MBM Build - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Erich H
  • 2 Post By csmithny06
  • 1 Post By csmithny06
post #1 of 6 Old 04-15-2016, 08:58 AM - Thread Starter
Quoted: 93 Post(s)
Liked: 39
MBM Build
I am building 2 MBMs using the kit's and flat packs from DIY Sound Group. These are to be paired with 1099s. I am a little un-sure on how long to cut the center tube length for the port. It likes like it should be 4.66" for a 36hz tuning however I am not really sure. I will have more as I continue to look into it.
ID:	1381802   Click image for larger version
ID:	1381810   Click image for larger version
Denon AVR-X4500
Pair of Volt 6's for surrounds
1099, Volt 6, Volt 6 Atmos builds
MBM 12s Build
Pair of Mini-Marty's with Dayton UM18-22
csmithny06 is offline
post #2 of 6 Old 04-15-2016, 09:28 AM
Erich H's Avatar
Quoted: 1846 Post(s)
Liked: 2642
The entire length of the port with flares should be about 11" long to tune around 35hz.
Port instructions are here:
http://www.psp-inc.com/tools.html
csmithny06 likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #3 of 6 Old 04-15-2016, 09:38 AM - Thread Starter
Quoted: 93 Post(s)
Liked: 39
Great thanks that was a lot easier than the semi guessing I was doing with the formulas on the paper that came with the port.
As always great service Erich
Denon AVR-X4500
MBM 12s Build
post #4 of 6 Old 04-16-2016, 01:09 PM - Thread Starter
Quoted: 93 Post(s)
Liked: 39
I have finished them up and after a hiccup with one of the inukes I have them up and running. I still need to run REW which I have not yet run at all for the room. I have been listening to them as is and I am very pleased so far. I setup them up according to @Tuxedocivic:
Channel 1 to MBM
- Low Pass = LR 24db/oct at 250hz
- Level = 0
- EQ should be based on measurements
Channel 2 to DIY Sound Group Speaker (ie. Fusion 8 or 10)
- High Pass = LR 24db/oct at 250hz
- Level = -5db (Fusion 10), -5db (Fusion 12), -6db (Cinema 8), -6db (Cinema 10 MAX), -7db (Cinema 1099)
- EQ may be available to further smooth the speaker response over an above what the passive XO does, ask the designer.
ID:	1385138   Click image for larger version
krholmberg and EarlK like this.
Denon AVR-X4500
MBM 12s Build
post #5 of 6 Old 04-28-2016, 10:51 PM
eng-399's Avatar
Quoted: 2409 Post(s)
Liked: 4958
So what's your thoughts now on this entire setup. It has to sound amazing in your room. Have you played around with any settings for the mbm's since your last post. The sound stage has to be really nice in your room.
eng-399 is offline
post #6 of 6 Old 04-29-2016, 01:15 PM - Thread Starter
Quoted: 93 Post(s)
Liked: 39
It does sound amazing I spent a bit of time Sunday running REW I want to run it a gain just to see if I can get it any smoother. It does sound great though. 1 more sub on back order still trying to decide if I should cancel and try a different model. Even without the 2nd sub it does sound good.
eng-399 likes this.
Denon AVR-X4500
MBM 12s Build
