Tower of Power build with 893, MBM, Volt 6 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #91 of 100 Old 05-19-2016, 03:25 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Didn't they also go from open back to sealed back at one point of time?
DIYSG 893 | Emotiva ERD-1 | Dual DIY 18" Subs
Emotiva XMC-1 | XPA-2 | XPA-5 | Dual Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Nvidia Shield | Oppo BDP-103 Bluray Player
luisev is offline
post #92 of 100 Old 05-19-2016, 05:44 PM
Erich H's Avatar
Quoted: 1845 Post(s)
Liked: 2639
Nope, the 4" Celestions are only made with a sealed back. The 5" model can be both, but the 1099 has always used the open back version.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #93 of 100 Old 05-19-2016, 07:06 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Gotcha... thanks for clarifying.
luisev is offline
post #94 of 100 Old 05-23-2016, 03:17 PM - Thread Starter
strakele's Avatar
Quoted: 96 Post(s)
Liked: 109
Finally got motivated to pull all the drivers out and get back to work on the cabinets. Routed out the terminals for 12's - went with woofer on bottom orientation. If anything that'll make them a bit more stable with the weight lower.
Put 45 bevels on the front side edges of all the cabinets:
Started making the angled side pieces for the towers:
The back piece is going to be hard since it won't be a 45 degree cut. Haven't done that yet.
Put a 45 bevel on the grill frames too and added some more metal supports since they're so thin now:
And I have some samples on order of different finishes. So progress is being made.
luisev, Hoodcom, ja00 and 1 others like this.
strakele is offline
post #95 of 100 Old 05-23-2016, 03:54 PM
BCRSS's Avatar
Quoted: 490 Post(s)
Liked: 454
Originally Posted by strakele View Post
Holy Cow , how tall is that monster? Looks cool. Nice job getting both to pair together.
BCRSS is offline
post #96 of 100 Old 05-23-2016, 04:05 PM - Thread Starter
strakele's Avatar
Quoted: 96 Post(s)
Liked: 109
It's 54 inches tall. Quite imposing. It's not an 1899, but it'll do
strakele is offline
post #97 of 100 Old 05-23-2016, 05:34 PM
luisev's Avatar
Quoted: 197 Post(s)
Liked: 111
Looks great... I'm really liking the way its coming along. Any side or pictures from the rear?
luisev is offline
post #98 of 100 Old 05-23-2016, 05:57 PM - Thread Starter
strakele's Avatar
Quoted: 96 Post(s)
Liked: 109
There will be. The back isn't done yet though so nothing to see until I figure out the angles.
strakele is offline
post #99 of 100 Old 05-27-2016, 08:17 PM - Thread Starter
strakele's Avatar
Quoted: 96 Post(s)
Liked: 109
And now it is!
Had the day off so I spent most of it cutting the side angle pieces and figuring out all the angles to make it fit together seamlessly. It was quite a bit of work with just a handheld circular saw and router. The side pieces were all 45's so that wasn't too bad, but the back was not so I routed the 45 bevel then cut the steeper angle by hand.
I started the taper a bit below the top edge of the MBM enclosure so it all flowed together which probably resulted in more work than necessary to get the side angle pieces to line up perfectly but oh well.
First side piece cut. There are 2 of those metal L brackets on each side.
And here's the completed enclosure, ready for finishing:
Close up on some of the angles:
Very minimal filler was needed which was nice.
Now on to the next one...
krholmberg, luisev and csmithny06 like this.
strakele is offline
post #100 of 100 Old 05-31-2016, 06:02 AM
Quoted: 93 Post(s)
Liked: 39
I really like how that turned out. Great job
krholmberg likes this.
Denon AVR-X4500
Pair of Volt 6's for surrounds
1099, Volt 6, Volt 6 Atmos builds
MBM 12s Build
Pair of Mini-Marty's with Dayton UM18-22
csmithny06 is offline
