 12:50 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Thanks guys
sjackson is offline
post #71 of 91 Old 01-01-2016, 11:18 AM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Here's what it looks like inside. Cross over is behind the batting on the left:
Although not truly necessary, behind the SEOS and CD:
All done... Now I just need to run Dirac and do some listening:
Erich H, sjackson and BCRSS like this.
luisev is offline
post #72 of 91 Old 01-01-2016, 11:40 AM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Thanks, appreciate those photos!
sjackson is offline
post #73 of 91 Old 01-01-2016, 03:00 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Anytime... glad it helped.
luisev is offline
post #74 of 91 Old 01-01-2016, 04:30 PM
Erich H's Avatar
Quoted: 1847 Post(s)
Liked: 2642
Great photo. Do you care if I use that on the website? I'm going to be updating the site very soon and need some decent photos.
luisev likes this.
The SEOS Waveguide Project
Erich H is offline
post #75 of 91 Old 01-01-2016, 04:33 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Sure, no problem Erich, feel free.
luisev is offline
post #76 of 91 Old 01-03-2016, 07:23 AM
Liked: 2225
Looks awesome!
luisev likes this.
post #77 of 91 Old 01-13-2016, 07:14 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
The trio sitting where will be their permanent spot, All I can say right now is wow, they sound really good! Everyone that heard them so far liked them a lot. I'll set them up better and run mcacc later on. I'm afraid I'm not going to want to take them out of my room to finish them. I still need another layer of 1/4 mdf all around. As they are right now it's only 1/2 ". On the sides. Honestly I think they are fine like that. But when I get them back to the shop I guess I'll finish them with the other layer before I do the paint. I'll do some more listening in the next couple days and share my thoughts on how they sound.
Just checking in to see if you finished them @chrisvw How are they treating you thus far?
luisev is offline
post #78 of 91 Old 01-13-2016, 10:28 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I haven't finished them, I'm having a hard time taking them out of my room! They have been pretty good, although I haven't had a lot of listening time here lately. I'm probably going to wait until it warms up before I paint them.
post #79 of 91 Old 04-12-2016, 09:00 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
So after enjoying the hell out of my 893's for about three months, I finally got them out of my room and into the shop for finishing. Before painting them I wanted to appreciate what they had to offer. After several movies, music concerts in bluray and video games, I can say they are worthy of a nice finish.
I choose a color from one of my favorite cars it's called black magic pearl effect. And I'm adding brushed aluminum accent stripes. I hope they turn out well. I am putting a lot of time into them.
It's been a week that I have been working on them in the evenings mostly. I'll post some pictures of the progress I've made in the week.
post #80 of 91 Old 04-12-2016, 09:04 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
The back
post #81 of 91 Old 04-12-2016, 09:07 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I added an 1/8 layer to get the stripes I wanted
luisev and Shadowed like this.
post #82 of 91 Old 04-12-2016, 09:33 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
First coat of epoxy primer going on!
post #83 of 91 Old 04-12-2016, 09:38 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Glazing putty to fill small imperfections that I couldn't see on the raw mdf
luisev likes this.
post #84 of 91 Old 04-13-2016, 05:10 AM
Quoted: 93 Post(s)
Liked: 39
Looking good can't wait to see how they end up. I wish I had some abilities to finish speakers.
Denon AVR-X4500
Pair of Volt 6's for surrounds
1099, Volt 6, Volt 6 Atmos builds
MBM 12s Build
Pair of Mini-Marty's with Dayton UM18-22
csmithny06 is offline
post #85 of 91 Old 04-13-2016, 03:57 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Thanks, if you need help with finishing let me know!!! I'm here to help!
csmithny06 likes this.
post #86 of 91 Old 04-17-2016, 09:53 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
2 coats of Base coat went on smoothly
krholmberg likes this.
post #87 of 91 Old 04-17-2016, 09:56 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
I hanged all three speakers, so I could spray them all around at the same time.
post #88 of 91 Old 04-17-2016, 10:00 AM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
After I finished the last of 3 coats of clear
krholmberg, luisev and csmithny06 like this.
post #89 of 91 Old 04-23-2016, 08:09 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
It's been a week since the cabs were sprayed. I have begun wet sanding and polishing.
krholmberg and luisev like this.
post #90 of 91 Old 04-23-2016, 08:50 PM - Thread Starter
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
Left one is before, the right one is wet sanded and polished
